Staro 28.12.2004., 13:40   #1
Mailman
Mailman's Avatar
Postovi: 1,606
Omega Drivers v2.5.97a (Cat 4.12)
What's New in Omega Drivers?
Update v2.5.97a
* Based on the Catalyst 4.12 Official drivers.
* Fixed the version typo from previous release.
* Forced some wide screen resolutions that didn't worked on previous set.
* Could have fixed the FireGL OGL problems, need to test it thou.
* Changed readme to html style instead of text.
* Added a new section to readme to include RadLinker specific changes and fixes.
What's new for RadLinker?
v2.026
* Fixed installation problems with Windows 9x.
* Fixed GUI problems with Windows 9x.
* Added RadClock back to the package to help set the clock rate during bootup for people that have this problem.
* Added option to remove context menu selection (thus removing ~90% of RadLinker's functionality)
* Added fixed Polish language translation thanks to Adam "Poke" Grubba.
http://www.omegadrivers.net/
Mailman je offline   Reply With Quote
Staro 29.12.2004., 02:55   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Sutra ih skidam, da li je već probao netko?
Staro 29.12.2004., 13:01   #3
Mailman
Mailman's Avatar
Postovi: 1,606
Probao; kao i obično nikakvih problema nema
Staro 30.12.2004., 19:06   #4
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
e pa meni neče uopće da prođe instalacija...
pa sam skinuo oriđiđi ATI i softmodane da mogu clocknut sa ATItool-om, i super.
ja sam do sada isprobavao i oriđiđi i Omega, ali razlike apsolutno nikakve..
s tim da u benchevima Omega daje malo slabije rezultate.
U igrama sve je to ista kita...
Staro 01.01.2005., 12:08   #5
rprivrat
Lokacija: Ribarska 29, 52203 Medulin, Hrvatska
Postovi: 225
Sve OK
Skinuo odavno i već zaboravio
Sve radi OK, igre, Benchovi itd, rezultati isti kao sa Omega 4.10
rprivrat je offline   Reply With Quote
Staro 02.01.2005., 00:20   #6
Jelc
Super Moderators
Postovi: 17,485
Sve dela ok
Čuo sam da nekima dela Radlinker problem pri instalaciji, neka instaliraju bez Radlinkera.
Pa njega poslje restarta.
Staro 04.01.2005., 02:07   #7
un4given_2
un4given_2's Avatar
Lokacija: Azeroth
Postovi: 106
skinuo sam doticne drivere ali mi svaki put nakon restarta windowsa radlinker vraca vrijednosti na default...help...
un4given_2 je offline   Reply With Quote
Staro 04.01.2005., 02:28   #8
Jelc
Super Moderators
Postovi: 17,485
Ako hoćeš da ti se grafa svaki put diže sa taktovima koje si ti odredio-moraš odrediti takt i stisnuti Use Current.
Ako lupiš samo Set-pri svakom restartu će se vratiti na staro.
Staro 04.01.2005., 03:09   #9
vodokotlic
vodokotlic's Avatar
Lokacija: ZG - VŽ
Postovi: 375
evo da ne otvaram novi thread, trebam pomoc u vezi omega ( i ati drivera opcenito).
radio sam prije par mjeseci reinstal winsa i stavio sam omegu 2.5.90 sve je ok radilo i nisam se previse igrao u zadnje vrijeme.
Problemi dolaze kad sam instalirao NFSU2. Pri pokretanju igre ekran se zacrni i kreten pocne zajebavat, monitor skljoca kao pri promjeni refresha i reze i to tak ide jedno minutu da bi onda pokrenuo igru ali bez slike. onda mi je prekipilo i kresnem ja po restartu i pokusam ponovo. igra se podigne ali je donekle igriva tek u 800x600 sa svim na low. mislim si nije ovaj nastavak nista zahtjevniji od prvog a prvi je isao u toj rezi sve na full.
odlucio ja se rijesit omege. deinstaliram ih u control panelu, restartam, pokrenem driver cleaner omega edition, restartam, deinstaliram setup od omega, restartam u safe mode i pocistim jos sa driver cleanerom. kad sam ga opet restarto pokrene mi se new hardware wizard i napise mi da je naso vga adapter, radeon 9600 series (omega 2.5.90). odlucim stavit catalyst 3.4 (to sam imo pri ruci, a i ti driveri su radili odlicno kad sam prvi put instaliro tu karticu).
kad sam restarto sve radi super, igra leti sa 800x600 i sve na high. e sad idem ja sljedeci dan pokrenut igru a ona se ili pokrene odmah ili se ne pokrene uopce, ovisi o raspolozenju kompa.
ta ista igra radi normalno kod frenda bilo s catalystima ili omegama.
ako neko ima rijesenje molio bi da napise a ako ne neka napise koje da drivere stavim nakon sto kompu poklonim zakasnjeli bozicni poklon zvan Format C:
vodokotlic je offline   Reply With Quote
Staro 04.01.2005., 03:45   #10
un4given_2
un4given_2's Avatar
Lokacija: Azeroth
Postovi: 106
hvala na tako brzom odgovoru...
Staro 04.01.2005., 11:00   #11
ZiViky
ZiViky's Avatar
Lokacija: Ljubljana-Rijeka-Cres
Postovi: 154
da radlinker definitivno radi problem kod instalacije (imao sam prilike probati na kakava 3-4 PC).
Probajte sa Driver Cleanerom ocistiti CAB fajlove i prijasnju instalaciju Omege i trebalo bi sve biti ok.
Sto se tice samih drajvera sa svakom novom verzijom mi se smanjuje 3Dmar05 score:
Catalyst 4.11..........1589
Omega 2.5.90.........1623
Omega 2.5.97.........1590
Omega 2.5.97a.......1581
HP NX9420
Core Duo T2400 1,83GHz
2GB RAM
Seagate 100GB SATA
ATI X1600PRO 256MB ram
17" LCD
ZiViky je offline   Reply With Quote
Staro 04.01.2005., 14:23   #12
Jelc
Super Moderators
Postovi: 17,485
Meni nije još delao probleme, ali sam čuo da su se neki žalili.
Benchevi su mi sa novom verzijom sporiji kakvih 1%, ali zato HL2 ide dosta bolje.
Staro 04.01.2005., 14:28   #13
Jelc
Super Moderators
Postovi: 17,485
Trebao si sve očistiti, lupiti ponovno drivre za ploču, DX i nove za grafu.
Omega za 96xx seriju preporučuje da ako ima problema-FastWrite uključiš.
Staro 05.01.2005., 14:07   #14
Hido
Hido's Avatar
Lokacija: Velika Gorica
Postovi: 624
znaci nisam samo ja imal takvih problema , prije par mjeseci i ja sam isto imal takvih problema ko Vodokotlic,istih takvih i nikak doc na zelenu granu sa NFSU2 sve sam pokusaval mjenjat drivere ma bas sve , ni jedan nacin nije bio toliko ucinkovit kao format C:
sta se mora mora se
Hido je offline   Reply With Quote
Staro 05.01.2005., 14:28   #15
Jelc
Super Moderators
Postovi: 17,485
Pa, kad se drži osnovnih pravila pri promjeni drivera-takvih problema je manje.
A i neke igre znaju zezati, najbolje je onda spremiti pozicije i lupiti re-instal igre.
