Staro 17.11.2010., 18:20   #1
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,040
(riješeno) Silicon Power USB ne radi na Dell N5030
Dakle Silicon Power Ultima II 16Gb stick i Dell Inspirion N5030 ne surađuju.
Stick radi na svim drugim računalima, pa čak i na jednom od 3 usb utora na laptopu.
Sva tri usb utora na laptopu rade normalno sa 2-3 druga sticka.
Friška instalacija win 7 x64 pro, probano sa Ubuntu 10.10 x64,
Win XP sp3 također proban.
Instalirani svi driveri sa Dell stranice za Windbloze, stavljen zadnji bios,
Ubuntu na lspci i na lsusb ne javlja nikakve nepoznate uređaje.
Legacy usb enable/disable isproban.
Na dva porta pored napajanja usb stick jednostavno zasvijetli na sekunudu i to je sve.
Ima li netko neke ideje?
Pomo je online   Reply With Quote
Staro 17.11.2010., 20:16   #2
eyeballl
eyeballl's Avatar
Postovi: 132
Da li se vidi stick u device manageru?
Da li ga vidiš u Administrative toolsima/disk menagementu?
CPU: Intel Core 2 Duo E5400 @ 3.7GHz / Sonic Tower
MBO: Asus P5N-E SLI
RAM: 2 x 2GB DDR2 800MHz Kingmax @ 900MHz
GPU: Gigabyte GeForce 9800GT OC / Acellero S2
HDD: 2 X Western Digital 320GB Blue, Raid
OPT: DVD-ROM
PSU: Corsair VX 450W
CASE: Moded
OS: Windows 7 Ultimate 64bit
CPU: Intel Core 2 Duo E1200 @ 1.6GHz / Stock
MBO: Gigabyte
GPU: Nvidia GeForce 7100 Onboard
HDD: Maxtor 80GB PATA + Seagate 160GB SATA
OPT: Optiarc DVD-ROM
PSU: Corsair VX 400W
CASE: Old School
OS: Windows 7 Ultimate 32bit
CPU: Intel Core 2 Duo E1400 @ 2.0GHz / Stock
MBO: Gigabyte
RAM: 2 x 1GB DDR2 800MHz Kingmax
GPU: Gigabyte GeForce 8500GT / Acellero S2
HDD: Western Digital 250GB
OPT: DVD-ROM
PSU: Chieftec 400W
CASE: Old School
CPU:
MBO:
RAM:
GPU:
HDD:
OPT:
PSU:
CASE:
OS:
U nabavi mrežnog servera....
D-link 8 Portni Switch
Siemens Router C-010-I ISDN
eyeballl je offline   Reply With Quote
Staro 17.11.2010., 20:22   #3
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,040
Nema na ova dva problematična porta.
Kad ga ubodem u treći port, radi ko urica, autoplay i sve.
'buntu isto tako.
Staro 18.11.2010., 11:33   #4
6Finger
Lokacija: Zagreb, trešnjevka
Postovi: 1,166
Pogađam ali mi se čini da ta 2 porta nemogu dat dovoljno struje tom sticku o.O
Inace uopce neznam kavi su "potrošači" stikovi od 16GB, da probaš naći to u specifikacijama kakvim..
6Finger je offline   Reply With Quote
Staro 20.11.2010., 08:20   #5
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,040
Evo situacije.
Laptop sam odnesao na drugu reklamaciju u Links.
Potrošnja uređaja je problem, to stoji.
To sam zaključio nakon testiranja usb ladice sa diskom koji zahtijeva 1000mA.
Također radi samo u trećem portu.
E, sad reklamacija.
Dell ima nekakve Power usb portove, koji imaju plusić kraj one oznake za usb.
Takvi portovi bi trebali biti u stanju pogoniti ovakve jače potrošaće bez beda.
Ovi imaju tu oznaku i očiti problem sa većim potrošaćima.
Jedino nisam izmjerio točno koliko struje daju, ali vjerujem da ne zadovoljavaju ni usb specifikaciju,
koja ako se ne varam iznosi 500mA.
Što se mene tiče riješeno, samo je još pitanje ućerat garanciju.
Zadnje izmijenjeno od: Pomo. 20.11.2010. u 08:44.
Staro 02.12.2010., 14:08   #6
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,040
E pa nisam bio u pravu.
Problem je količina plastike oko usb portova.
Slučajno ova dva uređaja koja imam nisu radila.
Rade uredno preko produžnog kabela.
Očito ne sjednu do kraja u port.
Jedino što ne vidim razliku koliko sjedne u port sami stick i produžni kabel.
Razlika je očito picina dlaka, ali dovoljna da uzrokuje probleme.
