Staro 26.11.2010., 13:59   #661
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Autor nathan.fake Pregled postova
steta sto je PowerColora vise nema za kupit kod nas (doduse ima, sestrinski, VTX3D, al oni imaju samo osnovne modele)
Sta je onda ovo u stinksu ?
viper je offline   Reply With Quote
Staro 26.11.2010., 16:27   #662
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
MSI Announces Radeon HD 6870 Twin Frozr II OC Graphics Cards
Internationally renowned graphics card and mainboard manufacturer MSI announces today the R6870 Twin Frozr II graphics card. It is equipped with the latest 40nm AMD Radeon HD6870 GPU, IGB GDDR5 high-speed graphics memory, and the award-winning Twin Frozr II thermal solution. As a result, the operating temperature and noise of the R6870 Twin Frozr II are reduced by 19°C and 12.8dB respectively (versus the reference design). Also, the overvoltage function from the MSI-exclusive Afterburner software further enhances the OC potential of the Barts GPU, and AMD’s Eyefinity Technology provides optimal multi-display 2D/3D output for gaming, productivity and entertainment. Along with the super reliable Solid CAPs which prolong product life and enhance product stability and quality, the R6870 Twin Frozr II is the best choice ever for power users looking for graphics cards with ultimate performance and low operating temperature.
Exclusive Twin Frozr II thermal solution maintains perfect balance between cooling and noise control
The Twin Frozr II found on the R6870 Twin Frozr II consists of a large-area copper base heat-sink with high density radiation fins, dual 8cm temperature-controlled PWM fans, and five heat-pipes to increase airflow and enhance heat conductivity for the GPU and neighboring components. In addition to the superb cooling effect, it is quiet! Under full load, the Twin Frozr II cooler reduces temperature and noise by 19C and 12.8dB respectively versus the reference design. By design, the R6870 Twin Frozr II is the industry-first graphics card that achieves a perfect balance between thermal solution and noise reduction.
Support for Afterburner overvoltage function to unleash display performance
In terms of software support, the R6870 Twin Frozr II supports the MSI-exclusive Afterburner OC software designed for instantaneous GPU and memory clock adjustments and advanced fan speed control. Users can even save up to 5 OC profiles of their own for gaming, productivity and entertainment. With the Afterburner, users can further adjust the GPU voltage to break through the limit of GPU and thereby unleash the power and performance of graphics cards. The Afterburner can also monitor the GPU temperature and fan speed for power users to totally control their graphics cards.
AMD Eyefinity and 3D Video
The R6870 Twin Frozr II is equipped with the AMD-exclusive Eyefinity Technology for multi-display, supporting up to four screens. DisplayPort 1.2 and HDMI 1.4a (which support 3D video and 7.1-channel lossless TrueHD and DTS-HD audio formats) help provide consumers with the most exciting audio/visual fun.
http://www.techpowerup.com/135191/MS...ics-Cards.html
Hlađenje kao stvoreno za vađenje masti na zraku
C L O W N I N G A R O U N D
Staro 29.11.2010., 09:48   #663
Doink the Clown
Postovi: 6,214
Staro 05.12.2010., 12:29   #664
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
Izgleda da su 6950 i 6970 krenule prema dućanima, barem prema ovom postu na forumu britanskog dućana overclockers.co.uk. Autor posta je valjda jedan od zaposlenika.
Cijene su očekivane, s obzirom na cijene konkurencije: 300 funti (~2650 kuna, znači najmanje 3000 kod nas ) za 6950 i 400 funti (~3500 kuna) za 6970.
cccp je offline   Reply With Quote
Staro 05.12.2010., 14:44   #665
sliver
Datum registracije: Jan 2010
Postovi: 149
Super, onda nemam kaj čekat nove kartice jer neće sigurno utjecat na cijenu HD 68xx serije.
sliver je offline   Reply With Quote
Staro 05.12.2010., 14:54   #666
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,780
Autor sliver Pregled postova
Nemas 68xx serija je odlicna.
