Povratak   PC Ekspert Forum > Računala > Overclocking > Memorije
Staro 19.04.2010., 03:20   #61
JohnNY-Z
JohnNY-Z's Avatar
Lokacija: Zadar/Pula
Postovi: 46
Ako ne radim overclocke ddr3 memorije, dali mi je potrebno uzimat hlađenje za nju? Mislio sam uzet Corsair Dominator Airflow fan.
JohnNY-Z je offline   Reply With Quote
Staro 19.04.2010., 03:28   #62
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Autor JohnNY-Z Pregled postova
Nepotrebno.
Ni klokanje sa max voltažama za DDR3 ne zahtjeva neko dodatno hlađenje a kamoli držanje na stocku.
blaa
Staro 19.04.2010., 08:52   #63
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
Potpis, nema potrebe ako imaš donekle dobar protok kroz kučište a recimo ako ideš u neke ekstreme i ako se baš zagrijava staviš neki vent da ti puše po memoriji. Ali to će ti vjerojatno samo za benchanje trebati.
d4rk_ch1ld je offline   Reply With Quote
Staro 08.05.2010., 14:19   #64
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Fastest Memory Race Heats Up - Corsair Announces 2533MHz DDR3
The whole 'fastest memory' halo product race is a bit of a farce. In terms of DDR3, Corsair started the race back in 2007 with their first set of Dominator modules, running at 1600Mhz, 10-8-8-24. This has been followed and bested, mainly by Corsair, but with sneak appearances by Kingston, G.Skill and Patriot.
Available as single sticks from the Corsair website, these new GTX4 modules will set you back $325 for each 2GB stick. With rather slack timings of 9-11-10-30 at 1.65V, each module is handtested using a Core i7 Lynnfield CPU on a Gigabyte P55 motherboard. Michal Nowicki, Corsair's inhouse overclocker, advises that 'most CPUs will require sub-ambient cooling to run [these modules] at their maximum speed'.
Despite the lifetime warranty and the ability to boast about a 'halo' product, I can't see a point in these sticks - even for overclockers. With such slack timings to begin with, I wonder just how much headroom is available, when other 2400+ kits with better timings are available. At $325 a stick, you really are shooting yourself in the foot.
But alas, these modules will sell, and Corsair know they will.
A brief (and abridged) history on the latest and greatest memory is summarised below:
http://www.anandtech.com/show/3705/f...-2533mhz-ddr3-
C L O W N I N G A R O U N D
Staro 15.05.2010., 13:46   #65
-Stinger-
-Stinger-'s Avatar
Lokacija: ZG/KA/OS
Postovi: 305
4 GB ( 2+2 ) = cca 2200kn-a, pa nije tak strašno...
I reject your reality and substitute my own!
-Stinger- je offline   Reply With Quote
Staro 19.05.2010., 16:21   #66
Astral
Postovi: 2,523
jel ovo dobra memorija?
mogu je dobit za 500kn, kolko mogu ocekivat od nje?
dakle Patriot signature 2x2gb 1066mhz cl7 za onog kojem se neda link otvarat
Astral je offline   Reply With Quote
Staro 24.05.2010., 14:45   #67
Doink the Clown
Postovi: 6,214
Staro 24.05.2010., 17:04   #68
Bukva
Pokemon prve generacije
Bukva's Avatar
Postovi: 109
Pitanjce!
Vidim da više-manje svi DDR3 moduli dolaze s ovakvim ili onakvim heatsinkom. Negdje sam pročitao da zapravo pošto DDR3 radi na daleko nižim frenkvencijama, cooler uopće nije potreban niti u kakvom obliku.
Pa čisto informativno - ti heatsinkovi, fanovi i ostalo što danas dolazi uz memoriju - reklamni trik ili ipak nešto što je potrebno?
Mogu patchat sve osim korisničke gluposti.
Bukva je offline   Reply With Quote
Staro 24.05.2010., 17:24   #69
Astral
Postovi: 2,523
fan > heatsink, al u biti oboje nepotrebno, ako bas kuris ram onda samo fan i to je to
ps. koje su ti latencije na 1600mhz?
Staro 24.05.2010., 18:40   #70
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,752
Autor Bukva Pregled postova
...Negdje sam pročitao da zapravo pošto DDR3 radi na daleko nižim frenkvencijama, cooler uopće nije potreban niti u kakvom obliku...
Odakle ti to da ddr3 radi na manjem taktu? Zapravo DDR3 radi na vecim frekvama ali isto tako na manjoj voltazi, pa je zbog toga manje i grijanje. Sto se tice heat-sinkova, nije ih lose imati jer ipak koliko-toliko pridonose hladjenju rama (kupe toplinu sa ddr3 cipova).. Efekt hladjenja dolazi do boljeg izrazaja ako neki vent puse po tom heatsinku..
