#121 |
Datum registracije: Feb 2011
Postovi: 190
ADM 1 x DDR3 4GB (2x2GB) Kingmax, 1333MHz, FLFE 1 x Asrock M3A770DE, AM3 - AMD 770 + AMD SB710, ATX, FSB2600, Dual C 1 x HDD SAMSUNG 500GB 7200rpm 16MB cache Serial ATA II-300, F3 1 x Gigabyte GZ-KX1, midi tower, bez PS, crno, USB, Fire wire, 1×120 1 x Napajanje FORTRON 400W, FSP400-60APN, Super Silent, 12cm 1 x Procesor AMD Phenom II X4 840, socket AM3, BOX , 2Mb cache, 95W 1 x GAINWARD GTX460 768MB GDDR5 192bit, PCI-X 2.0 x16, Core : 648MHz 1 x LG W2040S-BF 20" ,crn, wide screen, LCD, DFC 70.000:1, 300 cd/m2 4.273,49Kn ovo je loše kućište a možeš još skinuti 100kn sa evc kućištem bez cd/dvd čitača je konfa |
#122 |
Datum registracije: Apr 2011
Postovi: 30
Predlažem ti ovo: AMD Athlon™ II X2, 245, 2,90 GHz, AMD 760G, 1x 2 GB DDR3, 1333 MHz, ATI Radeon, 3000, SATA, 320 GB, DVD±RW DL Light scribe, 10/100 Mbit, Microtower, 180 W, USB Optical Mouse, USB Standard Value Keyboard, Microsoft Office Starter 2010 Preloaded. cijena:2900 kn Monitor:LCD,20",16:9,1600X900(max),2 ms(odaziv) cijena:880 kn ____________________________________ Sve skupa: 3780 kn |
#123 | |
Datum registracije: Oct 2010
Postovi: 6
Monitor LCD 22" LG W2240S, 1920x1080, 5ms 901,14 Kućište Gigabyte mid tower GZ-X1BPD-100 , crno, bez napajanja 250,28 Napajanje 400W Xilence Office Edition 222,29 Procesor sAM3 Phenom II X2 555 (3.2GHz, 7MB, 80W) box Black Edition 582,19 Matična ploča sAM3 Gigabyte MA770T-UD3, AMD770X+SB710, DDR3, ATX 561,13 Graficka kartica VTX 3D PCI-E ATI Radeon HD5770 1GB 858,41 Memorija DDR3 1333MHz 4GB, 2x2GB, Kingmax , CL9.0, 128Mx8, FLFE 303,49 HDD SATA II 500 GB Seagate, 7200rpm, 16 MB, ST3500418AS 277,74 SONY Optiarc AD-7260S 24x SATA black 151,28 UKUPNO: 3907,95 .....ostatak love jos ide za tipkovnicu mis i ostale gluposti.....amd x2 sam uzeo jer ima brzi cache i opcenito mislim da mi x3 ili x4 nece nista znacit za igranje igara....eto ako moze neki komentari ak bi nesto mjenjali i zasto i tak....puno hvala Zadnje izmijenjeno od: koko1o. 12.04.2011. u 16:08. |
#124 |
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Promjenio bi napajanje i uzeo barem OVO isto tako i HDD bi uzeo ili Samsung ili WD pouzdaniji su od tog Seagate-a, te bi i pržilicu promjenio i uzeo neku LG ili Samsung koju imaju.Ostalo je OK s obzirom na buđet, premda bi ja uzeo i drugi procesor OVAJ ali ako se neuklapa u buđet onda će i izabrani X2 555BE biti dovoljan.Glede igara mislim da bi jedan X3 ili X4 bolje funkcionirao jer igre sve više koriste višejezgrene sustave i mislim da sad X2 baš i nema smisla ukoliko se sad kupuje novo. |
#125 |
Postovi: 190
ovako nešto iz protisa? Monitor LCD 22" LG W2240S, 1920x1080 901,14 kn HDD SATA II 500 GB SAMSUNG SpinPoint F3 277,50 kn Kućište Gigabyte GZ-KX1, crno, bez napajanja 201,31 kn Memorija DDR3 1333MHz 4GB, 2x2GB, Kingmax 303,49 kn Napajanje 400W Fortron 60APN, 24pin 282,99 kn DVD-ROM optički uređaj Samsung SH-D163C SATA 114,88 kn CPU Desktop Phenom II X4 840 (3.2GHz, 2MB, 95W,AM3) box 672,67 kn Matična ploča sAM3 Asrock M3A770DE, - AMD 770 + AMD SB710 433,81 kn Grafička kartica Sapphire PCI-E ATI Radeon HD5770 Vapor-X GDDR5 968,33 kn Miš Logitech S96 crni 41,34 kn Tipkovnica Logitech Deluxe 250, crna PS/2 54,20 kn ukupno: 4251,66 kn Zadnje izmijenjeno od: MiroGavran. 12.04.2011. u 21:29. |
#126 | |
Postovi: 6
#127 |
► Play ▌▌ Pause ■ Stop
Datum registracije: Jan 2010
Postovi: 1,180
Varaš se, X4 je puno bolji izbor. Moj je X2 i srećom šta se da otključat u X3 i neke stvari puno bolje rade, pogotovo neke igre (npr. GTA 4). Jedino ako se misliš kockat sa otključavanjem tog X2 555 i ako se da otključat, ostavio bi ga.
