Staro 08.12.2010., 18:07   #241
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Autor Halos Pregled postova
Oke, napočetku mi je bilo čudno kako si dao onu lovu za kučište ono svoje.
Ali ovo, e ovo mi se sviđa
Moj ukus
Eto vidiš, samo je pitanje osobnog ukusa i kad vidiš nešto što ti na prvi pogled izazove onaj drul jednostavno si moraš to kupiti kad tad.
Sad valjda malo bolje kužiš zašto sam si uzeo Obsidiana
C L O W N I N G A R O U N D
Staro 08.12.2010., 18:25   #242
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,327
još kad mi ga mogli normalno nabavit :S
SetH je offline   Reply With Quote
Staro 16.12.2010., 19:21   #243
Doink the Clown
Postovi: 6,214
Zalman Releases GS1200 ATX Full-Tower Chassis
Zalman pleased to inform that the GS1200 is now available for order. Its mesh design with two large 200mm fan provided delivers powerful cooling and excellent air flow at once. On top, to maximize user’s convenience and faster data transfer, front USB3.0 port is adopted. Top cover HDD Docking deck which makes convenient addition of the HDDs possible is another ideal feature of this new generation case to satisfy enthusiast’s requirement.
Key Features
  • Mesh Design for Effective Air Circulation (Front Bezel)
  • Maximum Cooling Performance by 2 large 200mm fans o Left side (1) and top (1) panel
  • 92mm Fan Mounted for HDD Cooling
  • USB 3.0 Ready for Rapid Data Transfer Datao Transfer Rate: 5Gbps Max
  • Convenient Tool-Free HDD Installation
  • Docking Support on the Top of Case
  • 350mm Wide Interior Space for Convenient Parts Installation
  • Separate Apertures for Convenient CPU Cooler Installation
  • Tube Apertures for Liquid Cooling Systems
MSRP: Euro 185.00
http://www.techpowerup.com/136452/Za...r-Chassis.html
Dosta funkcionalno i sviđa mi se ovaj docking station za disk ali ova izbočenja na front panelu (gdje se nalaze ventovi) i na bočnoj stranici baš nagrđuju kućište.
Staro 16.12.2010., 19:34   #244
6Finger
Lokacija: Zagreb, trešnjevka
Postovi: 1,166
Kejs je extra extra, ni cijena ako kod nas bude dobavljiv po navedenoj
6Finger je offline   Reply With Quote
Staro 19.12.2010., 14:17   #245
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Zanimljiv je ovaj Zalman.
Po preporučenoj cijeni pogotovo.
Links zna ubaciti kojeg Zalmana u ponudu, ako ubace ovoga po poštenoj cijeni planut će im u roku odmah.
blaa
Staro 19.12.2010., 14:58   #246
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Poznavajući Links, nećemo ga nači po poštenoj cijeni
fran123456 je offline   Reply With Quote
Staro 19.12.2010., 18:01   #247
dzeneral
Valar morghulis
dzeneral's Avatar
Postovi: 280
Osobno mi se više sviđa stariji model GS1000 Plus
"The objective of war is not to die for your country, but to make the other bastard die for his."
dzeneral je offline   Reply With Quote
Staro 12.01.2011., 16:46   #248
Flake
Lokacija: Mostar
Postovi: 203
koje je best buy kuciste do 2000kn
upada mi u oci cosmos pure u linksu 1999kn
Obsidan 700d/800d ne bi jer nemam vodeno hl. pa mi je preglomazno
a ja trazim neku tihoću
Flake je offline   Reply With Quote
Staro 13.01.2011., 08:40   #249
hammer_of_thor
Postovi: 5,430
Cosmos definitivno.
Nemoš pogriješiti sa njim.
blaa
Staro 13.01.2011., 11:36   #250
sodom
sodom's Avatar
Postovi: 593
da, i ja sam gledao taj pure model otkada je došao..vizualno prekrasno kućište, bio je 2222kn, sada izgleda da su spustili cjenu ali poznavajući links moglo bi se vratiti na staro pa nemoj puno razmišljati
sodom je offline   Reply With Quote
Staro 13.01.2011., 15:46   #251
siloman
siloman's Avatar
Lokacija: Otok Krk
Postovi: 330
znam da nije high end al jabi mjenjao svoj m59....premal mi je...preuzak,cooler mi dotice bocnu,gore nemam mjesta za ventove...trebam vece...do 750kn sta da uzmem?
ciljao sam na cm 690II lite ili nzxt phaenton
ponudite mi nesto jer me ovaj case zivcira lagano
siloman je offline   Reply With Quote
Staro 13.01.2011., 16:04   #252
dzeneral
Valar morghulis
dzeneral's Avatar
Postovi: 280
Autor siloman Pregled postova
Postoji samo nzxt phantom i on ti košta oko 1400 kn, tako da ti se ne uklapa u budžet. Ako ti se sviđa cm 690II lite uzmi njega i mirna Bosna.
Staro 13.01.2011., 16:16   #253
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
u tom rangu najbolje cm 690II
također za 50kn vise pogledaj si i survivior-a i HAF912
Staro 13.01.2011., 16:16   #254
w0lfram_
Rasvjetno tijelo
w0lfram_'s Avatar
Postovi: 374
Autor dzeneral Pregled postova
vjerojatno je mislija na xigmatek pantheon?
