Staro 26.05.2010., 21:59   #1
Liquid Snake
Liquid Snake's Avatar
Postovi: 166
Catalyst 10.5 Official
Release Notes:
http://www2.ati.com/relnotes/Catalys...ease_notes.pdf
Code:
Driver Packaging Version            8.732-100504a-099996C-ATI
Catalyst™ Version                   10.5
Provider                            ATI Technologies Inc.
2D Driver Version                   8.01.01.1030
Direct3D Version                    8.14.10.0753
OpenGL Version                      6.14.10.9836
Catalyst™ Control Center Version    2010.0504.2152.37420
Download:
http://game.amd.com/us-en/drivers_catalyst.aspx
Liquid Snake je offline   Reply With Quote
Staro 26.05.2010., 23:14   #2
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Jel stavil ko a da ima 4890...ima kakvih pomaka?
danc00 je offline   Reply With Quote
Staro 27.05.2010., 00:09   #3
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,752
Maloprije inst preko starih 10.4 (ko i inace), sve zasad radi ok. Nisam testira performanse u cmarku i slicno jer sad nemam volje, spava mi se... Sutra cu odvrtiti koji test pa javim..
Staro 27.05.2010., 00:44   #4
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,812
Stavio ih maloprije na Asusovu hd4670 i poceli su mi se pojavljivati artefakti (vide se na crnoj podlozi), i ruše se svalih 3-4 minute. Roll back....
Sretno!
EDIT: Stavio sam ih samo preko starih 10.4a
alien-smilies-0046.gif von smiliesuche.de
PointDexter je offline   Reply With Quote
Staro 27.05.2010., 04:19   #5
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Napravio express uninstall all ati software,pa u safe mode-u pobrisao sa driver sweeperom sve što je ostalo,stavio frišku instalaciju 10.5 i za sada sve radi kako treba.
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 27.05.2010., 21:13   #6
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
instalirao preko 10.4 i sve za sada radi kako treba
Staro 27.05.2010., 22:39   #7
keyser_s()ze
Postovi: 590
čini mi se da sam dobio par fps-a u cod 4 (hd 4670)
keyser_s()ze je offline   Reply With Quote
Staro 27.05.2010., 23:32   #8
cserer
Od danas pa do sutra
cserer's Avatar
Lokacija: ZAPREŠIĆ
Postovi: 65
također instalirao preko 10.4 i sve za sada radi kako treba
cserer je offline   Reply With Quote
Staro 28.05.2010., 03:44   #9
Neo-ST
Neo-ST's Avatar
Postovi: 8,487
Otkad sam instalirao 10.5, svaki put nakon restarta mi se ikone po desktopu poremete (kao da vratim na 800x600 pa opet na 1920x1200, ali ostanu skupljene sve u jednom kutu). Morao instalirat neki program Fences, da ih drži na okupu jer svaki put kada ih ja razmjestim, nakon restarta ili ponovnog paljenja računala sve bude poremećeno
Staro 28.05.2010., 11:51   #10
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Evo i ja sam stavil 10.5, samo prek starih. Nije mi se dalo sve prebrisavat, i radi ko i sa 10.4...zasad nisam niš igral ni vrtel 3D mark, bum sad probal.
Staro 28.05.2010., 12:51   #11
Kapica
Lokacija: Varazdin
Postovi: 108
..jos nisu ispravili bug na Splinter Cell Conviction... Win 7....
Kapica je offline   Reply With Quote
Staro 28.05.2010., 13:39   #12
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Autor jopcx Pregled postova
Može download link, ja nemogu nać nego 10.4.
http://support.amd.com/us/gpudownload/Pages/index.aspx
Odaberi sistem i grafulju i skidaj...
Staro 28.05.2010., 13:50   #13
Deathclaw13
Lokacija: Osijek - ZG
Postovi: 305
kakve su vam temp nakon ovog novog drivera, cito sam na drugim forumima da su se ljudima digle temperature nakon ovog update-a
i navodno su podignuti taktovi u 2D (idle) modu- kao zbog flickeringa na multimonitor setupima
pa ako ovaj update cini vece temp i ne daje mi nista ako nemam multimonitor setup, onda ne vidim puno smisla updateat drivere
Deathclaw13 je offline   Reply With Quote
Staro 28.05.2010., 13:53   #14
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Meni je sve isto...
