Staro 04.01.2005., 15:15   #1
dDario
dDario's Avatar
Datum registracije: Jun 2004
Postovi: 1,567
Vmod
Jel mi može neko objasnit šta sve trebam za vmod iz ovog teksta:
Quote:
Originally posted by utherwun
i got 2 15k vrs and 1 25k vr. i know one 25 and one 15 would do it for the cpu and ddr, but im not sure about the vdd. will the 15k be too much, too little, or just right for the vdd????
Woa there! You need 1 MEGA OHM, or 1000K Ohm resistor AND a 1 MEGA Ohm variable resitor. 25k aint gonna cut it!
I got a 47K for the VCORE from radio shack and a 20K for the mem from Fry's. You could use a 47K for the mem to if you had to...
I actually used 2 50ks cus I couldn't find any, but the value you want it set at is 25k and 15k. If you can find a mult-turn trimpot @ a higher value (not too high like 100k) then just use that but turn it down the appropriate resistance.
IBM T43 > Centrino M750 > 2GB DDR2 > 60GB > DVD-RW > 14" XGA
Atom 230 > D945GCLF > 1GB Buffalo > 120GB > DVD-RW > HP L1940
Atom 330 > D945GCLF2 > 2GB G.SKILL > 160GB > DVD & DVD-RW > SM720N
E1400 > G31-M7 TE > GB DDR2 > 80GB > DVD & DVD-RW > SM720N
E1400 > G31-M7 TE > 2GB DDR2 > X1600Pro > 250GB > DVD & DVD-RW > SM932B
X4 9950 > AM2NF3-VSTA > 2x2GB G.SKILL > Parhelia 256 > 2x 640GB > DVD-RW > 2x SM205BW
E6300 > ASUS P5B > 2xGB kingmax > X1900AIW > 2x320GB > DVD-RW & DVD-RW > LG 194WT
Zadnje izmijenjeno od: dDario. 06.03.2007. u 03:51.
dDario je offline   Reply With Quote
Staro 04.01.2005., 19:24   #2
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Ja ću ti sve objasnit, ali mi reci šta točno želiš napravit.
Skoncentriraj se najprije na jedan mod...
Nemam više lema!!!
Staro 04.01.2005., 22:11   #3
Pr0clocker
Master
Pr0clocker's Avatar
Postovi: 350
Lord imam jedno pitanje za tebe...
Da li se moze napraviti mod na A7N8X-X pa da mi onda daje vece voltaze na CPU (preko 1,85v) ?
..:: AMD Athlon64 3200 sck.939 ::..
..:: DFI LanParty UT nF4 SLi ::..
..:: Coolermaster vodeno ::..
..:: 2xLeadtek Winfast 6800ultra 800/2200 ::..
..:: 2x512 OCZ rev.2 ::..
..:: 2x74Gb Raptor (puno buke,a...) ::..
..:: OCZ PowerStorm 520W ::..
Pr0clocker je offline   Reply With Quote
Staro 04.01.2005., 23:15   #4
dDario
dDario's Avatar
Postovi: 1,567
Može se progooglaj i naći ćeš. Samo ako misliš držat proc preko 1.85 ćeš trebat stvarno dobro hlađenje.
@Lord
Onda prvo vdimm.
Imam ovo - xtremesystems
i ovo - vdimm
i još ovo - vdimm
Staro 04.01.2005., 23:20   #5
LorD ClockaN
od LemilicE
Postovi: 4,712
Koji CPU imaš. Ja sam na svom 2,4B (533FSB) napravio volt mod spojivši pinove CPUa i dobio voltažu do oko 2V
@dario:
Moraš mi točno reć šta ti treba za VDIMM i sliku moda.
Iz prvog posta ti se ne kuži šta ti treba ta VDIMM, a niti na slici nije naznačen vdimm
Nemam više lema!!!
Staro 04.01.2005., 23:44   #6
Pr0clocker
Master
Pr0clocker's Avatar
Postovi: 350
Ma imam XP2200+ i A7N8X-X kojih mi nije steta ni da se skure jer imam nove kompove
Staro 04.01.2005., 23:47   #7
dDario
dDario's Avatar
Postovi: 1,567
Jel ima takvih šema sa pinovima za AMD (bartone)?
