Staro 24.11.2010., 20:16   #61
Postovi: 7,568
Autor luks 88 Pregled postova
kako to da i5 imaju po 6mb cache-a?, manje nego 1156 i5 serija?
Zato jer je Intel odlučil da nova generacija Core i5 procesora čist dobro prolazi i sa 6MB i unatoč tome je bolja/brža od aktualnih Core i5 i i7 LGA-1156 modela.
Nova arhitektura donosi poboljšanja na svim podfručjima, pa više nema potrebe za masovnim cacheom, jer su i mainstream (bez HT-a) Sandy Bridge procesori bolji od sadašnjih Core-i7 LGA-1156.
Intel Sandy Bridge Core i7-2600K Review
Zadnje izmijenjeno od: McG. 26.11.2010. u 16:36.
Staro 02.12.2010., 14:27   #62
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Arrow Informacije, recenzije i pitanja u vezi Intelovih s1155 procesora i P67/H67 ploča
Stvari se sve vise zahuktavaju, vijesti se mnoze diljem neta pa mislim da bi bilo dobro to sve imati na jednom mjestu...
Pocele su se i perjanice najavljivati
ASUS P8P67 WS Revolution Motherboard Pictured
ASUS unveiled its new workstation-grade socket LGA1155 motherboard that supports 2011-series Core i3/5/i7 processors, as well as, upcoming Xeon LGA1155 processors, the P8P67 WS Revolution. It is packed to the brim with features. To begin with, the CPU is powered by a 16+2 phase digital VRM, the socket is wired to four DDR3 DIMM slots for dual-channel memory, supporting speeds of over DDR3-2200 MHz. There are four PCI-Express 2.0 x16 slots, supporting 3-way SLI/CrossFireX, probably using a bridge chip such as the NVIDIA nForce 200, and three PCI-E x1.
Storage features include four SATA 6 Gb/s ports, and four SATA 3 Gb/s. Connectivity features include two Intel GbE controllers, 8+2 channel HD audio, two USB 3.0 ports, and a number of USB 2.0 ports. Other features include a system diagnostics card, EPU energy-efficiency processor, TurboV Processing Unit (TPU), and Quick Gate instant-on OS. ASUS will announce pricing when it most probably releases this board in January.
ASUS Designing Fatal1ty-branded Motherboards
Leading professional gamer Fatal1ty has branded all kinds of PC hardware, including peripherals, headsets, sound cards, graphics cards, and even motherboards made by erstwhile Abit. Motherboards with the Fatal1ty branding are making a comeback, this time under the charge of ASUS. It is reported that ASUS is designing some socket LGA1155 motherboards based on the Intel P67 chipset using the Fatal1ty branding, in a motherboard that faintly appears to be derivative of the Republic of Gamers series. ASUS will show off its latest motherboards at CES 2011, which will also be the time when Intel unveils its 2011 Core processor family. Socket LGA1155 processors, coupled with Intel P67 platform is the key segment that targets gamers.
Izvor:techpowerup
______________________________________________________________________________________
Evo i dobar pregled ploce koja ima potencijala (ovisno o cijeni naravno) da bude vrlo popularna
ASUS P8P67 Deluxe Sandy bridge mobo preview
This motherboard is using a 16+2 phases (digital) design cooled by blue'ish heatsinks. Of course features like SATA 6G and USB 3 are available as well, and guess what, the board supports SLI and Crossfire, albeit in a x8:x8 configuration. There even is a 3rd mechanical x16 slot though that one is limited at x4 PCE lanes (still handy for a PhysX card).
Key feature of this board is its Dual Intelligent Processors 2- with DIGI+ VRM. DIGI+ VRM combines digital and analog VRM design, delivering less switching delay while offering better accuracy at the same time. Delivering better permeability and less power loss, meaning less heat will be produced under the compared with the traditional digital VRM design.
Izvor: guru3d
Zadnje izmijenjeno od: bluefluid. 23.12.2010. u 19:41.
Staro 03.12.2010., 13:59   #63
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
MSI P67A-GD65 Motherboard
The MSI P67A-GD65 will be a good option for users looking for a high-quality mid-range socket 1155 motherboard with lots of features. Its highlights include four SATA-600 ports, four USB 3.0 ports, automatic overclocking by simply pushing a button (“OC Genie II”), dual BIOS, two PCI Express x16 slot (x16/x8 configuration) supporting both SLI and CrossFireX modes, voltage monitoring points, and a high-end voltage regulator circuit.
Izvor:hardwaresecrets.com
Zadnje izmijenjeno od: bluefluid. 03.12.2010. u 14:09.
