Staro 04.01.2010., 20:24   #1
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
EVGA Classified SR-2 Info Thread
No, da li je itko vidio ovo cudo???
'A day or two ago we already reported that eVGA is working on a dual-socket (LGA 1366) motherboard. A new photo appeared.
This will be an uber high-end tweakers dual LGA-1366 motherboard based on the Intel 5500 "Tylersburg" chipset with the usual ICH10R Southbridge.
Considering you'll need SMP support the dual-socket motherboard will have to support the Xeon 5500 series. Probably, a future high-end Intel Core family CPU is released that is capable of dual-socket setups, too. The picture reveals two LGA-1366 sockets, each powered by an 8-phase digital PWM circuit. Each socket is wired to six DDR3 DIMM slots supporting triple-channel memory for that socket.
The board has 7 PCIe slots and to feed them the motherboard is equipped with two NF200 (NVIDIA) bridge chips to add additional PCIe lanes. It is now rumoured that this amazing board will also have an amazing price tag .. over 500 EUR.'
Izvor:guru3d
'The recently surfaced high-end dual socket LGA-1366 motherboard is pictured in full, without its cooling assembly. The picture reveals quite a bit about EVGA's new monstrosity. To begin with, the motherboard is neither ATX, nor EATX in the truest sense. Like the recently announced X58 Classified 4-way SLI which was based on the "XL-ATX" form-factor, this motherboard seems to be 13.58 inches (344.93 mm) long, and about as wide as EATX (330 mm, 13 inches), or maybe a little more.
Each LGA-1366 socket is wired to six DDR3 DIMM slots for triple-channel memory, and is powered by an 8-phase digital-PWM circuit. Each socket further has a 3-phase power circuit for its DIMM slots. The CPU VRM for each socket takes input from an 8-pin ATX, and what appears to be a 6-pin +12V (PCI-E?) connector. The motherboard further takes power from a 6-pin PCI-E power connector apart from the usual 24-pin ATX power connector. Some of these inputs may be redundant and needed only for additional electrical stability to support competitive overclocking.'
Izvor:techpowerup
Staro 04.01.2010., 20:39   #2
Baja 001
Baja 001's Avatar
Postovi: 7,504
To je ploča za render ekipu i par 3D Čmark jusera
Koliko RAMa? 24GB
Staro 04.01.2010., 20:44   #3
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
To ću si kupit.....za 5 godina
Divota od "pločice" nema daljnjeg.
Staro 04.01.2010., 20:45   #4
Mad_Duke
Prebrutalno. Toliko snage na jednoj ploči. Ekipa kaj renderira će plakati od sreće. Da ne pričam mogućnosti od strane GPGPU-ova.
Staro 04.01.2010., 20:52   #5
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Bolesno, 12 DIMM utora, 7 hebenih PCI-E slotova, baš me zanima koliko će staza imati
Ovo je farma u jednom
blaa
Staro 04.01.2010., 20:53   #6
ivand123
otišo po cigare i nesto
ivand123's Avatar
Lokacija: Zagreb (Maksimir)
Postovi: 373
Cijela ta platforma je blesavo moćna i ukoliko se ne koristi u profi svrhe krajnje nepotrebna plus cijena od oko 500 eura, pa to je skoro više od moje cijele konfe.
ivand123 je offline   Reply With Quote
Staro 04.01.2010., 22:01   #7
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Mislim da tih 500+ eura nije puno u odnosu na njezine karakteristike.
Staro 04.01.2010., 22:18   #8
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
Drito to,prepolovis ju na 250E i opet imas sick plocu,mada imas samo pola ploce .
Majo je offline   Reply With Quote
Staro 04.01.2010., 22:56   #9
hobitxxx
hobitxxx's Avatar
Datum registracije: Jul 2009
Lokacija: Koprivnica
Postovi: 412
Mene zanima kolko ce to WATA trebati kad bude puno OC-anih komponenata zapiknuto unutra.....2KW?
hobitxxx je offline   Reply With Quote
Staro 04.01.2010., 23:21   #10
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
ma to je za amere, a kod njih ionak samo papci kupuju napajanja ispod kilovat i pol
ploca je savrsen pocetak za pilu iz snova: dva 975, 4x5870cfx, rama koliko ide i to sve pod vodom...
Staro 04.01.2010., 23:23   #11
Majo
Postovi: 2,281
Pocetak?Sto li je kraj te pile onda ?
Staro 04.01.2010., 23:32   #12
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Autor bluefluid Pregled postova
To da..ali ima jedan mali problem. Cijena.
