Staro 29.03.2010., 22:02   #1
chingyos
chingyos's Avatar
Postovi: 375
DVI konektor
Uzeo danas samsunga B2230 i konacno mislio da cu vidjeti DVI ulaz na djelu i skontam da na grafickoj imam DVI-I conector a na monitoru DVI-D,i sada sam morao na analogni ulaz ustekati,jel imam kakav kabel za uzeti?nisam znao da postoje vise DVI ulaza
chingyos je offline   Reply With Quote
Staro 29.03.2010., 23:06   #2
chingyos
chingyos's Avatar
Postovi: 375
Staro 29.03.2010., 23:18   #3
Raven_1
Night shift
Raven_1's Avatar
Datum registracije: Jul 2002
Postovi: 884
Autor chingyos Pregled postova
DVI-D (muski) ide u DVI-I (zenski) na grafickoj. Znaci standardni DVI-D to DVI-D sljaka.
Proc: AMD X2 3800+ cooled by TT BigTyphoon
Matična: ABIT AN8 SLI
RAM: 2x512MB OCZ Platinum EL rev2 PC3200
Grafička: SAPPHIRE ATI RADEON HD3450 256MB
HDD: WD 40GB i Samsung 160GB @ 7200
RW:DVD-ROM Pioneer DVD-106
PSU: 420W Xilence RedWing
"NOBODY expects the Spanish Inquisition! Our chief weapon is surprise...surprise and fear...fear and surprise.... Our two weapons are fear and surprise...and ruthless efficiency.... Our *three* weapons are fear, surprise, and ruthless efficiency...and an almost fanatical devotion to the Pope.... Our *four*...no... *Amongst* our weapons.... Amongst our weaponry...are such elements as fear, surprise.... I'll come in again."
--uoɥʇʎd ʎʇuoɯ--
Raven_1 je offline   Reply With Quote
Staro 29.03.2010., 23:25   #4
chingyos
chingyos's Avatar
Postovi: 375
Aj mi samo reci koji kabel da kupim
Staro 29.03.2010., 23:32   #5
Raven_1
Night shift
Raven_1's Avatar
Postovi: 884
Pa reko sam obicni DVI-D to DVI-D. Znaci izgledaju konektori kao na ovome.
--uoɥʇʎd ʎʇuoɯ--
Staro 29.03.2010., 23:36   #6
chingyos
chingyos's Avatar
Postovi: 375
Ok thx budem
Staro 29.03.2010., 23:47   #7
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,744
Ovako, DVI-I je i digitalni i analogni a DVI-D samo digitalni i oni ssu kompatibilni samo moraš spojit sa kablom koji podržava DVI-D, tj tak kabal nema ona 2 pina iznad i spod onog dugačkog pima koji je na lijevoj strani.
http://www.playtool.com/pages/dvicom...onnscables.jpg
Kolega me pretekao, dobro ti je rekao
Staro 03.04.2010., 00:25   #8
Mar
Suit up!
Mar's Avatar
Postovi: 5,967
Već je bilo govora o tome, DVI-D kablovi idu u DVI-I konektore, ali ne i obrnuto.
- Barney Stinson
Staro 23.07.2010., 10:36   #9
Locutus
laik
Locutus's Avatar
Datum registracije: Apr 2009
Lokacija: Doma
Postovi: 63
A DVI-D na VGA? Da li je potreban konverter, ili postoji adapter? Adapter nisam nigdje uspio pronaći.
Locutus je offline   Reply With Quote
Staro 23.07.2010., 10:41   #10
Mar
Suit up!
Mar's Avatar
Postovi: 5,967
Da, ima DVI->VGA i obrnuto, obično dobiješ s grafičkim karticama koje imaju 2 DVI utora.
Ukoliko nemaš, možeš kupiti - nije skupo, oko 10ak kn.
- Barney Stinson
Staro 23.07.2010., 10:44   #11
Locutus
laik
Locutus's Avatar
Lokacija: Doma
Postovi: 63
Autor Mar Pregled postova
Imam takav, ali izlaz na novoj grafičkoj mi je DVI-D .. to je opet neki drugi standard i razlikuje se od običnog DVI po tome što nema još one 4 iglice okolo jedne izdvojene... uglavnom, za taj DVI-D nisam pronašao adapter, a trebam priključiti VGA monitor.
