#841 | |
Postovi: 7,568
- AMD Initiates Work on Android Platform: Looking for Android Developers |
#843 |
Datum registracije: Feb 2004
Postovi: 1,030
To je cijena cijelog sistema ("System price"). Pretpostavljam da će se cijene formirati prema konkurenciji. 8 jezgreni Zamezi je vjerojatno konkurencija i7 2600, znači nekih 300 dolara (u "meriki"), ali o perfomansama se trenutno ne zna ništa tako da je sve to nagađanje na klimavim nogama. Zadnje izmijenjeno od: McG. 01.09.2011. u 21:46. |
#844 |
Anything Goes Martial Art
Lokacija: Tendo Dojo
Postovi: 542
samo je pitanje šta njima ulazi u "system". ovako na prvu bi rekao proc+ploča jer sve ostalo varira. za 8-jezgri bi moglo biti potreno izdvojiti i do 4 hiljadarke. ploča i proc.
"Water! Why does it always have to be water?!" |
#845 |
Postovi: 7,568
Asus 990FX Sabertooth AM3+ ploča
With the socket AM3+ platform, Asus wants to rally around its top motherboard brands, including Republic of Gamers (ROG), with the Asus Crosshair V Formula, and the The Ultimate Force (TUF) Sabertooth 990FX, for AMD's next top of the line 990FX chipset that is designed to run up to four discrete graphics cards. The 990FX Sabertooth keeps up with the color scheme of the other TUF-series members. It boasts of highly durable components. The AM3+ socket is powered by a 10-phase Digi+ VRM. It is wired to four DDR3 DIMM slots supporting dual-channel DDR3-1866 MHz memory, and connects to the 990FX chipset over a HyperTransport 3.1 link.Izvor: techPowerUp |
#846 |
Lokacija: VG
Postovi: 1,760
MSI 990FXA-GD80 Socket AM3+ Motherboard Detailed
Earlier referred to as "Big Bang Conqueror", MSI's next top-end AMD platform motherboard has emerged under its final name, 990FXA-GD80. The socket AM3+ motherboard that supports AMD's upcoming FX series processors, is based on the AMD 990FX + SB950 chipset. The CPU is powered by a 10-phase VRM that makes use of tantalum-core capacitors, and SFC chokes (that don't whine), driver-MOSFETs (DrMOS). Expansion slots include four PCI-Express 2.0 x16, supporting NVIDIA SLI and AMD CrossFireX; two PCI-E x1, and a PCI.Izvor: techpowerup; mygarage.ro |
#847 |
Postovi: 7,568
Gigabyte i ASRock Llano APU ploče
Gigabyte GA-A75M-UD2H FM1 Llano APUOvaj FM1 socket podsjeća na stare 754 ploče. ![]() Zadnje izmijenjeno od: McG. 29.05.2011. u 00:34. |
#848 |
Postovi: 7,568
Gigabyte i Asus Bulldozer ploče
Gigabyte GA-990XA-UD3 AM3+ Zadnje izmijenjeno od: McG. 28.05.2011. u 23:36. |
#850 |
Postovi: 7,568
Gigabyte, Asus i ASRock Bulldozer ploče
Gigabyte GA-990XA-UD3 AM3+ |
#852 |
Postovi: 7,568
990GX teško, jer dosad nije bilo govora o takvom čipsetu, pošto imaju Llano, a 990FX na mATX ploči ovisi o proizvođačima. |
#853 |
Datum registracije: Oct 2010
Postovi: 73
Jel isplivala u zadnje vrijeme kakva info o nadolazecim bulldozerima? AMD jos nije nikakvu sluzbenu informaciju dao? Zadnje izmijenjeno od: McG. 01.09.2011. u 21:46. |
#854 |
Postovi: 7,568
Zadnja je od Computex konferencije i nakon toga zatišje. |
#855 |
Postovi: 73
A sluzbeno predstavljanje bi trebalo biti krajem ovog mjeseca? Ili sam krivo informiran? Zadnje izmijenjeno od: McG. 01.09.2011. u 21:47. |
#856 |
Postovi: 7,568
Službeno predstavljanje bi po novom trebalo biti između sedmog i devetog mjeseca. - AMD FX 8 Core and 4 Core Processor Systems Seen Running at E3 Zadnje izmijenjeno od: McG. 08.06.2011. u 00:39. |
#857 |
Postovi: 1,811
Jel onda definitivno ništa od podrške za nove procesore na am3 pločama. ja se mislim nešto da bi ubo ovu ploču i prebacit se na dd3 memu http://uk.asus.com/Motherboards/AMD_AM3/M4N98TD_EVO/ Zadnje izmijenjeno od: darkijas. 09.06.2011. u 16:10. |
#858 |
Postovi: 7,568
Ne znam, ali očito da to nije sprovedeno u djelo onak kak su Asus i MSI naveliko reklamirali. AM3+ ploča nisu ništ pretjerano skuplje od AM3 modela, pa rađe izaberi neku noviju, a da ti odgovara cijenom i mogućnostima. Ko zna kakve sve peripetije čekaju one koji se odluče na AM3 i Bulldozer kombinaciju - u slučaju da se netko uopće krene zabavljati s tak nečim. Zadnje izmijenjeno od: McG. 16.09.2011. u 00:23. |
#859 | |
Postovi: 542
pa gledaj da uzmeš neku sa "crnim" socketom a ne da imaš eventualne komplikacije poslije.
