Staro 15.11.2009., 21:32   #331
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Evo malo o i9-ki, a i Intel će se malo pozabaviti rebrandingom (čitaj - i3)
http://www.techpowerup.com/97604/Det...d_Core_i9.html
A evo i jedne zgodne tablice
C L O W N I N G A R O U N D
Staro 15.11.2009., 22:10   #332
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Još Intel ima lufta za nove modele i popunjavanje rupa, ovi parni projevi su ostali slobodni, i4, i6, i8.
Matth€w je offline   Reply With Quote
Staro 15.11.2009., 23:44   #333
Dottore
Dottore's Avatar
Postovi: 7,736
Autor Halos Pregled postova
Samo nek štancaju, meni ce za 600kn Q6600 bit uber entuziast(ionak je vec sad "star" i "slab")
Đe to vidiš? ako ima kupujem ja odmah
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 16.11.2009., 00:01   #334
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Autor Dottore Pregled postova
I ja isto, cuj, to ocekujem, jer se neskidaju sa 1000-1200 kn vec skoro dvije godine. A sad i5 i i7 svi koji prelaze idu na takve konfe. Logično je da q6600 bude vise dolazio na tržnice, mada bude bilo grabanje
Staro 16.11.2009., 11:54   #335
Wolverine
Wolverine's Avatar
Postovi: 12,433
Autor IcyTexx Pregled postova
Odlicno, s1366!
Necu trebat dugo mijenjat plocu.
Isti socket kao za i7? Ima neka lista čekanja? Where do I sign up?
Vama baš treba 12 logičkih jezgri ili je to samo za naterat veći skor u 3DČmark06
btw ako je samo 10% brži onda je to pušiona no opet, prije bi rekao da je to neki overall postotak jer mislim da će u aplikacijama koje vide i mogu iskoristit 6 jezgri odnosno 12 logičkih imat puno veći postotak
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 16.11.2009., 12:01   #336
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Nisam koristio novije revizije Premiere-a, aj ak netko zna jel ove nove revizije doticnog programa koriste sve 4 jezgre ili jos uvijek samo 2?
Staro 16.11.2009., 13:38   #337
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,724
Bolje da su napravili quad channel i DDR4 ili DDR5 RAM memu.
Bilo bi više koristi nego ovako ubirat pare ko od šale...
Pa što se mene tiče neg i mijenjaju socket ponovo...
MMA
Staro 16.11.2009., 15:02   #338
lit
Lokacija: hr
Postovi: 977
10% je sigurno dijelom što primjerak radi na 2.4 Ghz a i to šta kažeš nema tu još pravih aplikacija koje će koristiti sve njegove jezgre...
Ustvari teško da će i iduće godine išta novo izaći da bude baš za takav procesor osim benchmarkova...
Mislim i danas svi najnoviji programi recimo Adobe-ovi nisu u potpunosti iskoristili 4 jezgre, iduće godine kad počnu izlazit nove verzije programa za windows7 e to bi trebalo biti potpuno iskorištenje 4-jezgrenih procesora. A 6 i više teško da će itko od nas to moći iskoristiti osim ako neke posebne aplikacije neće biti napravljene za taj proc. A te posebne će koristit ljudi na unikatnim projektima sigurno ne za široku publiku...
Ali opet stvarno mi je čudno da nisu sa novim i9 krenuli sa ddr3 1600mhz kao standardna podrška...
lit je offline   Reply With Quote
Staro 16.11.2009., 16:44   #339
Wolverine
Wolverine's Avatar
Postovi: 12,433
Autor lit Pregled postova
Ooo postoje aplikacije koje mogu iskoristit pun potencijal 8 ili 16 pravih jezgri
Hint
Cinema4D - do 16 jezgri zasad (NET rendering preko 100 clustera sa po 16 jezgri)
Lightwawe - do 16 jezgri
Artlantis 2 - do 8 jezgri Artlantis 3 će možda biti do 16
ArchiCAD 12 - do 8 jezgri
a ima toga još
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 16.11.2009., 16:54   #340
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Sto bi rekli po seljacki da ovi nasi forumski useri sa cetverojezgrasima trajbaju struju - bezveze
Staro 16.11.2009., 16:56   #341
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,369
Kolega, davno je to bilo, LW od verzije 9.2 korisit jezgri koliko god imas posto postoji "automatic" mode koji ubere SVE sto imas, vidio sam kako radi na 32 jezgre prije 2,5 godine .
Sto se tice 10-20% to je bila usporedba i9 na 2.4GHz vs i7965 na 3.2GHz po defaultu tako da bi na istom taktu dao sigurno 30-35% brze rezultate ako ne i vise. Ne bojim se ja da je spor i neisplativ .
Meni sad i7920 na 3.8GHz neke scene renda 2-3x brze od Q6600 na 3.33 Ghz (27min/frame vs 8min/frame) tako da ce i9 sjest ko KEC na DESETKU .
Staro 16.11.2009., 16:57   #342
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Autor Dizel Pregled postova
ma kakvi, svi nesta renderiraju
Staro 16.11.2009., 17:01   #343
Wolverine
Wolverine's Avatar
Postovi: 12,433
Autor Lewis Pregled postova
Evo, još bolje...
