Staro 06.11.2010., 19:02   #1
Postovi: 7,568
ATi Radeon HD 7xxx - vijesti i glasine
It is not long after the release of AMD Radeon HD 6800 series graphics cards, again it is said that AMD Radeon HD 7000 codenamed "Southern Islands" will be possibly released in the 2nd quarter of 2011, as RumorPedia reported. According to the previous information, AMD Radeon HD 7000 series graphics cards would be unveiled in the 3rd or 4th quarter of 2011. However, in order to surpass nVidia in the 28nm manufacturing process, AMD has decided to take its time to cooperate with GlobalFoundries to do the research.
And therefore, it remains to be seen whether "Southern Islands" can be released in the 2nd quarter of 2011, as it depends on 28nm manufacturing process research of GlobalFoundries. Yesterday we have just reported that nVidia has got 28nm sample chips, it seems that AMD should go for it. All these infos, seems to point out that AMD is advancing pretty well with its future graphics card architecture, although I would suggest you to take this news with a huge grain of salt considering the sources cited.
However, there may be some truth to these rumors, since one can pretty much assume that if nVidia has 28nm chip samples, AMD most definitely has access to the same manufacturing technology, making the 28nm HD 7000 graphics card family possible.
Izvor: EXPreview i Softpedia
Na stranu sve ostalo, ali gledajući da je AMD-ATi lansiral HD 4000 seriju sredinom 2008, HD 5000 krajem 2009. i novu HD 6000 krajem 2010. godine, ovi datumi za novu HD 7000 (ako uopće budu išli s tim nazivom) se i ne čine tolko nategnuti i(li) pretjerani. Još ako se k tome doda da na novoj 28nm Southern Islands arhitekturi ne rade "od jučer", isto kak nisu "od jučer" radili na prethodnim generacijama, ne bi bilo ništ čudno da za godinu (ili manje) dana AMD skupa s nVidijom opet lansira i službeno predstavi novu generaciju kartica baziranih na novoj arhitekturi.
Bulldozer (od quad do octo-core modela) i Llano (od dual do quad modela) su nakon svih silnih (pogotovo za Llano) odgađanja, napokon "na putu" i još ako se poklopi da u slično vrijeme uspiju predstaviti i nove Radeon HD 7000 modele - tim (za kupce i tržište) bolje. Istinabog AMD je isplaniral nove Bulldozer procesore kombinirati sa sada aktulanim i nadolazećim HD 6000 karticma u sklopu Scorpius platfrome, pa HD 7000 vrlo vjerojatno ide u kombinaciju s procesorima koji dolaze nakon kaj se Bulldozer modeli već udomaće.
Još je tu i Intel koji bude u svojem prepoznatljivom stilu sljedeće godine ljudima ponudil (za LGA-1155 platformu) 32nm Sandy Bridge (koji dolaze s DirectX 10.1 IGP-om) i 22nm Ivy Bridge (koji dolaze s DirectX 11 IGP-om) procesore - i opći kaos ne bude izostal.
Zadnje izmijenjeno od: McG. 06.11.2010. u 20:02.
Staro 06.11.2010., 19:10   #2
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Koji je vrag njima, pa ljudi se još nisu kako treba ni upoznali sa HD68xx serijom a već kruže glasine da serija 7 kuca na vrata, istinabog, sve su to još glasine ali takav scenarij je itekako moguć da se i realizira sljedeće godine.
Lol, ljudi će stvarno početi mijenjati grafe kao čarape
C L O W N I N G A R O U N D
Staro 06.11.2010., 19:16   #3
Postovi: 7,568
Ništ čudno da su već počeli s glasinama. nVidia je već službeno najavila kaj planira (Kepler i Maxwell) u sljedeće tri godine, Intel je "lud totalno" jer je na svojim IDF-ovima svima dal do znanja kaj ih čeka do 2013. (22nm i 16nm procesori i dvije nove Sandy Bridge i Haswell arhitekture). Ovo za možebitnu HD 7000 seriju, smo čak i na HD 6000 temi spomenuli, a i sam AMD je na službenom predstavljanju HD 6000 modela, obznanil da imaju u planu (barem) još dvije generacije HD XXXX kartica. Vidli budemo kak se bude sve to odigralo.