#860 |
Postovi: 1,811
Mislio sam nvidia čipset i sli. (do sada sam imao samo njihove čipsete pa sam mislio da tako i ostane) Svakao je logičnije sačekati ploče am3+ sa 990 čipsetom (između ostalog i sli podrška je tu) Zapravo je taj am3 zapeo u blato jer trebao je biti kakti ulog za budućnost a ispada da stare am2 i am2+ ploče podržavaju više procesora. Šteta što ta asusica podržava samo ddr 3 i am3 procesore pogotovo (neide u nju ovaj moj 940be), da je drugačije odmah bi išao po nju, ovako se dvoumim. Eh da mi je naći m4n82 deluxe.. |
#861 | |
Doomster
Datum registracije: Mar 2008
Lokacija: Kraj Donji
Postovi: 400
AM2/AM2+ ploče podržavaju više procesora jer postoji više procesora koji rade na DDR2 nego na DDR3. Najbolje bi ti bilo pričekati i uzeti AM3+ procesor, ploču, i DDR3, a trenutni komplet prodati.
#862 |
matori
Datum registracije: Feb 2011
Lokacija: ZADAR
Postovi: 183
Biostar announces a trio of Llano-ready (FM1) motherboards ![]() Taiwanese company Biostar today introduced its first motherboards compatible with AMD's upcoming A-Series (codename Llano) APUs (accelerated processing units), a full ATX model called TA75A+ and two micro ATX solutions named TA75M+ and TA75M. All three Biostar boards make use of the Hudson-D3 (A75) chipset and feature an FM1 socket, four DDR3 memory slots, six SATA 6.0 Gbps ports, one (TA75M) or two (TA75A+, TA75M+) PCI-Express x16 slots (only CrossFireX is supposed on the latter models), 7.1 channel audio, two USB 3.0 ports, and D-Sub, DVI and HDMI video outputs. No word on prices but those should be revealed soon enough as Biostar's boards will become available next month. Izvor: TechConnect magazine |
#863 |
Lokacija: VG
Postovi: 1,760
Evo super pregled ASUS-ove postave ploca sa novom generacijom chipseta. Zadnje izmijenjeno od: McG. 05.07.2011. u 17:00. |
#866 |
Propali Amigaš
Lokacija: Nin
Postovi: 7,011
A evo i cijena novih procesora, doduše još su nedostupni. Zadnje izmijenjeno od: McG. 05.07.2011. u 17:01. |
#867 |
matori
Lokacija: ZADAR
Postovi: 183
Asus F1A75-I Deluxe mini-ITX FM1 Two months after its Computex unveiling, Asus' AMD A75-powered F1A75-I Deluxe mini-ITX motherboard has now received a proper welcome, complete with a press release, some nice, detailed images but no retail pricing or concrete shipping date. Likely set for an arrival later this month, the F1A75-I Deluxe supports AMD FM1 APUs (accelerated processing units), and features the DIGI+ VRM technology, Dual Intelligent Processors (TPU and EPU), two DDR3 memory slots, four SATA 6.0 Gbps ports, and one PCI-Express x16 slot (enables Dual Graphics support). Asus' compact board also includes USB 3.0 connectivity, an eSATA port, 5.1 channel audio, Bluetooth, Gigabit Ethernet, UEFI BIOS, and three display outputs - DVI, HDMI and DisplayPort. As mentioned, there was no price tag put next to the F1A75-I Deluxe but we did find it listed at €114. ![]() ![]() Izvor: TechConnect Magazine |
#870 |
Postovi: 73
jel ima napokon kakva informacija kad bi se bageri mogli pojavit kod nas? |
