Staro 24.11.2009., 17:37   #1231
Mad_Duke
Koliko su koštale Radeon 9800XT ili X850XT PE?
Koliko su koštale Endivijine 8800 Ultra ili GTX295 kad su izašle?
U ovo vrijeme prošle godine
Asus Radeon HD4870x2 - 4580 kn u M Sanu
Ako otiđeš još dalje u prošlost još je kritičnija situacija. Recimo. Mislim da je GF2 (ne mx smeća) bila u svoje vrijeme toliko skupa da su se paralelno još debelo prodavale GF1, te Rive TNT.
Staro 25.11.2009., 09:57   #1232
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Radeon 5950 due in Q1 2010
'According to a recent article on German-language Hardware Infos, AMD might be planning a release of a new dual-GPU graphics card, which will be officially announced sometime in the first quarter of 2010. The specifications and features of the new card are somewhat similar to AMD's current flagship, the HD 5970, as both cards are based on the same 40nm RV870 graphics processing units.
Said article also gives a summary on the previous reports on the rumored HD 5950, including details on the GPU and memory clock speeds. Unfortunately, these specifications haven't yet been finalized and we are expecting the HD 5950 to work at between 650MHz-675MHz core clock, or 1800-2000MHz memory clock. Additional features include 2 x 1440 Stream Processors, 2 x 72 PBC, 2 x 32 ROPs and 2 x 256-bit GGDR5 memory.
Unfortunately there's no word on pricing, but the new card will debut sometime around the same period as NVIDIA's much-anticipated Fermi-based line of GeForce graphics cards. This should ultimately enable AMD to lower the prices on their latest generation of Radeon cards, as the Fermi-based architecture is expected to deliver an impressive performance boost, over the current GT200 family of GPUs.'
Izvor:guru3d
Staro 25.11.2009., 12:26   #1233
Postovi: 33,924
Dakle, 5970 je trebala biti 5870X2 i zamijeniti 4870X2. Međutim, na defaultu po performansama i tehničkim karakteristikama više liči na 5850X2 tj. 5850 CF. Šta će onda biti 5950? 5830X2?
Staro 25.11.2009., 13:06   #1234
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,743
Ako je 5970 5870 u CF sa smanjenim taktovima, 5950 će onda vjerojatno biti 5850CF sa smanjenim taktovima.
Staro 25.11.2009., 18:35   #1235
Wolverine
Wolverine's Avatar
Postovi: 12,425
Autor coconut Pregled postova
Pričaš gluposti.
HD5970 i jest HD5870x2 odnosno zamjena za HD4870x2, samo što se zove HD5970. Ako bolje pogledaš vidjeti ćeš da se radi o da punokrvan Cypress grafička procesora kakvi se nalaze na HD5870.
Što se taktova tiče, razlog potraži u ATX specifikacijama potrošnje
HD5950 bi pak trebala biti, ajmo to nazvat, HD5850x2 odnosno kartica sa dva okljaštrena Cypressa
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 26.11.2009., 17:41   #1236
win32
win32's Avatar
Datum registracije: Apr 2008
Postovi: 1,517
ATI Radeon 9800XT je bila cca 4600 kn kada je izasla te na vise. Znaci minimalno 4600 kn. Znam jer sam onda sa 9600XT presao na 9800XT te se na Master kupovalo.
Ne znam baš da je 9800XT ikad koštao 4700kn,ali dobro.
Je, to je bila ta cijena (100 kn vise-manje). Naravno, pricamo o ATI.Imali su serije "SE", "Pro" i "XT" (mozda mi je neka promakla). Vrijeme kada je ATI derao nVidiu malo zesce nego sto je to danas situacija.
Znam da sam nakon te ATI presao na nVidiu i ima sam ih sve do sada kada sam uzeo ovu koju sada imam.
LP
P.S.
Vi gore sto se "svadate" bez veze...ne znam, ali meni pokazuje tocno ovo:
Giga HD5970, 2GB GDDR5, 2xDVI, PCI-E
Cijena 5.275,35 kn.
