Staro 28.01.2010., 22:49   #1801
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Stigle zvijeri
blaa
Staro 28.01.2010., 22:52   #1802
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
sexy, miriši mi na puno ventova na placu s tvoje strane.
d4rk_ch1ld je offline   Reply With Quote
Staro 28.01.2010., 22:52   #1803
Co0ki3^^
Datum registracije: Dec 2009
Postovi: 177
uuu...najs...ja sam svoje počeo krotiti onim scytheovim potenciometrom i mogu ti reći da kad je load odvrnem,a kad odem spavat sve na min i tiho ko zmaj xD
a ventovi takoreći crap
Co0ki3^^ je offline   Reply With Quote
Staro 28.01.2010., 22:59   #1804
hammer_of_thor
Postovi: 5,430
Zasad su još malkoc glasni, čekam da mi dođe drugi potenciometar, pa će svi biti mirni i lijepi
blaa
Staro 28.01.2010., 23:01   #1805
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Autor hammer_of_thor Pregled postova
Hebeni Studio54
Koliko te to sve na kraju para izašlo?
C L O W N I N G A R O U N D
Staro 28.01.2010., 23:06   #1806
hammer_of_thor
Postovi: 5,430
10$ a piece= 80$ ventovi
~15$ shipping
Iz Engleske su, tako da shipping nije tako strašan
Udarili su mi malu carinu, sve skupa 95$ roba + shipping i 100tinjak kn carine
blaa
Staro 29.01.2010., 00:05   #1807
Dottore
Dottore's Avatar
Postovi: 7,703
na koliko deklarirano vrte?
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 29.01.2010., 00:09   #1808
hammer_of_thor
Postovi: 5,430
1500 RPMa/60ak CFMa
Biti će 2 potenciometra, Zalman ZM-MFC1 i Scythe Kaze Master, ili se možda riješim ovog Zalmana pa uzmem 2 Scythea
blaa
Staro 29.01.2010., 00:42   #1809
Razer
Razer's Avatar
Postovi: 11,642
Iz kojeg si shopa uzimao te ventove? Za koliko su došli? Malo mi je bed naručivati iz Performance-PC jer treba gotovo mjesec dana da to sve stigne. Ako su ovi iz Engleske, to bi trebalo moći doći u roku od 10-ak dana (sjećam se kad sam uzimao iz Memoryc-a)
Staro 29.01.2010., 00:44   #1810
Co0ki3^^
Postovi: 177
1500 RPMa/60ak CFMa
i to si uzmi kaze q jer je jeftin i njime reguliraj ventove na kućištu a s ovim masterom proc i ostale koji su važniji...tako bi barem ja...
Staro 29.01.2010., 00:58   #1811
hammer_of_thor
Postovi: 5,430
Autor Razer Pregled postova
E-Bay, zaboravio sam ime sellera, vidiš, moram mu ostavit feedback
Za 9 dana su došli
A istina za PPC's, presporo je to, makar i imaju daleko najbolju ponudu što sam skoro vidio, no cijene im nisu baš neke bajne, a i shipping im po USPS cijeniku, dakle čim je neka kutija ~70x70 cm već je 50$
blaa
Staro 29.01.2010., 01:32   #1812
d4rk_ch1ld
d4rk_ch1ld's Avatar
Postovi: 695
Prekrasni su ventovi
Staro 29.01.2010., 01:32   #1813
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,357
Autor Čuks Pregled postova
daj stavi i sliku sa prednjom stranom kucista, btw, koji je case u pitanju?
Ima pod Moj komp a slika prednje strane je pod "...radno mjesto" topicom.
Autor SetH Pregled postova
za disk je to previše ...uzmi neki scythe onaj tanki i stavi na njega
A di bi ga ti stavio Ma ak ništa drugo ne smislim ić će disk van kućišta u Scythe Quiet drive. Moram se ovih dana malo poigrat sa protokom zraka...
Staro 29.01.2010., 01:42   #1814
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,327
tanak je pola cm,jel nebi stao?
