Datum registracije: Dec 2009
Lokacija: Zagorje
Postovi: 874
SN Margin
Poštovanje i pozdrav! Evo borim se kod kuće s brzinom dsl-a i pizdim. Imam hr.duo i trenutno mi se vrti brzina na 512/192 i to kad mi ograniče brzinu na 512. sad sam tražio da mi dignu na 1mbit i sad je stanje 448/192. ok, kužim, imam lošu liniju, ali stvar koja me zaintrigirala je da susjed preko puta ima čak i malo lošiju liniju, ali njemu se spaja na 1mbit bez problema. evo podataka JA - ST 780wl Modulation: G.992.1 annex B Bandwidth (Up/Down) [kbps/kbps]: 192 / 448 Data Transferred (Sent/Received) [KB/MB]: 768,00 / 2,99 Output Power (Up/Down) [dBm]: 5,0 / 13,0 Line Attenuation (Up/Down) [dB]: 31,5 / 63,0 SN Margin (Up/Down) [dB]: 12,0 / 19,0 Vendor ID (Local/Remote): TMMB / BDCM Loss of Framing (Local/Remote): 0 / 0 Loss of Signal (Local/Remote): 0 / 0 Loss of Power (Local/Remote): 0 / 0 Loss of Link (Remote): 0 Error Seconds (Local/Remote): 0 / 0 FEC Errors (Up/Down): 0 / 0 CRC Errors (Up/Down): 0 / 7 HEC Errors (Up/Down): 0 / 4 SUSJED - Thomson TG782 Bandwidth (Up/Down) [kbps/kbps]: 252 / 1.031 DSL Type: G.992.5 annex B Output Power (Up/Down) [dBm]: 11,5 / 15,0 Line Attenuation (Up/Down) [dB]: 40,0 / 63,5 SN Margin (Up/Down) [dB]: 12,0 / 9,5 Vendor ID (Local/Remote): TMMB / BDCM Loss of Framing (Local/Remote): 81 / 0 Loss of Signal (Local/Remote): 39 / 0 Loss of Power (Local/Remote): 0 / 0 Loss of Link (Remote): 0 Error Seconds (Local/Remote): 518 / 0 FEC Errors (Up/Down): 451 / 0 CRC Errors (Up/Down): 451 / 20.0 Jedino stvar koja se bitno razlikuje je SN margina. Malo sam istražival po netu i piše da niža SN Margina daje bolje brzina, ali i nestabilniju vezu, tj. viša margina daje stabilniju vezu. E sad jel zna netko o čemu ovisi margina? Kak ju sniziti? Kome treba popušiti i platiti za 1mbit? ![]() e da, vidim da se modulacije također razlikuju. jel to do modema ili isp-a? |
#2 | |
super user
Lokacija: Houston, TX
Postovi: 1,805
![]() btw sve ovo mozes sniziti jednio tak oda se približis centrali (LOL) i da postavis nove instalacije .. heh susjed ti je i na drugoj modulaciji pa valjda zbog toga moze imat 1mbit ... ovo je stvarno žalosno ..... Zadnje izmijenjeno od: viper. 31.05.2010. u 14:37. |
Lokacija: Zagorje
Postovi: 874
mislim da nema nikakvih problema s instalacijama u kući. nema paralelnih spojeva. ruter je odma na glavnoj liniji i imam jedan samo telefon. da žalosno je :'( pa o čemu ovisi modulacija? jel zato kaj je on na t-comu a ja kao na iskonu (hr.duo)? evo danas su me zvali iz t-coma pošto su mi ograničili na 1mbit. uglavnom sad najedamput imam ovu modulaciju isto ko i susjed, wtf. brzina je i dalje koma, a u jednom trenutku se čak smanjila atenuacija za 2db, svašta! da i priča mi tip iz tekoma da ja imam lošiju brzinu od susjeda jer za razliku od njega imam i iskonov broj pa se tu troši brzina, a na to sam mu reko da je to obična glupost jer voip ide preko neta i nema zasebnu brzinu, na to je zašutio. a na pitanje o čemu ovisi sn margina kaže nezna, pa ti razgovaraj snjim... Zadnje izmijenjeno od: Full Throttle. 31.05.2010. u 17:17. |
Postovi: 23,676
Odgovarajuća tema već postoji: http://forum.pcekspert.com/showthread.php?t=81437, tumaćenje brojeva: http://forum.pcekspert.com/showpost....5&postcount=49 Admin neka spoji teme. On topic: U liniju ulazi ukupno ožičenje od porta na centrali pa do priključka u zidu u stanu / kući. Još nekako možeš utjecat / popravit ovaj dio u kući a dalje kompletno ovisiš o T-Koma/Iskon - u. Dovoljno je da imaš stare oksidirane / oštećene / loše spojene žice parice i dobit ćeš ovo šta sad imaš. Možeš jedino žugat, tražit da nađu drugu ispravnu paricu, ako je imaju uopće. Ovo inaće rijetko rade jer zahtjeva gnjavažu / fizikalu a pogotovo jer se radi većoj udaljenosti. |
