Staro 25.06.2011., 06:36   #1
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,562
Scythe Mugen 3
While optimizing the performance the whole heatsink design of Mugen 3 CPU Cooler was re-worked which resulted in creation the improved fin-structure M.A.P.S. (Multiple Airflow Pass-Through Structure). Enhancements were achieved by reducing the aerodynamic resistance as well as improving of the overall heatsink stability. Furthermore Mugen 3 is equipped with total of six high-quality copper-heatpipes where the predecessor had only five. Typical for Scythe is the excellently processed and flat surface of the copper base which was refined by a thin nickel layer to prevent corrosion.
Furthermore the mounting mechanism F.M.S.B. (Flip Mount Super Back-Plate) was improved and upgraded to 4th version. Hence resulted in enhanced back-plate and allows easier and faster mounting procedure of Mugen 3 CPU Cooler. Compatibility list is includes Intel sockets LGA1155, LGA1156, T / LGA775 and LGA1366 as well as AMD sockets AM2, AM2+, AM3 and the new AM3+.
Scythe Mugen 3 CPU Cooler carries the same 35,90 EUR (excl. VAT/TAX) price tag as the predecessor Mugen 2 at its time.
http://www.techpowerup.com/img/11-06-24/137a.jpg
http://www.techpowerup.com/img/11-06-24/137b.jpg
http://www.techpowerup.com/img/11-06-24/137c.jpg
http://www.techpowerup.com/img/11-06-24/137d.jpg
Članak http://www.techpowerup.com/147991/Sc...er-Series.html
Staro 25.06.2011., 06:39   #2
Baja 001
Baja 001's Avatar
Postovi: 7,504
Ako u nas bude ~45€ bit će dobro. Mugen 2 je bilo solidan cooler.
Staro 25.06.2011., 08:57   #3
BojanZD
BojanZD's Avatar
Postovi: 1,398
U vrijeme dok je bio oko 310kn, Mugen2RevB je bio apsolutni best buy.
Debelo bolji od svih drugih u cijenovnom rangu a jako blizu cooler koji su prelazili 500kn.
Ako ovaj bude isti ili bolji..ja ga svima preporučam!
BojanZD je offline   Reply With Quote
Staro 11.07.2011., 16:01   #4
skyman
skyman's Avatar
Datum registracije: Aug 2008
Postovi: 775
Dostupan u Linksu
skyman je offline   Reply With Quote
Staro 11.07.2011., 16:48   #5
Baja 001
Baja 001's Avatar
Postovi: 7,504
Zadnje izmijenjeno od: Baja 001. 11.07.2011. u 16:57.
Staro 22.09.2011., 22:19   #6
Postovi: 16,928
Ja ga imam i prezadovoljan sam.. Kupio sam potenciometar za njega, radi na 450-600 rpm, proc mi je oc-ani na 3.0 (ništa pretjerano) i drži ga na 30 stupnjeva... Kada ga dignem na 1600 nije bučan nego se čuje samo protok zraka kao kod sobnog ventilatora.. I temp je na nekih 26-27..
10/10 od mene
Staro 22.09.2011., 23:29   #7
Boskre
Boskre's Avatar
Datum registracije: Jun 2010
Postovi: 31
Nadam se da montaža nije bolna kao kod Mugen2 ?
Gledao video o nanošenju paste na "ispravan" način...
Pokušao sa Mugen2-ojkom jedan veliki montaža uspjela pasta umrla !
Boskre je offline   Reply With Quote
Staro 23.09.2011., 09:00   #8
Postovi: 16,928
Autor Boskre Pregled postova
Je, isto je teško montirati.. Vađenje matične i svega, i "štafanje" od ispod.. Tako da je malo teže...
Ja sam uspio i jedno i drugo a prvi put radio to
Staro 23.09.2011., 10:42   #9
Boskre
Boskre's Avatar
Postovi: 31
Svaka čast evo video koji sam gledao...
http://www.youtube.com/watch?v=EyXLu1Ms-q4
Da uspijem tako lijepo spustiti matičnu na cooler i još stisnuti i zarotirati da izbacim "air bubbles" dok se pasta ravnomjerno rasporedi na procesor...
Sa Mugen2 jako teško možda moguće ali teško.
Staro 23.09.2011., 22:51   #10
Postovi: 16,928
Iskreno, nije mi baš jasan video.. nije pokrio 40% proca.. Ali ok.. Ima jako dobar post ovdje za nanošenje paste.. Ja sam prvi puta sam radio i super je.. Nemreš fulat.. Ovo je ok, sama fizika govori da se kružno raspršuje, ali meni nije to to.. neznam iskreno kak je vama...
Staro 24.09.2011., 08:47   #11
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,562
Nije bitno sto "tebi nije to to " . Bitno je koja metoda daje najbolje rezultate, uostalom nije ni jezgra procesora cijelom povrsinom pod HSom nego samo na sredini.
Staro 24.09.2011., 11:14   #12
Dottore
Dottore's Avatar
Postovi: 7,661
Autor xulos Pregled postova
Točno!
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 24.09.2011., 11:16   #13
Postovi: 16,928
No, sve jasno.. Samo kažem da sam prvi put radio i dobro mi je ispalo, pa se držim ovoga napisanoga ovdje na pc expertu.. Pasta i prsti
Staro 04.10.2011., 21:23   #14
Postovi: 16,928
Kupio sam potenciometar (speed fan controller) za 4pinski vent, spojio Mugen 3, sada vrti na 500-550 okretaja, nečujan je, a drži moj proc na 34 stupnjeva max..