#129 |
Postovi: 6
ovo kuciste u tvom prijedlogu izgleda zanimljivo al nemrem nac nigdje u specifikacijama koje tocno napajanje ima unutra....ostali sta mislite o ovom kucistu Zadnje izmijenjeno od: McG. 13.04.2011. u 15:45. |
#130 |
Postovi: 34,141
Kao i svaki Frontier - sačuvaj Bože. Radije uzeti u Linksu neki LC Power zbog solidnijeg napajanja.
#131 |
Lokacija: xMetrox
Postovi: 1
1 x CoolerMaster Elite 335, black, (W)185 x (H)413 x (L)486 mm, 6kg 1 x MSI 770-C45, AMD 770+SB710, S. AM2+, 6xSATA RAID, DDR3 800/1066/ 1 x Procesor AMD Phenom II X4 840, socket AM3, BOX , 2Mb cache, 95W 1 x HDD SAMSUNG 500GB 7200rpm 16MB cache Serial ATA II-300, F3 1 x Napajanje XFX Core Edition 80+ 450W PSU - EasyRail technology 1 x DVD upisivač LG GH24NS, DVD±RW, 24x DVD±R ,8x DL , 40x CD-R 1 x MSI GTS450 1GB GDDR5, N450GTS 1GD5/OC , Dual-Link DVI x2,m-HDMI 1 x LG W2246S 22" ,black, full HD, LCD, DFC 30000:1, 300 cd/m2 1 x DDR3 2048MB ( 2GB ) Kingmax, 1333MHz, CL9, FLFE85F-B8EE9 4.249,50Kn www.adm.hr 2gb lako dodas kad budes imao para ![]() |
#132 |
Datum registracije: Aug 2010
Postovi: 5
Pozdrav ljudi. Zakljucio sam da je doslo vrijeme za kupnju nove masine. Posto nemam bas nekog dobrog znanja o hardwareu, evo mene ovdje da pokupim savjete i preporuke. Treba mi konfiguracija za gaming i nes malo rad s grafikom. Ja sam si slozio ovako nesto: Asrock P67 EXTREME4 B3 - Intel P67, ATX, 4xDDR3 2133MHz -1.170 kn Procesor Intel Core i5-2500K 3.3GHz,1MB/6MB,95W,Socket 1155 -1.574 kn DDR3 4GB (2x2GB) Kingston, 1600MHz, CL9, HyperX Genesis -430 kn Gigabyte GTX 560 Ti 1Gb GDDR5 (ili mozda od MSI-a ?) -1740 kn Totalka- 4914 kn Eto, sad jel to kaj valja... nemam pojma. Komponente sam odabrao po onome sto ADM ima u ponudi. Trebalo bi nadodati napajanje i kuciste, HDD nije potreban. |
#133 |
Lokacija: Zd
Postovi: 4,778
Dobro si odabra komponente, s tim da se iz istih da izvuci jos dosta besplatnih performansi (citaj dobro se oc'aju). Sto se tice napajanja uzmi SEASONIC 520W, SS-520GB. Za kuciste ti mogu preporuciti Cooler Master - no ovisi na sto ciljas... Ako se radi o nekom solidnom a po nicemu posebnom kucistu (ocim crne unutrasnjosti) kupi si CoolerMaster Elite 430, ako pak oces nesto kvalitetnije i prozracnije onda Coolermaster 690 II LITE. Naravno uvik se moze ustediti, pa tako i na komponentama koje si gori napisa, npr. ne ako ne mislis slagati multi-gpu setup onda ti ne triba ploca sa vise pci-e utora za grafe. U tom slucaju moze proci i jedna Asrock P67 PRO3-B3. Ram takodjer moze biti nesto konzervativniji, na kraju krajeva on i ne igra neku ulogu u igrama (bitnija je kolicina), 2x2GB Kingmax ce biti sasvim ok. Za razliku u lovi mozes recimo uzeti kvalitetan aftermarket cooler poput ovog ili ovog koji ce napraviti realnu razliku u performansama (dopustajuci veci oc nego tvornicki cooler) tako i u buci... Sto se tice grafe, prakticki je svejedno... Obe su kvalitetne, tihe i daju se dobro oc'ati.. Osobno bi isa na MSI (ponajvise zbog izgleda). |
