Staro 07.01.2011., 17:23   #1
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Arrow Informacije, testovi i recenzije zračnih i vodenih hladnjaka
Zalman's new CNPS11X Extreme features a custom heatpipe and a V-shaped dual heatsink design.
Thursday during CES 2011, Zalman introduced a new CPU cooler using a V-shaped dual heatsink design. Called the CNPS11X Extreme, the heatsink is made of pure copper and aluminum, weighs 600g and measures 135 (L) x 80(W) x 154(H)-mm.
According to the company, the V-shape design dramatically increases cooling performance by increasing the "Thermal Control Area" of the heatsink which in turn increases airflow and reduces noisy turbulence. The design also uses denser heatsink fins which prevent loss of surface area for maximum heat dissipation without sacrificing cooling efficiency.
The Zalman CNPS11X Extreme series CPU cooler also features the company's "Composite Heatpipe" design. This utilizes two combined components: a "Sintered Metal" type wick that generates outstanding capillary pumping performance, and the high thermal conductive design of the "Axial Grooves" which increases the heat transfer rate by 50-percent compared to ordinary heatpipes.
In addition to the design and custom heatpipe, Zalman's new V-shaped CPU heatsink also sports black-pearl nickel plating, an ultra-quiet 120-mm blue LED PWM fan, high-performance super thermal grease ZM-STG2M, and a heat dissipation area of 7,600-cm2.
Although Zalman did not provide pricing or availability, the heatsink joins other featured products at the show including the CNPS7X Performa/LED heatsink, the CNPS5X SZ, the Z9 and Z9 Plus chassis, the hefty-but-tasty GS1200 chassis and more.
http://www.tomshardware.com/news/Hea...11X,11937.html
C L O W N I N G A R O U N D
Staro 17.01.2011., 17:22   #2
Dottore
Dottore's Avatar
Postovi: 7,703
Antec Kuhler H2O 920 and 620
Antec will have two products upon release, the Kuhler H2O 920 and Kuhler H2O 620, both based on a 3rd generation Asetek all-in-one design that brings a few unique changes over previous generations.
Both units include the same low profile integrated pump & block system and feature a 120mm radiator (heat exchanger), while the Kuhler 920 doubles the thickness of the rad over the 620 and features a push-pull airflow fan configuration.
Asetek ih proizvodi. Corsair ih kupuje pa prepakira svojim imenom.
Prodaja kreće krajem ovog mjeseca, a cijene još nisu objavljene.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 18.01.2011., 21:20   #3
Doink the Clown
Postovi: 6,214
Cooler Master Ships 120 mm Turbine Master Fans
Cooler Master shipped its Turbine Master 120 mm series fans. As the name suggests, the fan has many blades (16 in number), shaped to look like an aircraft turbine. This design allows the fan to achieve high air flow at lower rotation speeds. The Turbine Master 120 is available in two variants based on rotation speed: Mach 0.8, that spins at 800 rpm, Mach 1.2 with 1200 rpm speed, and Mach 1.8 with 1800 rpm speed. Of these, only the 1200 rpm variant is out now, with the other two slated for a little later.
The Turbine Master 120 Mach 1.2 with its 1200 rpm rotational speed pushes 56.5 CFM of air with a rated noise output of 21.1 dBA. The fan uses a round frame with holes for 120 mm spacing, with both rubber and metal screws bundled. The motor uses a barometric ball bearing with a high lifespan. It uses standard 3-pin fan input, but a Molex to 3-pin cable is bundled. The impeller is detachable to help clean better. The Cooler Master Turbine Master 120 Mach 1.2 fan is priced at US $16.
http://www.techpowerup.com/138702/Co...ster-Fans.html
Staro 18.01.2011., 21:28   #4
nino
nino's Avatar
Postovi: 12,613
Vec vidjeno kod Aerocool ventova.
