Staro 29.01.2011., 20:55   #31
generic
generic's Avatar
Postovi: 1,082
Autor MAGARAC Pregled postova
TRebat ce onda puno downclockat GPUe..
...što je super stvar za krajnjeg korisnika. Uz dobro hlađenje (možda kiler od auta ili potegnuti cijev od klime), dvoglava zvijer će potezati s tih niskih frekvencija na prave GTX 580 frekve
Staro 29.01.2011., 21:22   #32
nexusone
Datum registracije: Apr 2008
Postovi: 139
Kolko bu to kostalo kod nas. 1000 eura?
Kod nasih trgovaca valda 1000€ + PDV...
nexusone je online   Reply With Quote
Staro 29.01.2011., 21:46   #33
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Opa, pa ovo čudo bi moglo prestić Aresa po cijeni
fran123456 je offline   Reply With Quote
Staro 30.01.2011., 05:09   #34
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Autor fran123456 Pregled postova
Hebeš cijenu, ljudi traže performanse
C L O W N I N G A R O U N D
Staro 18.02.2011., 22:39   #35
doky
doky's Avatar
Datum registracije: Nov 2010
Postovi: 1,942
Očito će ta GTX 590 zvijerka biti brzo predstavljena jer su je naveli u 266.7x beta driverima.
GeForce GTX 590 and GTX 550 Ti pops up in New Beta Driver
A recent released 266.7x driver revealed two new graphics card entries. This implies a pending release of
The GeForce GTX 590 and GeForce GTX 550 Ti cards are nearing. GeForce GTX 590 is a dual GF110 GPU solution with 3GB GDDR5 memory while GTX 550 Ti is based on GF116-400, comes with 1GB GDDR5 memory.
We think (and hope) that the GTX 590 is based on GF110 cores and packs 1024 stream processors, 128 texturing units, 96 ROPs and dual 384-bit memory interfaces.
The Nvidia GeForce GTX 590 is ideal to compete with AMD's Radeon HD 6990 "Antilles" GPU that is also expected to arrive in the first quarter of 2011.
doky je offline   Reply With Quote
Staro 18.02.2011., 22:46   #36
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Bas me zanima koja ce prva izac. Bilo je svakakovih informacija da nece uopce, da ce bit sporija od radeonke i sl. U svakom slucaju ce bit spektakularna grafa i strahovito me zanima TDP, odn na koju foru ce bit 300w.
Staro 20.02.2011., 17:15   #37
Astral
Postovi: 2,523
zvuci zanimljivo u svakom slucaju
Astral je offline   Reply With Quote
Staro 01.03.2011., 21:00   #38
Romano.Cule
Outer Space
Romano.Cule's Avatar
Lokacija: Vinkovci
Postovi: 854
Jel mozda netko zna koliko ima konektora za napajanje? 2 x 8 pin ili 1x 6 i 1 x 8 ili 1x6 2x8 pin? Bas i nisam raspolozen da mjenjam ovo svoje jer ima samo 2 x 8 pin PCI konektor
Staro 01.03.2011., 22:05   #39
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,314
investiras u "adapter" 20 kn, molex => sto god ti treba
Chuby je offline   Reply With Quote
Staro 02.03.2011., 12:26   #40
Romano.Cule
Outer Space
Lokacija: Vinkovci
Postovi: 854
Ma nemam sta investirati,imam tih adaptera ko blata,nego se radi o tome da napajanje nije predvidjeno za napajanje takve graficke,cim nema dodatni PCI 8 pin konektor.
Staro 02.03.2011., 13:04   #41
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Nije predvideno ali radi bez greske. Nije tx650 onda ni prilagoden za vise od 1 grafe a ja sam bez problema ganjal 3 kom sa njim. Bilo kako bilo ak mislis takvu zvijer ganjat, odn. imat neke koristi od nje bez 2560x1600 monitora ili 3 manja i i7 proca na 4.0ghz nema smisla.
Staro 02.03.2011., 13:19   #42
Astral
Postovi: 2,523
To nema veze, jako malo graficki ga uopce zahtjeva, gledaj samo jacinu napajanja, pod to mislim na kolicinu ampera na 12v railu. Ni jedno napajanje nije "customizirano" za odreden tip kartica...