#134 |
Postovi: 5
Puno hvala na brzom i kvalitetnom odgovoru majstore. Jos cu si razmisliti o MBu, jer sumnjam da cu uparivati graficke. ![]() Zadnje izmijenjeno od: McG. 16.04.2011. u 16:01. |
#135 |
Datum registracije: Aug 2009
Postovi: 73
lega me je zamolio da mu sastvaim novu konfu s monitorom u protisu plaćat će kešom koliko ja znam reko je da ima 5 somova za potrošit pa bi tražio prjedloge sorry zaboravio to navest koristit će je za igre vrlo malo photosopa i premier pro-a P.S. on je AMD fanboy!!! Zadnje izmijenjeno od: McG. 19.04.2011. u 02:11. |
#136 |
Lokacija: Zd
Postovi: 4,778
Heh, fanboy .. Nebitno jeli on AMD fan ili ne, cinjenica je da mu se svakako vise isplati uzeti AMD konfu jer je isplativija - pogotovo kad monitor ulazi u cijenu... Znaci ovako:Mbo: Asrock 770 EXTREME3 - 523kn Cpu: AMD Phenom II X4 955 - 875kn Ram: Kingmax 2x2GB 1333MHz - 303kn Vga: Sapphire Radeon HD6850 - 1216kn Psu: XFX Core Edition 80 550W - 424kn Hdd: WD Caviar Blue 750Gb - 374kn Dvd: LG GH22NS50/RBBB - 146kn Case: Thermaltake Dokker - 380kn Monitor: LG W2240T full hd - 996kn ------------------------------------------- ~5230 kn Nek se rastegne tih 200-tinjak kn ako moze, ako ne ubacit cemo jeftiniji monitor i kuciste... Btw ako mu ne "smetaju" nvidijine grafe moze se umisto radeonke ubaciti đi-forsica poput GTX460 1Gb.Performanse su tu negdi a vjerojatno bi mu dobro posluzila radi Cuda-e u programima kojima se bavi... |
#137 |
Postovi: 73
a šta kažeš na ovu konfu http://tinypic.com/r/20hlfur/7 reko mi je da je spreman dati još 500kn Zadnje izmijenjeno od: McG. 17.04.2011. u 16:51. |
#138 |
Lokacija: Dalmacija
Postovi: 6,024
Konfa, uglavnom za multimediju filmove, poneku igricu tu i tamo ništa sad ekstremno. ADM 1 x Procesor AMD Phenom II X4 840, socket AM3, BOX , 2Mb cache, 95W 1 x Gigabyte MA770T-UD3 , AM3, AMD 770+SB710, S.,6xSATA RAID, 4xDDR3 1 x XFX HD5670 1GB DDR5 775M, HDMI, DVI, Dispay Port 2 x DDR3 2048MB ( 2GB ) Kingmax, 1333MHz, CL9, FLFE85F-B8EE9 1 x HDD SAMSUNG 500GB 7200rpm 16MB cache Serial ATA II-300, F3 1 x DVD upisivač LG GH24NS, DVD±RW, 24x DVD±R ,8x DL , 40x CD-R 1 x Napajanje XFX Core Edition 80+ 450W PSU - EasyRail technology 1 x Gigabyte GZ-KX1, midi tower, bez PS, crno, USB, Fire wire, 1×120 Sve skupa: 3.280,51Kn sry sta nisan reka, ovo ja prijatelju slazen, pa cisto trazim komentar jel ovo valja, znam da bi bolja graficka bila, pa bolja, ali $$$ Zadnje izmijenjeno od: McG. 19.04.2011. u 02:13. |
#139 | |
Lokacija: Zd
Postovi: 4,778
![]() Btw, zar nisi reka u prvom postu da ce kupovati u Protisa? |
#140 |
Datum registracije: Dec 2010
Postovi: 2
