Staro 15.04.2010., 21:10   #1
Jole1986
Lokacija: Vukovar
Postovi: 3
Exclamation Smrzavanje sustava tijekom surfanja i igranja
Version 5.1.2600 Service Pack 3 Build 2600
System Manufacturer VIA694
System Model AWRDACPI
System Type X86-based PC
Processor x86 Family 6 Model 7 Stepping 1 AuthenticAMD ~1300 Mhz
BIOS Version/Date VIA694 - 42302e31, Award Modular BIOS v6.00PG, 2.3.2001
Total Physical Memory 639,48 MB
Available Physical Memory 349,24 MB
NVIDIA GeForce4 MX 440 with AGP8X-64MB RAM
Maxtor-20GB Hard Drive
Imam problem neznam sa cime u device manager-u kaze sve ok nema !.
Međutim malo duze radim na njemu surfam ili igram neku prastaru igricu desi se da smrzne i nemogu nista samo ugasit i ponovo upalit.
Ako je netko imao slicnih problema neka slobodno kaze ..pozzz...i...
Hvala...
Jole1986 je offline   Reply With Quote
Staro 16.04.2010., 02:24   #2
Joke
N00B
Joke's Avatar
Postovi: 3,886
Pogledaj u Start -> Control Panel -> Administrative tools -> Event Viewer -> pod system vidi kakvih gresaka ima.
PS. Malo precizniji budi sa konfiguracijom, (popuni opsciju "Moj komp").
IE6
Linux is Not Windows
Staro 16.04.2010., 11:39   #3
Jole1986
Lokacija: Vukovar
Postovi: 3
AMLI: ACPI BIOS is attempting to read from an illegal IO port address (0x71), which lies in the 0x70 - 0x71 protected address range. This could lead to system instability. Please contact your system vendor for technical assistance.
The DHCP allocator has disabled itself on IP address 10.10.5.248, since the IP address is outside the 192.168.0.0/255.255.255.0 scope from which addresses are being allocated to DHCP clients. To enable the DHCP allocator on this IP address, please change the scope to include the IP address, or change the IP address to fall within the scope.
To dvoje je od danas dosta se ponavljaju u Event Viewer-u
EDIT:
Advanced configuration power interface. It controls standby functions etc.
May i suggest a check of the bios power settings, turn control off there and let XP handle it.
A bios upgrade may cure it, but in view of the dangers involved, not recommended.
Probao sam iskljucit ACPI .ali nece onda da pocne ocitavat windowse...
Znaci jedini ljek je da probam unaprijedit Bios...ali to bas nije preporucljivo..
EDIT:
Evo jos nesto ovo su podatci od maticne pise da max procesor moze do 1.2GHZ, a ja imam 1.3Ghz dali mozda i to zeza...
SOCKET-A 200MHZ FSB
FOR DURON (SPITFIRE) & ATHLON(THUNDERBIRD)
UP TO 1.2GHZ
VIA VT8731 KT-133
VIA VT82C686A (OPTIONAL 686B FOR ATA-100)
3 x DIMM 168-PIN
3.3V SDRAM
1 x ISA
5 x PCI
1 x AGP
ATX Power connector
19CM x 30.5CM
IDE : ULTRA DMA ATA-66 (ATA-100 OPTIONAL)
2S : 2 x 16C550 UARTS
1P : 1 x SPP/EPP/ECP
2 x USB
2 MINI-DIN PS2 MOUSE & K/B
SOUND + JOYSTICK (OPTIONAL)
AC-97 SOUND (OPTIONAL)
A.M.R SLOT (OPTIONAL)
2X/4X AGP PORT
EDIT:
--- ENGLISH ---
In this page i post the solution of the so-called k7vat freeze problem . A serious bug that affects the Lucky Star K7VAT motherboard that sometimes “ freezes “ when using it under Windows XP (but it can also freeze on other operative systems) . All that you have to do is to download the “ vlatency patch “ down and execute it. Nothing More.
Evo nasao sam taj neki patch skinio ga instalirao pa cemo vidjeti...
EDIT:
Opet mi se smrznio ovo ga muci valjda??????
Zadnje izmijenjeno od: domy_os. 16.04.2010. u 15:35. Razlog: spajanje postova > koristi EDIT tipku!
Staro 16.04.2010., 14:37   #4
Joke
N00B
Joke's Avatar
Postovi: 3,886
Autor Jole1986 Pregled postova
Cek sto je sa ovom adresom (10.10.5.248)?
To si ti postavio rucno na svojoj LAN kartici ili sto?
Ako jesi promjeni IP da ide 192.168.x.x (znaci samo da je "prefiks" 192.168).
IE6
Staro 16.04.2010., 16:12   #5
Jole1986
Lokacija: Vukovar
Postovi: 3
Imamo bezicnu vezu u selu spajem se preko NET GEAR-a..10.10.... je moja IP adresa idemo preko mikrotika i hot spota ,ma mora da je tu negdje nekakva zavrzlama..
Staro 16.04.2010., 16:19   #6
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Your computer was not assigned an address from the network (by the DHCP Server) for the Network Card with network address 0x001C2531FB43. The following error occurred: 0x79. Your computer will continue to try and obtain an address on its own from the network address (DHCP) server.
Meni se javlja ovaj error pet stotina puta dnevno,neam pojma šta je.
Ali isto tako mi se komp smrzava u igrama,te mi se čak jednom smrznuo tokom surfanja,odnosno - apdejtao sam BFBC2,došlo je na pola i stavio sam skidati Realtek drivere za zvučnu,pa se smrznuo.Ne znam što bi moglo biti,ali mislim da je kod mene napajanje u pitanju.Izgleda da je defektivno,pošto je staro cca 5 mjeseci i od novog napajanja vučem taj problem.Jednom kroz dva mjeseca kad upalim komp mi ne posta,ugasim ga i onda "uhvati" i boot-a normalno.Prvo ću napajanje riješiti,pa poslije toga prvom prilikom matičnu riješit.
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
