Staro 17.06.2010., 00:30   #1
Liquid Snake
Liquid Snake's Avatar
Postovi: 166
Catalyst 10.6 Official
Release Notes:
http://www2.ati.com/relnotes/Catalys...ease_notes.pdf
Code:
Driver Packaging Version            8.741-100527a-100948C-ATI
Catalyst™ Version                   10.6
Provider                            ATI Technologies Inc.
2D Driver Version                   8.01.01.1038
Direct3D Version                    8.14.10.0761
OpenGL Version                      6.14.10.9901
Catalyst™ Control Center Version    2010.0527.1242.20909
Download:
Catalyst 10.6 WHQL (Windows XP 32bit)
Catalyst 10.6 WHQL (Windows XP 64bit)
Catalyst 10.6 WHQL (Windows 7/Vista 32bit)
Catalyst 10.6 WHQL (Windows 7/Vista 64bit)
Liquid Snake je offline   Reply With Quote
Staro 17.06.2010., 01:50   #2
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Autor Liquid Snake Pregled postova
Release Notes:
Code:
Download:
jel se opet mora cekat verzija "a" za bc2?
Edit:a popravili su izgleda...ajde nek neko testira heh
viper je offline   Reply With Quote
Staro 17.06.2010., 03:14   #3
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,562
igrao bc2 oko 3 sata i radi dobro sve
Staro 17.06.2010., 04:15   #4
djcristian
Lokacija: Vinkovci
Postovi: 15
Instalirao preko starih i nakon pokretanja filmica na youtube-u blue screen... Idem pocistiti sve i probati ponovno instalirati. Kartica HD4870
djcristian je offline   Reply With Quote
Staro 17.06.2010., 15:18   #5
gmax
Tuco “the Rat” Ramirez
gmax's Avatar
Postovi: 477
Stavio ih gore, odvrtil sam BC2 oko cuku vremena i nikakvih problema. Kasnije cu jos probati Dirt 2 i DA:O.
Staro 17.06.2010., 19:09   #6
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Dobio par FPSa u BFBC2,loading time ostao isti (33 sekunde).
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 17.06.2010., 20:27   #7
zaki
Lokacija: Philippines
Postovi: 69
Djeluju OK, osjeti se mali porast Fps-a
zaki je offline   Reply With Quote
Staro 18.06.2010., 00:38   #8
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,757
Instalirao sam ih samo zbog HW aceleracije u flashu, ali na Windows XP mi je na 720p filovima load veci nego sto je bio.
Bono je online   Reply With Quote
Staro 18.06.2010., 01:46   #9
Neo-ST
Neo-ST's Avatar
Postovi: 8,645
Meni se BFBC2 ponaša malo čudno sa ovim driverima, nekako zna zatreperit i na sekundu se prikazati crni ekran, i kao da je dobio nekakav lag kada klikam po menijima, pogotovo kada se treba joinat u igru...
Staro 18.06.2010., 04:09   #10
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,562
e ja sam sa 10.3 drajverima imo oko 18k 3dmark06
sada svakom verzijom daljnjom sve manje i manje, sa 10.6 imam 14k
Staro 18.06.2010., 08:17   #11
cserer
Od danas pa do sutra
cserer's Avatar
Lokacija: ZAPREŠIĆ
Postovi: 65
Meni se pak samo zamrzne slika na nekoliko sekundi ,
što me jako iritira.Vračam se na stare drivere.
cserer je offline   Reply With Quote
Staro 18.06.2010., 10:13   #12
Metamphetamine
Flaccitra
Metamphetamine's Avatar
Lokacija: Vinkovci
Postovi: 276
Za sada sve u redu, nisam ništa benchao, DXVA radi u MPC-HC, meni super
Metamphetamine je offline   Reply With Quote
Staro 18.06.2010., 14:43   #13
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 460
pregazio stare 10.4 i primijetio enormo ubrzanje loadinga bc2,uglavnom sada mi se loada za nekih 8-9sec(prije preko 25-30sec) i među prvima sam na mapi!
ostalo mi se ćini isto!
dart_tom je offline   Reply With Quote
Staro 18.06.2010., 19:11   #14
2 die 4
2 die 4's Avatar
Postovi: 2,284
Autor dart_tom Pregled postova
Ja sam napravio isto, i sve štima, nisam primjetio ništa ni bolje ni lošije, nisam radio Bench.
