Staro 30.03.2010., 13:00   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ComboFix Updated
ComboFix updated - download if you have any malware and spyware issues.
"ComboFix is a program that scans your computer for known malware, and when found, attempts to clean these infections automatically. In addition to being able to remove a large amount of the most common and current malware, ComboFix also displays a report that can be used by trained helpers to remove malware that is not automatically removed by the program.
You should not run ComboFix unless you are specifically asked to by a helper. Also, due to the power of this tool it is strongly advised that you do not attempt to act upon any of the information displayed by ComboFix without supervision from someone who has been properly trained. If you do so, it may lead to problems with the normal functionality of your computer.
Please note that due to the nature of Combofix, it is advisable to use it only if you are guided by a computer expert."
Download it if you need it - not for novices.
http://www.majorgeeks.com/Combofix_d6402.html
