Staro 18.08.2010., 21:28   #31
KorisNick
Datum registracije: Aug 2010
Lokacija: daleko, daleko iza 9 sela, daleko sam ja...
Postovi: 260
Autor luks 88 Pregled postova
di si vidio cijene?
Koja je razlika i7 2600 i i7 2600K?
I svi i5 imaju po 6mb keša, kako to da imaju manje nego sadašnja generacija?
Pa uglavnom, trenutno otključani množitelji su skuplji. Ne kažem za ove nove modele, nego pitam jer mi nije jasno u čemu je caka što se može napravit s otključanim procom a s zaključanim ne? To me zanima, jer vidim da to intel sve češće radi. I da i 5ice su sve po 6MB, al vidim da je potrošnja struje vrhunski smanjena.
KorisNick je offline   Reply With Quote
Staro 18.08.2010., 21:33   #32
KorisNick
Postovi: 260
Mogu si mislit, koliko će doći ovi od 3.8 GHz i 7ice. Kad vidim kolike su cijene, ovih sad modela od 3.4 GHz glava me zaboli.
Staro 27.08.2010., 22:21   #33
Postovi: 7,568
The Sandy Bridge Preview
While Intel is still a few weeks away from releasing Sandy Bridge performance numbers at IDF, we managed to spend some time with a very healthy sample and run it through a few of our tests to get a sneak peak at what's coming in Q1 2011.
Sandy Bridge puts all current integrated graphics solutions to shame, and even looks to nip at the heels of low end discrete GPUs. For HTPC users, Clarkdale did a good enough job - but for light gaming there wasn't enough horsepower under the hood. With Sandy Bridge you can actually play modern titles, albeit at low quality settings. The fact that you can get Radeon HD 5450 performance for free with a Core i5 2400 is just awesome.
With no quad-core 32nm desktop parts on the market today, Sandy Bridge only needs to beat Lynnfield to be more power efficient - which it does very well: Idle power remains unchanged, but load power is much lower at the same clock and even within the same price target. Sandy Bridge seems to offer a 10% increase in performance. Keep in mind that this analysis was done without a functional turbo mode, so the shipping Sandy Bridge CPUs should be even quicker. I'd estimate you can add another 3 - 7% to these numbers for the final chips. That's not bad at all for what amounts to a free upgrade compared to what you'd buy today. Power consumption will also see an improvement. Not only will Sandy Bridge be noticeably quicker than Lynnfield, it'll draw less power.
The high end Sandy Bridge parts don't arrive until the second half of 2011 which add more cores and more memory bandwidth.
Izvor: AnandTech
Staro 29.08.2010., 11:04   #34
m4x
Postovi: 579
znači bit će brži oko 10%,imat će grafiku,manja potrošnja i opet novi socket 1155...
hoće li intel uopće izbacit 6-jezgreni procesor za lga 1156?
ovako ostajemo bez mogućnosti nadogradnje....860 mi neće ništa značajno donijet ako ga stavim umjesto i5 750
m4x je offline   Reply With Quote
Staro 29.08.2010., 13:29   #35
Postovi: 7,568
Autor m4x Pregled postova
Ne, jer je LGA-1156 platforma za mase i sve one kojima je LGA-1366 preskupa kupnja. Core-i7 990X, 980X i 970 procesori su namijenjeni za high-end i idu na platformu predviđenu za one koji ne pitaju za cijenu. Intel nije AMD, tj. nije u takvoj nepovoljnoj financijskoj poziciji, pa da mu je u interesu ljudima nuditi jeftine šesterojezgrene procesore koji idu i na ploče otprije dvije-tri godine. LGA-1366 je aktualan već dvije godine, a LGA-1156 oko godinu dana i Intelu je to sasvim dosta da predstavi kompletno nove platforme i zaradi još koju hrpu novci.
Staro 29.08.2010., 14:02   #36
m4x
Postovi: 579
taj sandy bridge je dobar za one koji žele štedljiv a brz procesor a ne žele u računalu imat još posebnu grafičku osim ako se igraju...
a zbog čega intel nejde na novi high end? i kada će doć novi high end procesori i matične?
jer između lga 1136 i 1156 nema značajnih razlika osim ako stavimo 6-jezgreni procesor a on je opet previše skup
Staro 29.08.2010., 14:08   #37
Postovi: 7,568
Sandy Bridge procesori su dobri za sve, a ako se nekome ne dopada to kaj imaju IGP i kaj se više ne clockaju na istom principu, lako ostane na sadašnjim Lynnfield i(li) AM3 modelima. I Intel i AMD žestoko idu na integraciju svega mogućeg u sam procesor, tak da bude u godinama koje dolaze, sve više procesora koji imaju inetgriranu grafičku karticu. Intelov novi high-end je LGA-2011 i stže pred kraj ljeta i početkom jeseni sljedeće godine. Do onda bude aktualna nova LGA-1155 platforma namijenjena srednjem tržištu.
