Xulos :)
Postovi: 7,565
Scythe Mugen 3
While optimizing the performance the whole heatsink design of Mugen 3 CPU Cooler was re-worked which resulted in creation the improved fin-structure M.A.P.S. (Multiple Airflow Pass-Through Structure). Enhancements were achieved by reducing the aerodynamic resistance as well as improving of the overall heatsink stability. Furthermore Mugen 3 is equipped with total of six high-quality copper-heatpipes where the predecessor had only five. Typical for Scythe is the excellently processed and flat surface of the copper base which was refined by a thin nickel layer to prevent corrosion. Furthermore the mounting mechanism F.M.S.B. (Flip Mount Super Back-Plate) was improved and upgraded to 4th version. Hence resulted in enhanced back-plate and allows easier and faster mounting procedure of Mugen 3 CPU Cooler. Compatibility list is includes Intel sockets LGA1155, LGA1156, T / LGA775 and LGA1366 as well as AMD sockets AM2, AM2+, AM3 and the new AM3+. Scythe Mugen 3 CPU Cooler carries the same 35,90 EUR (excl. VAT/TAX) price tag as the predecessor Mugen 2 at its time. http://www.techpowerup.com/img/11-06-24/137a.jpg http://www.techpowerup.com/img/11-06-24/137b.jpg http://www.techpowerup.com/img/11-06-24/137c.jpg http://www.techpowerup.com/img/11-06-24/137d.jpg Članak http://www.techpowerup.com/147991/Sc...er-Series.html
Postovi: 7,504
Ako u nas bude ~45€ bit će dobro. Mugen 2 je bilo solidan cooler. |
Postovi: 1,398
U vrijeme dok je bio oko 310kn, Mugen2RevB je bio apsolutni best buy. Debelo bolji od svih drugih u cijenovnom rangu a jako blizu cooler koji su prelazili 500kn. Ako ovaj bude isti ili bolji..ja ga svima preporučam! |
Datum registracije: Aug 2008
Postovi: 775
Dostupan u Linksu |
Postovi: 7,504
~350 kn. Solidna cijena, samo da bude minimalno u rangu starog. ![]() EDIT: Evo i neki reviewea (koliko mogu bit pouzdani): Zadnje izmijenjeno od: Baja 001. 11.07.2011. u 16:57. |
Postovi: 16,937
Ja ga imam i prezadovoljan sam.. Kupio sam potenciometar za njega, radi na 450-600 rpm, proc mi je oc-ani na 3.0 (ništa pretjerano) i drži ga na 30 stupnjeva... Kada ga dignem na 1600 nije bučan nego se čuje samo protok zraka kao kod sobnog ventilatora.. I temp je na nekih 26-27.. 10/10 od mene ![]() |
#8 | |
Postovi: 16,937
Je, isto je teško montirati.. Vađenje matične i svega, i "štafanje" od ispod.. Tako da je malo teže... Citiraj:
Datum registracije: Jun 2010
Postovi: 31
Svaka čast evo video koji sam gledao... http://www.youtube.com/watch?v=EyXLu1Ms-q4 Da uspijem tako lijepo spustiti matičnu na cooler i još stisnuti i zarotirati da izbacim "air bubbles" dok se pasta ravnomjerno rasporedi na procesor... Sa Mugen2 jako teško možda moguće ali teško. |
#10 | |
Postovi: 16,937
Xulos :)
Postovi: 7,565
Nije bitno sto "tebi nije to to " ![]()
Postovi: 7,664
__________________ |
#13 | |
Postovi: 16,937
OC addict
Datum registracije: Apr 2009
Lokacija: Gothenburg, Sweden
Postovi: 1,001
Jel to idle temperatura ili tako dobro hladi da je u loadu 34C ? ![]() |
#17 |
Xulos :)
Postovi: 7,565
#18 |
Postovi: 5,991
Pitanje je sa kojim je to programom mjereno i kako je taj program narihtan. Hladnjak je solidan ali nista vise od toga. 350kn nije neki specijalno dobar deal ali ok. Za neki i7 bi trazio nesto bolje a za ostalo je taman. |
#19 |
Datum registracije: May 2009
Postovi: 389
To ti gledaš vjerojatno temp. koja piše za jezgre, to je ok za intela al kod amd se gleda baš ona koja piše cpu. Ili može bit da u programom sa kojim gledaš uopće nije taj senzor za cpu, il si stvarno u hladnjči nekoj ![]() |
#20 | |
...samo te gledam...
Postovi: 2,829
#21 | |
Postovi: 16,937
![]() Sada mi vi recite šta je tu prava temperatura, i da li je to ok ![]() ![]() Zadnje izmijenjeno od: Mommistake. 05.10.2011. u 10:40. |
#23 |
Xulos :)
Postovi: 7,565
Koji si ti lik. Pa mozes igrat 10 sati i kad ugasis igru proc se ohladi i ode u idle .Upali real temp i igraj dok je upaljen .kad zavrsis s igranjem pogledaj max temp u real tempu.
#24 | |
Postovi: 2,829
#25 | ||
Postovi: 16,937
![]() EDIT: Nakon pola sata diglo se na 40 stupnjeva... Zadnje izmijenjeno od: Mommistake. 05.10.2011. u 11:41. |
#27 |
Postovi: 2,829
... i otkrij tajnu modela svog kućišta. Ako su istinite brojke koje imaš u onom očitanju, onda stvarno skidam kapu takvim temperaturama. Druga mogućnost je da ti matična ploča laže ko pas oko temperatura. |
#28 | |
Postovi: 16,937
#29 | ||
Postovi: 7,504
#30 |
Postovi: 16,937