SetH je offline   Reply With Quote
Staro 29.01.2010., 10:10   #1815
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Mogli su bar kablove od ventova staviti u neki buzir, somine. Bitno je da si ti zadovoljan, pa makar i na par dana
Usput ja zavrsavam klepanje svog "Les Noir Pitona", davitelja svih s.370 konfiguracija; samo da jos stigne Asus GeForce 3 Ti500 Deluxe i bit ce spreman za slikanje i objavu. Kad se sjetim kako je kuciste bilo ruzno, onako prljavo i sugave ivory boje - sad je ludnica, iako se bas nisam previse potrgao oko bojanja...
Staro 29.01.2010., 10:12   #1816
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,357
Jok,nema mjesta.
Staro 29.01.2010., 14:32   #1817
boris87
boris87's Avatar
Lokacija: Žepče
Postovi: 407
38-39 na stock kuleru klokan? Pa gdje toga ima?
Ima kod mene,evo ako nevjerujes...
Idle 30c stock cooler
Full load dok renda scenu..
Max 38-43 stock cooler
Temp u sobi:
Zadnje izmijenjeno od: boris87. 29.01.2010. u 14:47.
boris87 je offline   Reply With Quote
Staro 29.01.2010., 14:39   #1818
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
I danas usarafio napajanje, naravno Asus - da bude u stilu, jos jedino cekam da mi stigne oldskul zvjercica Asus GeForce 3 Ti500 i onda ce kompletna biti nekadasnja zvijer za kojom je vecina u ono vrijeme samo drulala na slikama...da ne spominjem da je takva konfiguracija nekoc kostala sigurno 20.000kn...
I frekvencija na kojoj trenutno sljaka, Prime95 stabilno
Staro 30.01.2010., 07:57   #1819
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,357
Revizija 2 Pošto se ono em previše grijalo em je protok bio sheban em je bilo...glasno E pa:
Je da lijepo (bar meni) izgleda sprijeda al je killer za temperature diska...koje meni nisu same po sebi problem al zvuk vrućeg diska - je:
Pa se opet ja bacio na posel...najprije sam blokiral jednu bočnu stranicu sa običnim papirom (sprintal crno tak i da je dobra kamuflaža ) i dodal 2xSharkoon Silent Eagle 2000 (regulirano prek MBO,@700rpm) na bok:
I da ne duljim:
Di je disk? Vani Čeka se Scythe Quiet drive pa bu išel u njega tak da bum i njega kaj se tišine na taj način riješil. Sa ovim svim temperature unutar kućišta su:
CPU: 30-40 (Chief@5V)
MBO: 35
VGA: 54
I kaj reći još? Mislim da bi moglo i bolje. Gornja stranica će ić na obradu,ozrezat će se 2x120mm rupe da odvode zrak van kućišta al to bude...kad bude Prijedlozi?
Staro 30.01.2010., 09:14   #1820
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Obozavam desktop kucista i monitor gore na njemu (citaj:mjesta na stolu kao u prici), ali nikad nisam zadovoljan kad treba nesto kopati po njemu...
Koliko je kostalo to kuciste i gdje? I jos jedno pitanjce, jel ide normalno ATX napajanje(jer vidim nekakav kabel provucen s jedne strane kucista na drugu za 220V) i full ATX ploca u njega? Bilo bi idealno za moju PIII-S masinu koja se ne grije ni najmanje...
Staro 30.01.2010., 11:05   #1821
Thorax
Doomster
Thorax's Avatar
Datum registracije: Mar 2008
Lokacija: Kraj Donji
Postovi: 400
Autor Dizel Pregled postova
Jedino kaj živcira kod tog kućišta je što napajanje ide iznad kulera... i daj čitač pofarbaj, ovak strši iz crnila kućušta
Ja sam svoju kombinaciju upario sa 6600 GT, al ipak je prejaka za taj procesor...
