Staro 15.12.2009., 22:33   #1261
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Nebumo više u OT
Staro 11.01.2010., 13:14   #1262
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Redwood GPU za nadolazeći HD 5670/5650, praktički prepolovljeni Junpier GPU po specifikacijama. Šipment počinje kroz sljedeća dva tjedna.
Coming January 21 for €79
According to a few early listings, AMD's no thrills Redwood GPU will ship on January 21 with prices starting at €79. We're expecting even lower prices once it starts shipping, but don't expect a bargain. AMD has the lead and has no reason to cut prices on DirectX 11 cards, even in the low end.
The Redwood is basically a halved Juniper. It features 400 stream processors and 40 texture units, but it retains the 128-bit memory bus. It will be available in 512MB and 1024MB versions. At this point we're not sure about the clocks either, as some retailers claim the GPU runs at 850MHz, while others are listing 775MHz. The same goes for memory, 1000MHz to 1200MHz depending on who you ask.
The cards are expected to ship within the next two weeks and some retailers claims they will have them in stock in 10 days, January 21.
Fudzilla.com
Matth€w je offline   Reply With Quote
Staro 11.01.2010., 18:40   #1263
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
Malo sam se prek vikenda igrao sa 5970...majko mila koje cudoviste od grafe. Jedva stala u chifteca big tower.
Dojmovi su predobri, u stanju je potjerat kaj god vam padne na pamet
Evo usporedba velicine sa Logi G15 tipkalom i 8800 GTS grafom.
E da, btw, nemojte ju drzat u kompu koji je blizu radijatora
vga killer je online   Reply With Quote
Staro 11.01.2010., 18:46   #1264
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Meni se na kraju i nije činila toliko bučnom, mislim glasna je, ali ne onoliko koliko bi mogla biti.
Staro 11.01.2010., 20:51   #1265
Jelc
Super Moderators
Postovi: 17,485
Autor vga killer Pregled postova
Žalibože tebi dat ATI-cu u ruke
Staro 11.01.2010., 21:39   #1266
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Imaš li što sačuvano od rezultata,koje igre si igrao? Da baš vidimo C2D prosječan komp i takvu živinu.
Staro 11.01.2010., 22:34   #1267
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
Nazalost nisam nis odvrtio, nisam bas bio prevec doma, a i nije mi se prevec dalo.
Jedino su me driveri malo nazivcirali, npr. u wowu kad se dignu detalji u kontrol panelu na max je slika mutna....vratis na difolt i sve super sa slikom :S
Da sam bar imo jacu karticu prije pa da mogu mnalo usporedit par igri kak spada, al iovak nema tog cuda kaj nece pokrenut na max-u....osim mozda Krizu na 24x AA, jer su nam u tom slucaju i 3 5870 umrle
Staro 12.01.2010., 17:29   #1268
Enter Sandman
dark paradise
Enter Sandman's Avatar
Postovi: 551
Evo ako neko bude imao problema sa serijom 5xxx i sa mišonjom:
5xxx
Da zna o čem se radi...
Enter Sandman je offline   Reply With Quote
Staro 13.01.2010., 12:33   #1269
Zvone2772
interferometar
Zvone2772's Avatar
Postovi: 768
ATI HD5670 review - The New Mainstream Warrior
http://www.hardwarezone.com/articles...?cid=3&id=3109
10% brža od GT240, ali i dalje malo sporija od 9800GT
Zvone2772 je offline   Reply With Quote
Staro 13.01.2010., 12:51   #1270
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Thumbs up Radeon HD 5830 Coming with HD 4890 Performance, But Cheaper
According to a recent post at NordicHardware, AMD is not only launching the first budget card of Radeon HD 5600 series in several days, and also unveiling a new addition to the Radeon HD 5800 series – Radeon HD 5830.
The report suggests that the Radeon HD 5830 will use GDDR5 memory and deliver equal performance to HD 4890, but costing less. We haven’t seen any sign of HD 5830 in the roadmap, but it comes as no surprise that AMD decides to offer a more cost-effective card to compete better.
Radeon HD 5830 is said to appear on January 25th with a price tag of no more than $200. Stay tuned for more details in the days to come.
en.expreview.com
Staro 13.01.2010., 13:19   #1271
Postovi: 33,943
Nekidan sam baš gledao roadmap za mobilne grafe i tamo ugledao 5830 pa sam se baš zapitao kad će doći do desktop sistema. Nadam se da neće biti promašaj kao 4830.