Bono je online   Reply With Quote
Staro 05.12.2010., 15:27   #667
Minox
Minox's Avatar
Postovi: 565
ali zato oce na 58xx seriju
Minox je offline   Reply With Quote
Staro 07.12.2010., 00:31   #668
Postovi: 7,568
Stvari oko HD 6900 serije se sve više zahuktavaju s približavanjem službenog dana (13.12.) lansiranja i predstavljanja. Kad se iz svega kaj kola netom i mnoštvom stranih foruma izdvoji ono kaj donekle ima smisla, HD 6950 i HD 6970 su već jedno dulje vrijeme u rukama kojekakvih testera. Slika prvih inženjerskih primjeraka i modela koji su već pripremljeni od strane proizvođača ima u izobilju, novi Catalyst 10.12 je (navodno) pripreman posebno za HD 6900 seriju i poslužil bude kao temelj za nadolazeće APU procesore, a kruže i kojekakvi interni dokumenti koji sve to u jednu ruku i potvrđuju.
Situacija je slična na skoro svakoj stranoj HD 6900 temi (na slici su dvije HD 6970), a jedino za kaj se ne zna ko pije, a ko plaća je datum lansiranja. GTX 570 izlazi sutra, a po novome bi na neku ludu foru taj isti dan trebal isteći NDA za HD 6900 seriju, dok bi kartice imale službeno predstavljanje 08.12. - malo teže vjerojatno, ali ko zna. Performanse su u najgorem slučaju u rangu s GTX 580 ili malo bolje, yield čipova je na strani HD 6970, tj. više ih je potpuno ispravnih, a ostatak ide za HD 6950, a kaj od svega ovog bude se pokazalo kao istina - ostaje za saznati u sljedećih tjedan dana.
Zadnje izmijenjeno od: McG. 07.12.2010. u 00:47.
Staro 07.12.2010., 23:50   #669
snob
Majo
Datum registracije: Dec 2009
Postovi: 186
U koliko sati krece predstavljanje novih kartica?
snob je offline   Reply With Quote
Staro 08.12.2010., 00:39   #670
Postovi: 7,568
Sarkazam ili ne, ali ako misliš na današnji dan kao istek za NDA i sutra kao službeno lansiranje - ništa od toga, jer je tak jasno da spada u žešću klasu optimist. Jedini razlog zbog kojeg sam to spomenul i linkal u prijašnjem postu, je čista suludost i forsiranje koje se odvija na stranim forumima. Isto ko i konstatno (u slučaju HD 6970) spominjanje 30 do 40% boljih performansi u odnosu na GTX 580. Jednostavno suludo namatanje okorjelih zagovornika AMD-ATi grupacije. Okorjelih u tom smislu da i na R600 fijasko gledaju kao super proizvod.
AMD je danas predstavil nove Athlon II i Phenom II procesore, dok je na dan lansiranja GTX 580 modela, predstavil planove i proizvode bazirane na Bulldozer i Bobcat arhitekturama. HD 6900 kartice su i dalje u planu za početak sljedećeg tjedna, jer bi u suprotnom već sad (kak je to bil slučaj s HD 6800) net vrvil neslužbenim recenzijama, dok bi se oko ponoći sve službene recenzije stavljale na naslovne stranice IT portala diljem svijeta.
Dvije HD 6970 kartice koje su poslane u Guru3D, a slika je danas postana i kasnije maknuta od strane Hilberta Hagedoorna - vlasnika i glavnog urednika spomenutog portala.
NIje teško zaključiti da su dosad svi vodeći IT portali dobili svoje primjerke finalnih proizvode za službeno testiranje.
S obzirom da je Guru3D prvi "slučajno" objavil i nakon toga povukel svoju recenziju HD 6800 kartica, ne bi bilo ništ čudno da i s HD 6900 serijom naprave isto.
Zadnje izmijenjeno od: McG. 08.12.2010. u 21:40.
Staro 09.12.2010., 01:08   #671
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Evo malo se poigrao sa grafom da vidim ide li to kako. TriXX na djelu
http://slike.hr/slike/clock6850_232bf.png.html
http://slike.hr/slike/6850mjerenja_0160f.jpg.html
Zadnje izmijenjeno od: ECHO. 09.12.2010. u 01:24.