Lokacija: Zagorje
Postovi: 874
daleko sam od centrale, to je glavni razlog. još u 10. mjesecu imao sam sx763 i na njemu sam se spajao skoro uvjek oko 1200kbps. oko nove godine sve je otišlo u 3 pixe marmelade. prvo je veza prema dnsu odbijala poslušnost, pa problem sa ispisom broja (vjerojatno nesikronizirani protokoli iskona i tekoma) i na kraju totalni pad brzine. a i prema parametrima susjeda vidi se da je stvar u udaljenosti i čisto sumnjam da je glavni problem stanje parice. razmatral sam i mogućnost da je to zbog masovne najezde maxtv-a blizu centrale, al opet si mislim ak susjed može imat 1mbit onda valjda i ja mogu izvući tu brzinu. sad sam reko iskonovcu da mi vrate na adsl1 modulaciju pa budem videl dal ima kakve promjene. PROBLEM RIJEŠEN! (recimo) rješenje: linija iz parice ide direkt u DSL utor u modemu, a telefon je uključen isto u modem. dakle bez ikakvog splitera. čim stavim spliter brzina pada na 300kbps i nije problem u spliteru jer sam dva isprobal. problem je sad da imam samo telefon od iskona al ne i od t-coma. ima tko kakvih ideja kak da dobim i t-com broj da funkcionira? evo stanje linije, stvarno je stabilno i leti: Modulation: G.992.5 annex B Bandwidth (Up/Down) [kbps/kbps]: 189 / 1.023 Data Transferred (Sent/Received) [MB/MB]: 1,64 / 1,79 Output Power (Up/Down) [dBm]: 7,0 / 9,5 Line Attenuation (Up/Down) [dB]: 39,0 / 63,0 SN Margin (Up/Down) [dB]: 12,0 / 9,5 Vendor ID (Local/Remote): TMMB / BDCM Loss of Framing (Local/Remote): 0 / 0 Loss of Signal (Local/Remote): 0 / 0 Loss of Power (Local/Remote): 0 / 0 Loss of Link (Remote): 0 Error Seconds (Local/Remote): 0 / 0 FEC Errors (Up/Down): 151 / 0 CRC Errors (Up/Down): 20 / 21 HEC Errors (Up/Down): 657 / 9 evo SN margina se spustila na identičnu vrijednost ko i susjedu, tojeto Zadnje izmijenjeno od: Jelc. 24.01.2011. u 22:08. |
#6 | |
super user
Postovi: 1,805
Lokacija: Zagorje
Postovi: 874
nema veze s modulacijom. ak stavim spliter pa iz splitera u modem brzina opet pada. stvarno mi nije jasno kak može biti ak odijelim analognu t-com liniju da mi odnese po 700kbps, onak wtf! EDIT: još sam danas tražil da mi stave na adsl1 modulaciju al su rekli da to nemogu jer sad sve ide na adsl2 tehnologiju, tj nema vraćanja. a još mi je do pred koji dan bil adsl1... TT UPDATE! ljudi ja ću se ranit! evo priče, idem ja kod susjeda uzet starcraft2. pošto on isto ima hr.duo, velim ja dok se prebacuje aj idemo vidit na tavanu kakvo ti je stanje s dslom. njemu se isto loše spaja mada ima atenuaciju bolju od mene. i gore na tavanu visi mu jedan spliter neiskorišten, stari zahrđali, noname. dok spliter koji koristi je isti ko i moj. i sad velim ja njemu daj da uzmem taj stari zahrđali spliter i isprobam doma onak iz zajebancije. stavim ja doma taj spliter i veza šiba na 1mbps bez frke! ljudi klonite se splitera na kojima piše ACUWA! al nebi mi bilo žao da nisam doma imal 3(riječima: tri) splitera ACUWA i svaki je bio govno. najvjerojatnije i ovaj ACUWA kod susjeda također govno. jel zna netko u kojem dućanu u zagrebu ima za kupit kvalitetnih splitera? Zadnje izmijenjeno od: Jelc. 24.01.2011. u 22:09. |
#8 | |
super user
Postovi: 1,805
http://www.nabava.net/trazilica.php?...=Pretra%C5%BEi al neznam kolko to valja ... vjerovatno ovi skuplji su i bolji |
Postovi: 23,676
U "igri" sa splitter - ima obratite pažnju kakvu adsl liniju imate Annex A ili B jer su interno različiti. |
Lokacija: Obronci Medvednice
Postovi: 19
Postovi: 23,676
Pa normalno da su niskopropusni filteri, poznate su "granične" frekvencije za POTS, ISDN, poviše toga ADSL. |