Nije na skladištu.
Napravljen samo c/p sa stranice na koju ste dali link tj. ovdje:
http://217.14.221.177/StartEU.ashx?_...PEiufAHpxgKsH4
"In the beginning there was 0. And then there was 1. A mind-bending meditation on the transcendent power of digital computation."
Pošteni trgovac: 1, 2, 3, 4, 5...
Zadnje izmijenjeno od: win32. 26.11.2009. u 18:03.
win32 je offline   Reply With Quote
Staro 26.11.2009., 18:03   #1237
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Znam ja šta je ATi imao,nisam se rodio prije 2h,hvala.
Staro 26.11.2009., 18:06   #1238
win32
win32's Avatar
Postovi: 1,517
Nisam to ni rekao, vec samo komentiram cijenu posto znam koliko sam je platio kada je izasla.
Sjecam se jos i recenzije koja je bila u BUG-u te prodaje svoje 9600XT i kupovine ove 9800XT.
LP
Staro 26.11.2009., 18:29   #1239
nino
nino's Avatar
Postovi: 12,599
Evo i mene
http://www.omcomputers.it/index.php?...oducts_id=3299
585 : 1,2 = 487,50€ x 7,3 = 3560kn
Staro 26.11.2009., 18:39   #1240
Herr Flick
Herr Flick's Avatar
Lokacija: ČK
Postovi: 133
Autor nino Pregled postova
To je još i puno.
Evo u Austriji imaš za 475€.
Još ako uzmeš dolje mwst. ispadne 475*0.85(jer ne dobiš puni povrat poreza)= 404€*7,3=2950kn
http://geizhals.at/a483407.html
Samo nažalost ak potvrdiš povrat mwst. na slovenkoj granici, slovenci javljaju našima sve povrate prek 400€ tak da bi se morala platiti carina.
Al i sa plačenom carinom ispada jeftinije nego kod nas.
Herr Flick je offline   Reply With Quote
Staro 27.11.2009., 08:22   #1241
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Staro 27.11.2009., 08:41   #1242
D-I-A-B-L-O
Bannija :D
D-I-A-B-L-O's Avatar
Lokacija: Sisak
Postovi: 1,098
Prestrašno, koliki fanatik moraš biti da ideš davat soma dolara za grafičku koja će za par tjedana pasti na polovicu te cijene....
D-I-A-B-L-O je offline   Reply With Quote
Staro 27.11.2009., 08:41   #1243
Postovi: 33,924
Što je najgore, mogla bi se naći neka budala koja će ju kupiti po toj cijeni.
Staro 27.11.2009., 08:46   #1244
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
sta su ti entuzijasti, ha
Staro 03.12.2009., 12:53   #1245
win32
win32's Avatar
Postovi: 1,517
Ista situacija kada je izasla 8800GT pa je bila ona nestasica grafickih te ih ekipa pograbila po trgovinama i onda tu i na newsima prodavala po vecoj cijeni.....i koliko se sjecam ljudi se kupovali!
Svaka roba ima svoga kupca.....
Staro 03.12.2009., 15:01   #1246
Herr Flick
Herr Flick's Avatar
Lokacija: ČK
Postovi: 133
Evo, izasla HD5670
www.techpowerup.com
Staro 06.12.2009., 01:30   #1247
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
nzm jeste vidjeli no imate beta drivere za W7 (ima i za xp), neki kazu da je posebno za CF-ovce no opet neki kazu da imaju malo vece i bolje performanse...9.12b
vista/W7
xp x86/x64
izvor:guru3d
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
Staro 06.12.2009., 14:59   #1248
Liquid Snake
Liquid Snake's Avatar
Postovi: 166
Ti navodni 9.12 beta driveri za win7/vista su zapravo malo drugačiji 9.10 driveri.