Staro 18.01.2011., 23:20   #5
Dottore
Dottore's Avatar
Postovi: 7,703
Corsair H60
Izvor : vr-zone.com
Službeni : Corsair
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 19.01.2011., 01:09   #6
hari123
Brucos
hari123's Avatar
Lokacija: Bosnia
Postovi: 174
da li se jedan vent 80mm smije prikljucit na jedan prikljucak od 6pin od grafe , imaju dva 3pinska
hari123 je offline   Reply With Quote
Staro 20.01.2011., 19:59   #7
Doink the Clown
Postovi: 6,214
EverCool Intros Transformer 3 CPU Cooler
EverCool announced its latest CPU cooler, part of its Transformer series, the Transformer 3. It features similar design and styling as the Transformer 4. As the number next to "Transformer" indicates, this cooler uses three heat-pipes compared to 4 on its bigger sibling. Measuring 130 x 161 x 78.5 mm, the heatsink weighs 630 g. The three 6 mm thick nickel-plated copper heat pipes are evenly spread along the plane of the aluminum fins, and make direct contact with the CPU at the base. A 120 mm chrome-plated fan is in charge of ventilation, it spins at speeds between 800 and 2200 RPM, is PWM-controlled, and has a rated noise output of 15~34 dBA. It is compatible with all current sockets including LGA1366, LGA1155/LGA1156, LGA775, AM3/AM2+/AM2. The company did not give out pricing.
Staro 21.01.2011., 13:04   #8
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Staro 25.01.2011., 16:14   #9
Doink the Clown
Postovi: 6,214
Scythe Announces Setsugen 2 VGA Cooler
The Japanese cooler manufacturer Scythe presents a new graphics card cooler called Setsugen 2. The successor of the popular and award-winning Setsugen 1, improving the well-known basic design and is highly compatible with current graphics cards. Four copper-heatpipes distribute heat generated by the graphics card over the entire surface of the cooler. The direct heat dissipation is achieved by a fanned arrangment of the heatpipes. Thanks to this well-balanced heat distribution, the air flow of the built-in 120 mm Slip Stream Slim fan is used with maximum efficiency despite the small dimensions of the heat sink. Low height of only 33 mm allows easy trouble-free SLI / Crossfire mode.
For the active cooling a Slip Stream 120 mm Slim fan with only 12 mm height is used, which allows a speed control range of 800 (± 20%) to 2,000 rpm (± 10%). Thus an air flow of 19.40 to 45.47 CFM / 32-76 m³/hr is generated. Fan speed is controlled by a rotary potentiometer which is easily accessible via a PCI slot bracket on the back of the PC. This allows the user to find the ideal compromise between performance and noise level (from 19.53 to 33.67 dBA) for his system.
For Setsugen 2 a revised version of the U.M.C.P. (Universal Multi-Platform Compatibility Plate) mounting mechanism is used. Two different mounting-plates in connection with the universal backplate provide not only simple and easy bolt assembly, but also an almost across the board compatibility with standard ATI® and NVIDIA® graphics cards. The compatibly list contains among others the ATI® Radeon® HD 5750 / HD 5770 / HD 5830 / HD 5850 / HD 5870 / HD 6950 / HD 6970 and Nvidia® GeForce® GTX 460 / GTX 465 / GTX 470 graphic crads. (See specifications for full compatibility list) Included with the Setsugen 2 graphics card cooler are several aluminum memory heat sinks and special heat sink for VRAM and voltage regulators. Original Scythe thermal compound and a PCI-Express extension cable are supplied as well.
New Scythe Setsugen 2 VGA Cooler (Model No. SCVSG-2000) is already available for 38.90 EUR (excluding VAT).
Product Details
  • Model Name: Setsugen 2
  • Model No.: SCVSG-2000
  • Compatibility NVIDIA: Geforce Fx5900 /6600 /6800 /7300 /7600 /7800 / 7900 /8500 /8600 /8800GTS (G92) /8800 GT (G92) 8800 (G80) /9600 GT /9600 GSO /9800 GT /9800 GTX /9800 GTX+ /GTS 250 /GTX 260 /GTX 275 /GTX 280 /GTX 285 /GTX 460 /GTX 465 /GTX 470
    o ATI: 9*** /X*** /X1300 /X1600 /X1650 /X1800 /X1900 /X1950 /HD 2600 /HD 2900XT /HD 3650 /HD 3850 /HD 3870 /HD 4770 /HD 4830 /HD 4850 /HD 4870 /HD 4890 /HD 5750 /HD 5770 /HD 5830 /HD 5850 /HD 5870 /HD6950 / HD6970 (Note: VGA Heatsink compatible with HD 6850/6870,VRAM Heatsink not included)
  • Overall Dimensions: 176 x 33x 139 mm / 6.93 x 5.47 x 1.30 in
  • Weight: 435 g / 15.34 oz.