Pozdrav svima, Odlučio sam kupiti novi kompjuter i prijatelj mi je rekao da je najpametnije da pitam vas tu na forumu za savjet što da kupim i eto, poslušao sam ga ![]() Raspolažem sa 3000 do maksimalno 4000kn za konfiguraciju, bez monitora, sa zvučnicima i tipkovnicom, miš ne treba. Koristio bih ga za igranje uglavnom RPG-ova (među njima i WoW), sportskih simulacija, programe za grafičku obradu, itd. Našao sam na Linksu neku konfiguraciju koju imaju u ponudi i čini mi se ok, ali mi se ne sviđa što je dual core procesor i možda bih htio malo bolju grafičku, evo link: http://www.links.hr/index.php?option...kl=030.005.071 Koji su vaši prijedlozi? Zadnje izmijenjeno od: LD1986. 18.04.2011. u 18:19. |
#141 |
Lokacija: Dalmacija
Postovi: 6,024
je da san fan intela i nVidie al ja bi radije tu x4 AMD-a nego tog intela em je jeftiniji 200 kn , ima 4 jezgre za razliku od intelove 2 , je bolji u svim testovima(osim u potrošnji i zagrijavanju) i je bolji za programe za grafičku obradu intel je bolji samo u srednjem visokom i visokom rangu cijena, dok amd je puno bolji u srednjem i niskom, mada u ultraniskom opet bi prije intela uzeo ![]() |
#142 |
Postovi: 190
ADM 1 x Procesor AMD Phenom II X4 840, socket AM3, BOX , 2Mb cache, 95W 1 x Asrock 870 EXTREME3 - AMD 870, AMD SB850, ATX, FSB 2600, Dual Ch 1 x DDR3 4GB (2x2GB) Kingmax, 1333MHz, FLFE 1 x Coolermaster Elite 310, MIDI, crno-plavo, bez PS 1 x Napajanje SEASONIC 380W, SS-380GB, S12, aktivni PFC 1 x HDD SAMSUNG 500GB 7200rpm 16MB cache Serial ATA II-300, F3 1 x DVD upisivač LG GH24NS, DVD±RW, 24x DVD±R ,8x DL , 40x CD-R 1 x Gigabyte HD6850 1GB DDR5,256bit, Dual-DVI-I / HDMI, DirectX 11 3.990,48Kn |
#143 |
Postovi: 73
#144 |
Lokacija: Zd
Postovi: 4,778
WD 1TB, WD10EALX ili SAMSUNG SpinPoint F3 1Tb, ako ti ne triba toliki disk onda WD 640Gb, WD6400AAKS ili WD 500GB, 5000AAKX |
#146 |
Postovi: 2
Trebao bi malu pomoć oko nadogradnje. Nisam u financijskom stanju promjenit cjelu konfiguraciju, no htio bi si malo unaprjedit komp za gaming, pa da li se može nešto učiniti. Koju bi komponentu preporučili da mjenjam i u šta. Bio bi zahvalan Konfiguracija: Mainboard : ASRock A780GMH/128M Chipset : AMD 780 Processor : AMD Athlon 64 X2 4000+ @ 2100MHz Physical Memory : 4096MB (2 x 2048 DDR2-SDRAM ) Video Card : NVIDIA GeForce 8500 GT ![]() |
#147 |
Postovi: 34,141
Koliko para je u igri? Ubaci neki X3 ili X4 procesor i bolju grafu. http://www.asrock.com/mb/cpu.asp?Model=A780GMH/128M
#148 |
Postovi: 5
Ploca i rami nisu toliko losi, graficka je naj veci problem, a proc jedino ako kupujes neki Phenom .Uzmi 5750 graficku na to, cijenom su stvarno otisle dole, a sa tom konfiguracijom ce raditi super. |
#149 |
Postovi: 2,354
Neznam jel tako teško popuniti opciju "Moj komp" ili što......Na koji će se to monitor spajati što onda povlaći i izbor grafičke kartice(GPU) glede procesora pogledaj koje MBO podržava i najbolje neki X3-X4 Athlon a grafa sve ovisi od financ. mogučnosti ali nebi išao ispod 5770 ili 450 GTS. |
#150 | |
Postovi: 138
Pa to ne bi kupio niti za 400kn ![]() |
