Staro 20.11.2009., 18:26   #2701
Srdan
Srdan's Avatar
Postovi: 1,212
Ne mislim nikada dati 10k po komponenti i slicno (osim ako dobijem na lotu), onda bez frke radim to?
Rekao bi ni iznad 5 ali opet lako se dogodi da nes polovno za male novce uleti pa...
Jel' ima šta ženskih starih
što vole strance da
nas vozaju u autu
i kupuju skupe lance
Srdan je offline   Reply With Quote
Staro 21.11.2009., 03:37   #2702
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor Srdan Pregled postova
Pa tako ja nebi dao 12k kn za stakleni stol ali je susjed svejedno dao
btw da ne idem bas skroz u OT kabel napreduje lagano...nemam bas puno vremena pa ne stignem...sad sam na 30-35cm
btw ovaj rack/stalak za tv je mrak,a opce cijena nije napuhana
http://www.ekran-avc.hr/p502/norston...duct_info.html
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 21.11.2009., 15:14   #2703
fanATIk
fanATIk's Avatar
Lokacija: Maksimir / Dugave
Postovi: 4,023
Yep, baš je krasan, samo je mali...
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
Staro 21.11.2009., 18:26   #2704
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Zanimaju me vasa misljenja o doticnim integriranim pojacalima.
1) Rotel RA-01
2) Rotel RA-02
Kolika je razlika medju njima, koliko okvirno vrijede.
Naime, dobio sam ponudu da mijenjam Logitech Z-5500 za jedno od tih pojacala. Ukoliko bi se radilo o Rotel RA-01, bila bi i mala doplata u pitanju, od strane tog lika.
Zanima me jos jedna stvar. S jednim od tih pojacala upario bih bookshelf zvucnike tipa Wharfedale Diamond 9.3, 9.2 ili neke druge u tome cjenovnom rangu. Kako bi se to pojacalo nosilo s njima?
Hvala vam unaprijed
Flikoman je offline   Reply With Quote
Staro 21.11.2009., 18:42   #2705
John_Doe
John_Doe's Avatar
Postovi: 275
Autor syss Pregled postova
http://www.audiofil.net/oglasnik/vie...50155994351348
http://www.audiofil.net/oglasnik/vie...02751402061125
možda malo svijetlija varijanta, za tamniju traži nad kao amp.
ne treba ti woofer uz ovu kombu, meni osobno super zvuče ovi brončani monitori i vrlo vjerovatno da sebi nekaj slažem bi potražio nekog nada jer inače volim tamnije sisteme.
Kupio sam jučer Bronze B5, zvučnici su mi predobri.
Sad slušam Queen i sređujem sobu, perverzija kako detaljan zvuk daju.
Slike novog pojačala i zvučnika sutra kada sredim sobu do kraja i stavim novi stol za komp.
Bez linkova u sigu
John_Doe je offline   Reply With Quote
Staro 21.11.2009., 23:28   #2706
gamer
dark seraphim
gamer's Avatar
Postovi: 777
Pozz!
Trebam preporuku nekog ok suba za mjuzu/HT/gaming tj. sve.
Soba trenutno 16m2, u buducnosti ce se koristiti u vecoj, 25+m2.
Max cijena cca 4000kn.
Najvise mi se u ponudi ducana do 4kkn(gotovina) svida Jamo 650(30cm woofer,naspram deklarirane snage pristojna potrosnja struje,ide do 24Hz(kao),kompresiona kutija), pa ako ga netko ima, bio bih zahvalan za pokoju informaciju.
Hvala.
gamer je offline   Reply With Quote
Staro 21.11.2009., 23:45   #2707
tech
Postovi: 1,687
Mene je ovo čudo iznenadilo, je da je ružan ko noć ali...
http://www.anthonygallo.co.uk/pages/...oofers-tr1.php
U sonusartu je oko 3k-3.5k kn.
Staro 22.11.2009., 02:05   #2708
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor fanATIk Pregled postova
vjerovatno bi jos koja polica predstavljala problem stabilnosti...
Ono obozavam bilo sto crno-zelene kombinacije tako da mi je ovo jako interesantno jedino sto bih i ja htio da je malo vise polica i mozda krace malo
Logitech MX500
DELL 2007FP
Abit AV8
Staro 22.11.2009., 13:32   #2709
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Autor Flikoman Pregled postova
1) Rotel RA-01
2) Rotel RA-02
Hvala vam unaprijed
Nitko?