  • SLI & CF Compatibility: Yes
  • Supplied Fan: Scythe Slip Stream Slim 120 mm (with fan controller)
  • Fan Dimensions: 120 x 120 x 12 mm / 4.72 x 4.72 x 0.47 in
  • Fan Speed: 800 (± 30%) ~ 2,000 rpm (± 10%)
  • Noise Level: 19.53 ~ 33.67 dBA
  • Air Flow: 19.40 ~ 45.47 CFM
http://www.techpowerup.com/139135/Sc...GA-Cooler.html
Staro 30.01.2011., 16:13   #10
Schtefek
Schtefek's Avatar
Datum registracije: Jun 2010
Lokacija: Križevci
Postovi: 172
Znam da malo kasnim, nemojte mi to zamjerit, ali kaj nije ovaj identičan ovom Thermalright Ultra 120
Schtefek je offline   Reply With Quote
Staro 30.01.2011., 16:31   #11
Schtefek
Schtefek's Avatar
Lokacija: Križevci
Postovi: 172
ZALMAN ZM-SF3
Hmm zanimljive specifikcije/features, bas me zanima cijena kad dodje u nas.
Zanima me jel ima kod nas za kupiti ovaj ventilator gdje? Jel toliko dobar koliko ga reklamira Zalman?
Koji je Ventilator najbolji i najtiši na tržištu, cijena nije bitna?
Staro 31.01.2011., 22:54   #12
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,017
Molim preporuku hladnjaka za AM2/AM3 socket do maksimalno 450-500 kn da ima ventilator na sebi ili posebno. Hladio bi AMD x6 1055 laganini 24/7 overclock.
Svi dućani u Zagrebu i okolici dolaze u obzir.
Staro 31.01.2011., 23:11   #13
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,761
Za lagani oc i to pogotovo Phenoma II ti ne triba cooler od 450-500kn (osim ako u buducnosti ne mislis dobrano oc'ati), dovoljan bi bija jedan ZALMAN CNPS10X Performa koji ima odlican omjer ulozeno/dobiveno ili
Cooler Master Hyper 212 Plus. Ako svejedno zelis skuplji cooler onda Scythe Yasya SCYS-1000 ili ZALMAN CNPS10X Quiet...
Staro 01.02.2011., 00:12   #14
Doink the Clown
Postovi: 6,214
Autor Schtefek Pregled postova
Najočitija razlika ti je u pajpovima; Cogage ih ima 4 a TRUE 6
Staro 01.02.2011., 01:53   #15
MAGARAC
MAGARAC's Avatar
Postovi: 5,996
U pravu je. Isti je kao i "stari" ultra 120 sa 4 pipea, koji nije isti kao truljo sa 6.
MAGARAC je online   Reply With Quote
Staro 01.02.2011., 02:06   #16
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Kenjčino stara.. Imaš TRUE i TRU.
Thermalright Ultra 120 Extreme vs. Thermalright Ultra 120
Staro 01.02.2011., 09:26   #17
Doink the Clown
Postovi: 6,214
Autor Bullet1 Pregled postova
Kenjavče
Ja sam usporedio sa svojim hladnjakom, što sad cjepidlačite
Staro 01.02.2011., 13:34   #18
dejanbinladen
konjpjukter
Postovi: 934
taj cougage je kopija muxa120
dejanbinladen je offline   Reply With Quote
Staro 03.02.2011., 10:38   #19
Doink the Clown
Postovi: 6,214
Koolance Intros High-Flow 120 mm, 184 CFM Fan
Evo jedan helić za OC ekipu
Enthusiast PC cooling expert Koolance introduced its latest product, a 120 mm high-flow fan for cases, air-coolers, and radiators, but we're inclined to think it's designed to let users make the most out of smaller 2-fan radiators. The FAN-12038HBK-184 from Koolance measures 120 x 120 x 38 mm, it draws power from a 3-pin fan header and includes speed monitoring. With a top-speed of 4,000 RPM, the fan can push 184 CFM of air with a rated maximum noise output of 59 dBA. Since it spins at tremendously high speeds and uses a high amperage motor (2.0A), Koolance cautions its users to use a grill along with it, as its blades pose a safety hazard. At $11.99, the Koolance FAN-12038HBK-184 is relatively affordable compared to similar fans from Sanyo-Denki/San-Ace, Delta, PanaFlo, or Yate Loon.