Liquid Snake je offline   Reply With Quote
Staro 12.12.2009., 14:04   #1249
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Sapphire Solves Eyefinity Issue
til now anyone wishing to use a 3rd display in Eyefinity mode on ATI 5000 series graphics cards had to use a DisplayPort screen. This was seen to be quite restrictive by end users as they essentially had to buy a new monitor but Sapphire has come to the rescue.
Now users can take advantage of resolutions up to 7680x1600 over 3 DVI enabled screens by installing the DisplayPort to DVI adapter which is an active powered device (USB power).
It will be interesting to see if Sapphire begin bundling this with their high end hardware in the future.
http://www.driverheaven.net/news.php?newsid=485
Staro 13.12.2009., 03:09   #1250
2 die 4
2 die 4's Avatar
Postovi: 2,240
ovo bi moglo biti vrlo interesantno, samo koja će biti cijena?????
RedGreenBlue
Staro 13.12.2009., 23:17   #1251
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 13.12.2009., 23:26   #1252
Wolverine
Wolverine's Avatar
Postovi: 12,425
Autor fre@k Pregled postova
Da samo kaj je pitanje dal prek toga šljaka Ajfiniti
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 14.12.2009., 00:25   #1253
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
a zas nebi sljako ak more pustiti sliku preko adaptera moro bi sljakat ili...
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 14.12.2009., 01:24   #1254
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Treći monitor može ići isključivo preko DP-a i u tom slučaju mora bit na njemu konverter DP to DVI signala, jer inače ništ od toga. Ako ga samo spojite na DP (na monitor koji ima DP), prepoznat će ga, ali ga nećete moći forsirati kao trećeg monitora.
Matth€w je offline   Reply With Quote
Staro 15.12.2009., 22:10   #1255
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Guide: How to build your own little Satan
http://www.hwbox.gr/gpu-vmods/7256-5...ods-guide.html
C L O W N I N G A R O U N D
Staro 15.12.2009., 22:16   #1256
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
Bolje receno kak sjebat karticu od 4 kile kuna ( ovak nije dovoljno jaka) ?
Doink the clown , nist osobno samo link komentiram
Staro 15.12.2009., 22:20   #1257
maX
maX's Avatar
Postovi: 7,326
A čuj, kome treba...
http://forum.pcekspert.com/showthread.php?t=169476
Široko mu polje...
Staro 15.12.2009., 22:27   #1258
Wolverine
Wolverine's Avatar
Postovi: 12,425
Autor xulos Pregled postova
Ha kaj, spalit će je ko šibicu i mirna Bosna. Bu tata qpil drugu
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 15.12.2009., 22:29   #1259
Jelc
Super Moderators
Postovi: 17,485
A ak ne uvjek se može malo raspisat na Garancije, povrat novca, zamjena robe... threadu
Staro 15.12.2009., 22:31   #1260
Wolverine
Wolverine's Avatar
Postovi: 12,425
Drito
kikić: Ali ne, jednostavno je slika nestala. Ko na prekidač. Ja zaista ne znam što se to desilo.
lik: A ovi ostaci tinola, razvaljena lemna mjesta i fleke po kartici?
kikić: Ma zbilja ne znam, to ja kupio takvo
Autor maX Pregled postova
Široko mu polje...
Ma treba brate, dašta da treba. Treba da se klokuje to, pošteno to da se raazguzi. Moraš to da moduješ, tada imaš da osvojiš prvo mesto, garantovano. Onda lepo ako pobediš ima da odeš u srbiju da se natječeš sa svetski priznatim overklokerima. Da predstavljaš svoju naciju. Jel tako drug Jelc?
To je veoma velik uspeh za tebe i tvoju zajednicu. Če tada ceo svet da zna tvoje ime. Ima da budeš belosvetski priznat overkloker.
Nije to mala stvar. Jel tako drug Jelc?
Autor Jelc Pregled postova
Nebumo više u OT
Ma šta drug Jelc. Tek smo počeli. Ima da razguzimo ovaj thred
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Zadnje izmijenjeno od: Wolverine. 15.12.2009. u 22:42.
