Postovi: 8
Problem s instalacijom Vista SP1
Imam Acer Aspire 3694WLMi. Prije dva dana sam napravio restore to factory settigns, dolazi s predinstaliranim Vista Home Basic. Pokušavam instalirati SP1, ali mi stalno izbacuje grešku 0x8007000D. Niti jedan postupak s priloženog linka nije pomogao. Mučim se s time već dva dana, a htino mi je da instaliram SP1 pa onda SP2. Molim pomoć. |
Postovi: 12,613
Postovi: 12,613
Onda google izbacuje. Code:
For install error 0x8007000D, let's try the following: Run SIGVERIF Click Start > Run Type "SIGVERIF" (w/o quotes) Press OK Click Advanced Select "Look for other files that are not digitally signed" In the "Look in this folder" box type in C:\WINDOWS\SYSTEM32\CATROOT (Edit path a necessary depending on where Windows is installed) Check Include Subfolders Click OK, then click Start When the report completes it should list any unsigned files, CAT files. If we see any here we will want to locate them and move them out of the CATROOT folder. Download and install the updates from Windows Update. If the error persists download and install one of the updates from: http://www.microsoft.com/technet/security/current.aspx Do you get an error message? Let us know the results.
Postovi: 8
Nije pomoglo. SIGVERIF ne izbacuje ništa, pokrenuo sam Windows Update i skinuo sve Important i Optional, doduše nekoliko ih je bilo Failed, pa sam nakon toga pokušao opet instalirati SP1, ali opet izbaci istu grešku. |
