Povratak   PC Ekspert Forum > Računala > Overclocking > Memorije
Staro 07.09.2010., 09:54   #91
Autor marko.m Pregled postova
Evo imam nekoliko pitanja u svezi memorije
Naime imam proc i7 870S i namjeravam uzeti Asrock P55 Deluxe3 ploču , a
na tržnici sam naletio na ovo http://forum.pcekspert.com/showthread.php?t=197035
pa me zanima da li bi ova memorija odgovarala ovoj ploči i procu.
Na stranicama Asrocka sam pogledao http://www.asrock.com/mb/memory/P55%20Deluxe3.pdf
ali te se Muskin niti ne spominje a komoli ovaj model pa vas molim za savjet.
Hvala
raditi će bez problema. G.Skill recimo kaže za svoje memorije da su npr. isključivo za Asus P55 bazirane ploče, a rade na svima ostalima.
Staro 07.09.2010., 10:38   #92
marko.m
Lokacija: zadar
Postovi: 112
Hvala Brko
..suicide is like a solution that can't be undone.....
marko.m je offline   Reply With Quote
Staro 26.10.2010., 18:22   #93
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,903
Staro 23.11.2010., 17:53   #94
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
OCZ Announces High-Performance 'Xtreme Thermal Exchange' and Blade 2 DDR3 Memory
OCZ Technology Group, Inc., a leading provider of high-performance solid-state drives (SSDs) and memory modules for computing devices and systems, unveils new Xtreme Thermal Exchange (XTE) and Blade 2 high-speed desktop memory, providing the optimal balance of blazing DDR3 performance and cooling efficiency in one solution. Committed to staying ahead of the curve in the high performance segment of the memory market, OCZ is offering high-end memory that keeps pace with intensive overclocking, gaming, and other high-productivity computing environments.
“Building on our previous lines of enthusiast overclocking memory, the new XTE and Blade 2 DDR3 memory series are designed to set the benchmark once again and deliver the ultimate in performance and stability,” said Alex Mei, CMO of OCZ Technology Group. “Featuring new compact, yet highly efficient heatspreader designs, these hand-tested kits are the ideal solution for overclockers gaming and productivity applications, and are optimized for the latest generation of platforms from Intel and AMD.”
Offering enthusiasts extreme speeds, Blade 2 Series features a new finned anodized aluminum heatsink design for superior thermal management, and are available in 2400MHz and 2133MHz performance kits. Other new additions include the Platinum XTE and Gold XTE Series, to be deployed in premium 2133MHz, 2000MHz, and 1600MHz solutions, coupled with a sleek low-profile anodized aluminum heatspreader design to offset high temperatures that can damage DRAM ICs.
Developed for next generation platforms that take advantage of extreme speeds, OCZ XTE and Blade 2 solutions are the choice counterparts for leading-edge performance and reliability, meeting the demand for high-speed AMD AM3, Intel Core i3, i5, and i7 processors. With an ideal combination of frequency and low latency, OCZ’s latest 6GB and 4GB memory kits are specifically designed and qualified on a range of motherboards supporting enhanced clock speeds beyond typical JEDEC profiles.
OCZ’s XTE and Blade 2 triple-channel and dual-channel kits are available in PC3-19200, PC3-17000, PC3-16000, and PC3-12800 speed ratings, and are 100% hand-tested for quality assurance. Furthermore, each OCZ module is backed by the OCZ Lifetime Warranty and industry-leading technical support for unparalleled peace of mind.
http://www.techpowerup.com/135069/OC...R3-Memory.html
_________________________________________________________________________________________________________________
Corsair Intros Vengeance Series of DDR3 Memory Kits
Corsair introduced a new line of PC3-12800 (DDR3-1600 MHz) memory kits based its latest memory module design, the Corsair Vengeance. The Vengeance modules make use standard height DIMM PCBs, making use of a 'light' heatsink that goes on to be slightly taller than the PCB. 'Light', because unlike the heatsinks on the Dominator modules, Vengeance's heatsink looks to consist of just thick metal plates of the heatspreader elongating into a few heatsink fins, much like G.Skill's RipJaws modules.
