Staro 19.03.2011., 17:28   #451
NemoRS
NemoRS's Avatar
Postovi: 518
Nemam to.Glupavo su to rijesili.Bolje da imam jos dva usb ulaza na prednjoj strani.To mi je potrebnije nego ovo.
A evo kako sam ja to slozio.Jo samo da mi je crni Venomous X.Ali ako netko zeli ovog kupit ja cu ga prodat
http://img6.imageshack.us/f/19032011290.jpg/
http://img864.imageshack.us/i/19032011291.jpg/
http://img96.imageshack.us/i/19032011292.jpg/
http://img853.imageshack.us/f/19032011293.jpg/
Zadnje izmijenjeno od: NemoRS. 19.03.2011. u 18:12.
NemoRS je offline   Reply With Quote
Staro 19.03.2011., 18:50   #452
Postovi: 8,222
Autor NemoRS Pregled postova
Pa možeš uštekat te kablove i u obični usb, ništa se neće desiti. I imat ćeš naprijed 2 usb 2.0 utora plave boje
Čestitke na novom kućištu!
Staro 19.03.2011., 19:21   #453
baban
baban's Avatar
Datum registracije: Aug 2008
Lokacija: DE
Postovi: 591
Cubitek Magic Cube Modular Cases
evo nesto 'drugacije'
Cubitek Launches ''Magic Cube'' Modular Case Series
The “Magic Cube” enclosures are made of 100% Aluminum and offer a revolutionary, modular design. Two models - the Magic Cube B210 and Magic Cube B211 with freely configurable modules are available immediately...
...Also constructed purely of Aluminum, all traditional parts of a normal chassis have been modularized with the Magic Cube cases. These sets consist of three separate enclosures: the main module for the motherboard, CPU and graphic cards, the storage module for 3.5 inch hard drives and the drive module for optical drives and card readers...
izvor: http://www.techpowerup.com/142484/Cu...se-Series.html
http://www.cubitek.com/products/pro-...-mcs-list.html
vidim ima ih u casekingu po 180€ (B210) i 200€ (B211) http://www.caseking.de/shop/catalog/...:29_10743.html
baban je offline   Reply With Quote
Staro 19.03.2011., 23:34   #454
locks
Datum registracije: Mar 2010
Lokacija: Vukovar
Postovi: 3,627
Cestitke na novom kucistu,nisi pogrijesio
Staro 22.03.2011., 10:21   #455
NemoRS
NemoRS's Avatar
Postovi: 518
Pitanje jedno vezano uz Haf-X. Ponekad mi gornji ventilator na kucistu pocne srotat. Nije to strasno ali ga cujem. Dobro sam provjerio koji je i definitivno je on. Kad se cuje ja ga malo pritisnem i onda prestane. Da ga reklamiram ili ga mogu nekako mozda skinuti pa malo lezaj podmazat ili?
Staro 22.03.2011., 10:57   #456
ehohr
ehohr's Avatar
Postovi: 348
Bas ti skripi ili se drukcije cuje strujanje zraka?
ehohr je offline   Reply With Quote
Staro 22.03.2011., 12:13   #457
NemoRS
NemoRS's Avatar
Postovi: 518
bas lezaj! Nikakav zrak
Staro 22.03.2011., 14:16   #458
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,752
Ja bi na tvom mistu odma reklamira.. Meni se ista stvar dogodila i na cpu i na gpu ventu.. U pocetku lagano groptanje neko vrime, a zavrsili tako da su pri vrtnji zvucali kao da netko melje orahe unutra...
Staro 22.03.2011., 22:11   #459
locks
Lokacija: Vukovar
Postovi: 3,627
Odmah reklamiraj,zamijenit ce ti kuciste....
Staro 22.03.2011., 22:29   #460
NemoRS
NemoRS's Avatar
Postovi: 518
Nazvao sam danas frenda tamo i rekao mu da se to ponekad dogodi i rekli su da ce poslati upit prvo u servis. Bolje da mi posalju samo vent jer nije da mi se bas opet da sve rastavljat. Stvar je da se to ponekad cuje,evo sad recimo ne ali opet da mi kazu da donesem da poslusaju nece se cuti sigurno.LOL. Svakako cu inzistirat na tome da zamjene.
Staro 31.03.2011., 21:02   #461
crusher
crusher's Avatar
Postovi: 159
crusher je offline   Reply With Quote
Staro 31.03.2011., 22:12   #462
Neo-ST
Neo-ST's Avatar
Postovi: 8,500
Nije mi jasno, čemu ova naopaka kućišta? Naprave vrhunsko kućište i onda sve s*ebu s tim, šta će mi kabeli viriti gore?
Staro 31.03.2011., 22:22   #463
Postovi: 8,222
Autor Neo-ST Pregled postova
Meni se isto nesviđa takva orjentacija. Da je klasična, bilo bi mi skoro pa odlično.