Edit: Magarac me prestigo :-)
Staro 02.03.2011., 20:39   #43
Romano.Cule
Outer Space
Lokacija: Vinkovci
Postovi: 854
Mislis da nema potrebe? 3D Vision zahtjeva dupli prikaz u 1680 x 1050 pa sam mislio malo pojacati.Proc mi je 3.8 ghz Quad core Phenom II
Staro 02.03.2011., 20:53   #44
Astral
Postovi: 2,523
uzmi grafu ako mislis da ti treba, ali napajanje nemas potrebe mijenjat
Staro 09.03.2011., 22:19   #45
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
NVIDIA GeForce GTX 590 Launch Date is March 22
The dust seems to have settled down, after AMD's launch of the Radeon HD 6990, extending the red-team's performance lead previously held precariously by the Radeon HD 5970, to the GeForce GTX 580. It looks like NVIDIA will challenge the performance leadership with GeForce GTX 590, a dual-GPU graphics card that uses two GF110 GPUs (the ones on GTX 570 and GTX 580), for an SLI-on-a-stick solution. Rumors of NVIDIA working on this card became concrete as early as in November 2010, when NVIDIA's reference board became public for the first time.
Latest reports suggest that NVIDIA has chosen March 22 as the launch day of GeForce GTX 590. Incidentally, that is also the launch date of EA/Crytek's much-hyped, initially DirectX 9 action/shooter game, Crysis 2. GeForce GTX 590 uses two GF110, though the shader configuration and clock speeds are not known. Since NVIDIA is chasing the top-spot, you can expect the most optimal configuration for the GF110s. A total of 3 GB (1536 MB per GPU system) on board, and NVIDIA's workhorse PCI-E bridge, nForce 200 will be the traffic cop and radio station between the two GPUs. The card will be able to do 3DVision Surround (NVIDIA's multi-display single head technology comparable to ATI Eyefinity) on its own, without needing a second card.
http://www.techpowerup.com/141837/NV...-March-22.html
Staro 09.03.2011., 23:06   #46
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Znači nije 15. nego 22.
Još samo ako uspiju hlađenje riješit da nije promašaj kao 6990...
Staro 10.03.2011., 11:11   #47
Doink the Clown
Postovi: 6,214
Autor T}{OR Pregled postova
Nadam se da će vapor chamber sistem biti dovoljan da solidno odradi hlađenje na referentnim modelima dok kod MSI TF/Gigabyte modela ne bi trebalo biti problema prema dosadašnjim performansama od GTX460 pa nadalje
Staro 10.03.2011., 23:26   #48
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Ako je suditi prema novoj 5xx seriji trebali bi, no s druge strane (ako se ne varam) i HD6990 ima "parnu komoru" pa se ipak na pojedinim review-ima gasila zbog pregrijavanja.
Staro 12.03.2011., 12:52   #49
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Matth€w je offline   Reply With Quote
Staro 12.03.2011., 19:59   #50
kripton
Cars & Tunning
kripton's Avatar
Lokacija: Vukovar - Rijeka
Postovi: 536
Jedva su G92 hladili na signle slot, ovo ce imat naljepnicu na sebi 'zapaljivo'
NovA Squadron
kripton je offline   Reply With Quote
Staro 12.03.2011., 20:07   #51
Doink the Clown
Postovi: 6,214
Autor Matth€w Pregled postova
Pardon for the mistake, we missed out the bottom part of the cooler which is about a slot thick so GeForce GTX 590 is still a dual slot card.
Toliko o tome
Staro 12.03.2011., 20:17   #52
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Ma normalno da je dual slot, gdje bi stao taj treći aktivni DVI za mogućnost single card nVidia Surrounda kojeg su više puta najavili, a i sumnjam da ne bi još pored njih imala i HDMI/DP izlaz, jednostavno ne bi fizički stalo na single slot I/O backplate. Da ne pričam o količini topline (i vrlo vjerojatno većeg RPM-a/buke ventilatora) koje bi proizvodila ma koliko god da hladnjak bio dobar.