Staro 03.12.2010., 14:42   #64
NJUNJO_HR
NJUNJO_HR's Avatar
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 674
Zanima me kaj oni "skrivaju" ispod ovog hladnjaka. Malo skuplje ploče tu ga imaju
a niko ne priča kaj je ispod.
PCE 100+kg demolition squad
LCD 19'' Philips 190P6 | Coolermaster Stacker ATX/BTX (STC-T01) Black | Corsair HX520
ASRock P55 Extreme | Intel i5 760 | G.Skill F3-12800CL7D-4GBECO 2x2GB | XFX 7950 GT 512MB DDR3
Benq DW1670 & Plextor PX-755A | WD Black 1TB (WD1002FAEX), WD Green 2TB (WD20EARS)
Creative SB Audigy Player SB0090 | TP-Link TL-WN651G
Microsoft Wireless Optical Desktop for Bluetooth (Miš i Tipkovnica) | Razer Copperhead (Green) | Genious KB-16e Black
___ <<< Enchantress >>> ___
Parts of watercooling:
Laing DDC-1 water pump
3x Magicool Extreme radiators
EK-Supreme-Acetal for CPU
EK-NF4 rev1.1 for chipset
EK-FC79 for GPU
EK-Multioption reservoir 400 + EK-Multioption RES Bottom Rev.2
& green tubes.
Loop:
rezervoar / pumpa / GPU / rad1 / NB / rad2 / CPU / rad3 / rezervoar
Par slikica iz galerije
H2O galerija
___ <<< ex Morgoth >>> ___
Parts of ex aircooling:
Celeron 420 | ASRock 4CoreDual-SATA2 | XFX 7900 GS 600M
Thermalright Ultra-120 Extreme for CPU lapped
Thermalright HR-05 IFX for chipset lapped
Thermalright HR-03 PLUS for GPU
Lapping galerija
NJUNJO_HR je offline   Reply With Quote
Staro 03.12.2010., 15:32   #65
Elpresidente1
Datum registracije: May 2009
Postovi: 389
NF200 možda (ako sam točno reko tako se zove), i dodatne PCIe stazice donosi, a koje ploča ima.
Elpresidente1 je offline   Reply With Quote
Staro 06.12.2010., 16:57   #66
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Gigabyte P67A-UD4 Sandy bridge motherboard Sneak Peek
This standard ATX sized motherboard is to be called the P67A-UD4 and comes with a 12+2 phase VRM design. The chipset and VRM/MOS area have been covered by passive cooling, heatinsk.
Some key features:
- PCIe 2.0 graphic interfaces support both 2 way NVIDIA SLI and 2 way ATI CrossFireX
- All New Matte Black PCB and Thermal Design
- Supports 2 Power eSATA connectors for enhanced Storage flexibility
- 4 USB 3.0 ports with superfast transfer rates of up to 5 Gbps
- Extensive 12 phase power Design for CPU VRM
- Support for dual channel DDR3 memory
- 8 SATA Ports with RAID (6 onboard, 2 rear)
- Precision OV provides more precise voltage control for CPU, Chipset and memory
- GIGABYTE Patented DualBIOS™ Technology
- Provides Marvell SE9128 and Intel P67 high speed SATA3 storage interface.
Zadnje izmijenjeno od: bluefluid. 23.12.2010. u 19:28.
Staro 07.12.2010., 14:41   #67
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
ASRock H67M-GE/HT Intel H67 board review (first look) Exclusive @ OCWorkbench
On the mainboard, there are 2 USB 3.0 ports at the rear, PCIe GbE, Multi vga output options including D-SUB, DVI-D, HDMI and Displayport. There is also front USB 3.0 support using the bundled USB 3.0 front panel.
ASRock on it’s new generation boards uses Etrontech USB 3.0 controller which is supposedly faster than the NEC USB 3.0 chipset. It claims that it is 3.7% faster than NEC in CyrstlaDiskMark 3.0 (Read Seq) and 97.7% (8M Write) faster in ATTO Disk benchmark.
In addition, ASRock also bundled in a MCE remote controller & multi angle receiver allowing you to control your PC using the remote control thrown in for FREE. On top of that, ASrock also bundled a 3D Red/Cyan Anaglyph Glasses, allowing you to enjoy 3D with Intel INTRU 3D technology. You no longer need to buy special monitor to view 3D Bluray as it is able to decode Stereoscopic 3D Bluray playback in full HD 1080p resolution over HDMI 1.4a.
For those who prefer the old text based BIOS, be in for a treat as UEFI BIOS now gives you a graphical visual display of yoru system. You can now control different aspects of the BIOS using a mouse. UEFI also supports bootable HDD over 2TB.