Staro 31.03.2011., 22:37   #464
gunther
Postovi: 1,366
Autor crusher Pregled postova
Krasno kuciste...
...ali jos cu se neko vrijeme morat zadovoljit Stackerom
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2
gunther je online   Reply With Quote
Staro 31.03.2011., 22:48   #465
DarkGuard
Datum registracije: Feb 2011
Lokacija: .
Postovi: 52
Zbog termodinamike. Od svih kućišta koja sam imao, ovo koje imam sada- silverstone raven, najbolje hladi komponente od svih. Kabeli su mi bolji kada ovako stoje.
DarkGuard je offline   Reply With Quote
Staro 01.04.2011., 00:08   #466
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
Moj wet dream. Oće ko kupit bubreg?
d4rk_ch1ld je offline   Reply With Quote
Staro 01.04.2011., 00:44   #467
aard
aard's Avatar
Datum registracije: Jul 2009
Lokacija: Zaprešić
Postovi: 120
Autor d4rk_ch1ld Pregled postova
Mislim da ce ovo kuciste smanjiti vrijednost bubrega na trzistu - svi nude
aard je offline   Reply With Quote
Staro 01.04.2011., 01:09   #468
croclocker
croclocker's Avatar
Datum registracije: Apr 2008
Lokacija: GER
Postovi: 724
silverstone temjin tj11
vanka samo kosta 559 eura
totalno je jeftino ovo kuciste
trebaju ti skoro 2 bubrega
croclocker je offline   Reply With Quote
Staro 01.04.2011., 01:13   #469
crusher
crusher's Avatar
Postovi: 159
da košta brdo jer je cijelo od alumnija + uni body... Zbog toga košta brdo para. 800D je od čelika napravljeno osim prednje strane. Svakako moje dream kućište!
Staro 01.04.2011., 01:42   #470
croclocker
croclocker's Avatar
Lokacija: GER
Postovi: 724
u nas ako dode bit ce nekih 4500 do 5000 kuna kao i inace kad se prebacuje iz eura u kune
mislim da je to previse puno previse
moze biti zlatno al sto je puno puno je
Staro 01.04.2011., 01:45   #471
ehohr
ehohr's Avatar
Postovi: 348
Mislim, o ukusima se ne raspravlja ali za 600 eura bi moglo doci i sa nekim i5 procesorom barem.
Staro 01.04.2011., 02:44   #472
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,759
Nista posebno, isti dizajn guraju kroz masu kucista.
Mislim da se ne moze usporediti sa 800D, koje isto tako ima vecinu nepotrebnih stvari koje ionako nitko ne koristi.
Staro 01.04.2011., 03:27   #473
croclocker
croclocker's Avatar
Lokacija: GER
Postovi: 724
izmedu 700d i 800d samo je razlika u bocnoj stranici koliko vidim ?
EDIT
naso razliku
http://www.youtube.com/watch?v=9oJ_Cort1HE
bas mi se ne svida prozirna stranica, a svida mi se naprijed ova vratasca
zasto nema neki 900d s tam opcijama :P
Staro 01.04.2011., 19:22   #474
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Ovaj Temjin TJ11 je prelijep, ali premalo nudi za tu cijenu naspram jednog Lian-Lia manjeg cijenovnog ranga (X1000, X2000)
Ogromno je kučište, što je pohvalno, ali pre-premalo unutra prostora za toliko kučište.
blaa
Staro 01.04.2011., 19:44   #475
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,123
Gdje ti ima premalo prostora? Uzmi u obzir da ima veću visinu od dužine zbog položaja matične ploče.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 01.04.2011., 22:32   #476
crusher
crusher's Avatar
Postovi: 159
premalo prostora??? Veće je 25% od tj07 o0
6diskova+3ssd; 9*3.5 bay-s + možeš vadit dio di dolazi matična za lakšu instalaciju? šta biš ti još )
Staro 01.04.2011., 23:42   #477
d4rk_ch1ld
d4rk_ch1ld's Avatar
Postovi: 695
Ovo kučište je napravljeno za jednu stvar, a to je da na dno bubneš 2 quad radijatora i mislim da kupce ovog kučišta drugo ni ne zanima. Uz to da nameču 2,3 ili 4 grafiče unutra
Staro 02.04.2011., 00:31   #478
croclocker
croclocker's Avatar
Lokacija: GER
Postovi: 724
meni se svida lian li x2000 i x1000 je isto super
nego jeli stanu ove nove grafe duge u njega
dimenzija vanjska je 442mm
Staro 02.04.2011., 01:37   #479
Dottore
Dottore's Avatar
Postovi: 7,691
kako ne..
S 5 kom NF-P14 FLX i standarni hladnjak NH-D14 sa NF-P14 FLX i NF-P12 ventilatorom
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 02.04.2011., 02:07   #480
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
[QUOTE=Dottore;1883936]kako ne..
mora da je tiho bez nekog fan kontrolera
(jgb, ja sam vodohladac)
Bez potpisa.