@ Majo
6 x 30" monitora sa ultratankim rubom
Staro 04.01.2010., 23:43   #13
Jerry
Jerry's Avatar
Postovi: 1,816
Ploca zahtijeva 1500W (24+8+8+6+6) ima dva NF200 chipa te je VECA od EATX standarda (vjerujem da NITKO od vas ne moze naci takav PSU a ne stane ni u koje SERVERSKO SSI EATX kuciste!).
Sve u svemu - promasaj (u odnosu na prethodni Skulltrail koji se takodjer nije proslavio)!
Stupid is as stupid does
Jerry je offline   Reply With Quote
Staro 05.01.2010., 00:09   #14
Func
Func's Avatar
Postovi: 483
500€ nije previše s obzirom koliko znaju koštati neke asusice, a opet 2x I7 920 je jeftinije nego i7 975 extreme. Uzmu se dva napajanja i stvar funkcionira. Naravno procevi se naclockaju.
Some say that he's Mac compatible, and that he once punched a horse to the floor. All we know is, he's called The ...
Func je offline   Reply With Quote
Staro 05.01.2010., 00:17   #15
Wolverine
Wolverine's Avatar
Postovi: 12,431
Autor Jerry Pregled postova
Potpis!
Ploča je totalni promašaj što zbog cijene, što zbog dimenzija, što zbog navedenih energetskih zahtjeva.
SkullTrail platforma je bila nešto pristupačnija pa nije zaživjela niti se proslavila.
Jedino za što je dobra jest kao tematika mokrih snova lokalne DFP ekipice
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 05.01.2010., 09:55   #16
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Naravno, vidis kako Krankenšvester i ekipa drulaju naveliko
Staro 05.01.2010., 10:30   #17
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Podsjeća me na serverske dual Slot 1 modele. Naravno,ova je na steroidima.
Staro 05.01.2010., 12:37   #18
Jerry
Jerry's Avatar
Postovi: 1,816
Btw, ploca te kofiguracije vec postoji par mjeseci a i (po zadnjim informacijama) - u pola cijene!
http://www.supermicro.com/products/m...0/X8DTH-6F.cfm
Samo sto uz SM dobijete vrhunsku kvalitetu i support, standardne dimenzije, standardno EPS napajanje, dvostruko vecu kolicinu rama (do 96GB - ako to nije pokazatelj kvalitete PCBa ne znam sto jest) te izgubite dva rostilja na PCBu u obliku nf200 chipova.
Staro 05.01.2010., 12:39   #19
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ovdje je samo bitno da se slini na eVGA, XFX i ostale sarenjake.
Staro 05.01.2010., 12:50   #20
Wolverine
Wolverine's Avatar
Postovi: 12,431
Jerry ali ono nije eVGA i nema rdeče utore + crni PCB
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 05.01.2010., 14:36   #21
Jerry
Jerry's Avatar
Postovi: 1,816
Ocito!
Staro 06.01.2010., 01:36   #22
vm@
vm@'s Avatar
Datum registracije: May 2009
Lokacija: donji lapac
Postovi: 547
moram si tak nekaj nabavit da mi grije sobu umjesto radijatora
vm@ je offline   Reply With Quote
Staro 06.01.2010., 01:43   #23
DomagojX
Lokacija: Zagreb/Sesvete
Postovi: 1,307
zaš misliš da se to jako grije?
DomagojX je offline   Reply With Quote
Staro 06.01.2010., 01:46   #24
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Nije mislio na to, nego na cijeli setup kad slozis gore
Staro 06.01.2010., 01:59   #25
hobitxxx
hobitxxx's Avatar
Postovi: 412
pa napikas recimo 7 komada 4850-etki sa onim tankim hladnjakom i 2 i7 sa stock kulerima i malo ih naklokas i grije ko ludo hehhehe VM@ nece ti grijati sobu nego kucu sorry zbog OT...
Staro 06.01.2010., 04:09   #26
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
da... pogotovo 7x4850
Staro 06.01.2010., 04:42   #27
Pegasus8
Pegasus8's Avatar
Postovi: 482
Cemu tolke 4850-ice, dosta su dvije 2900pro i evo ti centralnog
Što se tiće ploče, ništa posebno. Jedino sexy izgleda
Pegasus8 je offline   Reply With Quote
Staro 06.01.2010., 11:12   #28
Jerry
Jerry's Avatar
Postovi: 1,816
Autor Pegasus8 Pregled postova
Za tu lovu ima puno stvari koje izgledaju sexy!
Staro 06.01.2010., 12:04   #29
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,795
Dabome.
Programer
Staro 06.01.2010., 12:26   #30
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Autor hobitxxx Pregled postova
Ovo i nije problem za nekoga tko ima novaca za tako nešto.
3 corsaira od 1000W paralelno spojena i deri mile
Spoiler alert!