@siloman evo ja ti preporucam antec p182, po mogucnosti moj
Pošteni trgovci: 1, 2, 3, 4, 5, 6, 7, 8, 9,10
w0lfram_ je offline   Reply With Quote
Staro 13.01.2011., 17:13   #255
gazda099
gazda099's Avatar
Lokacija: Velika Gorica
Postovi: 170
zna li tko koja je razlika između cm 690 II lite i advanced verzije? pokušao sam naći nešto o lite modelu no uzalud. ni na cooler master-ovim stranicama ništa.
gazda099 je offline   Reply With Quote
Staro 13.01.2011., 18:06   #256
Flake
Lokacija: Mostar
Postovi: 203
Autor gazda099 Pregled postova
Adv. ima 5 stvari koje nema lite, npr. sata dock i sl. pogledaj review advancea na youtubeu, ja gledao nedavno
Staro 13.01.2011., 18:08   #257
Flake
Lokacija: Mostar
Postovi: 203
Autor bluefluid Pregled postova
survivor je grozno kuciste, za 10-15 C je veca temp. u njemu nego u npr. haf 922 ili CM690II
Staro 13.01.2011., 18:12   #258
gibo
gibo's Avatar
Datum registracije: Feb 2010
Postovi: 187
Lite verzija ti nema hdd dock na vrhu, vga holder i ne dolazi sa 140 mm ventom na vrhu. I prednji vent je 120 mm, dok advanced ima 140 mm.
gibo je offline   Reply With Quote
Staro 13.01.2011., 18:31   #259
gazda099
gazda099's Avatar
Postovi: 170
zahvaljujem obojici
Staro 13.01.2011., 21:36   #260
siloman
siloman's Avatar
Lokacija: Otok Krk
Postovi: 330
da,mislio sam na xigmateka...on mi se cini kao besbuy...nije los ni taj p182 al je preskup jer cu dobit isto sta sada imam
haf mi je preruzan...tako da ostajumi sruvivor,xigmatek i cm
Staro 13.01.2011., 21:56   #261
dzeneral
Valar morghulis
dzeneral's Avatar
Postovi: 280
Autor Flake Pregled postova
Daj mi molim te reci od kud ti podaci da je tolika razlika u temp?
Imaš neki link gdje je ista konfa držana u jednakim uvjetima u svim navednim kućištimna?
Staro 13.01.2011., 23:25   #262
Flake
Lokacija: Mostar
Postovi: 203
moze
http://www.bit-tech.net/hardware/cas...v1020-review/3
na listi kucista ga potrazi pa usporedi temperature
Staro 14.01.2011., 15:53   #263
siloman
siloman's Avatar
Lokacija: Otok Krk
Postovi: 330
sada sam naletio na fractal design kucista...predobra su,se moze kako do toga kod nas?
Staro 14.01.2011., 16:03   #264
Doink the Clown
Postovi: 6,214
Nema te egzotike kod nas još, jedino da naručiš izvana.
Staro 14.01.2011., 20:24   #265
dzeneral
Valar morghulis
dzeneral's Avatar
Postovi: 280
moze
Moram priznati da mi je nevjerojatno da postoje tolike razlike u temp između CM690II i survivora, pošto su prilično slični po strukturi i još survivor ima ove 200mm ventove..
Staro 14.01.2011., 22:50   #266
Flake
Lokacija: Mostar
Postovi: 203
znam, ni ja nisam mogao vjerovati... vrlo slicna kucista a opet ogromne razlike
Staro 15.01.2011., 00:48   #267
win32
win32's Avatar
Datum registracije: Apr 2008
Postovi: 1,517
Koja je razlika u tome Cosmos Pure u odnosu na "stari" tj. RC-1000-KSN1-GP osim boje?
Odlicno mi izgleda taj Pure...mozda bi cak mjenjao Obsidiana za njega koliko na slikama ok izgleda.
No kako imam losa iskustva sa navedenim RC-1000-KSN1-GP, nekako sam malo skeptican i prema tome Pure modelu...pogotovo zato sto je "stari" Cosmos bio osjetljiv na ogrebotine ko' "leptir", strasno se grijao radi one izolacije i imao lose izveden cable management i to su neke cinjenice...kablovinje je bilo jako lose rijeseno u RC-1000-KSN1-GP i to me poprilicno zivciralo. Uz to straznja bocna stranica se nikada nije dala zatvoriti kako treba. Dali je to na Pureu ispravljeno ili je ostalo isto? Ako je ispravljeno mozda uistinu uzmem to kuciste.
"In the beginning there was 0. And then there was 1. A mind-bending meditation on the transcendent power of digital computation."
Pošteni trgovac: 1, 2, 3, 4, 5...
win32 je offline   Reply With Quote
Staro 15.01.2011., 01:04   #268
lateralus_eye
lateralus_eye's Avatar
Postovi: 603
Autor win32 Pregled postova
stvarno moraš biti jako jako opičen da ideš obsidiana mjenjati za bilo šta. to već graniči sa ludosti.
lateralus_eye je offline   Reply With Quote
Staro 15.01.2011., 01:46   #269
win32
win32's Avatar
Postovi: 1,517
Da, znam....
No kazem, imao sam Cosmosa i znam koji su njegovi plusevi i minusi i bas radi tih brojnih minusa sam ga i prodao te sam kupio Obsidiana.
Sa Obsidianom sam prezadovoljan no dode ti nekada da promjenis neku stvar...nar meni dode.
Kazem, mozda bih razmisljao o promjeni ako su sve minuse ispravili u Pure verziji....ako su samo boju promjenili, onda nema sanse ni pod "razno".
Cosmos je mogao biti odlicno kuciste, ali zeznili su ga sa morem sitnih nedostataka...ocito je dizajn bio na prvome mjestu, a funkcionalnost na drugome.
Staro 16.01.2011., 19:43   #270
locks
Datum registracije: Mar 2010
Lokacija: Vukovar
Postovi: 3,627
Mislim da danas nema kućište za koje bi vrijedilo dati Obsidiana.Po meni perfektno i savršeno kućište u svakom pogledu....Ako budeš prodavao Obsidiana,javi se