Staro 09.12.2010., 17:32   #672
Postovi: 7,568
Cijene za MSI HD 6950 1GB i HD 6970 2GB su objavljene na cjeniku francuskog web-shopa. Vrijeme dobavljivosti je 11.12. za HD 6950 i 23. 12. za HD 6970. Poprilična svota od ~€400 za HD 6950 i ~€500 za HD 6970 stvaljaju kartice u cjenovni rang novih GTX 570 i GTX 580 modela. Strani forumi se i dalje pune sa žuči, dok Fuad cijelo vrijeme pušta kojekakve nebulozne specifikacije, mada se cijela službena prezentacija već dva tjedna povlači po netu. Ali yebiga, ne bi Fuad bil Fuad i ne bi ljudi bili ljudi. Istovremeno se oni koji imaju kartice hruste i bahate sa screenshotovima, ali se sve promptno miče i nema šanse da netko da neku konkretnu informaciju o performansama novih HD 6900 kartica.
Staro 10.12.2010., 16:49   #673
cccp
cccp's Avatar
Postovi: 1,030
Američka vlada bi trebala učiti od ATI-a kada je u pitanju tajnost podataka.
Sve je više glasina o tome da HD6970 ima 1536 stream procesora (24X16 SIMD-a vs. 20X16 SIMD-a kod HD5870), a HD6950 1408. Kako su u ATI-u rekli, nova VLIW4 konfiguracija daje slične rezultate uz 10% manje prostora od VLIW5 konfiguracije. Prema tome 1536 4V je približno jednakih perfomansi kao i 1920 5V, znači teorijski HD6970 ima 20% više SP-a od HD5870. Ako pretpostavimo da su HD6870 (1120SP) i HD5850 (1440SP) jednakih performansi ispada da su novi stream procesori 28,5% "brži" od starih. Zbrojimo onih 20% i ovih 28,5% ispada da bi HD6970 trebala biti 48,5% (ovih pola posto je jako važno ) brža od HD5870, naravno u teoriji. Kako je gospodin krešo napisao u recenziji Caymani bi trebali biti 25% brži od HD5870 da bi pobijedila GTX570, to će valjda uspjeti. Opet prema spekulacijama izgleda da ATI ima namjeru HD6970 pozicionirati upravo protiv GTX570, a ne 580, tu borbu bi trebala preuzeti HD6990.
Još jedna zanimljiva stvar je veličina čipa kod Caymana od 390 mm2 nasuprot 530 mm2 kod GF110 (~35% veći), za usporedbu GF104 je veličine 367mm2, Barts 255mm2. Poprilično dobre TDP specifikacije, 190W za vrijeme igranja, max 240W. Spominje se i promijenivi TDP, tj. da ga korisnik može na neki način ograničiti.
Sve su to moje spekulacije na osnovi tuđih spekulacija (), ali kada se sve uzme u obzir ima nekog smisla. Moderatori neka slobodno brišu ako nije primjereno ovom forumu.
Staro 10.12.2010., 17:02   #674
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
Kinezi kao testirali 6970 i kao da je malo brža od 580-ke.
d4rk_ch1ld je offline   Reply With Quote
Staro 10.12.2010., 17:12   #675
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Lepa slika
Naravno, radi se o HD6970.
Staro 10.12.2010., 17:18   #676
d4rk_ch1ld
d4rk_ch1ld's Avatar
Postovi: 695
12.12.2010.? Vremeplov? Jebeno veliki šubler ti treba za nove kartice
Staro 10.12.2010., 17:26   #677
Momir
Momir's Avatar
Postovi: 1,012
Meni slika smrdi na fejk.
Pa kako to da jos pise ATi na turbini???
Momir je offline   Reply With Quote
Staro 10.12.2010., 17:34   #678
Postovi: 7,568
Ne mora biti, jer i na stranim forumima oni koji su dobili prve primjerke, također imaju ATi naljepnice. Kaj se tiče 1536SP za HD 6970 - Fuad radi svoje, a Internet se pretvara u pokvareni telefon.
Već danima se svađaju oko toga diljem stranih foruma i začarani krug je stvoren. HD 6990 se sastoji od dva Cayman čipa s 1920SP-a u VLIW4 izdanju, ali svi i dalje bruje o 1536SP-a za jači HD 6900 model.
Staro 10.12.2010., 19:51   #679
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Autor d4rk_ch1ld Pregled postova
Ma svi su već, koji su trebali, istestirali Caymane od davno. Preostaje samo čekanje završetka embarga, odnosno 15.12., tako da ne bi se čudio da je ta vijest i točna.
