#1 | |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATI Catalyst™ 10.4/10.4a Preview
Postovi: 2,258
Instalirao preko starih, bez CCC-a i sve za sada radi normalno, navečer ću isprobati dali je poboljšano vrijeme ulaska u BFBC2 kao što kažu pa postam ovdje ![]()
![]() RedGreenBlue |
Postovi: 5,991
#5 | |
Postovi: 5,991
Jedva čekam još koji profil je je zadnji radi odlično. |
Postovi: 2,258
Uh koja razlika što se tiće loadanja BFBC2, pa sada sam praktički uvijek prvi na serveru kada se starta mapa ili runda, GJ za ATI/AMD s ovim driverima! Ostale stvarčice me nisu ni zanimale!
Lokacija: osijek
Postovi: 1,887
Ako Vam je život tužan, ne brinite! Barem Vam je plaća smiješna |
Super Moderators
Postovi: 17,485
Pa driveri idu kao i prije, jedino su izlaskom 5xxx serije rekli da budu malo češće izbacivali fixeve za igre ako zatreba-u ovom slučaju je za Bad Company 2 ![]()
#12 | |
Super Moderators
Postovi: 17,485
Ovo za Bad Company 2 se tiče 5xxx serije, za 4xxx je rečeno Citiraj:
Super Moderators
Postovi: 17,485
Evo i za 4xxx seriju i starije ![]() ATI Catalyst™ 10.4a Preview Back Last Updated 4/21/2010 Article Number GPU-66 ATI Catalyst™ 10.4a Preview features: The ATI Catalyst 10.4a Preview provides resolution for the following issue: Long load times for new maps in Battlefield: Bad Company 2 when using a Windows 7 / Windows Vista based system with an: ATI Radeon HD 5xxx series graphics card ATI Radeon HD 4xxx series graphics card ATI Radeon HD 3xxx series graphics card ATI Radeon HD 2xxx series graphics card The XP driver is provided only as an early look of Catalyst 10.4 Note! This driver is provided as is and is not supported by AMD. It has not completed full AMD testing, and is only recommended for users experiencing the particular issue described above. This release is not supported by ATI Radeon™ HD5800 Eyefinity 6 series of products. Additional Recommendations: If the issue continues to occur after installation of the driver preview, the following troubleshooting steps can help resolve the issue: The problem may be a result of issues within the game application. Install any patches and / or updates available for the game application. Contact the game developer for instructions on how to obtain / install the latest patches and / or updates for the game application Conflict between the graphics card and motherboard’s BIOS version can cause performance issues. To reduce any hardware compatibility conflicts, install the latest BIOS version available for the motherboard Contact the motherboard manufacturer for instructions on how to obtain / install the latest BIOS version for the motherboard Installation errors that may have occurred during the installation of the game application may cause performance instability. Perform a clean install of the game application First uninstall the application Perform a fresh install of the application Install any available patches / updates for the application If the problem persists, reinstall the ATI Catalyst 10.4a Driver Preview Installation errors that may have occurred during the installation of the ATI Catalyst Software may cause performance instability. Perform a clean install of the ATI Catalyst Software For detailed instructions on the recommended steps for uninstalling / installing ATI drivers, refer to: Article GPU-33 for a Windows 7 based system Article GPU-1 for a Windows Vista based system Article GPU-2 for a Windows XP / Windows 2000 based system Applicable Products: This article applies to the following configuration(s): Hardware ATI Radeon™ HD 5xxx series of products ATI Radeon™ HD 4xxx series of products ATI Radeon™ HD 3xxx series of products ATI Radeon™ HD 2xxx series of products Software Battlefield: Bad Company 2 Operating System Windows 7® 32bit Windows 7® 64bit Windows Vista® 32bit Windows Vista® 64bit Windows® XP Professional and Home Windows® XP Professional x64 http://support.amd.com/us/kbarticles...-a-Hotfix.aspx
Postovi: 2,258
Ma ako je i 20% od onoga što su napravili za 5xxx seriju dobro je!