Malo OT:
ovo da si među prvima na mapi, pa to je malo čudno obzirom na to da postoji 15ces delay pa skoro svi ulaze istovremeno
RedGreenBlue
Staro 18.06.2010., 19:33   #15
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 460
Autor 2 die 4 Pregled postova
Malo OT:
prije je većina već krenula kada sam ja upo u mapu,kao što rekoh nekih 30sec,sada upadam obićno među prvima i odbrojava mi 8sec kao kada zaginem dok ne mogu ući ali i tada obićno sam tu ja i možda još njih dvoje,ono baš se vidi razlika
e sada ne znam kako je bilo na 10.5 jer sam njih preskoćio jer su neki prićali da imaju problema ali ovo je odlićno!
edit(video)-kmplayer,mdc rade bez ikakvih problema
Zadnje izmijenjeno od: dart_tom. 18.06.2010. u 19:51.
Staro 18.06.2010., 19:42   #16
NJUNJO_HR
NJUNJO_HR's Avatar
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 674
Meni sa 10.6 nema više u KMPlayer slike . Iste postavke sa 10.5 je sve bilo ok.
Postavke su: MPC - video decoder za dxva i odabrao Enhanced video renderer. Sa 10.5 je bilo sve ok.
EDIT: evo vratil sam na 10.5 i sad sve radi kak i prije.
PCE 100+kg demolition squad
LCD 19'' Philips 190P6 | Coolermaster Stacker ATX/BTX (STC-T01) Black | Corsair HX520
ASRock P55 Extreme | Intel i5 760 | G.Skill F3-12800CL7D-4GBECO 2x2GB | XFX 7950 GT 512MB DDR3
Benq DW1670 & Plextor PX-755A | WD Black 1TB (WD1002FAEX), WD Green 2TB (WD20EARS)
Creative SB Audigy Player SB0090 | TP-Link TL-WN651G
Microsoft Wireless Optical Desktop for Bluetooth (Miš i Tipkovnica) | Razer Copperhead (Green) | Genious KB-16e Black
___ <<< Enchantress >>> ___
Parts of watercooling:
Laing DDC-1 water pump
3x Magicool Extreme radiators
EK-Supreme-Acetal for CPU
EK-NF4 rev1.1 for chipset
EK-FC79 for GPU
EK-Multioption reservoir 400 + EK-Multioption RES Bottom Rev.2
& green tubes.
Loop:
rezervoar / pumpa / GPU / rad1 / NB / rad2 / CPU / rad3 / rezervoar
Par slikica iz galerije
H2O galerija
___ <<< ex Morgoth >>> ___
Parts of ex aircooling:
Celeron 420 | ASRock 4CoreDual-SATA2 | XFX 7900 GS 600M
Thermalright Ultra-120 Extreme for CPU lapped
Thermalright HR-05 IFX for chipset lapped
Thermalright HR-03 PLUS for GPU
Lapping galerija
Zadnje izmijenjeno od: NJUNJO_HR. 18.06.2010. u 20:34.
NJUNJO_HR je offline   Reply With Quote
Staro 18.06.2010., 20:15   #17
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,764
Kod mene 10.6 povisuje temp u idleu i to vise nego 10.5 driveri.. Razliku u perf nisam testira tako da tu nemam sto reci..
Staro 19.06.2010., 13:07   #18
markecSMB
Lokacija: Cro
Postovi: 1,044
Autor djcristian Pregled postova
Meni se ruše drriveri, ili zabloksa prilikom youbito ili mpc hc.