For overclockers, ASRock includes AXTU. AXTU is a tuning program software utility that suppoerts overclocking and hardware tuning such as energy usage, hardware monitoring and speed control and OC DNA.
Izvor: ocworkbench.com
Zadnje izmijenjeno od: bluefluid. 23.12.2010. u 19:39.
Staro 09.12.2010., 10:43   #68
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Exclusive Preview: Gigabyte H67MA-UD2H Motherboard (with video)
We take a quick look at the Gigabyte H67MA-UD2H Motherboard. It's one of the first motherboards to feature the Intel H67 chipet, designed for the new Intel "Sandy Bridge" LGA 1155 CPUs from Intel. It's primarily aimed at the mainstream and HTPC market, and comes with FULL Dolby Theatre, HDMI, DisplayPort, DVI, with 2 x PCIe slots and Crossfire support. But that's not all ... it also has USB3.0, eSATA, SPDIF optical, SATA RAID, Gigabit ethernet and of course, ALL of Gigabyte's innovative great features.
Izvor: funkykit.com
Zadnje izmijenjeno od: bluefluid. 23.12.2010. u 19:31.
Staro 09.12.2010., 18:14   #69
Ranma 1/2
Anything Goes Martial Art
Ranma 1/2's Avatar
Lokacija: Tendo Dojo
Postovi: 542
hmh...nema PCI slotova
Volio bih da ima barem jedan za UDMA kontroler.
"Water! Why does it always have to be water?!"
Ranma 1/2 je offline   Reply With Quote
Staro 10.12.2010., 11:40   #70
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
MSI Big Bang Marshall P67 Motherboard with Lucid Hydra
MSI is readying a new high-end socket LGA1155 motherboard based on the Intel P67 chipset, geared for overclocking, that features the LucidLogix Hydra Engine chip, that gives out no less than eight PCI-Express x16 slots (electrical lane configurations may vary). The Big Bang Marshall is an XL-ATX motherboard, it makes use of a strong 18-phase CPU VRM that makes use of DrMOS, solid-state chokes, and POSCAP capacitors.
Izvor: techpowerup
Staro 10.12.2010., 16:55   #71
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Na hoh-ovim stranicama su izlistali 28 s1155 ploca sa cijenama.
Cisto percepcije radi, neke od zanimljivijih:
Asus P8P67 - 134 €
Gigabyte GA-P67A-UD3P - 160 €
Asus Sabertooth P67 - 175 €
Gigabyte GA-P67A-UD7 - 320 € (izgleda prehebeno!)
Asus Maximus IV Extreme - 320 €
Staro 11.12.2010., 17:59   #72
Bubych
Postovi: 7
Meni idealna. A i izgleda super.
ECS H67H2-M
pcstats
neoseeker
Bubych je offline   Reply With Quote
Staro 12.12.2010., 13:05   #73
Ranma 1/2
Ranma 1/2's Avatar
Postovi: 542
vidio sam ranije recenziju za tu ploču. zgodno čudovište, ima sve što treba pitanje je jedino cijene.
Staro 12.12.2010., 15:59   #74
snob
Majo
Datum registracije: Dec 2009
Postovi: 186
Wow kakva divna ploca .
A tek ovo:
Asus P8P67 - 134 €
Do 1000kn,a ploca opremljena do ibera.Vrhunski!
snob je offline   Reply With Quote
Staro 12.12.2010., 23:41   #75
Ranma 1/2
Ranma 1/2's Avatar
Postovi: 542
Autor snob Pregled postova
Asus P8P67 - 134 €
kod nas ipak malo skuplja, ako je vjerovati Nabavi. ali ima ju samo jedna trgovina. do iduće godine će i cijena pasti.
http://www.nabava.net/trazilica.php?...P8P67&x=10&y=9
A izgleda da ima i na drugim mjestima:
Intel P67
Intel H67
Zadnje izmijenjeno od: Ranma 1/2. 13.12.2010. u 12:07.
Staro 13.12.2010., 15:40   #76
Postovi: 8,259
Izgleda da će i ASrock prožvakati već sto puta prožvakano i potrošeno Fatal1ty ime i brand!
Asrock Fatal1ty P67 Professional
Iako moram priznat da ploča izgleda sasvim uredno, vidi se da im je asus matori. Još da performanse budu uredne i nitko sretniji od korisnika Samo se nadam da će cijena biti u korelaciji sa ASrock brandom, a ne sa RoG-om.
PS Jel se to men čini il nigdje na ploči i kutiji nepiše ASrock
Zadnje izmijenjeno od: Pupo. 13.12.2010. u 15:47.
