#121 |
Lokacija: Zgb
Postovi: 1,108
#123 |
Datum registracije: Feb 2010
Postovi: 964
Jako puno ovisi dal je velika gužva. Recimo oko božića +/- 1mjesec dolaze stvari tek nakom 30dana, ako uleti neki praznik sve se produžuje 5 dana. Do sada mi je sve došlo bez problema, ako se naruči više stvari a jedne ili više nema na lageru pošalju ostale da se ne čeka bezveze i dobiješ komad papira na kojem je naškraban partnumber itema koji nisu poslali izgleda smiješno i ja ga nisam prvi put vidio nego se žalio da nisam dobio sve kaj sam naručio pa su mi poslali neke stvari 2 puta ![]() Ako je sve ok nakon 2-3 dana je stvar zapakirana i onda se šalje i treba 20-15 dana da dođe. U prosjeku 15 dana sa dealextreme-a a sa betofferbuy-a 20 dana. |
#124 |
Lokacija: Zgb
Postovi: 1,108
Dear Customers, Chinese Mid-Autumn Festival (Sept 22th,2010) is around the corner, DX team, including Customer Service and Order Fulfillment Center, will take two days off for this holiday and back to work on Sept 24th,2010. And the following National Day (Oct 1st, 2010), we will be off from Oct 1st, 2010 to Oct 3rd, 2010 as well. During the holidays, you will still be able to place orders for any items on our website, but your CSE tickets and unshipped orders will probably be held. We will strive to clear up the backlog of tickets and existing orders before and after the holiday. Please accept our sincerely apologies if any inconvenience it may caused you. Your understandings are highly appreciated. ***Update*** {2010.10.04}The CS team and Fulfilment center are back to work today and we're getting down to process the unawser tickets and the delayed orders. All processing are in queue, should you have waited a bit, please allow us a few more days, we will catch up as soon as possible. We appreciated your understanding and patience. {2010.10.05}Currently, you may find your order(s) on hold even though the items purchased are available in stock. Besides the holiday, the delay was caused by a system upgrade which launched on 28th Sept, 2010. With the new system, all the stock information has been corrected and we are able to purchase what exactly customers needed from the suppliers. In other words, we will be able to view the accurate stock information in nearly future. Most orders on hold are actually available for shipment, but because of a backlog orders from the holiday and the appropriate adjustments made on warehouse and fulfillment center base on the new system, the order processing therefore has to be put off for some extend. Anyway, all the adjustments have been done at present. We understand the importance of timely receipt of the orders and we will spare no effort to complete your orders in the following days. Thank you for your understanding. Best Regards, DX Team |
#126 |
Lokacija: Zgb
Postovi: 1,108
ok, promijenili su mi status, pakiraju. Odlicno. |
#127 |
Lokacija: rijeka
Postovi: 3,897
#131 |
Postovi: 30
Zanima me za carinu jel se mora placat carina i do kolko se moze kupovat bez carine , i jel se moze kupovat za vise od dozvoljenog ako se uzme onaj gift za 0,01 dolara . |
#132 | |
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,418
2) Koliko sam čitao po netu u Splitu bez carine do 1000 kn, a u ostalim djelovima Hrvatske do 160. 2) Može se kupovati više od dozvoljenog sa giftom i bez njega, ali onda treba računati na točku 1 i 2. ![]()
#134 |
Lokacija: Kuća
Postovi: 5,418
#135 |
Fresh Juice
Postovi: 4,586
Već tri ili četiri dana status paketa je Packaging. Valjda će ga i poslat jednom hehe |
#136 |
Datum registracije: Mar 2008
Postovi: 347
Sad počinju blagdanski dani, za očekivati je da će duže trebat čekati na isporuku. Uostalom, to i sami navode na stranici. Treba samo čekati ... |
#139 | ||||||||||||||||||||||||||
Postovi: 504
Jeli ovo znači da je još u Kini? Na DE piše da je poslano 30.11. Ovo gore je IPS Ovo je sa Kineske pošte:
#141 |
Postovi: 504
Jasno, naručivao sam već dosta s interneta ali ovo je prvi put s DE. Ne kužim kako mi mogu javiti da je poslano 30.11 (naručeno 22.), a zapravo je 11.12 još uvijek u Kini. Nisam nestrpljiv iz razloga što želim da mi šta prije stigne, nego neću biti doma od Božića do par dana iza Nove godine, pa će mi se dogoditi da će baš onda doći. Odmah bih potpisao da stigne 10.1. Edit: evo čitam na ebay temi da nije poletio ni jedan avion za Hrv ovaj tjedan. Ako je to istina, dogodit će mi se upravo ovo gore. Divotica.. Zadnje izmijenjeno od: murina. 18.12.2010. u 11:36. |
#144 |
Postovi: 504
Godinama već naručujem s interneta. U ovom slučaju sam bio naivan i vjerovao njihovim tablicama po kojima je trebalo doći oko 15. najkasnije 20. prosinca. Moj je iz nekog razloga zapeo prvo na "pakiranju", pa u pošti u Kini. |
#146 |
Lokacija: Kuća
Postovi: 5,418
#147 | ||
Postovi: 504
Nisam, 22.11. mi nije bio Božić na pameti Edit: Citiraj:
![]() Da nebi bilo zabune, ja pi*dim zato jer mi je paket bio na "pakiranju" više od 10 dana, a još su mi u međuvremenu i javili da je poslano (a nije bilo ni u idućih 6, 7 dana). Tek onda je do pošte došlo gdje je stajao ne znam koliko dana. Ovo mi je prva kupovina sa DE i stvarno sam povjerovao u onu tablicu sa fazama slanja paketa (i danima u zagradi) Citiraj:
edit2: jok, ne znaju gdje je, pa ga ne mogu ni tražiti Zadnje izmijenjeno od: murina. 22.12.2010. u 13:56. |
#150 | ||
Datum registracije: Aug 2008
Lokacija: Kod konzum u njemacku
Postovi: 261
znaci ako je RB pocetak ce da dodje za 2 tjedna Citiraj:
