Staro 15.04.2010., 02:00   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATI Catalyst™ 10.4/10.4a Preview
ATI Catalyst™ 10.4 Preview features:
The ATI Catalyst 10.4 Preview provides resolution for the following issue:
Long load times for new maps in Battlefield: Bad Company 2 when using an ATI Radeon HD 5xxx series graphics card
Note! This driver is provided as is and is not supported by AMD. It has not completed full AMD testing, and is only recommended for users experiencing the particular issue described above. This release is not supported by ATI Radeon™ HD5800 Eyefinity 6 series of products.
For detailed instructions on how to install the driver preview, refer to:
Article GPU-33 for a Windows 7 based system
Article GPU-1 for a Windows Vista based system
Article GPU-2 for a Windows XP / Windows 2000 based system
Additional Recommendations:
If the issue continues to occur after installation of the driver preview, the following troubleshooting steps can help resolve the issue:
The problem may be a result of issues within the game application. Install any patches and / or updates available for the game application.
Contact the game developer for instructions on how to obtain / install the latest patches and / or updates for the game application
Conflict between the graphics card and motherboard’s BIOS version can cause performance issues. To reduce any hardware compatibility conflicts, install the latest BIOS version available for the motherboard
Contact the motherboard manufacturer for instructions on how to obtain / install the latest BIOS version for the motherboard
Installation errors that may have occurred during the installation of the game application may cause performance instability. Perform a clean install of the game application
First uninstall the application
Perform a fresh install of the application
Install any available patches / updates for the application
If the problem persists, reinstall the ATI Catalyst 10.4 Driver Preview
Installation errors that may have occurred during the installation of the ATI Catalyst Software may cause performance instability. Perform a clean install of the ATI Catalyst Software
For detailed instructions on the recommended steps for uninstalling / installing ATI drivers, refer to:
Applicable Products:
This article applies to the following configuration(s):
Hardware
ATI Radeon™ HD 5xxx series of products
ATI Radeon™ HD 4xxx series of products
Software
City of Heroes (Beta Release)
Operating System
Windows® 7 32bit
Windows® 7 64bit
Windows® Vista 32 bit
Windows® Vista 64 bit
http://support.amd.com/us/kbarticles...-4-Hotfix.aspx
Staro 15.04.2010., 18:30   #2
2 die 4
2 die 4's Avatar
Postovi: 2,247
Instalirao preko starih, bez CCC-a i sve za sada radi normalno, navečer ću isprobati dali je poboljšano vrijeme ulaska u BFBC2 kao što kažu pa postam ovdje
RedGreenBlue
Staro 15.04.2010., 18:37   #3
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Autor 2 die 4 Pregled postova
je za pola i nema više apsulutno nikakvih problema u toj igri + kaj ide super s cf profilom
Staro 15.04.2010., 18:41   #4
2 die 4
2 die 4's Avatar
Postovi: 2,247
Ajd drago mi za čuti, ali ipak ti imaš CF konfu možda je sa single card drugačija priča!
A možda su u šumi
RedGreenBlue
Staro 15.04.2010., 18:48   #5
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
A možda su u šumi
Bilo je puno problema s vertikalnim linijama.Kaj se tice loada mislim da nema veze koliko i koja grafa je u igri i da če ti bit bar za pola bolji.
Jedva čekam još koji profil je je zadnji radi odlično.
Staro 19.04.2010., 17:50   #6
2 die 4
2 die 4's Avatar
Postovi: 2,247
Uh koja razlika što se tiće loadanja BFBC2, pa sada sam praktički uvijek prvi na serveru kada se starta mapa ili runda, GJ za ATI/AMD s ovim driverima!
Ostale stvarčice me nisu ni zanimale!
RedGreenBlue
Staro 19.04.2010., 18:56   #7
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
ljepo je ATI krenio s izbacivanjem drivera, svako malo izbace nesto, ali neka vazno da rade
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
Staro 19.04.2010., 18:59   #8
Mad_Duke
Autor fre@k Pregled postova
Pa onak odavno izbacuju svaki mjesec driver lol
Staro 19.04.2010., 19:05   #9
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
pa ja sam imao HD4850 dok mi nije riknula, i djabe driveri kad mi u dosta igara nije radilo kak spada, stalno sam linije imao, i eto riknula mi memorija na toj grafi i od kada imam 5750 radi bolje nego 4850
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 19.04.2010., 23:45   #10
Jelc
Super Moderators
Postovi: 17,485
Pa driveri idu kao i prije, jedino su izlaskom 5xxx serije rekli da budu malo češće izbacivali fixeve za igre ako zatreba-u ovom slučaju je za Bad Company 2
Staro 20.04.2010., 02:56   #11
jurbAs
jurbAs's Avatar
Postovi: 2,583
jel ima kakve razlike sa starijim kartama?
jurbAs je online   Reply With Quote
Staro 20.04.2010., 09:51   #12
Jelc
Super Moderators
Postovi: 17,485
Ovo za Bad Company 2 se tiče 5xxx serije, za 4xxx je rečeno
HD 4000 series should get a fix next week
Staro 21.04.2010., 21:57   #13
Jelc
Super Moderators
Postovi: 17,485
Evo i za 4xxx seriju i starije
ATI Catalyst™ 10.4a Preview Back
Last Updated
4/21/2010
Article Number
GPU-66
ATI Catalyst™ 10.4a Preview features:
The ATI Catalyst 10.4a Preview provides resolution for the following issue:
Long load times for new maps in Battlefield: Bad Company 2 when using a Windows 7 / Windows Vista based system with an:
ATI Radeon HD 4xxx series graphics card
ATI Radeon HD 3xxx series graphics card
ATI Radeon HD 2xxx series graphics card
The XP driver is provided only as an early look of Catalyst 10.4
If the problem persists, reinstall the ATI Catalyst 10.4a Driver Preview
Hardware
ATI Radeon™ HD 3xxx series of products
ATI Radeon™ HD 2xxx series of products
Software
Operating System
Windows 7® 32bit
Windows 7® 64bit
Windows Vista® 32bit
Windows Vista® 64bit
Windows® XP Professional and Home
Windows® XP Professional x64
http://support.amd.com/us/kbarticles...-a-Hotfix.aspx
Staro 21.04.2010., 22:18   #14
2 die 4
2 die 4's Avatar
Postovi: 2,247
Ma ako je i 20% od onoga što su napravili za 5xxx seriju dobro je!
RedGreenBlue