Staro 28.05.2010., 15:38   #15
Deathclaw13
Postovi: 305
evo naso sam od tweaktowna review drivera
http://www.tweaktown.com/reviews/331...sis/index.html
razlike u performansama nema
osim ko sto vidjeh da su i oni napisali da su povecani taktovi u idle-u i da su vece temperature...(mozda se to odnosi samo na 5xxx seriju grafa, sto je i moja, pa mislim da cu preskocit ove drivere...)
Staro 28.05.2010., 15:53   #16
Thermaltake
1
Postovi: 3,590
maknuo 10.4 i instaliro 10.5 hotfix radi super na hd3850 AGP
Zadnje izmijenjeno od: Thermaltake. 28.05.2010. u 23:13.
Staro 28.05.2010., 17:02   #17
m4x
Postovi: 579
Autor Deathclaw13 Pregled postova
da,meni su povećane temperature na 5850,sad su 44 celzija ali je i vruće vani,prije su bile oko 40
m4x je offline   Reply With Quote
Staro 28.05.2010., 17:59   #18
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
evo ja sam sad pogledao takt dok sam u windowsima i stoji mi na 625mhz za xfx 4850 sto je default za 3d dok mi je sa 10.4 bilo 125 i idleu
Staro 28.05.2010., 18:04   #19
stopalo9
stopalo9's Avatar
Postovi: 763
nemam nikakvih problema sa sadasnjim drivera a posto 10.5 ne donosi nikakvo povecanje performansi preskacem ih..
stopalo9 je offline   Reply With Quote
Staro 28.05.2010., 20:11   #20
Metamphetamine
Flaccitra
Metamphetamine's Avatar
Lokacija: Vinkovci
Postovi: 276
Sve radi u najboljem redu, 2d clockovi i dalje 157/300, iako je nešto veća idle temp. Sad, dali je radi veće temp ambijenta ili drivera, ajd ga znaj
Metamphetamine je offline   Reply With Quote
Staro 28.05.2010., 20:16   #21
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Staro 28.05.2010., 20:23   #22
Neo-ST
Neo-ST's Avatar
Postovi: 8,487
Super, hvala. Sada čekamo 10.5a, pa 10.5a hotfix da popravi probleme od 10.5a, i hotfixa prije njega.
Staro 28.05.2010., 21:53   #23
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Autor Mansky Hunt Pregled postova
Mogel si i napisat o čemu se radi
The ATI Catalyst 10.5a Hotfix provides resolution for the following issue:
Battlefield: Bad Company 2 - Long load times for new maps when using a Windows® 7 / Windows Vista® based system with an:
ATI Radeon HD 4xxx series graphics card
ATI Radeon HD 3xxx series graphics card
ATI Radeon HD 2xxx series graphics card
Staro 28.05.2010., 23:34   #24
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,752
Autor Metamphetamine Pregled postova
Kod mene potpuno ista situacija, clockovi isti a temp veca za stupanj-dva... Misljenja sam da je temp veca zbog vrimena, ipak je ovih dana velika sparina (barem u mom selu )
Staro 29.05.2010., 00:15   #25
bAKa-47
Postovi: 157
isprobao na BFBC2, MW2, Metro2033 moj subjektivni dojam loše. Vratio na 10.4. Kartica 4870
bAKa-47 je offline   Reply With Quote
Staro 29.05.2010., 00:50   #26
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Također nisam ništa primjetio.
Način installa:
uninstall
restart
driver sweeper (not safe mod)
10.5 driver, sm bus driveri
restart
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 29.05.2010., 18:33   #27
matrix30zg
matrix30zg's Avatar
Postovi: 176
4850x2
isto sve,nema razlike...
matrix30zg je offline   Reply With Quote
Staro 30.05.2010., 02:10   #28
Xenomorph
Arroyo settler
Xenomorph's Avatar
Lokacija: .::Zagreb::.
Postovi: 316
4850 isto tako,nikakve razlike nema
Xenomorph je offline   Reply With Quote
Staro 30.05.2010., 04:08   #29
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,752
Evo primjetih razliku (u ove sitne sate ), ipak se pojavia problem sa clockovima.. I to u idleu tj. u windozima (sa par pozadinskih programcica), samo se odjednom tema prominila .. Clockovi se popeli na vrijednosti onih u 3d-u. Ponovno inst 10.4 i nema problema
Staro 31.05.2010., 13:52   #30
gmax
Tuco “the Rat” Ramirez
gmax's Avatar
Postovi: 476
Ista stvar i kod mene, vrnul se nazad na 10.4 i sad je ok.