Staro 22.11.2009., 13:47   #2710
tech
Postovi: 1,687
Go for it, IMO odi na RA02.Plus, bili su na oglasniku neki bowersi nedavno, bowers+rotel je fina kombinacija i još dobiješ "imam bowerse efekt"
Staro 22.11.2009., 13:59   #2711
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Autor tech Pregled postova
Gledao sam i Monitor Audio Bronze BR2, 1699kn u TehnoMaxu. Bowersi su na njuskalu 2200kn, to mi je trenutno malo previse. Diamondi 9.3 su bili u oglasniku za 1500kn, al su ocito osli, nema vise oglasa.
Takodjer, dal je imao netko iskustva sa Mission 701 zvucnicima? Sa stalcima 1000kn.
Jos netko u vezi ovih pojacala?
Staro 22.11.2009., 14:42   #2712
Juan
Juan's Avatar
Postovi: 295
Evo malo hvalisanja, gotova i moja prva samogradnja prema nekom projektu. Pored je prva samogradnja uopće, na kojoj sam naučio furnirati i koristiti se frezom.
Visaton VIB 130 TL.
Finiš, premda je zamišljen visoki sjaj, nisam mogao ne probati savjet koji su mi dali dečki iz chromosa o pravilnom nanošenju boje na alternativne načine (posao me sasvim slučajno odveo tamo). I tako i bi, ima sjaja dovoljno, a opet se prašina ne vidi toliko.
Sve je doslovno po nacrtu, i nigdje se nije odstupalo, osim što je mdf 18 mm a ne 19, jer ga kod nas nema, te su korišteni malo kvalitetniji elementi u skretnici, točnije MKP kondenzatori.
Juan je offline   Reply With Quote
Staro 22.11.2009., 14:58   #2713
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
svakako kao sto je i kolega preporucio Rotel RA2 ide i moj glas, a za zvucnike eto mogu preporucit Jamo E660, meni osobno missioni ne leže
gbijelic je offline   Reply With Quote
Staro 22.11.2009., 15:02   #2714
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Autor gbijelic Pregled postova
Ciljao sam na bookshelf zvucnike.
Eto, jos jedno tehnicko pitanje. Gledajuci prema ebayu taj rotel, prema otkupnoj cijeni, ako zanemarim aukcije, dojde izmedju 350 - 400 eura.
Sad si postavljam pitanje gdi je tipu tu isplativost takve zamjene. Ne bih htio dobit neko reparirano pojacalo, poluispravno itd. Naime, radi se o clanu Imagine, vi cete sigurno bolje znati. Cini se kao jako pristojna osoba, prema tome koliko smo dosada komunicirali prema maila.
Staro 22.11.2009., 15:15   #2715
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,778
taj rotel se prodaje po 1500-2000kn ovisno o starosti (barem su bile takve cijene dok sam ja pregledavao oglasnike), ovo po ebayu pretpostavljam da su cijene novih.
Staro 22.11.2009., 15:16   #2716
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
za zvučnike imas u njuskalu Dali lektor 1, a sto se pojačala tiče to bi trebala biti ta cijena po kojoj se i Logitech sistem prodaje
Staro 22.11.2009., 15:17   #2717
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Puno hvala na pomoci
Staro 22.11.2009., 15:24   #2718
tech
Postovi: 1,687
Gle uzmi tog rotela i bok...
Na audiopulsu imaš Bowerse 602S3 za 1800kn.
Staro 22.11.2009., 15:26   #2719
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
A kaj sa kabelima, koji su ti na meti?
Staro 22.11.2009., 15:46   #2720
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Iskreno. nemam pojma. Vidio sam u TehnoMaxu, 3.5mm na činče za 120kn, to bi mi bilo za AUX.
A za zvucnike, iskreno, ne znam sto bih uzeo. Nemam niti nesto previse novaca za bacanje, tako da, dobro bi mi dosli vasi prijedlozi.
Ima susjed dosta tih kablova, poprilicno debelih, vjerojatno i duplo nego sto ima moj Z5500, pa sam isprva mislio to iskoristit, samo ne znam kakvi bi mi konektori trebali s koje strane.
Dok sam testirao ono Technics pojacalo, dovoljno je bilo kablove polemit s tinolom sa svake strane, no ne znam dal rotel ima jednake konektore iza.
Nadam se da sam bio jasan.
Staro 22.11.2009., 15:51   #2721
tech
Postovi: 1,687
Ukratko-nisi...
Kaj bi ti lemio po terminalima?Vulgaris sfrkanu žicu u terminal i zategni, možeš i terminirati sa vilicama/bananama, estetika..
