Staro 21.01.2010., 18:04   #1
Shyehiem
Shyehiem's Avatar
Datum registracije: Jan 2010
Postovi: 1
Post Bridge mode - Thomson ST780iWL & Linksys BEFSR41 v4.2
Dobar dan svi
Oprostite ali ne govorim Hrvastke dobro, ja sam iz Francuske ali sada ja sam u Zagrebu.
Okay, really sorry all that I have to write in English, but cant do it in Croatian at the moment.
Here is my problem:
I have a DSL connection through t-com, and they gave me the modem/router Thomson ST780iWL. Now that's fine, but I would like to use my own router, a Linksys BEFSR41 v4.2.
As far as i understood, to do so i need to put the ST780iWL in bridge mode, which is done by setting "PPPoE Pass-Through" status to On.
Here are my questions:
- Do I need to leave DHCP on in the ST780iWL? i dont see why i should as i plan to set up manually BEFSR41 and the IP of the computers on my lan.
- How can i make it so i connect from the BEFSR41 and not the ST780iWL?
Long story short, i want to get rid completely of the ST780iWL (but for MaxTV obviously), and set up my lan and internet connection through the BEFSR41.
Any suggestions?
Hvala puno
Shyehiem je offline   Reply With Quote
Staro 22.01.2010., 00:32   #2
thopok
Lokacija: Splity
Postovi: 3,003
is it already done?
SpeedTouch>Set Up
Staro 11.02.2010., 12:45   #3
bajica
Just a member
bajica's Avatar
Postovi: 39
Ja imam sličan problem, kupio sam Linksys WRT160NL u namjeri da se riješim Thomsona ST780iWL by t-com u potpunosti, problem je što novi ruter nem konektor za telefonsku liniju.
trenutno je spojen ethernet kablom u thomsona koji je spojen telefonskom linijom na net, meni bi trebalo nekakav konverter telefonska linija -> ethernet kabal, i dali bi tako nešta radilo bez problema, treba mi samo internet i wlan za komp. hvala!
bajica je offline   Reply With Quote
Staro 11.02.2010., 13:28   #4
Postovi: 23,490
U biti isto pitanje na koje ti je gore već predloženo rješenje.
U ST780 ugasi wireless i podesi ga u Bridge mode rada.
Staro 11.02.2010., 14:06   #5
bajica
Just a member
bajica's Avatar
Postovi: 39
Ideja je da se riješim thomsona, neželim koristit oba modema ako to nije potrebno, sješavam se thomsona zato što svako malo se resetira i gubim wlan, znači opcija sa samo linksys ruterom mi je poželjna,
Pokušao sam nešto ali bezuspješno, ubacio sam telefonski kabal u ruter al ima "lufta" sa obje strane i neznam dali je isti redosljed na koji su pinovi spojeni
Ovo su mi opcije u postavkama rutera
No neupješno sam se pokušao spojit, dali je to u postavkama ili kabal nesmije biti tako spojen?
Staro 11.02.2010., 14:30   #6
Postovi: 23,490
Neće ići jer si kupio krivi uređaj, kupio si wireless router a tebi treba adsl wireless router. Trebao si uzet WAG160N.
Ili zamjeni ako ga imaju ili napravi gore navedeno.
Osim navedenog ugasi DHCP server u ST780, uređaje spajaš lan kabelom ST780 Lan1 - Internet WRT160Nl. Kad ovo napraviš onda ćeš podesit konekciju (slika poviše) s tim da je poželjno da postaviš ip uređaja na 192.168.1.2 i manualno uneseš DNS servere.
Staro 11.02.2010., 15:12   #7
bajica
Just a member
bajica's Avatar
Postovi: 39
Imaju više modela
Koji je za mene
Staro 11.02.2010., 15:20   #8
Postovi: 23,490
Ako je T-Koma onda treba biti adsl Annex B.