Staro 06.11.2010., 20:41   #4
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
Možda izbace neku karticu u svrhu testiranja 28nm procesa kao što je to bila HD4770 za 40nm. Moža baš bude 6770
cccp je offline   Reply With Quote
Staro 09.11.2010., 19:07   #5
J0Błack'
J0Błack''s Avatar
Datum registracije: Aug 2009
Lokacija: WC
Postovi: 19
Haha,gledajući kako izlaze nove serije 58x0 serija ce vec bit "stara".
J0Błack' je offline   Reply With Quote
Staro 09.11.2010., 19:46   #6
generic
generic's Avatar
Postovi: 1,081
Autor J0Błack' Pregled postova
58x0 serija već jest stara s pogleda teselacijskih mogućnosti.
No, pametni su ovi u ATI-ju, pardon, AMD-u () shvatili su da treba proći ohoho vremena prije nego se sve nove điđe-miđe novih direct X-ova počnu primijenjivati u igrama (od 15-tak standardnih benč igri, u koliko se korist teselacija? 3-4?). Uvjeren sam da su radi toga žrtvovali jaku teselaciju da bi dobili manji i štedljiviji čip. Zato sad malo sucka 58x0 serija u teselacijski zahtjevnim igrama.
Anyway, veseli me što AMD ima (kako sada stvari stoje) vrlo konkurentan roadmap
Zadnje izmijenjeno od: generic. 09.11.2010. u 22:11. Razlog: tese...nešto
Staro 09.11.2010., 20:15   #7
Rebbit
Postovi: 664
živi bili pa vidjeli sve to, a i imali para da si priustimo
nek sam isti kao on, ma nek sam isti ko stari moj, dok zivot juri, ja cu lagano....
Lenovo Thinkpad T14
Logitech MX Master 2S
Logitech MX Keys
Galaxy S23+
Rebbit je offline   Reply With Quote
Staro 14.11.2010., 07:51   #8
Albert Wesker
Albert Wesker's Avatar
Postovi: 525
ovo je bilo brzo...mislim da cu preskocit 6xxx seriju i krenut direktno na 7xxx seriju....posto ce biti radene na 28nm procesu onda ce manje trositi,imat ce vece taktove itd itd.samo nadam se da ce moja HD 4830 izdrzat novije igre
Albert Wesker je offline   Reply With Quote
Staro 14.11.2010., 10:58   #9
ivan77
vjerojatno, sl ijedi još jedna, u nizu "pakiranja starog pod novom oznakom" , nekakav, "hibrid" dviju serija, 6 i 7
Staro 14.11.2010., 11:25   #10
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
6xxx je bio doradjeni 5xxx. 7xxx bi trebao biti nov, sa "potpuno novom" arhitekturom i novim proizvodnim procesom.
Milentije je online   Reply With Quote
Staro 14.11.2010., 12:04   #11
Albert Wesker
Postovi: 525
Autor ivan77 Pregled postova
hoce li to biti nesto kao x1650 PRO ili 2900XT???nesto tipa ''niti simo niti tamo''
Staro 14.11.2010., 14:11   #12
Ivan123
Postovi: 191
Autor Milentije Pregled postova
Tocnije, 7xx0 je doradeni 6xx0 sa nekim svojstvima 5xx0 serije...
Southern Islands will feature hybrid design with several logic elements of Northern Islands and stream processors from Evergreen
To će sada biti tipa AMD x3 kojemu ne radi jedna jezgra za nizi segment i slicno, barem prema nekim nagadanjima... To će im omogućiti veliku fleksibilnost
Ivan123 je offline   Reply With Quote
Staro 14.11.2010., 19:06   #13
cccp
cccp's Avatar
Postovi: 1,030
Ali serija 6 već ima dvije arhitekture ako se nagađanja o Caymanu kao 4D arhitekturi ostvare.
