Datum registracije: Jan 2010
Postovi: 1
![]() Dobar dan svi ![]() Oprostite ali ne govorim Hrvastke dobro, ja sam iz Francuske ali sada ja sam u Zagrebu. Okay, really sorry all that I have to write in English, but cant do it in Croatian at the moment. Here is my problem: I have a DSL connection through t-com, and they gave me the modem/router Thomson ST780iWL. Now that's fine, but I would like to use my own router, a Linksys BEFSR41 v4.2. As far as i understood, to do so i need to put the ST780iWL in bridge mode, which is done by setting "PPPoE Pass-Through" status to On. Here are my questions: - Do I need to leave DHCP on in the ST780iWL? i dont see why i should as i plan to set up manually BEFSR41 and the IP of the computers on my lan. - How can i make it so i connect from the BEFSR41 and not the ST780iWL? Long story short, i want to get rid completely of the ST780iWL (but for MaxTV obviously), and set up my lan and internet connection through the BEFSR41. Any suggestions? Hvala puno ![]() |
#2 | |
Lokacija: Splity
Postovi: 3,003
SpeedTouch>Set Up |
Just a member
Postovi: 39
Ja imam sličan problem, kupio sam Linksys WRT160NL u namjeri da se riješim Thomsona ST780iWL by t-com u potpunosti, problem je što novi ruter nem konektor za telefonsku liniju. trenutno je spojen ethernet kablom u thomsona koji je spojen telefonskom linijom na net, meni bi trebalo nekakav konverter telefonska linija -> ethernet kabal, i dali bi tako nešta radilo bez problema, treba mi samo internet i wlan za komp. hvala! |
Postovi: 23,499
U biti isto pitanje na koje ti je gore već predloženo rješenje. U ST780 ugasi wireless i podesi ga u Bridge mode rada. |
Just a member
Postovi: 39
Ideja je da se riješim thomsona, neželim koristit oba modema ako to nije potrebno, sješavam se thomsona zato što svako malo se resetira i gubim wlan, znači opcija sa samo linksys ruterom mi je poželjna, Pokušao sam nešto ali bezuspješno, ubacio sam telefonski kabal u ruter al ima "lufta" sa obje strane i neznam dali je isti redosljed na koji su pinovi spojeni ![]() Ovo su mi opcije u postavkama rutera ![]() No neupješno sam se pokušao spojit, dali je to u postavkama ili kabal nesmije biti tako spojen? |
Postovi: 23,499
Neće ići jer si kupio krivi uređaj, kupio si wireless router a tebi treba adsl wireless router. Trebao si uzet WAG160N. Ili zamjeni ako ga imaju ili napravi gore navedeno. Osim navedenog ugasi DHCP server u ST780, uređaje spajaš lan kabelom ST780 Lan1 - Internet WRT160Nl. Kad ovo napraviš onda ćeš podesit konekciju (slika poviše) s tim da je poželjno da postaviš ip uređaja na 192.168.1.2 i manualno uneseš DNS servere. |
Just a member
Postovi: 39
Imaju više modela ![]() ![]() Koji je za mene ![]() |
Postovi: 23,499
Ako je T-Koma onda treba biti adsl Annex B. |