Staro 13.01.2010., 13:24   #1272
thedream
thedream's Avatar
Postovi: 5,458
Jedna će svakako biti,pogotovo s aspekta cijene u našim trgovinama, 5750/5770/5830,sve je to performansama a i cijenom preblizu,tim redoslijedom,čini mi se da će nastupiti poprilična gužva za tih 1000 +/- parsto kuna.
Ako će davati performanse kao 4890,znači li to da je 256bitna ili kako, pošto 128-bitna 5770 sa DDR5 na 4800 daje ekvivalent 4870/4870 1gb?
Gamers looking for an afforable alternative to the high-end Radeon HD 5850 that want a little more power than the 5770 provides may not have to wait much longer. Rumor site ATI Forum says that a 5830 card sporting the same design and cooling as the Radeon 5850.
Staro 13.01.2010., 13:48   #1273
Postovi: 33,943
Pretpostavljam da će biti 256bitna sabirnica na njoj i da će brzo postati best buy. Pokazalo se da je 128bitna sabirnica kočnica za 5770 na višim rezolucijama tako da bi ovo trebao biti pun pogodak po pitanju odnosa perfomanse/cijena.
Staro 13.01.2010., 13:56   #1274
thedream
thedream's Avatar
Postovi: 5,458
A da,nekako u maniri vidovitog milana bi ja predvidio 256bit bus ali sa downclockanom DDR5 na "samo" 1000 (4000) mhz,umjesto 4800,da ne zapapri 5850 previše,kao i broj SP-a bi trebalo vidjeti,ali ako piše a little more power over 5770,prognoze postaju realnije.
5770 je tiptop kartica za 1650x1080/high odnosno 1920x1080/1200 bez AA i AF, to nju ubije,tu se bus uguši,naravno i high detalji,ali prvo forsiranje dotičnih opcija. Još se ona odlično i predstavila vs. GTX260 216 i 4870/1gb, ja sam zadovoljan jako njenim performansama, uz minimalnu buku i zagrijavanje,jako ugodna kartica za rad se pokazala.
Vidjet ćemo,samo nek se gomilaju,kupci uvijek od toga mogu samo profitirati,pogotovo u Dx11 naslovima di bi ja ipak išao na 256bit bus karticu.
Staro 13.01.2010., 14:19   #1275
Postovi: 33,943
Obzirom na trenutne cijene 5770 i 5850 kod nas (1.250/1.900kn) i vani (180/300$), tipujem da će cijena kod biti 1.500-1.600kn.
Čitam vani i vidim da se spominje da će biti na bazi Cypressa, a ne Junipera što definitivno znači 256-bitnu sabirnicu. Iako ju je netko nazvao 5770 sa 256-bitnom sabirnicom, prije će biti downklokana 5850.
Staro 13.01.2010., 14:27   #1276
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
HD 5830 XGP, nemogu baš iz teksta razbratiti da li je to HD 5830 spojena ili HD 5870.
http://xtreview.com/addcomment-id-11...-5830-XGP.html
Staro 13.01.2010., 16:13   #1277
pingmachine
machine that goes ping!
Postovi: 478
Autor Zvone2772 Pregled postova
pa i nije baš nešto... kao nova low-end kartica super, ali nije upgrade za moju 4670 kao što sam se nadao
ja bih ovo: http://www.powercolor.com/eng/NewsInfo.asp?id=999
pingmachine je offline   Reply With Quote
Staro 13.01.2010., 19:06   #1278
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
Autor pingmachine Pregled postova
ovo mi se svidja, samo neznam zasto nenaprave neku 256 bitnu da vide kak ce se to ponasat, mislim nemoze biti lose, mislim da bi to odma kupio, ali ovo mi se bas svidja
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
Staro 13.01.2010., 19:27   #1279
kian
kian's Avatar
Datum registracije: Oct 2001
Lokacija: Velika Gorica
Postovi: 600
Fotke doticne.
Staro 13.01.2010., 22:29   #1280
pingmachine
Postovi: 478
idealna kartica. pasivno hlađenje + nema power connector = nirvana
samo, mislim da to nećemo vidjeti u hrvatskoj...
Staro 14.01.2010., 09:10   #1281
Postovi: 33,943
A što ne bi? Ako dolaze PCS verzije, zašto ne bi i ova? Znam da ima za kupiti nvidia Green grafa. Cooler joj je stvarno velik. Malo neobično da ima toliku hrgu za grafu koja malo troši i još manje se zagrijava.