The Vengeance modules can operate at 1600 MHz speeds with DRAM voltage of 1.5V, with CL8 and CL9 timings available in the lineup. The modules come in densities of 2 GB and 4 GB, making up single-channel (single module), dual-channel, and triple-channel memory kits, in capacities of 4 GB (single module), 8 GB (2x 4 GB) dual-channel, 6 GB (3x 2 GB) triple-channel, and 12 GB (3x 4 GB) triple-channel.
A list of models follows.
  • 4GB (1x4GB) 1600MHz 9-9-9-24 @ 1.5V Single-Channel DDR3 (CMZ4GX3M1A1600C9)
  • 6GB (3x2GB) 1600MHz 8-8-8-24 @ 1.5V Triple-Channel DDR3 (CMZ6GX3M3A1600C8)
  • 8GB (2x4GB) 1600MHz 9-9-9-24 @ 1.5V Dual-Channel DDR3 (CMZ8GX3M2A1600C9)
  • 8GB (2x4GB) 1600MHz 8-8-8-24 @ 1.5V Dual-Channel DDR3 (CMZ8GX3M2A1600C8)
  • 12GB (3x4GB) 1600MHz 9-9-9-24 @ 1.5V Triple-Channel DDR3 (CMZ12GX3M3A1600C9)
  • 16GB (4x4GB) 1600MHz 9-9-9-24 @ 1.5V Dual-Channel DDR3 (CMZ16GX3M4A1600C9)
http://www.techpowerup.com/135076/Co...mory-Kits.html
C L O W N I N G A R O U N D
Zadnje izmijenjeno od: Doink the Clown. 23.11.2010. u 21:02. Razlog: Corsair Vengeance
Staro 24.11.2010., 21:41   #95
Hrubi
Hrubi's Avatar
Datum registracije: Sep 2004
Postovi: 817
momci jel može preporuka za best buy DDR3 memu za i5 760+Asrock P55 Extreme?Klokat cu ju ziher,doduse ne odma,ali za godinicu kad se počne teglit;-)
Znači,nije mi bitno da li će biti 2x4Gb ili 4x2GB,uglavnom mora biti 8 ukupno
Hvala
Hrubi je offline   Reply With Quote
Staro 24.11.2010., 21:51   #96
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Za tu "godinicu" kako ti to kažeš, najmanji problem će ti predstavljat brzina memorije. Klokanjem memorije ionako nećeš dobit ništa osjetno ni sad ni za "godinicu". A pošto ideš na 8GB, stvar overclockinga je još teža jer više opterećuješ IMC. Ono od čega ćeš uvijek profitirat u većoj ili manjoj mjeri jest overclock procesora. Stoga, nepotrebno ti je razmišljat na način "trebam bijesnu memoriju jer ću klokat za godinu dana". Naravno, ako ti baš želiš bijesnu memoriju, nitko te nebude odgovorio od toga
Staro 24.11.2010., 21:56   #97
Hrubi
Hrubi's Avatar
Postovi: 817
žena možda;-)fala
Staro 02.12.2010., 00:23   #98
Doink the Clown
Postovi: 6,214
Staro 20.12.2010., 20:16   #99
Zebran
Zebran's Avatar
Lokacija: Bedekovčina
Postovi: 149
Dal ima kod nas za kupiti memorija 2x4 GB koja radi na 1600MHz i koja bi bez problema radila na AMD platformi? Vidim da na tržištu ima dosta 4 GB modula na 1600MHz ili više, ali samo za Intel. Ili se moram registrirati na PayPalu i pokušat sreću sa carinicima.
Zebran je offline   Reply With Quote
Staro 21.12.2010., 14:39   #100
bAKa-47
Postovi: 157
Autor Hrubi Pregled postova
Hvala
imam isto pitanje samo se radi od 2x2gb, dakle koju kupiti? Proc i ploča isti... Kupio bih je ovaj tjedan.
hvala
bAKa-47 je offline   Reply With Quote
Staro 22.12.2010., 08:56   #101
Autor bAKa-47 Pregled postova
hvala
IMHO, G.Skill RipJaw 2x2 CL7 1600MHz ako želiš brzu memoriju za ok para. A ako ne misliš memoriju OC-at, onda uzmi 2 keksa po 2GB Kingmaxa vulgaris, ili čak i 4 keksa.
