Staro 19.03.2010., 11:36   #1
~Trt~
red drum
~Trt~'s Avatar
Datum registracije: Aug 2008
Postovi: 144
Ethernet-over-power
Vjerojatno ste čuli ili već možda koristite ovakvo riješenje koje je uvjerljivo bolje od wireless-a.
Zanima me da li bi to radilo na dva različita brojila koja se nalaze u istoj kući.
Znači na prvom katu je jedno,a na drugom drugo.
Malo sam surfao ali sam zahrđao sa ovim stručnim pojmovima struje pa mi treba pomoć oko slijedećeg:
"All HomePlugs must be on the same power circuit."
This statement, that appears in the netcomm docs, is misleading. All Homeplugs need to be on the same phase. In many domestic situations there is only one phase, so the NP's will work between any two power points - even though there may be several circuits which are all connected to the one phase.
In industrial installations and some houses (eg mine) three phase power is supplied. The NP's will only work if both are connected to the same phase.
They will work if both power points are on the same circuit because, by definition, each circuit is connected to (only) one phase. In the situation where the power points are on different circuits but the same phase, no problem. Different circuits and different phases - won't work.
Jel to znači da bi bez obzira na brojila ova solucija radila? Znači sa jednog kata koje ima svoje brojilo na drugi kat koji ima svoje brojilo. Ili sam se totalno pogubio u tome svemu?
Hvala svima na odgovorima
~Trt~ je offline   Reply With Quote
Staro 19.03.2010., 13:09   #2
mahoona
mahoona's Avatar
Postovi: 284
Ne, ne radi preko brojila, svi umreženi elementi moraju biti iza istog brojila. Isprobano već
mahoona je offline   Reply With Quote
Staro 19.03.2010., 13:35   #3
~Trt~
red drum
~Trt~'s Avatar
Postovi: 144
Znači ne postoji nikakva mogućnost to spojit?
Staro 19.03.2010., 14:24   #4
mahoona
mahoona's Avatar
Postovi: 284
Autor ~Trt~ Pregled postova
Nažalost ne, brojilo je nepremostiva prepreka za ovu tehnologiju.
