Staro 18.05.2011., 16:11   #1
branimiros82
branimiros82's Avatar
Postovi: 113
ACPI\ABT2005 driver
dakle radi se o maticnoj Abit at8 32x i standardno win7 odrade svoj dio posla sto se tice vecine drivera,al ovo mi i dalje stoji kao Unknown devices.O cemu se tu radi i kako naci i instalirati taj driver.guglo sam al nista konkretno...thx
E da hardware ids je ACPI\ABT2005
*ABT2005
branimiros82 je offline   Reply With Quote
Staro 18.05.2011., 16:20   #2
tripl3
1337
tripl3's Avatar
Postovi: 42
The unknown device is the GURU microprocessor on the ABIT motherboard
To get rid of the unknown device in device manager. All you do is
install the latest GURU software from ABIT for your motherboard the
reboot. The unknown device is gone. Also, you don’t have to run th
GURU software if you don’t like simply go into the options of GURU an
disable it from start-up
Regards NAS
Admin 'www.etwclan.co.uk' (http://www.etwclan.co.uk/
Nadam se da pomaže =)
tripl3 je offline   Reply With Quote
Staro 18.05.2011., 18:46   #3
branimiros82
Postovi: 113
link je umro....
Staro 18.05.2011., 20:23   #4
nino
nino's Avatar
Postovi: 12,599
Malo snalazljivosti ne skodi. Iz gornjeg texta:
All you do is
reboot.
Ono nije link nego potpis tog admina valjda. Software za skinut imas na sluzbenom sajtu.
http://www.abit.com.tw/page/en/downl...E=Socket%20939
Izaberi onaj za vistu.
Staro 19.05.2011., 00:13   #5
branimiros82
Postovi: 113
ok hvala,hvala...probavao sam ja vec s tim guru naisao na to,al valjda nisam dobar skinuo ili sta jer nije ga maknilo...probam sutra i trudim se,al nekad neide bas.sori...
