#61 |
Registered Abuser
Lokacija: Velika Gorica \ ZG
Postovi: 747
#62 |
Datum registracije: Dec 2010
Postovi: 147
Čini se mrvicu sporijom od HD 6990. Al zato je tiša i nešto hladnija. |
#64 | |
Premium spammer
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
kad blokiraju 100% load na grafičkoj: Citiraj:
http://www.anandtech.com/show/4239/n...le-card-king/4 EDIT: LOL http://www.youtube.com/watch?v=sRo-1VFMcbc& |
#65 |
Premijum
Postovi: 1,360
"As a first step, I increased the voltage from 0.938 V default to 1.000 V, maximum stable clock was 815 MHz - faster than GTX 580! Moving on, I tried 1.2 V to see how much could be gained here, at default clocks and with NVIDIA's power limiter enabled. I went to heat up the card and then *boom*, a sound like popcorn cracking, the system turned off and a burnt electronics smell started to fill up the room. Card dead! Even with NVIDIA power limiter enabled. Now the pretty looking, backlit GeForce logo was blinking helplessly and the fan did not spin, both indicate an error with the card's 12V supply. After talking to several other reviewers, this does not seem to be an isolated case, and many of them have killed their cards with similar testing, which is far from being an extreme test." Izvor: Techpowerup Nece bas nesto bit pretjeranog dizanja voltaze ocito, ili ce bit jako puno skurenih kartica, toliko o 50% OCu ![]() |
#66 |
Lokacija: NaN
Postovi: 3,438
Pa bogami je nepotrebno odmah skočio s 1,0V na 1,2V, a što je s "prostorom" između? Ljudi su i sa 1,15V postizali ~920-950 MHz. Mislim, znam da GTX 580 može ići/je išla i iznad toga (1,2V), ali svejedno, pomalo glup i nadobudan potez. Zadnje izmijenjeno od: Matth€w. 24.03.2011. u 22:31. |
#67 |
...samo te gledam...
Postovi: 2,836
http://www.tomshardware.com/news/gef...deo,12454.html Izgleda dosta bolje od probnih verzija koje su se recenzirale ranije. |
#68 | |
Postovi: 118
Sine, ako stvarno nešto želiš u životu, morat ćeš raditi za to. A sada tišina! Počinje izvlačenje brojeva za lutriju |
#69 |
Lokacija: NaN
Postovi: 3,438
Oh-ho, nisam stigao baš pročitati previše reviewa, ali lijepa im je ovo "bolest" koja će očito imati svoju buduću konstantu kod modela. Budem se sljedeći tjedan dokopao jedne GTX 590, pa da vidimo da li će i taj primjerak raditi na bijeli dim. ![]() |
#70 |
Postovi: 5,997
"As a first step, I increased the voltage from 0.938 V default to 1.000 V, maximum stable clock was 815 MHz - faster than GTX 580! Moving on, I tried 1.2 V to see how much could be gained here, at default clocks and with NVIDIA's power limiter enabled. I went to heat up the card and then *boom*, a sound like popcorn cracking, the system turned off and a burnt electronics smell started to fill up the room. Card dead! Even with NVIDIA power limiter enabled. Now the pretty looking, backlit GeForce logo was blinking helplessly and the fan did not spin, both indicate an error with the card's 12V supply. After talking to several other reviewers, this does not seem to be an isolated case, and many of them have killed their cards with similar testing, which is far from being an extreme test." izvor: tehpowerup Ouchhh, ista stvar se ponavlja. Mozda ce to bit dobro ako povuku gtx 590 na kratko i sloze ju kak spada jer su nesto grdo fulali. Ja se ponadao da ce gtx 590 bit zvijer za OC sa 50% potencijala ali ne moze,bar ne jos. Po meni su performanse ocekivane s obzirom na mrsave taktvove. Vjerojano ce se stvar minimalno popravit sa driverima. Grafa je osjetno tisa od 6990, koja je trenutno najbucnija grafa sto postoji i to je jedini razlog zasto mi se 6990 ne svida. Za 5k kuna grafa treba bit tiha. Zadnje izmijenjeno od: MAGARAC. 25.03.2011. u 02:02. |
#72 | |
Postovi: 191
Uostalom kako ce driveri pomoci kartici da ne ispusti bijeli dim? Mogu jos dodatno optimizirati potrosnju, ograniciti je, ali mislim da je tu pitanje slabe regulacije + visoke temperature PCB-a i VRM-a. Po netu ima primjera i kada je kartica na defaultu odlazila u vjecna lovista http://www.youtube.com/watch?v=sRo-1VFMcbc Evo jedna slika, vidi se tocno veliko zagrijavanje kod VRM-a ![]() Zadnje izmijenjeno od: Ivan123. 26.03.2011. u 10:44. |