Staro 24.05.2010., 18:43   #71
Doink the Clown
Postovi: 6,214
Autor Sn4k3 Pregled postova
Vjerovatno je kolega mislio na nižu stock voltažu u odnosu na DDR2.
Staro 24.05.2010., 19:17   #72
Astral
Postovi: 2,523
ne bih se slozio, ddr43 se ne zagrijava dovoljno da bi opce poceli kupit toplinu...vise rade protiv hladenja nego za
opet kazem, to se mijenja kad se ide u extreme i kad se rami jako zagrijavaju, za obicnog korisnika koj ce clockat na normalnoj voltazi nemaju koristi...
Staro 24.05.2010., 20:26   #73
Bukva
Bukva's Avatar
Postovi: 109
Ispričavam se, trebalo je pisati voltaži, ne frekvenciji...
Staro 24.05.2010., 20:53   #74
Astral
Postovi: 2,523
moze odgovor na ovo plz tnx
Autor Astral Pregled postova
i na kolko voltaze?
Staro 25.05.2010., 15:57   #75
Doink the Clown
Postovi: 6,214
Jedan koristan review za buduće kupce 2x2Gb kitova (bar ovih koji su i kod nas dostupni).
Dual-Channel DDR3: Who Makes The Best 4GB Kit Under $150?
Staro 15.07.2010., 22:05   #76
Boki95
Datum registracije: Mar 2010
Postovi: 60
Exclamation A-Data,Apacer DDR3 1333Mhz
Znaci namjeravam kupiti jos jednu gigu rama(DDR3 1333MHz)..ali ducan u kojem ih zelim kupiti nema drugu marku osim A-Data i Apacer
Trenutno u kompu imam 2GB Kingmax DDR3 1333MHZ (u jednom keksu),(matcna je ASRock M3A770DE).
Ali ovi koje namjeravam kupiti imaju CL5 (neznam kaj je to),a ovi stgo trenutno imam u kompu su CL9...e sad oce to sta sporije radit il?
Namjeravam stavit u Dual chanel!!
Oce li to dobro raditi??
I koji su bolji od navedena 2?
Boki95 je offline   Reply With Quote
Staro 18.07.2010., 23:15   #77
Astral
Postovi: 2,523
heh, pa ono...nebu bas dual channel al nije bed, nebus ni vidio razliku, bit ce single channel, za dual trebas 2x2gb rama, a ne 1x2gb+1x1gb
e sad a data ili apacer nije ni bitno, sve je to isti dreq jedino sta mozes je pogledat support list za memorije koje ti podrzava maticna, ali cak iako ne pise da podrzava velika je vjerojatnost da ce radit
i btw cisto sumnjam da je to CAS5 na 1333mhz tako da to jos provjeri, prije ce bit CAS9
Staro 22.07.2010., 22:32   #78
m4x
Postovi: 579
gledajte ovo
http://www.bug.hr/vijesti/zeleni-ddr...ga/103038.aspx
hoće li napokon drastično pojeftinit ddr3 50-nanometarski?
nove memorije ddr3 u 30-nanometarskom procesu su zaista brze a i trebale bi se još dobro klokat zar ne?
m4x je offline   Reply With Quote
Staro 26.07.2010., 21:49   #79
Doink the Clown
Postovi: 6,214
Staro 01.08.2010., 17:20   #80
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
KINGSTON 1GB DDR3 1333MHZ VALUERAM
U Eurotradea vidim doticnu memoriju za 130kn/1GB. Ima li netko od vas ovu memu, pa da podili iskustva/komentar? Zasad me zanima cisto informativno jer necu jos prelazit na DDR3. Stanje na zalihama ne znam, ali mi se svidja 5g. garancije s obzirom na cijenu. Dok neki "anusi" u nas znaju prodavat npr. Elixir/Kingston memu s 1god. garancije?!
Iz mog nedavnog iskustva s Eurotradeom (CM Hyper 212+), treba po novom bit pravna osoba, odnosno kupuje se na R1.
Pomelo mi sig -.-
Zadnje izmijenjeno od: Drvoje. 04.08.2010. u 00:26.
Staro 04.08.2010., 17:53   #81
ivan77
Prijelaz na DDR3 ?
Kratko , se isplati? vidim da ima kitova memorije DD3 od 6 gb već za 800 kn tu dolazi i pripadajuća ploča , uglavnom zadržao bih sve , CPU i grafe... prodao svoju ploču i DDR2 i prešao na DDR3 platformu. Što vi mislite? Jel se to danas isplati? Koliki bi bio benefit?