Staro 23.12.2010., 15:21   #102
bAKa-47
Postovi: 157
hvala brko...
samo problem je što sve kupujem u ADM-u. Može neka preporuka od tamo raspoloživih memorija?
jel ovo ok ili ima i boljih solucija!?http://www.adm.hr/product_info.php?products_id=7643
thx
Staro 23.12.2010., 17:23   #103
Zebran
Zebran's Avatar
Postovi: 149
Našao!
Staro 23.12.2010., 18:26   #104
hvala brko...
thx
uštedi 140kn i uzmi OVO
Staro 23.12.2010., 22:56   #105
bAKa-47
Postovi: 157
hvala
Staro 24.12.2010., 09:45   #106
Doink the Clown
Postovi: 6,214
Kingmax Announces First DDR3-2400 MHz Memory Module Without Heatsink
The world-famous DRAM module manufacturer KINGMAX presented overclocking DDR3 2400MHz Nano Gaming RAM. It is the unique and the only one DRAM module can be operated at 2400MHz without conventional heat sink. Instead of adding conventional heat sink, Nano Gaming RAM adopts the nano thermal dissipation technology(NTD Tech)to improve thermal performance by 10%. Its bandwidth can reach up to 19.2GB/sec under low voltage which means the performance will be more conspicuously improved in 3D shooting games that involve more rigorous requirements for speed.
Heat dissipation is always the key issue for the stability of system operation. Particularly in overclocking or 3D games, high temperature may easily cause the instability of operation. Targeting the overclocking and game market, KINGMAX DDR3 Nano Gaming Ram adopting NTD Tech increases the effect of heat radiation, it not only keeps the working temperature far lower than conventional heat sinks, but improves thermal dissipation performance by 10%, thereby effectively maintaining low temperature and high stability. In other words, only NTD Tech can replace conventional heat sinks and only Nano Gaming Ram can allow overclocking enthusiasts and gamers to feel free to challenge the overclocking limit.
KINGMAX Nano Gaming Ram not only has excellent thermal dissipation performance, but reaches 2400MHz and provides high speed transfer bandwidth up to 19.2GB/s with low voltage 1.65V and CL value 9-11-9-27. It exhibits great effects of 3D games. Besides that, Nano Gaming Ram has ASIC chip embedded for anti-counterfeiting purpose design to prohibit counterfeiting. Meanwhile, it supports dual channel platform of Intel P55 chipset (2200MHz above), to reach 100% system compatibility and stability, to fully satisfy the high quality requirements of overclocking and game masters.
Nano Gaming Ram series include 1600MHz, 2000MHz, 2200MHz and 2400MHz for different kind of Motherboard and CPU matches. All products have passed not only 100% rigorous tests before ex-factory delivery, but CE (EU), Intel’s XMP certifications and RoHS. KINGMAX memory modules have been well acclaimed by consumers due to their excellent compatibility, stability and outstanding overclocking performance. KINGMAX provides worldwide lifetime warranty service to exemplify its persistence on premium quality and insistence on flawless customer service.
Features of KINGMAX DDR3 2400MHz Nano Gaming Ram:
  • Support Intel P55 Chipset
  • Adopting Nano Thermal Dissipation Technology
  • ASIC chip embedded for anti-counterfeiting purpose
  • Lead-free production process
  • TinyBGA technology adopted: with advantages as compact size, well heat dissipation and low EM interference
  • 100% product compatibility and stability
  • High data transfer performance for overclocking enthusiasts and hardcore gamers
Specification of KINGMAX DDR3 2400MHz Nano Gaming RAM:
  • 240-pin DDR3 2200MHz
  • CAS Latency: 10
  • Bandwidth: 17.6GB/sec
  • Voltage: 1.5~1.8v
  • Capacity: 4GB (2GB x2)
  • Worldwide lifetime warranty
http://www.techpowerup.com/137006/Ki...-Heatsink.html
Staro 10.01.2011., 18:09   #107
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Yey.. imamo se čime igrat u slobodno vrijeme haha.. Obavezno filmić pogledati
Crucial has launched a DDR3 memory line-up, dubbed Ballistix Smart Tracer, which allows users to control activity-indicating and ground-effect LED colors and patterns. The new modules also include integrated thermal sensor that allows users to monitor memory temperature. The two rows of lights can be customized using the Ballistix MOD utility that is offered for free by Crucial.
