Lokacija: VG
Postovi: 1,758
EVGA Classified SR-2 Info Thread
No, da li je itko vidio ovo cudo??? ![]() 'A day or two ago we already reported that eVGA is working on a dual-socket (LGA 1366) motherboard. A new photo appeared. This will be an uber high-end tweakers dual LGA-1366 motherboard based on the Intel 5500 "Tylersburg" chipset with the usual ICH10R Southbridge. Considering you'll need SMP support the dual-socket motherboard will have to support the Xeon 5500 series. Probably, a future high-end Intel Core family CPU is released that is capable of dual-socket setups, too. The picture reveals two LGA-1366 sockets, each powered by an 8-phase digital PWM circuit. Each socket is wired to six DDR3 DIMM slots supporting triple-channel memory for that socket. The board has 7 PCIe slots and to feed them the motherboard is equipped with two NF200 (NVIDIA) bridge chips to add additional PCIe lanes. It is now rumoured that this amazing board will also have an amazing price tag .. over 500 EUR.' Izvor:guru3d 'The recently surfaced high-end dual socket LGA-1366 motherboard is pictured in full, without its cooling assembly. The picture reveals quite a bit about EVGA's new monstrosity. To begin with, the motherboard is neither ATX, nor EATX in the truest sense. Like the recently announced X58 Classified 4-way SLI which was based on the "XL-ATX" form-factor, this motherboard seems to be 13.58 inches (344.93 mm) long, and about as wide as EATX (330 mm, 13 inches), or maybe a little more. Each LGA-1366 socket is wired to six DDR3 DIMM slots for triple-channel memory, and is powered by an 8-phase digital-PWM circuit. Each socket further has a 3-phase power circuit for its DIMM slots. The CPU VRM for each socket takes input from an 8-pin ATX, and what appears to be a 6-pin +12V (PCI-E?) connector. The motherboard further takes power from a 6-pin PCI-E power connector apart from the usual 24-pin ATX power connector. Some of these inputs may be redundant and needed only for additional electrical stability to support competitive overclocking.' Izvor:techpowerup |
Postovi: 7,504
To je ploča za render ekipu i par 3D Čmark jusera ![]() Koliko RAMa? 24GB |
Prebrutalno. Toliko snage na jednoj ploči. Ekipa kaj renderira će plakati od sreće. Da ne pričam mogućnosti od strane GPGPU-ova. |
otišo po cigare i nesto
Lokacija: Zagreb (Maksimir)
Postovi: 373
Cijela ta platforma je blesavo moćna i ukoliko se ne koristi u profi svrhe krajnje nepotrebna plus cijena od oko 500 eura, pa to je skoro više od moje cijele konfe. |
Lokacija: VG
Postovi: 1,758
ma to je za amere, a kod njih ionak samo papci kupuju napajanja ispod kilovat i pol ![]() ploca je savrsen pocetak za pilu iz snova: dva 975, 4x5870cfx, rama koliko ide i to sve pod vodom... |
Bazinga
Lokacija: Križevci
Postovi: 3,933
Postovi: 1,816
Ploca zahtijeva 1500W (24+8+8+6+6) ima dva NF200 chipa te je VECA od EATX standarda (vjerujem da NITKO od vas ne moze naci takav PSU a ne stane ni u koje SERVERSKO SSI EATX kuciste!). Sve u svemu - promasaj (u odnosu na prethodni Skulltrail koji se takodjer nije proslavio)!
Stupid is as stupid does |
Postovi: 483
500€ nije previše s obzirom koliko znaju koštati neke asusice, a opet 2x I7 920 je jeftinije nego i7 975 extreme. Uzmu se dva napajanja i stvar funkcionira. Naravno procevi se naclockaju.
Some say that he's Mac compatible, and that he once punched a horse to the floor. All we know is, he's called The ... |
#15 | |
Postovi: 12,425
Potpis! Ploča je totalni promašaj što zbog cijene, što zbog dimenzija, što zbog navedenih energetskih zahtjeva. SkullTrail platforma je bila nešto pristupačnija pa nije zaživjela niti se proslavila. Jedino za što je dobra jest kao tematika mokrih snova lokalne DFP ekipice ![]()
#18 |
Postovi: 1,816
Btw, ploca te kofiguracije vec postoji par mjeseci a i (po zadnjim informacijama) - u pola cijene! http://www.supermicro.com/products/m...0/X8DTH-6F.cfm Samo sto uz SM dobijete vrhunsku kvalitetu i support, standardne dimenzije, standardno EPS napajanje, dvostruko vecu kolicinu rama (do 96GB - ako to nije pokazatelj kvalitete PCBa ne znam sto jest) te izgubite dva rostilja na PCBu u obliku nf200 chipova. ![]()
#27 |
Postovi: 482
Cemu tolke 4850-ice, dosta su dvije 2900pro i evo ti centralnog ![]() Što se tiće ploče, ništa posebno. Jedino sexy izgleda ![]() |
#29 |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,765
#30 |
Avocado
Postovi: 7,856
Spoiler alert! |