Staro 04.08.2010., 18:20   #82
nino
nino's Avatar
Postovi: 12,613
Bilo je rijeci tu na forumu vec, searchaj malo.
Koliko se sjecam, sa istim procom dobici su bili zanemarivi, od 3-5%, pa ti ako imas love za bacanje, go for it.
Staro 04.08.2010., 18:28   #83
ivan77
znači ,jedino ako bi se išlo na neki I7 Intelom , inače "makes no sense"?
Staro 04.08.2010., 18:45   #84
D-I-A-B-L-O
Bannija :D
D-I-A-B-L-O's Avatar
Lokacija: Sisak
Postovi: 1,098
Kao što ti nino reče, svakako je bacanje novaca, jedino ako baš moraš zato što ti npr proc ne podržava ddr2, pa u tom slučaju ni nemaš izbora. U svakom slučaju, dok je ovakvo stanje sa cijenama memorija, nikakav upgrade niti prelazak nadrugi tip se ne isplati,jer su cijene još uvijek bolesno i bezobrazno previsoke.
D-I-A-B-L-O je offline   Reply With Quote
Staro 04.08.2010., 19:54   #85
ivan77
a THNX svima , jer dakle, trebao bih za memoriju i ploču odvojit minimalno 2000 kn za 5 %, e to je epic fail
Staro 09.08.2010., 14:48   #86
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
G.Skill Flare DDR3 2000 MHZ C7 AMD kit review
Evo review i ovih famoznih flare kitova.
The memory kit that G.Skill offers here is impressive. Not once did we stumble into any stability issues or anything. With the right motherboard, and the ASUS motherboards mentioned really help out, you can achieve 2000 MHz C7 very easily and within seconds without the need for manual tweaking and complex overclocking. Do yourself a favor though, make sure your processor has unlocked multipliers, as 2000 MHz memory screams for an overclock on the processor as well. Since you are pretty tied to the baseclock at 250 MHz and unlocked multiplier will obviously do wonders for you.
The bottom line: G.Skill's DDR3-2000 CAS7 Flare memory is intended for a very small audience, but if you are a hardware tweaker, aficionado or overclocker you might as well be a match for this kind of memory. The results are shy to find, but the memory itself will definitely not disappoint.
Također pogledati:
http://www.xtremesystems.org/forums/...d.php?t=256142
Zadnje izmijenjeno od: bluefluid. 09.08.2010. u 15:19.
Staro 12.08.2010., 13:45   #87
s3t hooligan
Datum registracije: Dec 2009
Postovi: 144
evo ja za novu konfu namjeravam kupit kit od 4gb ove gskill flare memorije od 1800 mhz, u linksu je pala sa 1200 na 1039kn , radit ce u kombinaciji s asrock 890gx exteme 3 i thuban 1055t ,dali bi to sve trebalo u redu radit i dali je dobra memorija? trazim emu za tog thubana odo 1000 kn pa mi se ona cini daleko najbolja.
s3t hooligan je offline   Reply With Quote
Staro 12.08.2010., 15:20   #88
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
A to ti je onako dosta šminka memorija, trebala bi biti optimizirana za rad sa Thubanima, da, ali mislim da neces uopce profitirati, pa ni od tih dodatnih MHz.
Ako lova nije problem naravno uzmi ih, cijena je ok s obzirom da je links u pitanju, ali mislim da neces pogrijesiti ako uzmes nesto sporiju memoriju, niti da ces osjetiti neke razlike u perf (recimo neke ripjaws-e, link, ili neke dominatore - link)
Staro 12.08.2010., 15:23   #89
s3t hooligan
Postovi: 144
ma znam , ali neki mi kazu da su imali problema s ripjawsima na amd platformama , a dominatori postoje optimizirani za amd ali mi ihe se ne uzima pa cu uzet ove , ionako im je pala cijena za skoro 300 kn ,doduse svim memorijama je opala cijena.
Staro 06.09.2010., 23:30   #90
marko.m
Lokacija: zadar
Postovi: 112
Evo imam nekoliko pitanja u svezi memorije
Naime imam proc i7 870S i namjeravam uzeti Asrock P55 Deluxe3 ploču , a
na tržnici sam naletio na ovo http://forum.pcekspert.com/showthread.php?t=197035
pa me zanima da li bi ova memorija odgovarala ovoj ploči i procu.
Na stranicama Asrocka sam pogledao http://www.asrock.com/mb/memory/P55%20Deluxe3.pdf
ali te se Muskin niti ne spominje a komoli ovaj model pa vas molim za savjet.
Hvala
..suicide is like a solution that can't be undone.....
marko.m je offline   Reply With Quote