Staro 29.08.2010., 14:19   #38
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Autor McG Pregled postova
Sandy Bridge procesori su dobri za sve, a ako se nekome ne dopada to kaj se više ne clockaju na istom principu
Mozes ovo pojasniti? Mislim isto imaju i BCLK i multy identicno lynnfieldima,bloomfieldima itd, pa me zanima kako se ne klokaju na istom principu
Staro 29.08.2010., 14:24   #39
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Autor xulos Pregled postova
Google i prouči malo značajke nove platforme, da je sve isto, čemu izdavat još jednu platformu? Nebi baš reko da je 100MHz i 133MHz isti BCLK a još k tome je Intel "najavio" nemogućnost monstrumskog OCa..
Staro 29.08.2010., 14:26   #40
Postovi: 7,568
Da, LGA-1155 procesori isto imaju BCLK, ali pogledaj kaj sve sad obuhvaća sistemska sabirnica i koja sranja se dešavaju nakon kaj BCLK ode iznad defaultnih 100MHz. BCLK je s novim procesorima zaključan, a ako se pretjera u clockanju imaš sve od rušenja RAID-polja, PCI-E, SATA, USB, memorijskog kontrolera i tome sličnog veselja. Intel je svima jasno dal do znanja da je clockanje kakvo je dosad bilo poznato - gotovo s novim Sandy Bridge procesorima. Naglasak je stavljen na K modele s potpuno otključanim množiteljima i na novi Turbo Boost režim rada. Clockeri (kojima se to ne dopada) budu sad fino trebali ili pričekati nove LGA-2011 procesore ili budu iskeširali za LGA-1155 K modele.
Staro 29.08.2010., 14:52   #41
m4x
Postovi: 579
vidim da lga 2011 donosi novi utor za grafičke PCIe 3.0,mogućnost stavljanja dva procesora na matičnu,čak četverokanalnu memoriju....kad bi bile cijene ko i za lga 1136 bilo bi dobro
jedino će se stari hladnjaci moć iskoristit
Staro 30.08.2010., 18:58   #42
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Intel's Sandy Bridge CPUs Will Play Blu-ray 3D
Intel's best attempt at IGPs yet.
Right now on Westmere chips are integrated graphics along with the CPU sitting on the same silicon, but Sandy Bridge will move them into a single die. This will boost performance in itself, and Intel boasts that the new IGP will be able to decode Blu-ray 3D media.
Intel's hasn't yet revealed everything on Sandy Bridge yet, but the company is likely to discuss the upgraded graphics part at the Intel Developer Forum on September 13 to 15.
The current graphics part in Westmere chips can already do 1080p Blu-ray decodes, but as we know from the consumer electronics space, newer and stronger hardware is required to render the additional images for 3D.
Intel spokesman Nick Knupffer confirmed that Sandy Bridge mobile chips will have the capability for Blu-ray 3D, which hopefully translates into greater 3D graphics performance too.
http://www.tomshardware.com/news/san...ray,11175.html
Intel's Core 2011 Mobile Roadmap Revealed: Sandy Bridge Part II
C L O W N I N G A R O U N D
Zadnje izmijenjeno od: Doink the Clown. 30.08.2010. u 22:26.
Staro 02.09.2010., 15:22   #43
nexusone
Datum registracije: Apr 2008
Postovi: 139
Nvidia southbridge za Sandy Bridge CPU-e
Evo prema ovom članku nvidia bi se trebala vratiti na tržište čipsetova i to sa southbridgeom za Intelove Sandy Bridge procesore koji će sadržavati i integriranu grafiku, a kako će to sve u svemu završiti, to ćemo još vidjeti.