Staro 14.11.2010., 19:15   #14
Ivan123
Postovi: 191
Da, ali to ne znaci da ce HD7xx0 koristiti Bartsov dio arhitekture. Vrlo vjerojatno ce taj biti namijenjen nekom nizem segmentu HD7xx0, a Caymanov dio high end-u? Tko ce ga znati...
Staro 14.11.2010., 19:30   #15
Postovi: 7,568
Southern Islands will feature hybrid design with several logic elements of Northern Islands and stream processors from Evergreen.
Jedini problem s ovim glasinama o hibridnoj HD 7000 seriji je to kaj su stare skoro devet mjeseci i datiraju u vrijeme kad se još nije znalo da li bude HD 6000 serija Northern ili Southern Islands. Na kraju se pokazalo ovo prvo i HD 6000 je ispala ta koja je hibridna, tj. koja objedinjuje mogućnosti Evergreen i nove Northern Islands arhitekture. Za potencijalnu HD 7000 se još ništ konkretnog ne zna, a sve kaj kruži po netu je spin-off glasina koje se kružile još prije HD 6000 serije. AMD za 2011. ima spremnu novu Bulldozer arhitekturu za procesore i sprema novu arhitekturu za novu HD seriju kartica. Nema govora o hibridima na CPU i GPU području, ovaj put okreću kompletno novi list.
Zadnje izmijenjeno od: McG. 14.11.2010. u 19:59.
Staro 15.11.2010., 13:25   #16
MausLuka
Datum registracije: Mar 2009
Postovi: 25
Autor McG Pregled postova
Čovjek je u pravu, nema šta.
MausLuka je offline   Reply With Quote
Staro 08.05.2011., 15:17   #17
prt scr
Datum registracije: Jan 2011
Lokacija: wild west
Postovi: 321
prt scr je offline   Reply With Quote
Staro 17.06.2011., 21:47   #18
cccp
cccp's Avatar
Postovi: 1,030
AFDS 2011
AMD Fusion System Architecture Overview - Southern Isle GPUs and Beyond
Jedan dobar prikaz svega što se događalo na ovogodišnje AFDS-u vezano uz novu generaciju grafičkih procesora iz AMD-a i buduće integracije CPU-a sa GPU-om.
Staro 18.06.2011., 07:48   #19
Mad_Duke
Ma, neka samo šibaju naprijed
Netko ih čeka
http://en.wikipedia.org/wiki/Id_Tech_6
Staro 06.09.2011., 00:31   #20
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Radeon HD 7900 series gets new architecture and XDR2 Rambus memory?
AMD will launch its first graphics card in the Radeon HD 7000 family during the fall and as expected it will be the first VLIW4 circuits at 28nm. The top models of the Radeon HD 7900 series aims higher and will according to recently leaked roadmaps use the AMD Graphics Core Next architecture and the high speed memory XDR2 from Rambus.
Staro 06.09.2011., 09:54   #21
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Nece da idu na kompleksne 512-bitne memorijske sabirnice, pa im treba memorija brza od GDDR5.
Staro 06.09.2011., 12:19   #22
Mad_Duke
Neka. Potrošnja mi izgleda jako lijepo! A eventualno korištenje Rambusa bi im moglo donijeti dugoročno pozitivne rezultate ako se bace dovoljno rano (i uspješno) na taj vagon!
Staro 06.09.2011., 12:31   #23
prt scr
Lokacija: wild west
Postovi: 321
koliko bi mogla koštat 7950?
Staro 06.09.2011., 13:00   #24
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,770
Autor SRV Pregled postova
Bolje za njih, pa i za nas krajnje kupce. Jednostavnija/jeftinija izrada = manja cijena..
Autor prt scr Pregled postova
Ako netko ima informaciju ili carobnu kuglu neka slobodno javi.
Salu na stranu, prerano je jos da bi se neka cijena mogla formirati, ali sudeci po proslim serijama mogla bi biti u rangu cijene 6950 kad je izasla pa i nesto visa - racunaj 2500kn+ u startu imho.
