Staro 27.06.2010., 10:11   #1
mstaglicic
mstaglicic's Avatar
Datum registracije: Apr 2009
Postovi: 173
BSOD-IRQL_NOT_LESS_OR_EQUAL
Pozdrav!
Imam računalo koje već duže vrijeme (preko 6 mj.) ima BSOD-ove.Nakon što sam maknuo Windows XP SP3 i stavio Windows 7 Ultimate,nije bilo BSOD-ova sve do sinoć.
Taman sam bio instalirao FIFA Manager 10 i htio ugasiti računalo,stisnuo start,a računalo izbaci BSOD:
A problem has been detected and windows has been shut down to prevent damage to your computer.
If this is the first time you/ve seen this Stop error screen,
restart your computer.If this screen appears again,follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation,ask your hardware or software manufacturer
for any windows updates you might need.
If problem continue,disable or remove any newly installed hardware
or software,Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components,restart
your computer,press F8 to select Advanced Startup Options,and then
select Safe Mode.
Technical information:
*** STOP: 0x0000000A (0xFFFFFDF4,0x00000002,0x00000001,0x82CA1129)
Collecting data for crash dump...
Initializing disk for crash dump...
Beginningdump of physical memory.
Dumping physical memory to disk:100
Physical memory dump complete.
Contact your system admin or technical support group for further assistance.
To je to.
Evo slika:
http://slike.hr/slike/dsc00091_65560.jpg.html
Osim tog problema,ima još jedan;a to je da računalo nakon isključenja iz utičnice izgubi sat.Datum ostane isti,al sat se vrati na 0:00.
Konfiguracija je kupljena u 10.mjesecu prošle godine.
Jedino su HDD i DVD uređaj stari 4 godine.
Kućište i napajanje je promijenjeno prije manje od mjesec dana.
Konfiguracija:
MBO: ASUS M4N78
CPU: AMD Athlon II X2 240 2.80 GHz
RAM: Mushkin DDR2-800 @ 400 MHz 2GB
GPU: ASUS EN 9500 GT 1279mb (767mb shared)
HDD: Seagate Barracuda 200gb (serija 7200.7)
DVD: Pioneer DVD-RW DVR-110D ATA
PSU: No name 420W (staro manje od mjesec dana)
Može li mi netko reći u čemu bi mogao biti problem sa tim BSOD-om i to što gubi sat nakon isključenja iz struje?
Zadnje izmijenjeno od: domy_os. 28.06.2010. u 11:54.
mstaglicic je online   Reply With Quote
Staro 27.06.2010., 10:29   #2
blueshadow
blueshadow's Avatar
Datum registracije: Jul 2009
Lokacija: Velika Gorica
Postovi: 214
Probaj ram u drugi utor pa ces vidjeti dal ce t ise to dogadjati. Sto se tice sata rikava ti baterija na mticnoj ploci pa ju probaj nabaviti i zamjeniti. Sretno
Zadnje izmijenjeno od: domy_os. 28.06.2010. u 11:52. Razlog: ne quoteaj post iznad svog!
blueshadow je offline   Reply With Quote
Staro 27.06.2010., 10:37   #3
mstaglicic
mstaglicic's Avatar
Postovi: 173
Autor blueshadow Pregled postova
Probavao sam i to da stavim ram u drugi utor jer imam dva žuta i dva crvena.
Stavio sam u drugi žuti utor,al nema još BSOD-a nikakvog.
Jel ima ikakve veze sa tim BSOD-om to što mi je računalo upaljeno bilo 7h i skidalo torrente i istovremeno sam igrao GTA IV?
Inače,prije par mjeseci dok sam imao XP računalo bi se nakon neodređenog vremena zamrznulo,zvuk bi treperio i miš i tipkovnica bi blokirali i nakon par minuta bi izbacio isti ovakav gore BSOD.Nakon par reseta bi se sve vratilo u normalu.
Što se tiče baterije,jel mogu ja to pod garanciju odnijet,jer mi je matična stara skoro 8 mjeseci,pa je pod garancijom?
Kako mogu provjeriti jel RAM na kraju svog radnog vijeka?
On je star koliko i matična,tako da ne znam u čemu bi mogao biti problem.
Staro 27.06.2010., 10:43   #4
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
probaj testirati ram sa memtest-om. Jednu po jednu pločicu.
Staro 27.06.2010., 10:51   #5
mstaglicic
mstaglicic's Avatar
Postovi: 173
Autor SaleFFS Pregled postova
Imam samo jednu pločicu rama.
Testirat ću.
Tnx.
Staro 27.06.2010., 11:05   #6
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
Rekao si da ti se svaki put sat vrati na 0:00, mozda je baterija od biosa gotova. Ako imaš mjerni uređaj probaj ispitati koliko ti volta daje.
Staro 27.06.2010., 11:25   #7
mstaglicic
mstaglicic's Avatar
Postovi: 173
Nemam mjerni uređaj,al jel postoji koja opcija u biosu da se promjeni to da računalo pamti/ne pamti sat?
Al mi je čudno što sam prije godinu dana imao komp koji je bio star 4 godine i nikad mu se nije mjenjala baterija od matične i nikad ne bi vraćao sat.
Jel bolje to pod garanciju odnijet?
Jel ima ikakvog smisla vrtiti memtest dok ovo pišem?
EDIT:
Morao sam otvoriti dva memtesta jer jedan ne može testirati 2048mb rama.
I sad ovaj prvi od 1024mb je otišao preko 100%,sad je na 109.2%.Jel to normalno?
Staro 27.06.2010., 11:31   #8
nino
nino's Avatar
Postovi: 12,613
Memtest se ne vrti iz windowsa. Skini Hiren's boot cd, zaprzi iso na cd i bootaj sa njega. Nadji memtest i pusti nek pici.
Btw, baterija ti kosta ~20kn.
Staro 27.06.2010., 11:34   #9
mstaglicic
mstaglicic's Avatar
Postovi: 173
Autor nino Pregled postova
Ok.
Tnx.
Ma znam da je jeftina,nije problem,al nekako mi je bolje pod garanciju ako je već pod garancijom.
Staro 27.06.2010., 15:37   #10
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
pa bilo bi ti najbolje ne dirati bateriju ako je pod jamstvom onda neka to oni rijese
Staro 27.06.2010., 15:47   #11
mstaglicic
mstaglicic's Avatar
Postovi: 173
Memtest je pokrenut i završio i nema nikakvih errora.
A što se baterije tiče,dat ću ja to pod jamstvo.