Ati 4850, ovo su prvi drajveri s kojima imam problema.
EPIC FAIL ATI.....
Staro 19.06.2010., 13:44   #19
2 die 4
2 die 4's Avatar
Postovi: 2,284
EPIC FAIL ATI.....
A meni se čini da su svi driveri koje ATI izbacuje u zadnje vrijeme usmjereni prema 5xxx karticama i na njima je najveći učinak, a starije serije očigledno trpe! IMHO jer ja nisam imao problema niti sa 10.2, 10.4, 10.6!
Ove ostale sam preskakao
RedGreenBlue
Staro 19.06.2010., 14:31   #20
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Zeza me hardwareska akceleracija na samo nekim MKV, DXVA videima pa prebacim onda na procesor posao.
Inače je sve vredu.
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 19.06.2010., 15:33   #21
Neo-ST
Neo-ST's Avatar
Postovi: 8,645
Staro 19.06.2010., 16:04   #22
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Autor Neo-ST Pregled postova
Load time dug ko i prije hotfixa, bc2 ide normalno, ccc se još uvijek ne pali. Zaobilazim ove drivere.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 19.06.2010., 16:08   #23
FujiLim
FujiLim's Avatar
Postovi: 103
Autor M4mut Pregled postova
Ja s ovom verzijom dobio 500 bodova više u 3dmark06.
FujiLim je offline   Reply With Quote
Staro 19.06.2010., 18:27   #24
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,562
meni s 10.6 dok igram bc2 crasha na desktop, kao da sam alt-F4 okinuo
prije tog nije bilo :/
Staro 19.06.2010., 23:20   #25
tictac
tictac's Avatar
Lokacija: Zgb
Postovi: 63
Ja sam sad na 10.2 i kmplayer mi steka na vecim rezolucijama
tictac je offline   Reply With Quote
Staro 19.06.2010., 23:42   #26
m4x
Postovi: 579
meni se ne crasha ali imam visoku temperaturu grafe od čak 95 celzija u farcry2
m4x je offline   Reply With Quote
Staro 20.06.2010., 00:23   #27
ivand123
otišo po cigare i nesto
ivand123's Avatar
Lokacija: Zagreb (Maksimir)
Postovi: 373
Stavio na frišku instalaciju sedmice, bc2 radi ko podmazan, u 3dmarku dobivam cca 600 bodova više (naspram 10.2) te ovi kaj kukaju da im kmplayer neradi neka pređu na vlc ili konkurenciju jer taj player se presto razvijat pa i tu leži velika mogučnost kasnijih problema.
Zadnje izmijenjeno od: ivand123. 22.06.2010. u 13:33.
ivand123 je offline   Reply With Quote
Staro 20.06.2010., 00:24   #28
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Autor m4x Pregled postova
Pogledaj dal radi automatska regulacija venta . Možeš s afterburnerom .
95c nije normalno i ne znam razlog kak bi došlo do toga osim zbog problema s ventom. Driver sam po sebi ne može radit takve probleme ,osim ak ne zariba regulaciju.
Staro 20.06.2010., 03:17   #29
Xenomorph
Arroyo settler
Xenomorph's Avatar
Lokacija: .::Zagreb::.
Postovi: 316
Meni na HD4850 radi puno bolje kad ulazim u COD4 i COD Waw(među prvima,a do sada sam bio 5 ili 6) i hrpa dobrih igrica radi bolje.Hmm.. čudno al ajde što se mene tiče driveri rade super na mom kompu.
Xenomorph je offline   Reply With Quote
Staro 20.06.2010., 09:58   #30
m4x
Postovi: 579
Autor MAGARAC Pregled postova
probao sam sa msi kombustor,stability test oko 8 minuta i maksimalna temperatura je bila 67
koliko moram vrtit taj stability test?