The Ballistix Smart Tracer memory is available in the following configurations:
2 GB module running at 1600 MHz with CL8 timings at 1.65 V, orange/blue LEDs or red/green LEDs, USD 59.99
4 GB kit (2 x 2 GB) running at 1600 MHz with CL8 timings at 1.65 V, orange/blue LEDs or red/green LEDs, USD 118.99
6 GB kit (3 x 2 GB) running at 1600 MHz with CL8 timings at 1.65 V, orange/blue LEDs or red/green LEDs, USD 178.99
Izvor: hardwaresecrets
Staro 19.01.2011., 10:08   #108
Flake
Lokacija: Mostar
Postovi: 203
pa zasto ne zivim u americi
$9.99 - 2GB ddr3
Flake je offline   Reply With Quote
Staro 19.01.2011., 17:11   #109
perich
I hate mondays..........
perich's Avatar
Datum registracije: Nov 2002
Lokacija: Zagreb - Zaprešić
Postovi: 1,544
ja ubo dva komada OVIH.... meni ok...
perich je offline   Reply With Quote
Staro 06.02.2011., 22:54   #110
stipe1771
stipe1771's Avatar
Lokacija: split
Postovi: 233
Sta mislite o ovom ,tj koja je ovo marka uopce,jos je tragicno da je jeftinije 10 puta njihova dostava nego nekog ducana iz zg-a
http://cgi.ebay.com/NEW-4GB-2x2GB-DD...#ht_2600wt_905
stipe1771 je offline   Reply With Quote
Staro 15.02.2011., 16:00   #111
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,970
Pozdrav,
Ima li tko u posjedu Corsair XMS3 2x4GB 1600MHz memoriju uz Phenom 2 procesore? Ne zanimaju me visoki heatspreaderi niti OCanje memorije. Želim samo deklariranu brzinu od 1600MHz, i da se u Zagrebu mogu nabaviti dva modula od po 4GB. Naravno, memorija mora biti stabilna, mislim da se to ni ne treba napominjati. Ploča i proc bi bili Gigabyte 890FXA-UD5 (memory compatibility list im je onak, čudan, dva 4GB modula samo navedena) i AMD Phenom 2 x4 970. Bilo koji drugi proizvođač osim Kingmaxa, a da je jeftiniji je dobrodošao.
Zahvaljujem na odgovorima.
Staro 17.02.2011., 21:26   #112
doocc
doocc's Avatar
Datum registracije: Apr 2008
Postovi: 8
1333 ili 1600 mhz
Kupujem novu maticnu i proc pa uzimam usput i nove rame same me zanima koji su bolji DDR3 2048MB ( 2GB ) Kingmax, 1333MHz, CL9, FLFE85F-B8EE9 ili
DDR3 2048Mb ( 2Gb ) Kingmax, 1600MHz, CL9, FLGE85F-B8KJ9A, NANO
idu na Asrock M3A770DE, AM3 - AMD 770 + AMD SB710, ATX, FSB2600, Dual C
doocc je offline   Reply With Quote
Staro 17.02.2011., 22:39   #113
Astral
Postovi: 2,523
pa bolji su 1600, al tak svejedno...ako je neka razlika u cijeni uzmi 1333, ak je vise manje isto onda uzmi jace
Astral je offline   Reply With Quote
Staro 18.02.2011., 13:06   #114
doocc
doocc's Avatar
Postovi: 8
Razlika u cijeni je 25 kn tako da i nije strasno :P tako da uzimam 1600 ..
Staro 16.03.2011., 14:17   #115
On January 11, 2011, OCZ announced that they will be discontinuing their RAM production citing poor market performance and the weakening global DRAM market. OCZ will discontinue their remaining lines of DRAM models by the end of their 2010 fiscal year on February 28, 2011.[2]
http://en.wikipedia.org/wiki/OCZ_Technology
OCZ to halt DRAM production completely
By Hilbert Hagedoorn, January 12, 2011 - 2:21 AM N/A
A while ago OCZ already announced that it would pull back from the enthusiast memory market, but in the latest Third Quarter Results OCZs Ryan Petersen, CEO mentioned that it is going to halt DRAM production completely.