Evo tu je najbolje objašnjen mod - vdimm i vcpu
Ja ne razumijem koje otpornike (ili rezistore ili vr rezistore) treba koristit. Jedni vele 10k, drugi 25k, pa 50k itd. Pa me još smotalo kaj tip veli da ne nego 1 MEGA OHM (gore sam quotao). E sad šta je to od 10k? I kolko to ustvari treba imat k?
Staro 05.01.2005., 00:10   #8
Pr0clocker
Master
Pr0clocker's Avatar
Postovi: 350
10k je predpostavljam 10kiloohma
Staro 05.01.2005., 00:15   #9
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,191
Pa prodaj čovječe, kog ćeš to vraga ić spalit...
Staro 05.01.2005., 22:27   #10
LorD ClockaN
od LemilicE
Postovi: 4,712
VR - variable resistor, hr= promijenjivi otpornik, preporučam trimmer
10k - 10000 Ohm-a, ili ti 10 kiloOhma
Odeš u Čipoteku i kupiš šta je navedeno na toj stranici
1 trimmer od 10kO
1 trimmer od 25kO
Možda ti neće imat točnu vrijednost, pa uzmeš malo veću. Lako pomoću malog potenciometra na njemu namjestiš 10 ili 24kO.
Prije lemljenja namjesti otpornike na navedenu vrijednost pomoću multi-metra, po mogučnošću digitalnog i počni lemit. (ako ne znaš neka ti to napravi netko stručan).
Zalemi 1 mod, pa probaj da li radi, pa tek onda drugi jer ako ti se dasi da napraviš oba 2 i nešto si krivo zalemio i ploča ti se ne želi bootat opet ćeš morat odlemljivat...
Šta još treba?
edit:
frajer na stranici ne koristi trimmere nego obične male VR-e. Trimmeri su puno finiji. Dobri će bit i ti lošiji ako nema trimmera u čipoteci
Nemam više lema!!!
Staro 05.01.2005., 22:42   #11
ćiber_manija
CyberSky
ćiber_manija's Avatar
Datum registracije: Feb 2004
Lokacija: Jastrebarsko
Postovi: 1,168
Pa kaj trimeri nisu promjenjivi kondenzatori??:confused:
Ispravite me ako griješim
The šuma...
Staro 05.01.2005., 22:55   #12
LorD ClockaN
od LemilicE
Postovi: 4,712
Ispravljamo te
Nemam više lema!!!
Staro 05.01.2005., 23:03   #13
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Znaci ti se nebi smio toj ploci pribliziti jer ce od uzasa ploca crknut sorry morao sam...
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 05.01.2005., 23:47   #14
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,815
Naravno da je. Radi se o kondenzatoru malog promjenjigov kapaciteta koji se obicno upotrebljava u paraleli s kondenzatorom velikog kapaciteta pri trazenju rezonantne frekvencije. Koristi se kod superheteroidnih prijamnika, recimo.
Potenciometar je pak "instrument" koji sluzi kao naponsko djelilo s kliznim kontaktom. Zbog slicnog nacina upravljanja (obicno se radi o metalnim plohama), potenciometar se kolokvijalno, iako ne i pravilno, zove i trimerom.
Programer
Staro 06.01.2005., 03:42   #15
komer
motocross
komer's Avatar
Lokacija: Kutina
Postovi: 2,442
imas za bartone onaj L12 mod koji nisam siguran ali postoje sheme kao force 166FSB ili force 200FSB mod,sve ovisi koje pinove spajas,nisam to isprobo,imas na xtremesystemu pa tamo potrazi pod mods,imas pod sticky
komer je offline   Reply With Quote
Staro 06.01.2005., 14:48   #16
dDario
dDario's Avatar
Postovi: 1,567
Ovaj L12mod dobro zvuči. Na XS su dobivali po 20 FSB više. Evo LINK
@Lord
Hvala. Ja bi to radio sa onim SMD Grabber-ima da nemoram lemit, a masu bi spojio na vent priključak na matičnoj. Jel bi to bilo ok ili je bolje zalemit?