Matth€w je offline   Reply With Quote
Staro 10.12.2010., 20:20   #680
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Autor Momir Pregled postova
Slika sigurno nije fejk. Niko (Tiborrr) ovu karticu ima kod sebe vec neko vrijeme.
Milentije je online   Reply With Quote
Staro 10.12.2010., 20:26   #681
krešo
Administrator
krešo's Avatar
Datum registracije: Sep 2002
Lokacija: PCE Lab
Postovi: 4,009
Slika je totalni fake. Ajd decki strpite se jos malo, pa 5 dana nije dugo, onda ce te sve znati
krešo je online   Reply With Quote
Staro 10.12.2010., 20:27   #682
Postovi: 7,568
Sve je već jedno dulje vrijeme u rukama onih koji budu sljedeći tjedan objavili svoje dojmove u službenim recenzijama. Jedino još Microsoft odugovlači s verificiranjem Catalyst 10.12 drivera, makar i to bude uskoro (ako već i nije) dobilo službeni WHQL "pečat". Do onda ostaje Fuadovo naklapanje na temelju kojeg su već mnogi počeli dodijeljiivati epic-fail epitet HD 6900 seriji, a i ono malo razumnih postova se uredno preskače, jer se to ne uklapa u opće viđenje stvari.
Fake ili ne - zaključite sami.
Fuad Abazović i njegovi sljedbenici vs. svi ostali.
Zadnje izmijenjeno od: McG. 10.12.2010. u 21:01.
Staro 10.12.2010., 20:57   #683
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
To što ima crveni PCB ne znači da takva kartica ne postoji. A i inače uvijek dobije te najranije ES kartice tako da ovo ne treba nikog čuditi.
Staro 10.12.2010., 21:05   #684
Postovi: 7,568
Nije jedini s takvim primjerkom. Na XS-u par tipova također ima HD 6900 modele s ATi logom, a dobili su ih već prije o-ho-ho. Jedini koji je pokazal friške referentne modele je Hilbert s Guru3D-a.
Usput je Guru3D tema o HD 6900 karticama kompletno obrisana, jer su postani 3DMark rezultati HD 6970 kartice.
Autor McG Pregled postova
Zadnje izmijenjeno od: McG. 10.12.2010. u 21:14.
Staro 10.12.2010., 21:29   #685
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Stvarno mi nisu jasni sa tim kršenjem NDA. Kao da će im neka plavušica pofafati kitu ako objave prvi rezultate.
Staro 10.12.2010., 21:31   #686
Postovi: 7,568
Valjda da dementiraju Fuada i ekipu ili jednostavno, jer više ne mogu izdržati, a da ne podijele sa svima. Na kraju je cijela tema dobila - cap.
Od ovog posta (uvećana slika koju je Bullet1 postal s jasno čitljivom zelenom naljepnicom), pa nadalje se stvari još više zapliću.
Zadnje izmijenjeno od: McG. 11.12.2010. u 00:35.
Staro 11.12.2010., 01:02   #687
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
To mi se vrtilo po mislima u par navrata. Već je dosta vremena prošlo od kako su oni podjelili određene primjerke ljudima. To predugo traje da bi se moglo okarakterisati kao čekanje da ih se nakupi dovoljno na lagerima za prodaju.
Izgleda da su podjelili "beta" verziju.
Staro 11.12.2010., 01:08   #688
Postovi: 7,568
Kolko se da iščitati iz svega vezanog uz te Slow Speed Board kartice s kojima raspolažu na stranim forumima - AMD-u je pun kufer curenja informacija i specifikacija. Pa su jedini koji imaju konkretne i finalne modele - sami recenzenti, koji jasno radi NDA ne smiju ništ otkriti. Da dana službenog predstavljanja se ništ ne bude znalo, a i čim se nekaj proba objaviti, stvar završi ko s Guru3D temom.
Staro 11.12.2010., 01:11   #689
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
I love where this story goes... Zbog ovakvih stvari se serije kartica pamte
Staro 11.12.2010., 14:36   #690
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,432
Meni isto nije jasno tko tu koga i zašto, ali mi se Fuadove informacije (osim njegovih zaključaka na temelju tih informacija) čine vjerodostojnima. Čarli je i sam rekao da lik nije potpisao ništa pa eto služi kao kanal za informacije ispod stola. I nije slučajno sad sve izletilo, AMD je tek prekjučer (ili dan prije) dijelio karte za testiranje.
