Lokacija: c:\http
Postovi: 10
VIA/S3G UniChrome IGP
Izvadio sam iz DirectX 9.0c ovaj report: ---------------------------------------- Operating System: Windows XP Professional (5.1, Build 2600) (2600.xpclient.010817-1148) System Manufacturer: ASUS System Model: A7V400-MX BIOS: Phoenix - Award BIOS v6.00PG Processor: AMD Sempron(tm) 2200+, ~1.5GHz Memory: 192MB RAM Page File: 165MB used, 349MB available Windows Dir: C:\WINXP DirectX Version: DirectX 9.0c (4.09.0000.0904) DX Setup Parameters: /PackageInstall DxDiag Version: 5.03.0001.0904 32bit Unicode --------------- Display Devices --------------- Card name: VIA/S3G UniChrome IGP Manufacturer: VIA/S3 Graphics, Inc. Chip type: VIA/S3G UniChrome IGP DAC type: Internal Device Key: Enum\PCI\VEN_1106&DEV_7205&SUBSYS_81181043&REV_01 Display Memory: 64.0 MB Current Mode: 800 x 600 (32 bit) (60Hz) Monitor: Default Monitor Monitor Max Res: Driver Name: vtdisp.dll Driver Version: 6.14.0010.0113 (English) DDI Version: 9 (or higher) Driver Attributes: Final Retail Driver Date/Size: 2/3/2004 18:27:40, 1951488 bytes WHQL Logo'd: n/a WHQL Date Stamp: n/a VDD: n/a Mini VDD: vtmini.sys Mini VDD Date: 2/3/2004 18:28:00, 134144 bytes Device Identifier: {D7B71FE6-3145-11CF-8273-12A1A0C2CB35} Vendor ID: 0x1106 Device ID: 0x7205 SubSys ID: 0x81181043 Revision ID: 0x0001 Revision ID: 0x0001 Video Accel: ModeMPEG2_B ModeMPEG2_A Deinterlace Caps: {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled DDraw Test Result: All tests were successful. D3D7 Test Result: All tests were successful. D3D8 Test Result: All tests were successful. D3D9 Test Result: All test -------------------------------------------------------- Instalirao sam Need for speed UNDERGROUND 2 Kada pokrenem igricu, umjesto opcija se pojavljuju kockice i nemogu ništa pročitati, kada sam stiskao samo enter počeo sam igrati, ali svejedno sve izgleda nekako.... Ako moram podesiti grafiku preko igre onda neznam kako ću jer umjesto opcija vidim samo one kockice.. Ako je u pitanju download novih drivera može li me tko uputiti koje da down. kako sam tek kupio računalo... Išao sam na http://www.viaarena.com/default.aspx?PageID=2 i dali da down. te drivere ili ne, i dali su mi uopće potrebni novi ??! Hvala.
admin@croit.org croit.org |
motocross
Lokacija: Kutina
Postovi: 2,438
probaj,nemas kaj izgubit.. koga si tak naljutio da ti je kupio maticnu s integriranom grafickom? |
Lokacija: c:\http
Postovi: 10
Uf... nebih na reskir down. kako mi treba puno vremena.... Integrirana je sada, bit će svašta... :burn: Pomozite mi oko ovoga plz. Dali će problem biti riješen sa novim drajverima ?? dali se inače ovakve stvari događaju... ?!
Lokacija: c:\http
Postovi: 10
Kada kažeš smeće dali misliš na sve ili samo grafičku ?! Istina grafička nije nešto, ali mislim da bi nfsu na sempronu 2,2Ghz bi trebao raditi bez problema... I zar su bitne godine ??! (17,7 , možda grafička neće zato što nemam 18 ? Just for laugh...anyway downloadovo sam ove gore drajvere i instalirao, odgovaraju ali je situacija ista, kockice i sl. Pročitao sam negdje da to mogu promjeniti preko same igrice (Options) ali kako ne vidim opcije kad pokrenem igricu dali postoji mogućnost da se to podesi u nekom fajlu ili kako već...
Administrator
Lokacija: Sesvete
Postovi: 15,964
S tom grafičkom imaš sreće da nešto vidiš, a ne da igraš nešto. Proc s igrom u ovom slučaju i nema previše veze, nego te grafa koči do besvjesti. I uz to imaš premalo RAM-a. Probaj još jedino u opcijama od grafičke (display properties) pod D3D i Open GL postaviti na najniže vrijednosti, jer ti vjerojatno po defaultu stoji na nekakvoj sredini. Ali i tada NFS ti se bude vukao kao krepana mačka. Radje kupi neku polovno GF2/3, Radeona 9000 ili tak nešto pa se budeš i možda igrao nečega za par stotina kuna. |
motocross
Lokacija: Kutina
Postovi: 2,438
ma po tvom pisanju mi se cini da imas 12 godina,nisam mislio na cijeli komp da je smece,semptron je ko i prije tbred,256 L2 cachea,to je ok za igre,ali ti imas komp za ured,za word i screensaver,192mb rama???definitivno premalo?koje windowse imas?imas na njuzima gf3 ti200 po 250kn ljudi prodaju a ti4200 po 350-400kn,to je malo s obzirom na to da te grafe iako nisu dx9,jos uvijek dobro vrte ut2k4,hl2,cod, itd....znaci investiraj malo |
Lokacija: c:\http
Postovi: 10
Slažem se tor da grafička nije nešto, ipak kad sam uzimao tražio sam integrisanu, digao sam je na 64MB. Od rama imam 256MB DDR Na računalu nisam imao nikad namjeru igrati igrice, inače sam programer i web dizajner i većinu vremena provodim na tome tako da igru možda upalim samo koji put... Računalo sam ja kupio od svog posla tako da sam za sada presušio, možda i kupim grafiču i još pokoji dio... Nemam ni vremena ni želje da uložim vrijeme u sređivanje računala za igrice tako da je ovo samo bilo kao nekakvo testiranje novoga računala....
Administrator
Lokacija: Sesvete
Postovi: 15,964
Da sam na tvom mjestu onda bi prvo uložio u još rama a tek potom na grafu. 256 je premalo za XP. S 512MB budeš itekako osjetio razliku. A igre, bah ako ih ne igraš onda ni nemoj I ja si sve razmišljam, koliko često igram i meni bi bilo dovoljno integrirano riješenje. |
#10 | |
Warcraft III TFT
Datum registracije: Jun 2004
Postovi: 862
#11 | |
Administrator
Lokacija: Sesvete
Postovi: 15,964