Staro 06.09.2011., 13:15   #25
prt scr
Lokacija: wild west
Postovi: 321
moram kupit 7950,to bi trebala bit zvijerjedva čekam
mislio sam na nvidiu ali od njih opet ništa,njima je u prvom planu nešto drugo a ne diskretne grafičke
potrošnja je super,ima taj xdr2 šta je valjda zadnja riječ tehnike,samo da nebude preskupa
Staro 06.09.2011., 13:32   #26
Mad_Duke
Nije, nego jednostavno opet kasne. Što je i dobro. Bolje tako nego da se zaletavaju kao prije sa obećanjima koja ne mogu ispuniti. Nvidia od ati 4xxx serije kasni i to im je glavna boljka. Nakon određenog vremena uspiju srediti kartulje i imaju dobre proizvode ali na prvu ruku to baš i nije tako.
A ovo da im je nešto drugo u "prvom planu" ne bih htio komentirat
Autor Sn4k3 Pregled postova
Ma, tak i onak bu prvo išle 7850 i 7870... pa treba čekati. A nekak mi se čini da bi te dvije opet mogle biti dosta dugo best buy. Barem 7850 model. (ako se stvari budu odvijale kao i do sada) Zbog potrošnje se iskreno nadam da bu bili mnogo dobri clockeri!
Staro 06.09.2011., 14:00   #27
prt scr
Lokacija: wild west
Postovi: 321
mislio sam da imaju tegru 2 i druga područja koja im donose (veću)zaradu
recimo gtx4** serija je podbacila da bi nvidia tek u drugom pokušaju napravila nešto dobro
7950 bi trebala bit super clocker,još ako će pasat musashi ili neki drugi hladnjak odmah ih stavljam
Staro 06.09.2011., 15:56   #28
Guls
Guls's Avatar
Lokacija: Sveta Nedelja
Postovi: 2,938
Ja krećem polako u prodaju svoje 6970 dok još ima kakvu takvu cijenu pa si planiram odmah po izlasku priuštiti jednu 7970. Ovo izgleda dobro, samo taj rambus... već je bilo kikseva s tom memorijom, sad opet kreću istim pravcem.
Intel i7 9700F
32GB Hyper-X DDR4-2666
2TB 970Pro PCIe NVMe M.2
Windows 11 Professional
Periferija
2 x 27" Dell P2723D
Corsair SP2500 2.1
Logitech MK270
17,3 FHD IPS 144Hz
AMD Ryzen 7 5800H
16GB DDR4-3200 RAM
1TB PCIe NVMe SSD
Sony Playstation 5
Staro 06.09.2011., 16:37   #29
cccp
cccp's Avatar
Postovi: 1,030
Nemojte se previše oslanjati na ove glasine. To nije ništa službeno. Puno toga se može dovesti u pitanje. Ako će 79x0 koristiti HP proces onda ne treba očekivati da se pojavi ove godine.
Staro 06.09.2011., 16:52   #30
BSA<AK-47>
Napokon dočekao DNF :)
BSA<AK-47>'s Avatar
Postovi: 1,460
Autor Guls Pregled postova
samo ti nju još čuvaj...
offt:
nije sa rambusom bilo toliko kikseva ,ako se dobro sjećam ,
je bila brža memorija ali je bila i dosta skuplja u odnosu na ddr...
čitao sam da su pokušavali monopolizirati tržište memorije ,pa samo pobirati lovu na royalty prinicipu ,ali im nije uspjelo.... hehe
ont:
pa ako ovi specs budu finalni proizvod ,fino ,fino...
samo gledam kako su skresali potrošnju kartica ,jer mi po ovom zgleda da bi buduća x2 riješenja mogla vući oko 300w
I dont know you. I dont know what you want. If you leave, that will be the end. I wont look for you, I wont pursue you. But if you dont, I will look for you, I will find you and I will ignore you.
BSA<AK-47> je offline   Reply With Quote
