Staro 04.12.2004., 11:14   #1
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
Omega 2.5.97 is out
Ljink
samo 17 MB
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 04.12.2004., 12:31   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Evo, u ovoj verziji drivera je konačno fiksirano forsanje ANISO filtriranja, Pinsla će se veseliti
* Based on the Catalyst 4.12 Beta drivers.
* New Radlinker installation method, now it should install correctly every time.
* Fixed gamma issues with color control panel.
* WMV acceleration is now off by default, you can turn it on in the Options panel.
* New quick shortcut for Radlinker, just right click your desktop and go directly
to all the Advanced 3D settings.
* Fixed Standby/Suspend/Hibernation bug.
* Added a lot of new resolutions for wide screen monitor/dfp users.
* Fixed the Forced Anisotropic settings, now they should not reset to Performance mode.
* Removed the special Counter Strike OpenGL from the package, now that CS:S is available,
this is no longer necessary.
* Fixed some uninstall issues, now the drivers should completely be removed if you select
to do so.
Well, at last, the fix for the dreaded overlay video on some laptops bug has been found.
The cause IS NOT the ATI drivers or any of my settings, the cause is a hardware bug, more
specifically a BIOS bug. In the testing, many people already updated their Sager notebooks
with a new BIOS provided by Sager and the video problem is GONE! So I encourage you to
go to your manufacturer's web page and see if a new bios update has been issued for your
laptop, and if not, e-mail the manufacturer so they can rush out a fix for this.
2. CCC will work with the Omega Drivers, but is NOT recommended that you install it, all
the functions found in CCC are already included with RadLinker Omega Edition or will
be included in a near future as this new CP project develops.
Staro 04.12.2004., 20:32   #3
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
konačno se je vrag prestal igrat World of Warcrafta te izbacio te drivere
ajd idem to skinut pa da vidimo dal HL2 može preko 100FPS na 1600x1200 6xaa 16xaf
pinsla je offline   Reply With Quote
Staro 04.12.2004., 20:59   #4
Tumor
prof.dr. gospodar svemira
Tumor's Avatar
Postovi: 432
Na 4xaa i 8xaf moze...
If you are not paranoid you don't have enough information
Tumor je offline   Reply With Quote
Staro 05.12.2004., 11:38   #5
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Kako mijerite FPSove?
Da li prethodno snimite svoj demo ili već ima neki, pa da i ja sa svojom malom ATIcom probam
Nemam više lema!!!
Staro 05.12.2004., 12:32   #6
Tumor
Tumor's Avatar
Postovi: 432
Za trenutne FPS-ove napises u konzolu cl_showfps 1, a za benchmark ima onaj neki ugradjeni demo.
Znam da sam ga jednom pokrenuo, ali se ne mogu sjetiti gdje sam ga u opcijama nasao...
Staro 05.12.2004., 21:56   #7
>>>KUKY-vk<<<
Lokacija: VINKOVCI
Postovi: 185
dali mi se isplati skidati ove drivere posto su radjeni na catalystu 4.12 beta?
trenuto perem sa 4.11.
bla-----
>>>KUKY-vk<<< je offline   Reply With Quote
Staro 06.12.2004., 00:52   #8
nodavilp
pUtNiK
nodavilp's Avatar
Datum registracije: Feb 2004
Lokacija: na forumu
Postovi: 342
omega izašla a baš sam skinuo beta 4,12 CAT
sam sam htio pitat s kojim programom mogu mjerit temp grafe. (9800XT)
nodavilp je offline   Reply With Quote
Staro 06.12.2004., 01:26   #9
Tumor
Tumor's Avatar
Postovi: 432
ATiTool ti pokazuje temperaturu graficke, a meni se ocitava i u najnovijem Everestu...
U ATiToolu mozes staviti da ti temperature zapisuje u log, pa onda nakon nekog mrcvarenja (igra) mozes pregledati log da vidis kako se kretala temperatura graficke.
Staro 06.12.2004., 16:27   #10
virty
Ronon Dex
virty's Avatar
Lokacija: DS9
Postovi: 1,625
Možeš ih mjeriti i sa FRAPS-om
http://www.fraps.com/
virty je offline   Reply With Quote
Staro 06.12.2004., 23:21   #11
nodavilp
pUtNiK
nodavilp's Avatar
Lokacija: na forumu
Postovi: 342
heh najače je da imam oba dva programa al da u nijednom nemrem vidjet di piše temp grafe
imam ati tool 0.0.22.-možda ta verzija nema to
u Everestu nigdje nevidim???
jel to možda jer nepiše proizvođač grafičke već ju sam prpozna ko 9800XT
Staro 07.12.2004., 00:50   #12
Tumor
Tumor's Avatar
Postovi: 432
U ATiToolu moras ukljuciti ocitanje temperature u opcijama Temperature Monitoring.
U Everestu se vidi pod Racunalo -> Senzor
Koliko ja znam 9800XT bi morala imati temperaturni senzor
Staro 07.12.2004., 23:04   #13
ZiViky
ZiViky's Avatar
Lokacija: Ljubljana-Rijeka-Cres
Postovi: 154
Mislim da nema svaka 9800XT i 9600XT senzor.
Ja i brati imamo iste Sapphire 9600XT (made in China), on ima ovverdrive i senzor, ja nemam.
ZiViky je offline   Reply With Quote
Staro 07.12.2004., 23:09   #14
LorD ClockaN
od LemilicE
Postovi: 4,712
Dobro došao ZiViky!!!
Vidim da si me poslušao
Uživaj u najbpljem forumu u Hrvata
Nemam više lema!!!
Staro 08.12.2004., 00:34   #15
ZiViky
ZiViky's Avatar
Postovi: 154
tnx, pokusat cu
I ne mozes mjeriti temp graficne ako nema senzor. S cime mislis mjeriti?
Staro 08.12.2004., 00:45   #16
nodavilp
pUtNiK
nodavilp's Avatar
Lokacija: na forumu
Postovi: 342
hebemu ja to nemam,fakat čudno jer imam r360:confused: ,ovaj powercolor je u qurcu
mislio sam da to ide s drajverima pa sam stavio nove 4,12 al ništa,
