Staro 10.11.2010., 16:27   #1
baTman
Lokacija: asfsafsa
Postovi: 327
BSOD na i5 760, MSI P55 Pro i Win7
Kompjuter je star 4 tjedna:
i5 760 @ 2.8
windows proffesional 64bit sa svim updejtima
p55 pro
4x2 gb ram ddr3 corsair 1333mhz
msi gtx 460 1 gb
Od jutros sam poceo dobivati plavi ekran neznam zasto.......nakon restarta kliknuo sam na details i dobio ovo:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 1050
Additional information about the problem:
BCCode: a
BCP1: FFFFFA8301342390
BCP2: 0000000000000002
BCP3: 0000000000000001
BCP4: FFFFF80002E76754
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\110910-12593-01.dmp
C:\Users\Haki\AppData\Local\Temp\WER-36609-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
skinuo sam bluescreenview.exe sa neta da postam log i evo ga 3 plava ekrana:
Dump File : 111010-13718-01.dmp
Crash Time : 10.11.2010. 16:05:42
Bug Check String : CACHE_MANAGER
Bug Check Code : 0x00000034
Parameter 1 : 00000000`00050830
Parameter 2 : fffff880`0456d708
Parameter 3 : fffff880`0456cf70
Parameter 4 : fffff800`02e86d46
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+70740
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7600.16617 (win7_gdr.100618-1621)
Processor : x64
Computer Name :
Full Path : C:\Windows\Minidump\111010-13718-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 7600
Dump File : 111010-13671-01.dmp
Crash Time : 10.11.2010. 15:13:48
Bug Check String : MEMORY_MANAGEMENT
Bug Check Code : 0x0000001a
Parameter 1 : 00000000`00041790
Parameter 2 : fffffa80`06649290
Parameter 3 : 00000000`0000ffff
Parameter 4 : 00000000`00000000
Processor : x64
Computer Name :
Full Path : C:\Windows\Minidump\111010-13671-01.dmp
Major Version : 15
Dump File : 110910-12593-01.dmp
Crash Time : 9.11.2010. 19:47:06
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
Parameter 1 : fffffa83`01342390
Parameter 2 : 00000000`00000002
Parameter 3 : 00000000`00000001
Parameter 4 : fffff800`02e76754
Processor : x64
Computer Name :
Full Path : C:\Windows\Minidump\110910-12593-01.dmp
Major Version : 15
Molim vas pomozite neznam zasto se ovo dogada....
baTman je offline   Reply With Quote
Staro 10.11.2010., 16:47   #2
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,211
memtestom testirat memoriju
driver sweeperom očistit drivere za grafičku u afe modu, te ih instalirat ponovno
kad to sve probaš javi
Staro 10.11.2010., 17:09   #3
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,816
Ostavi samo 2x2Gb memorije pa vidi da li ti se blesira. Moguće da te gnjavi "cold boot" problem. Ja sam imao taj problem sa 4 komada memorije, morao sam staviti 2x 4Gb...
http://gskill.us/forum/showthread.php?t=5425
Staro 10.11.2010., 19:33   #4
gibo
gibo's Avatar
Datum registracije: Feb 2010
Postovi: 187
Obavezno memtest odvrti. Ovaj zadnji BSOD je meni stalno bacao zbog neispravnog rama.
gibo je offline   Reply With Quote
Staro 11.11.2010., 20:13   #5
baTman
Lokacija: asfsafsa
Postovi: 327
Evo me.....
ocistio drivere i odvrtio mem test posto imam 4 procesora i 8gb rama upalio sam 3 mem testa u isto vrijeme 2 po 2 gb i 1 po 1.9 gb jer nisam zalio da dode do maximuma.
Evo ovo sam uzeo kad je test bio 60% ali na kraju nije nista pokazivalo vise tako da imam samo 1 error.... procitao sam sto kazu na njihovoj stranici da moze biti do OC a NISAM ga pravio,da moze biti neispravan ram ili da u biosu nesto namjetim na default sto nerazumjem sto su s time htjeli reci.
Sada.....ako je neispravan ram jeli mogu ja to poslati na servis jer jos imam garanciju od rama.......a ipak.....ako kupim 2x4 gb rama TKO ZNA hoce li mi OPET biti isti problem......
evo slike:
http://img517.imageshack.us/img517/7862/1111111111p.png
Pomozite molim vas.
EDIT: ja sam skinuo mem test sa http://hcidesign.com/memtest/ posto sada vidim da ima jos neki test za memoriju
Zadnje izmijenjeno od: baTman. 11.11.2010. u 20:25.
Staro 11.11.2010., 20:27   #6
nino
nino's Avatar
Postovi: 12,600
Memtest se ne radi u windowsima. napravi bootabilni cd, pokreni i odvrti memtest.
Staro 11.11.2010., 20:46   #7
baTman
Lokacija: asfsafsa
Postovi: 327
Mozes mi dati link gdje da to skinem jer ima nekoliko mem programa...
Staro 11.11.2010., 20:52   #8
nino
nino's Avatar
Postovi: 12,600
http://www.memtest86.com/ pa na Free Download.
Skini .iso file, zaprzi na cd, bootaj pa pokreni test. Ostavi ga na par sati (ili cijelu noc) i vidi rezultate kasnije.
Staro 11.11.2010., 21:21   #9
baTman
Lokacija: asfsafsa
Postovi: 327
ok stavit cu skidati sada
EDIT:
Evo skinuo sam ali mozes mi molim te reci kako da to preprzim da mi bude bootable? hocu ga samo preko nera staviti BOOT-DVD i staviti ovo sto sam skinuo,staviti u biosu da ga pali sa przilice i to je to?
Zadnje izmijenjeno od: baTman. 11.11.2010. u 21:37.
Staro 12.11.2010., 09:59   #10
Joke
N00B
Joke's Avatar
Postovi: 3,886
ISO image otvori samo sa nekim od programa (Nero, Power ISO, Ultra ISO, Magic ISO)..
Kad napravis to, u BIOS-u "first boot device -> CD-ROM" i "udri".
IE6
Linux is Not Windows
Staro 12.11.2010., 15:28   #11
baTman
Lokacija: asfsafsa
Postovi: 327
Jutros sam pokrenuo mem test i prosao ga 2 puta i nista nije nasao.......pokrenuo sam isto i wd diagnostic tool fast i excended opet nista nije nasao,vecer cu cijelu vecer odvrtiti onaj hirens boot i sutra navecer opet mem test cijelu vecer ako do tada ne nade nista onda stvarno neznam.....
