Staro 03.08.2010., 18:37   #1
Hammer O'Thor
Postovi: 8
Problem s instalacijom Vista SP1
Imam Acer Aspire 3694WLMi. Prije dva dana sam napravio restore to factory settigns, dolazi s predinstaliranim Vista Home Basic. Pokušavam instalirati SP1, ali mi stalno izbacuje grešku 0x8007000D. Niti jedan postupak s priloženog linka nije pomogao. Mučim se s time već dva dana, a htino mi je da instaliram SP1 pa onda SP2. Molim pomoć.
Hammer O'Thor je offline   Reply With Quote
Staro 03.08.2010., 18:43   #2
nino
nino's Avatar
Postovi: 12,613
Hr ili en verzija? Enivej, rucno skini sp1 i sp2 i proci ce. Ja se prosli tjedan iz***ao sa jednim Hp-om oko toga.
Sp1 = tu
Sp2 = tu
Staro 03.08.2010., 19:02   #3
Hammer O'Thor
Postovi: 8
Ručno i pokušavam, skinuto s MSDN-a, na Windows Updateu mi uopće niti ne prikazuje ni SP1 ni SP2.
Staro 03.08.2010., 19:37   #4
nino
nino's Avatar
Postovi: 12,613
Onda google izbacuje.
Code:
For install error 0x8007000D, let's try the following:
Run SIGVERIF
Click Start > Run
Type "SIGVERIF" (w/o quotes) Press OK
Click Advanced
Select "Look for other files that are not digitally signed"
In the "Look in this folder" box type in C:\WINDOWS\SYSTEM32\CATROOT
(Edit path a necessary depending on where Windows is installed)
Check Include Subfolders
Click OK, then click Start
When the report completes it should list any unsigned files, CAT files. If
we see
any here we will want to locate them and move them out of the CATROOT
folder.
Download and install the updates from Windows Update.
If the error persists download and install one of the updates from:
http://www.microsoft.com/technet/security/current.aspx
Do you get an error message?
Let us know the results.
Staro 04.08.2010., 01:47   #5
Hammer O'Thor
Postovi: 8
Nije pomoglo. SIGVERIF ne izbacuje ništa, pokrenuo sam Windows Update i skinuo sve Important i Optional, doduše nekoliko ih je bilo Failed, pa sam nakon toga pokušao opet instalirati SP1, ali opet izbaci istu grešku.