Ja sam si uzeo ove i sasvim sam zadovoljan... http://www.provox.hr/audio/proizvod....a=101&Source=1
Staro 22.11.2009., 16:41   #2722
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Ukratko-nisi...
Hvala ti
Staro 22.11.2009., 16:55   #2723
srale7
srale7's Avatar
Postovi: 5,805
Autor Juan Pregled postova
Visaton VIB 130 TL.
Ček, pa jel ti nisi radio vec neku samogradnju? Bookshelf sa ovim Monacor sph-165kep driverom?
Staro 22.11.2009., 19:50   #2724
Don
je gladan!
Don's Avatar
Postovi: 1,698
Visaton VIB 130 TL.
Jel može slika izbliza da se vide rubovi
Don je offline   Reply With Quote
Staro 22.11.2009., 19:51   #2725
Roso
Roso's Avatar
Postovi: 698
Svaka čast Juan, odlično izgleda! Je li imaš kakvu sliku unutrašnjosti i općenito nešto malo izbliže. Ni prošle samogradnje nisi ozbiljnije prikaza.
Autor srale7 Pregled postova
Iz Juanove izjave
bi se dalo zaključiti da ih je napravio minimalno 3
Roso je offline   Reply With Quote
Staro 22.11.2009., 21:33   #2726
Juan
Juan's Avatar
Postovi: 295
Jesam, i to je u biti ta kombinacija, osim što je skretnica prilagođena ovoj kutiji jer nikako nisam bio zadovoljan furnirom, pa sam ovako ujedno i riješio
"stalak" samo produživanjem (unutarnji volumen je jednak).
Autor Don Pregled postova
Možda kasnije, jer sam prelijen sad namještat fotić i čekat da se napune baterije. Ali znam što te zanima i ne, ne vidi se gdjegod sam si dao truda, a to su prednje i bočne stranice, te gornja.
Spojevi su dosta zaje**ni jer koliko god mjera bila idealna, uvijek ostaje ona debljina sloja ljepila, koja premda je izražena u desetinkama milimetra, opet se vidi.
Rješenje: ako je ljepilo na vodenoj bazi, i kit mora biti na vodenoj bazi, a isto tako i boja koju naknadno koristiš.
Prvo kitanje, šlajfanje, drugo kitanje, šlajfanje, treće kitanje sam izveo tako da sam kit na vodenoj bazi razrjedio sa bojom na vodenoj bazi.
Problem lakiranja tih rubova leži u tome što otapalo iz uljanih boja jednostavno digne kit, ili "pojede".
Daljnji postupak znaš
Evo primjer jednih kutija koje sam radio ljetos jednom kolegi, prednja ploča je obgrljena sa bočnim i gronjim/donjim stranicama. Tu sam stvarno zadovoljan kako sam upustio visoki, dok je kod misbassa malo nož pobjegao jer se ipak radi o većem promjeru.
Autor Roso Pregled postova
Iz Juanove izjave
Hvala
Nisam ih prikazivao jer kad sam prvi put okačio post sa 4-5 sličica veličine 400*300 i "težine" 40-50kb bile su obrisane jer nisu u thumbnailu....pošto mi se ne da zaje*** s tim, niti kršiti pravila foruma, dalje niti nisam.
BTW: http://www.pentatron.cz/katalogove_l...b130tl_tz1.gif
edit: uz najbolji trud, ali slike ne mogu bolje jer je fotić koma
Zadnje izmijenjeno od: Juan. 22.11.2009. u 21:55.
Staro 22.11.2009., 21:43   #2727
Don
je gladan!
Don's Avatar
Postovi: 1,698
Cijena, ako nije tajna cijelog uratka?
Skretnica, koje si elemente koristio, jel imaš shemu?
Lijepo, stvarno lijepo.
Valjda i svira kako izgleda.
Staro 22.11.2009., 22:01   #2728
Juan
Juan's Avatar
Postovi: 295
Nije tajna, nešto iznad 3000 kn.
Ponavljam, držao sam se slijepo visatonovog projekta VIB 130 TL:
http://www.visaton.com/en/bauvorschl..._tl/index.html
A svira...
Staro 23.11.2009., 02:06   #2729
srale7
srale7's Avatar
Postovi: 5,805
Ajmo Juan, neke bolje i preglednije slike i daj ostavi se tog imagshacka i predji na imagesforme..
Staro 23.11.2009., 02:22   #2730
tech
Postovi: 1,687
Zna li netko išta o Indiana Line zvučnicima?Konretno HC i Tesi series...