Mislim da ti full ATX ploča ne bu išla u ovo gore kućište... imam ja slično i također sam osuđen na mATX, i još k tome ne mogu ni normalno napajanje staviti.
CPU: AMD Athlon 640 under TX3
MBO: Asrock 870 Extreme3
RAM: 8 GB DDR3 Mushkin @ 1333, CL8
VGA: XFX HD4830
HDD: WD 6400AAKS
Monitor: Samsung 2470H
PSU: Fortron PNF 400W
OS: Win 7 Enterprise x64 SP1
Net: 12 Mbit/1,25 Mbit
Sound: Logitech X-530
CPU: Intel Celeron T3100
MBO: HP 1526
RAM: 2 GB DDR3
VGA: GMA 4500MHD
HDD: WD3200BEVT
Monitor: 15,6“ LCD
PSU: HP 65 W
OS: Win 7 Enterprise x86 SP1
Sound: Arctic Sound P281
CPU: AMD Athlon M320 undervolt @ 0.975 V
MBO: AMD 785
RAM: 2 GB DDR2 800
VGA: Integrated HD4200
HDD: Hitachi 250 GB
Monitor: LCD 15,6“
PSU: Delta Electronics 65 W
OS: Win 7 Ultimate x86
Net: 8 Mbit/768 kbit
Sound: integrated
Thorax je online   Reply With Quote
Staro 30.01.2010., 11:54   #1822
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Autor Thorax Pregled postova
...ko govno u punču Priznaj da ne prepoznajes svoje staro kuciste?
A i napajanje iznad kulera ima svojih prednosti - isisava zrak od hladnjaka dritto van kroz njega, jer ima 120mm vent koji u ovom polozaju stoji iznad hladnjaka
Jedini problem je taj sto je to Asusovo napajanje glasno u 3PM iako ima 120mm LED YateLoona pa sam morao srediti to sa dobrim starim frendom FenMejtom Cvaj.
Zadnje izmijenjeno od: Dizel. 30.01.2010. u 12:11.
Staro 30.01.2010., 12:48   #1823
mymoon
nautic expert
mymoon's Avatar
Lokacija: Rijeka-Opatija, negdje između
Postovi: 1,386
baš pola cm i nije, ako misliš na onaj 100mm vent, on ima punih 12mm plus nosač koji zauzme još 4-5 mm visine.
mymoon je offline   Reply With Quote
Staro 30.01.2010., 13:29   #1824
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,327
Autor mymoon Pregled postova
ma znam da,s*ebao sam se...al po slikama stvarno nigdje nestane :S
Staro 30.01.2010., 14:33   #1825
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Moglo bi i bolje
Staro 30.01.2010., 14:36   #1826
zkljaja
Brat od Đon Vejna
zkljaja's Avatar
Lokacija: zg-vg
Postovi: 1,204
jos kad bi bio malo vjestiji sa foticem...a da bi moglo bolje, moglo bi puno bolje
Staro 30.01.2010., 14:41   #1827
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Autor papčić Pregled postova
ah..nikako da izađem na zelenu granu sa Olympus FE-310
Staro 30.01.2010., 14:55   #1828
Doink the Clown
Postovi: 6,214
Mene samo bode u oči ovaj stock hladnjak i kabel s dva molexa za diskove koji si mogao provući sa unutarnje strane da se ne vidi toliko. Koje to napajanje imaš?
Staro 30.01.2010., 15:05   #1829
alengrosevic
alengrosevic's Avatar
Postovi: 3,791
bas, stock cooler, kao saka u oko...
no moglo bis se tu jos malo doraditi, provuci kablice iza, mozda okrenuti hard diskove prema iza konektore, posloziti to malo bolje. ima potencijala...
Staro 30.01.2010., 15:38   #1830
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Napajanje je Antec BP500U
http://www.antec.com/Believe_it/product1.php?id=Njk=
Diskove cu okrenut kad uhvatim vremena a sto se stock hladnjaka tice uskoro cu ga zamjenit..