Staro 12.03.2011., 20:18   #53
Doink the Clown
Postovi: 6,214
Ma normalno da je dual slot, gdje bi stao taj treći aktivni DVI za mogućnost single card nVidia Surrounda kojeg su više puta najavili, a i sumnjam da ne bi još pored njih imala i HDMI/DP, jednostavno ne bi fizički stalo na single slot I/O. Da ne pričam o količini topline (i vrlo vjerojatno većeg RPM-a ventilatora) koje bi proizvodila ma koliko god da hladnjak bio dobar.
Pa normalno, optimističan naslov, ništa drugo. Još gledam ono
Staro 14.03.2011., 18:17   #54
Doink the Clown
Postovi: 6,214
GeForce GTX 590 Key Features Revealed
An alleged partner presentation slide leaked to the internet reveals quite a bit more about the GeForce GTX 590 than what we already know. To begin with, it lays to rest speculations surrounding the shader configuration, each of the two GF110 GPUs have all 512 CUDA cores enabled. Next, the full width of the memory interface is utilized, giving you 1536 MB per GPU, or 3 GB of total memory on the card.
The rest are fascinating features, such as a removable cooler shroud that lets you clean the card from time to time (you might need to clean it now and then for the best cooling performance), heatsinks that use vapor-chamber technology, getting rid of those pesky heat-pipes, high-grade 12-layer PCB that uses 2 oz copper layers, and a 10-phase VRM (looks like 4+1 phase per GPU). As expected, the final iteration of the card needs to draw power from two 8-pin PCI-E power connectors. "Barely Street Legal"? Is it because they'll throw you out of LAN parties for having too much of a performance advantage? Hmmm.
http://www.techpowerup.com/142153/Ge...-Revealed.html
Staro 15.03.2011., 07:57   #55
Tumor
prof.dr. gospodar svemira
Tumor's Avatar
Postovi: 434
http://www.fudzilla.com/graphics/ite...ks-the-gtx-590
600MHz mi se cini puno prenizak takt.
Tako su vec "zaklali" GTX470 sa preniskim taktovima.
If you are not paranoid you don't have enough information
Tumor je offline   Reply With Quote
Staro 15.03.2011., 08:10   #56
generic
generic's Avatar
Postovi: 1,082
Autor Tumor Pregled postova
To barem znači da će se dati jako clockati uz dobro hlađenje (osim ako OCP ne ulati u igru).
Staro 18.03.2011., 18:22   #57
Doink the Clown
Postovi: 6,214
NVIDIA GeForce GTX 590 Launch Delayed to March 24?
Odgoda od par dana izgleda...
Originally slated for March 22, NVIDIA has reportedly delayed the launch of its new high-end GeForce GTX 590 graphics card to March 24, sources told Expreview.com. The reason for this delay is not known, and NVIDIA isn't confirming this delay. NVIDIA GeForce GTX 590 is a dual-GPU high-end graphics card that uses two GF110 GPUs in an SLI on a stick solution.
http://www.techpowerup.com/142428/NV...March-24-.html
Staro 19.03.2011., 15:09   #58
Romano.Cule
Outer Space
Lokacija: Vinkovci
Postovi: 854
Znaci ipak ce biti 2 x 8 pin PCIE.Ali ako ce se grijati kao svinja i trositi pola kilowata moram jos razmisliti o kupovini.
Staro 19.03.2011., 20:09   #59
crusher
crusher's Avatar
Postovi: 159
Objavljeni podaci:
D13U-50 GF110/P1020
CUDA Cores
1024
Graphics Clock
612MHz
Processor Clock
1224MHz
Memory Clock 3420MHz
Memory Interface Width
2 x 384-bit
Memory Config 3GB GDDR5
Power Connector
s
Dual 8-pin
Dimensions 11" x 4.5", Dual Slot
Read more: http://vr-zone.com/articles/nvidia-g...#ixzz1H4PkVc10
crusher je offline   Reply With Quote
Staro 24.03.2011., 15:56   #60
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