Staro 03.02.2011., 11:31   #20
Čevap
Čevap's Avatar
Postovi: 47
Di se mogu nabavit ovakve stvarčice?
Čevap je offline   Reply With Quote
Staro 03.02.2011., 11:42   #21
BojanZD
BojanZD's Avatar
Postovi: 1,398
U HR sigurno ne...za svaku pizdariju moraš van granica ili prek neta naručivat!
BojanZD je offline   Reply With Quote
Staro 03.02.2011., 12:15   #22
Schtefek
Schtefek's Avatar
Lokacija: Križevci
Postovi: 172
Autor dejanbinladen Pregled postova
Muxa 120 ??? koji je to hladnjak? jel bolji ili lošiji od TRU?
Staro 03.02.2011., 12:21   #23
Postovi: 8,237
Ima dobar komentar ispod objave
At that price this will be very popular with the extreme crowd. Well, would if they didn't already own a zillion high flow fans.
Onak, disu bili prije. Ak su ljudi u HR uspjeli nabavit delte koje su htjeli i koliko su htjeli, znači da ih vjerojatno već imaju i u zanzibaru.
Pa de idi makar na službeni web vidjeti o čemu se radi
http://www.thermalright.com/products...t_id=27&id=146
Staro 04.02.2011., 09:37   #24
Schtefek
Schtefek's Avatar
Lokacija: Križevci
Postovi: 172
Pa nemoj da se ljutiš
Nisam skužil da je proizvođač isti, a izgleda lepo ta muxa, i vent mi se čini solidan, ali na izgled
Staro 04.02.2011., 11:55   #25
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,761
Heh, nhf ali ko jos gleda izgled danas, imho efikasnost je na 1. mistu a ako uz to jos i dobro izgleda - super. Rewieve mozes naravno naci na netu... Da, slazem se da je hladnjak dosta dobar, ali uz ostale poput zalmana performe i sl. koji imaju bolji omjer bang for buck (a performanse ne zaostaju), tesko ga je preporuciti..
Staro 04.02.2011., 14:36   #26
Schtefek
Schtefek's Avatar
Lokacija: Križevci
Postovi: 172
Kad smo već kod toga, ja imam na svom procu Sythe Gama Cross, onaj veliki hladnjak koji ima na sebi 140mm vent, po vašem mišljenju dobar ili baš i ne?
Staro 04.02.2011., 18:18   #27
Doink the Clown
Postovi: 6,214
Thermalright Archon CPU Cooler
http://www.rwlabs.com/article.php?id=357
Staro 07.02.2011., 21:02   #28
baban
baban's Avatar
Datum registracije: Aug 2008
Lokacija: DE
Postovi: 591
120 mm Fan Roundup, Part I: 1350 RPM or Lower Rotation Speed
Today we are going to discuss 18 fan models with rotation speeds of 1350 RPM or lower. We will check out their acoustic performance and airflow readings.
120 mm Fan Roundup, Part 2: 1350 RPM or Higher Rotation Speed
We continue testing 120 mm fans and today we are going to check out 32 models, which rotation speed exceeds 1350 RPM. We will check out their acoustic performance and airflow
source: X-bit labs
baban je offline   Reply With Quote
Staro 15.02.2011., 19:55   #29
baban
baban's Avatar
Lokacija: DE
Postovi: 591
Staro 15.02.2011., 20:06   #30
Doink the Clown
Postovi: 6,214
EKL Unveils Alpenfohn Peter GPU Heatsink
Cooling specialist EKL unveiled the Alpenfohn Peter, a high-end VGA cooler which the company plans to release at this year's CeBIT event, in March. Visualized in CGI drawings below, Alpenfohn Peter is a large GPU heatsink which could span across the length of most high-end graphics cards. It makes use of two high-density aluminum fin arrays that use a zig-zag fin design to add turbulence and improve heat dissipation. Heat is conveyed to the two fin arrays by six nickel-plated copper heat-pipes that pass through the GPU block. For ventilation, Alpenfohn Peter will be the first VGA heatsink to use two massive 140 mm fans that latch on to it using a PCI bracket with a rail fastening system. The Alpenfohn Peter should be compatible with most square GPUs. More info and pictures at CeBIT.
http://www.techpowerup.com/140502/EK...-Heatsink.html