Staro 04.10.2011., 21:38   #15
xtreme96
OC addict
xtreme96's Avatar
Datum registracije: Apr 2009
Lokacija: Gothenburg, Sweden
Postovi: 1,001
Jel to idle temperatura ili tako dobro hladi da je u loadu 34C ?
Pošten trgovac: 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15...
- prije mi je bio nick "xTreme Gamer" (profil je isti ali sam promjenio nick)
xtreme96 je offline   Reply With Quote
Staro 04.10.2011., 23:26   #16
Postovi: 16,928
Autor xTreme GaMeR Pregled postova
Nije ni jednom prešla preko 36 stupnjeva... Ni u 3d marku, niti igrama, nigdje...
Staro 04.10.2011., 23:50   #17
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,562
Je da, jedino ako ti je komp u frizideru ili mozda zivis na aljasci ?
Staro 05.10.2011., 02:33   #18
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Pitanje je sa kojim je to programom mjereno i kako je taj program narihtan. Hladnjak je solidan ali nista vise od toga. 350kn nije neki specijalno dobar deal ali ok. Za neki i7 bi trazio nesto bolje a za ostalo je taman.
Staro 05.10.2011., 08:39   #19
Elpresidente1
Datum registracije: May 2009
Postovi: 389
To ti gledaš vjerojatno temp. koja piše za jezgre, to je ok za intela al kod amd se gleda baš ona koja piše cpu. Ili može bit da u programom sa kojim gledaš uopće nije taj senzor za cpu, il si stvarno u hladnjči nekoj.
Elpresidente1 je offline   Reply With Quote
Staro 05.10.2011., 10:29   #20
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,829
Meni na i5 2500K taj isti hladnjak izvuće 35-36°C kad je idle, 62°C full load i to u dobro hlađenom Antec P182 kućištu (doduše isto malo smanjen broj okretaja ventača radi tišine), jesi siguran da dobro očitavaš temperaturu? Da ne bi bilo da gledaš temperaturu matične ploče...
Staro 05.10.2011., 10:34   #21
Postovi: 16,928
Autor Sinac Pregled postova
Evo, ovo je nakon 1 sat cod4 i 3d marka... Na 440rpm.. Da ga dignem na 1600rpm, spustim ga na 25 stupnjeva.. Voltaža je na defaultu....
Sada mi vi recite šta je tu prava temperatura, i da li je to ok Iskreno, ako se ne gleda temperatura svake jezgre posebno, onda neznam ni šta se gleda
Zadnje izmijenjeno od: Mommistake. 05.10.2011. u 10:40.
Staro 05.10.2011., 10:54   #22
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Cod4 i 3d mark, nisi napsiao koji, sa svojih par sekundi CPU testa nisu neka mjerila a takav SS pokazuje samo temperaturu u idleu.
Staro 05.10.2011., 10:56   #23
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,562
Koji si ti lik. Pa mozes igrat 10 sati i kad ugasis igru proc se ohladi i ode u idle .Upali real temp i igraj dok je upaljen .kad zavrsis s igranjem pogledaj max temp u real tempu.
Staro 05.10.2011., 11:11   #24
Sinac
Sinac's Avatar
Postovi: 2,829
Daj mi odaj tajnu - koje kućište imaš? Gledam te brojke pa se sve čudim da ti je temperatura komponenata u kućištu gotovo niža od sobne temperature.
Staro 05.10.2011., 11:19   #25
Postovi: 16,928
Autor MAGARAC Pregled postova
3d Mark Vantage..
Pa zato smo tu da se neke stvari objasne.. Koliko ja trebam to mjeriti? Sada sam već 15 min u igri, 35 stupnjeva je atm, 36 max...
EDIT: Nakon pola sata diglo se na 40 stupnjeva...
Zadnje izmijenjeno od: Mommistake. 05.10.2011. u 11:41.
Staro 05.10.2011., 11:45   #26
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,562
Gle ovako : upali real temp.Igraj igricu sat dva ili odvrti 3d mark .ugasi igricu i pogledaj u real tempu max temp.
Staro 05.10.2011., 11:49   #27
Sinac
Sinac's Avatar
Postovi: 2,829
... i otkrij tajnu modela svog kućišta. Ako su istinite brojke koje imaš u onom očitanju, onda stvarno skidam kapu takvim temperaturama. Druga mogućnost je da ti matična ploča laže ko pas oko temperatura.
Staro 05.10.2011., 11:59   #28
Postovi: 16,928
Nema nikakve tajne.. Imam 1 vent koji upuhuje zrak ispod cd roma, s prve strane, direktno na mugen, i iza 1 koji ispuhuje.. Nemam ni jednu stranicu.. To je to Stvarno neznam da li postoji mogućnost da matična laže... Ja vam samo pokazujem brojke koje vidim
Staro 05.10.2011., 12:01   #29
Baja 001
Baja 001's Avatar
Postovi: 7,504
Šta za i7 triba minimalno Prolimatech Megahalems i ekipa od 100€?
Kolika ti je idle temp? 15°C
Staro 05.10.2011., 12:06   #30
Postovi: 16,928
Na 400rpm oko 30 °C, dok stavim na 12V vent, onda se spusti na oko 25°C