#73 |
Postovi: 1,081
#74 |
Postovi: 1,816
Stupid is as stupid does |
#76 | |
Datum registracije: Dec 2009
Postovi: 144
#77 |
Postovi: 1,816
#79 |
Postovi: 207
Nakon ovoga fiaska nije mi uopce jasno kako su oni uopce uspjeli od gtx 570 i 580 napravit dobre kartice.Prvo serija 400 izuzev gtx 460 promasaj i sada ovo crnjenje,mene je sram a kamoli ne njih.Neka fermi zaborave i bace se na keplar sta prije jer ce ih Ati ponovo satrat a da nece ni trepnit. |
#81 |
Postovi: 1,816
#82 |
Postovi: 1,081
#83 |
Jack of all, master of none
Lokacija: Matulji - Rijeka
Postovi: 6,214
#84 |
DBS
Datum registracije: Nov 2010
Postovi: 1,855
Službeni odgovor Nvidie oko uništenih primjeraka: http://www.hardwarecanucks.com/news/...tx-590-frying/ |
#86 | |
Postovi: 348
Ako ja dobro shvacam sto vi govorite da i GTX 570 ima velike sanse da rikne kako 590? Mislim na kraju krajeva MSI ima 3 godine garancije. |
#87 | |
Postovi: 1,081
![]() edit: I stand corrected. Zadnje izmijenjeno od: generic. 01.05.2011. u 12:31. |
#88 |
Postovi: 7,568
Pogledaj kak izgleda VRM/PWM kombinacija na GTX 580 i na GTX 590 i jasno je u čemu je problem. GTX 580 koristi 6+2 kombinaciju (a GTX 570 4+2 kombinaciju), dok GTX 590 za svaki GPU koristi jednostavniju/slabiju/jeftiniju 5-ero faznu regulaciju. nVidia se može do sudnjeg dana ograđivati sa službenim izjavama u stilu problem-je-u-korisniku-ne-u-proizvodu, ali na kraju dana ostaje činjenica da se naponska regulacija GTX 590 modela nije u stanju nositi s dva GF110 čipa. Ne krepavaju samo overclockane (bilo blago ili brutalno) kartice, već se u postotku krepanih, našlo i primjeraka koji su odapeli nakon nekog vremena sasvim normalnog korištenja. Zbog čega se nVidia odlučila na inferiorniju (u odnosu na GTX 580) naponsku regulaciju, mada koriste identične čipove samo s nižim taktovima - ostaje misterij. Tim više, jer prema ovome kaj sad šalju svima koji su recenzirali kartice, ispada da se GTX 590 ne smije ni krivo pogledati, a kamoli bilo kaj drugo, jer postoji šansa da kartica krepa izvan okvira koje je nVidia sročila kao obavijest za javnost. Ostaje nada da se neki od proizvođača (Gainward, MSI, Gigabyte, Asus i sl.) odluči na samostalno dizajniranje PCB-a i kompletne (bolje) VRM/PWM elektronike, jer neovisno o nVidijinim uputstvima; driveri i BIOS s boljom regulacijom vrtnje ventilatora ne mogu popraviti slabašnu naponsku regulaciju - mogu samo privremeno odgoditi eventualno krepavanje i probleme s karticom. Željeli su ljudima dati dual-GPU prozvod koji se manje grije i manje troši od konkurencije, a u postupku su šparali na krivim dijelovima. HD 6990 u loadu troši 390-440W, pa je rijetko koji recenzent to navel kao nedostatak koji bi potencijalne kupce odvratil od kupnje, jer je takva enormna potrošnja bila i za očekivati. Isti tretman bi dobila i GTX 590 i da je zadržana naponska regulacija s GTX 580 - ostalo bi mjesta za solidan overclock bez strepnje od krepavanjem kartice. Zadnje izmijenjeno od: McG. 27.03.2011. u 20:21. |
#89 | ||
Postovi: 1,081
edit: Mislio sam čisto sa stajališta vremena. Doći će podosta vremena dok se i ako se ne počnu štancati custom kartice. Zadnje izmijenjeno od: generic. 27.03.2011. u 20:40. |
#90 |
Postovi: 7,568
Da, pa tak je sa svakim novim modelom. Prilikom predstavljanja i lansiranja nVidia daje referentni dizajn, a proizvođači lijepe svoje naljepnice. Kasnije "dođu" Gainward/Palit/XpertVision, MSI, Asus i Gigabyte sa svojim PCB-om i naponskom regulacijom, pa ljudi mogu kupiti npr. GTX 570 koji ima 6+2 ili 8+1 faznu regulaciju i clocka se ko da nema sutra. Uglavnom, spomenul sam samo usputno, jer osim nanovo redizajnirane kartice, tj. elektronike, ne ostaje puno rješenja za ovo kaj nVidia trenutačno nudi i prodaje diljem svijeta. |