Staro 13.12.2010., 15:53   #77
Nakon Abita i OCZ-a eto i ASRocka. mislim da145€ joj je preporučena cijena, no nemrem nigdje naći link gdje sam to vidio. znam samo da je bila njemačka stranica. dakle, 1600kn kod nas kad dođe, vrlo vjerojatno.
btw, ni na ploči nigdje ne piše ASRock
Staro 13.12.2010., 16:07   #78
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Odličan layout.
fran123456 je offline   Reply With Quote
Staro 13.12.2010., 19:11   #79
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Asus P8P67 WS Revolution i Asus P8H67-M EVO
Kako je debilno osmisljen i postavljen Power ON, Reset i post display na P8P67 WS Revolution. Stasno!
Staro 13.12.2010., 20:17   #80
Postovi: 8,259
Autor Milentije Pregled postova
A ako ti je ploča u kućištu nije toliko debilo. Inače, fora mi je što je ovako na kartici jer se da složit produžni kabal
Staro 13.12.2010., 20:44   #81
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Ako je već u kućištu onda je kućište vjerovatno zatvoreno.
U slučaju stavljanja grafičke kartice u poslednji slot ovo ti apsolutno ništa ne znači. Niti možeš prići dugmićima niti možeš pročitati šta piše na displayu. Što se tiče produžnog to još i nekako stoji, ali onda su ga mogli isporučiti sa pločom.
Sve u svemu, mogli su to dosta bolje riješiti poslije silnih modela na koje su stavljali slične stvari.
Staro 13.12.2010., 21:14   #82
Postovi: 7,568
Gigabyte P67A-UD7 Most In-Depth Preview/Review
The new LGA1155 platform has a lot to offer the overclocking and enthusiast community, from great implemenations of the old, and ever expanding features of the new, Gigabyte products always pack that hard punch. From the great SLi design where peripherals do not eat up SLi bandwidth, to the huge tree of USB 3.0 devices, SLi and Connectivity have taken a turn for the better. No longer will your SATA6G SSD be slowed down because of your SLi, and vise versa. Although this board doesn’t use digital PWMs, it is for good reason because Digital PWMs are in their infant stages, and do not offer high switching frequencies, fast reponsivness, and reliability of their Analogue counterpart.
Staro 13.12.2010., 22:05   #83
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Čovjek se stvarno posvetio testu.
Treba uzeti vremena pa ovo s guštom pročitati.
Staro 15.12.2010., 13:35   #84
Momir
Momir's Avatar
Postovi: 1,012
Ovo (1,2) su neke linksove ili asrockove izmisljotine?
Pretpostavljam da je links kriv, ali kod asrocka se nikad nezna
Momir je offline   Reply With Quote
Staro 15.12.2010., 13:41   #85
Autor Momir Pregled postova
Pojavilo se na cjenicima firmi koje svoje stvari baziraju po MSAN-u. i moj sused koji ima firmu također ima te 2 ploče u ponudi, ali ih nema na stanju.
Staro 15.12.2010., 13:43   #86
Momir
Momir's Avatar
Postovi: 1,012
Ma jasno mi je da su se pojavile, ali pise s.1156??
Staro 15.12.2010., 13:48   #87
Asus P8P67
ASRock P67 Extreme4
Asus P8P67 Pro
dostupno DA a na ASRockovom sajtu ni traga ni glasa na popisu svih ploča. A bome ni Asus službeno "ne zna" ništa. MSAN je očito preduhitrio neke stvari
EDIT: Provjerio informacije. MSAN ima gorenavedene ploče na lageru. Procesori će se čekati još neko vrijeme. Eto, offical info
Zadnje izmijenjeno od: Brko. 15.12.2010. u 13:59.
Staro 15.12.2010., 16:35   #88
Postovi: 7,568
ASRock je napravil hibridnu ploču i ljudima ponudil P67 čipset (u obliku ASRock P67 Transformer ploče) za još uvijek aktualne LGA-1156 procesore.
Staro 15.12.2010., 22:25   #89
Prcko Prcić
Datum registracije: Sep 2010
Lokacija: Lepoglava
Postovi: 178
izgleda da cu ubost extreme4, samo me zanimaju cijene procesora? Hoce li to biti skupi procesori, ili ce biti i po 400-500kn modela?
Prcko Prcić je offline   Reply With Quote
Staro 15.12.2010., 22:30   #90
Postovi: 7,568
Teško, čak budu i Pentiumi bliže 700-800 kn, a to je low-end kaj se tiče novih Intelovih generacija. Imaš na Sandy Bridge temi cijene svih nadolazećih procesora.