In August 2010, the Company announced a strategic optimization of its memory products whereby it discontinued certain unprofitable commodity memory module products with the intent to continue only with certain high-performance memory products. However, since that time, there has been well-chronicled, continued weakness in the global DRAM markets.
Having balanced this DRAM market weakness against the capital needs of the Company's growing SSD products, the board has determined that it is in the best interests to accelerate plans to discontinue its remaining DRAM module products by the end of its current fiscal year of February 28, 2011. Accordingly, our DRAM products are now expected to have minimal, if any, sales in the next fiscal year and beyond.
http://www.guru3d.com/news/ocz-to-ha...on-completely/
nisam znao da su prestali proizvoditi RAM. najavljivali su nove Blade memorije, Reapere i kaj ja znam kaj i sada ovo izgleda da bu G.Skill došao svima glave
Zadnje izmijenjeno od: Brko. 16.03.2011. u 14:30.
Staro 16.03.2011., 23:02   #116
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,328
preporuka kojih rama do 450kn max 2x2gb ddr3 sa 1055t i asrock 890gx?
gledam ove genesis kingston ili?
SetH je offline   Reply With Quote
Staro 18.03.2011., 10:12   #117
Autor SetH Pregled postova
Može. sa njima nikakvih problema glede kompatibilnosti sa AMD tehnologijama. Moj sused prodaje isključivo Kingston i Transcend memorije i uglavnom na ove ASRock 890GX/FX trpa kingstone (value, hyperx, genesis) i nikakvih problema nema.
Staro 18.03.2011., 12:56   #118
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,018
Kolega ima problema s ASRock 870 extreme 3 pločom (amd 1055 proc-sve na defaultu) i memorijom http://www.corsair.com/memory/xms-cl...m2a1600c9.html
Naime memorija s 1 pločicom boota u svim slotovima na default taktu i voltaži 1.70v, dok druga pločica želi samo u 3. slotu.
Mem test je nakon jedno 9 sati pokazao jednu grešku (u dos-u ), da li je memorija za reklamaciju? Kad stavim u ikoji drugi slot ne boota uopće komp.
Kad stavim skupa obje pločice, ili uopce ne boota, ili boota i u BIOS-u pokaže samo 2 gb rama (tj prepozna 1 pločicu samo, to sve govorim dok je u biosu postavljeno kako treba biti timing i voltaza na 1.70v, te je na dodir kod mem testa memorija lagano topla).
Što mi je činiti? Već je kolega jednom odnio u ADM na reklamaciju memoriju, na što su oni odgovorili da su stavili voltazu koja treba biti i da memorija kod njih radi, makar je meni tek nakon 9h testiranja pokazalo grešku, oni vjerovatno nisu toliko testirali.
kasko je online   Reply With Quote
Staro 22.03.2011., 15:32   #119
skitnica
Debeli gad
skitnica's Avatar
Datum registracije: Jun 2010
Lokacija: Makarska
Postovi: 844
DDR3 8GB (2x4GB) Kingmax, 1600MHz, CL9.0
Ova memorija: LINK
Ukratko, zanima me da li ce ova memorija moci raditi na 1866Mhz. Kolega vjerovatno sutra kupuje konfiguraciju (i5 2500k, Asrock p67 Extreme 4) pa trazimo odgovarajucu memoriju. Do sada nam je izbor bio Corsair Vengeance koji je nekih 100kn skuplji, ali ako ovaj kingmax zadovoljava uvjete zasto ne. bar smo sigurni da cemo moci ugraditi Mugena na procesor.
skitnica je offline   Reply With Quote
Staro 22.03.2011., 16:33   #120
lit
Lokacija: hr
Postovi: 977
Ako može jedno pitanje u svezi 2x4GB modula, kako su u većini svi CL9, meni više treba da ja CL6 ili CL7, pa da li se može to postići sa takvim modulima?
I koliko na taj način "uništavam" memoriju tj. skraćujem joj vijek trajanja?
lit je offline   Reply With Quote