Staro 14.01.2010., 10:30   #1282
pingmachine
Postovi: 478
ne znam, jednostavno takav osjećaj... nadam se da se varam, jer STVARNO želim tu karticu
Staro 14.01.2010., 15:49   #1283
r!dEr
Postovi: 79
ovo je sve vise postalo preseravanje... ukoliko ta kartica bude kostala oko 1500 kn bit ce cisti promasaj s obzirom da se 5850 nadje za 1900 jer je razlika skoro ko da imas dvije slabije. a i ovo s 5770 je debelo trpanje gdje ne treba
po meni ce 5830 bit totalno neisplativa kupnja ukoliko bude preko 1300kn
r!dEr je offline   Reply With Quote
Staro 14.01.2010., 16:15   #1284
Jackson
Postovi: 648
Pa ako bude držala razliku od 400kn, isplativa po meni... Ako će biti omjeri performansi kao 4830 vs. 4850, 20% razlike u cijeni je definitivno čini isplatljivijom od 5850.
Jackson je offline   Reply With Quote
Staro 14.01.2010., 16:22   #1285
thedream
thedream's Avatar
Postovi: 5,458
Autor r!dEr Pregled postova
Ne znam otkud ti ovo,napravili su odličnu karticu koja direktno zamjenjuje 4870/1gb model i konkurira odlično GTX260 karticama, cijene su sve bolje, već oko 1100kn za nove modele u trgovinama, uz potrošnju od 18W i 37c stupnjeva zagrijavanje idle, i 108W odnosno 60tak c loada. Manje se griju kvragu nego procesori,a stock hladnjak je odličan što nije čest slučaj na stock 4870 modelima,istog cjenovnog ranga.
Baš su sa 5770 po meni napravili pun pogodak,to je jako dobra kartica,uz cijenu od 1100kn. Bez problema se možeš igrati i na 1920 rezoluciji bez forsiranja AA i AF ovisno o igri,negdje da,negdje ne,naravno. A tu je i Dx11 i Eyefinity.
Staro 14.01.2010., 16:40   #1286
Mad_Duke
Još kad bi ATi napravio matičnu sa integriranom nekom 56xx serijom u mini-ITX formatu to bi bilo zakon :P
3 DP-a za 3 monitora, običan proc i kaj ti treba više na stolu :P
(da, da znam da je bullshit, ali ono. Palo mi na pamet :P )
Staro 14.01.2010., 16:59   #1287
r!dEr
Postovi: 79
Autor Jackson Pregled postova
ne vjerujem da ce biti takvi omjeri... 5850 ima 1440 jedinica dok 5830 ostaje na 800 a po testovima 5850 dobrano nadmasuje 4870/4890
5770 je novija kartica sto se tice tehnologije izrade, ali u nekim stvarima je korak unazad naspram 4870. podrska za novi dx nema smisla ukoliko je kartica slaba da bi to podrzala a danas su standard monitori 1680 dok 1920 postaju sve cesci. steta sto kartica nema bar siru sabirnicu.
ako mi sad kartica moze dobro vrtit mw2, a crysis na 1680x1050 je taman da se moze igrat -> na 1920 vec sad knapira i to jako sto ce tek biti kad se budu vrtili dx11 naslovi (mozda grijesim, usporedbu vucem uz performanse jedne 4870, jer 5770 nemam) ?
na 5850 ove stvari rade bez problema tako da je po meni bolji izbor kad se uzme u obzir razlika od 20% sto iznosi 20tak kutija cigareta ili 2-3runde pica
po ovom sto sam za sada vidio tek ce 5830 biti dostojna zamjena za 4890 a 5770 jeftinija/zelenija solidna kartica za nezahtjevne
ono podebljano sam mislio na cackanje po sabirnici... da su ostavili 256bitnu nebi rijeci rekao
Zadnje izmijenjeno od: Jelc. 14.01.2010. u 20:08.
Staro 14.01.2010., 21:58   #1288
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
ATI HD5670 review
Eto još jedan, nek' se nađe
http://www.tomshardware.com/reviews/...5670,2533.html
C L O W N I N G A R O U N D
Staro 15.01.2010., 14:53   #1289
Zvone2772
interferometar
Zvone2772's Avatar
Postovi: 768
Pojavila se i u Linksu Sapphireova 5670:
939kn 1GB
739kn 512MB
Staro 15.01.2010., 15:52   #1290
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
Uff,puno...
Majo je offline   Reply With Quote