Digitimes is reporting that Nvidia engineers are currently hard at work on a new chipset solution that should combine the functions of a southbridge with a proper Nvidia GPU.
nexusone je offline   Reply With Quote
Staro 14.09.2010., 11:31   #44
Doink the Clown
Postovi: 6,214
Staro 19.09.2010., 13:34   #45
MP7
MP7's Avatar
Datum registracije: Aug 2008
Postovi: 174
MP7 je offline   Reply With Quote
Staro 19.09.2010., 13:56   #46
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Heh, sad vise neces morat traziti maksimalni FSB/BCLK nego max multy za najveci stabilni klok
Staro 27.09.2010., 22:29   #47
kian
kian's Avatar
Datum registracije: Oct 2001
Lokacija: Velika Gorica
Postovi: 600
Staro 27.09.2010., 22:55   #48
Postovi: 8,259
Vjerujem da će oc naklonjeni proizvođači izmislit neki takt lock il takt separator jer sumnjam da će oc samo tako nestati jer bi rekao da asus/gigabajt previše ulažu u taj segment da bi on jednostavno nestao.
Staro 28.09.2010., 00:00   #49
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,369
Cijena od 300-400$ za "jaci" model mi izgleda sasvim dobro za novu arhitekturu ?
Lewis je online   Reply With Quote
Staro 28.09.2010., 17:05   #50
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Intel želi spriječiti "zašto bi dao 1500 kn više za proc, kad mogu toliko ušparati i nakloukati jeftinijeg i imam istu stvar".
Koliko se proda najsnažnijih desktop procesora (ne računavši EE primjerke i slične)? Ne baš onoliko koliko bi oni htjeli očito.
E sad, klokabilni procesori će biti skuplji i spadat će u domenu budžeta entuzijasta, više neće biti procesora za budget entuzijaste.
Bude li tako ili ne, to ćemo tek vidjeti.
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 01.10.2010., 14:57   #51
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Matth€w je offline   Reply With Quote
Staro 06.10.2010., 00:03   #52
ironhide
ironhide's Avatar
Datum registracije: Sep 2010
Lokacija: Galaxy selo
Postovi: 25
A bože moj opet ću morat novi komp..XD
ironhide je offline   Reply With Quote
Staro 06.10.2010., 10:02   #53
Autor Matth€w Pregled postova
lako se njemu qrčiti sa time, radi u gigabyteu pa je već dobio matičnu za tjerat to čudo 50000+ u 3D Marku? to će biti brutala.
ovo mi baš nije jasno, dvojezgreni i3 će imati HT, pa quadovi i5 neće, pa onda i7 opet hoće sa 2MB više cachea... znači da su malo i recepturu promjenili u odnosu na socket 1156.
Staro 14.10.2010., 19:18   #54
Doink the Clown
Postovi: 6,214
Staro 14.10.2010., 21:05   #55
ironhide
ironhide's Avatar
Postovi: 25
Nadajmo se da će stvarno bit velik pomak.
Staro 17.11.2010., 10:25   #56
Doink the Clown
Postovi: 6,214
Staro 24.11.2010., 18:56   #57
Postovi: 7,568
Finalne specifikacije LGA-1155 Sandy Bridge procesora
There are 14 models of these Sandy Bridge processors which belong to Core i7/i5/i3 series. Faced with entry level, Intel will continue to follow Pentium and introduce Pentium G850/G840/G620/G620T. They features cache of 3MB, dual-core/dual threads design and LGA 1155 ports. It is noteworthy that core of Core i7-2600K/2500K are named as Intel HD Graphics 3000, while that of four Pentium series processors are Intel HD Graphics, others are named as Intel HD Graphics 2000.
Izvor: EXPreview
Staro 24.11.2010., 19:16   #58
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
Ako ovi pentiumi budu jeftini mogli bi uzrokovati probleme AMD na području low-end desktopa.
cccp je offline   Reply With Quote
Staro 24.11.2010., 20:05   #59
Postovi: 7,568
Jedini problem je kaj AMD za low-end ima Llano X2, X3 i X4 s IGP-om (od 480 SP-a) u rangu današnjih HD 5670 kartica. Bulldozer X4, X6 i X8 budu rezevirani za nadmetanje s Core i3, i5 i i7 Sandy Bridge modelima.
Prijašnja, tj. još uvijek aktualana generacija (700+ kn) Pentium G modela nije baš polučila neku bajnu popularnost, jer ljudi rađe kupe Core i3 i jeftinije/rabljene Core i5 procesore za istu cijenu.
Dok AMD danas po cijeni jednog Pentium G procesora nudi Athlon II X3 i Athlon II X4 modele, s tim da određeni X3 nude mogućnost otključavanja u X4. Sljedeće godine AMD ponuda bude još agresivnija.
Zadnje izmijenjeno od: McG. 24.11.2010. u 20:11.
Staro 24.11.2010., 20:13   #60
luks 88
luks 88's Avatar
Postovi: 477
kako to da i5 imaju po 6mb cache-a?, manje nego 1156 i5 serija?
luks 88 je offline   Reply With Quote