Ma ima aplikacija koje fakat požderu sve kaj im daš...crna rupa za resurse
Ma nisam ja ni mislio da je on spor
Velim da je tih 10% razlike srednja vrijednost kad se uzmu u obzir svi testovi koje su provodili a i kako već piše to je na njegovom default radnom taktu, odnosno koliko mu već Turbo Boost daje viši takt obzirom na opterećenje.
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 18.11.2009., 10:56   #344
Constantine
Constantine's Avatar
Postovi: 668
Jel mmoguće da ce se sa vremenom pojavit verzija core i9 procesora za 1156,kao sto sad postoje i7 procesori za isti socket?
Constantine je offline   Reply With Quote
Staro 18.11.2009., 11:05   #345
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,369
Autor Constantine Pregled postova
Nebi rekao jer pise u onoj tablici da ce i9 biti samo 1366 i vjerojatno ce ipak ostati samo "high end". Vjerojanto mu treba x58 chipset/propusnost/QPI/triple channel i slicne stvari da bi radio punim plucima .
Staro 18.11.2009., 11:21   #346
Wolverine
Wolverine's Avatar
Postovi: 12,433
A zašto bi išli enthusiast level procesor nudit na ajmo reći mainstream platformi? Sami bi sebi radili konkurenciju kao što su to napravili sa recimo i7 800 / i7 900
Ovako imaš fino definirane stupnjeve
Low-End -> i3 (LGA775) ; 1-4 jezgre, DC
Mainstream -> i5/i7 (LGA1156) ; 4 jezgre, bez/saHT-om, TB, DC
High-End -> i7 (LGA1366) ; 4 jezgre, HT, TB, TC
Enth -> i9 (LGA1366) ; 6 jezgri, HT, TB, TC
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 18.11.2009., 11:40   #347
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Zakon je sto u danasnje doba sve zivo i mrtvo radi i sa /sto to inetl voli prikazati/ low end komponentama, nekad si se sa low endom mogao samo slikati, ni u ludilu pokrenuti koju igru.
Staro 18.11.2009., 11:44   #348
Wolverine
Wolverine's Avatar
Postovi: 12,433
Pa dobro sa jednojezgrenim keljom sve više od slušanja muzike, surfanja i gledanja divxa je koma no sad sam u principu naveo 50% korisnika
No činjenica je da već sa E1500 možeš dosta toga.
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 18.11.2009., 13:51   #349
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,862
Živo me zanima kako će ispast ovo sa i3... Cijene bi prema svemu sudeći trebale biti manje od i5/7.
Kako će se primjerice četverojezgreni i3 nositi sa q6600 ili ekvivalentnim?
Arhitektura i3 će biti u suštini ista 65/45nm derivatima ili će biti sličnija i5/7?
Spoiler alert!
Staro 18.11.2009., 13:54   #350
Wolverine
Wolverine's Avatar
Postovi: 12,433
Reci mi da se zezaš
Pa Intel Core i3 je samo rebrandani Core2Duo/Core2Quad baziran na Wolfdale/Yorkfield jezgri
Pogledaj tablicu malo bolje
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 18.11.2009., 21:21   #351
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,862
Reci mi da se zezaš
E jebiga previdio sam post od klauna, nisam se zezo.
Hvala anyways
Dakle isti drek, očito će dugo biti u modi q6600
Spoiler alert!
Staro 18.11.2009., 21:25   #352
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Najdulje ce u modi biti ovakvi E1XXX kakvog i sam imam
Radi sve sto vole mladi i jos malo vise
Staro 19.11.2009., 00:36   #353
DomagojX
Lokacija: Zagreb/Sesvete
Postovi: 1,307
mi može neko reći jer ovo D0
DomagojX je offline   Reply With Quote
Staro 19.11.2009., 00:43   #354
dejanbinladen
konjpjukter
Postovi: 934
Autor domagojx Pregled postova
mi može neko reći jer ovo d0
slbej - d0
dejanbinladen je offline   Reply With Quote
Staro 23.11.2009., 14:18   #355
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Intel Core i9 (Gulftown) - 6 cores, 32 nm: hands-on review; PcLab.pl
Staro 23.11.2009., 14:39   #356
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,369
Autor Matth€w Pregled postova
Damn, naprave opsiran test na 11 stranica i ne istestiraju ono u cemu je naveca prednost vise jezgri - Rendering .
Staro 14.12.2009., 22:54   #357
palminjo
Lokacija: Rijeka, Croatia
Postovi: 60
Gulftown i7
palminjo je offline   Reply With Quote
Staro 15.12.2009., 10:13   #358
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Core i7 980X is hexacore
'Intel is all set to release a processor with Six cores as early as March 2010 already, yes that might be during CeBIT then. And yes you heard me right...six cores and thus 12 threads.
What we originally expected to be named a Core i9 processor is going to be called a Core i7 980X with the X for Extreme (and thus unlocked). The six core or hexacore processor goes by the codename "Gulftown". The Core i7 980X will be compatible with X58 chipset based motherboards which will require only a BIOS update. Gulftown supports 1066MHz DDR3 memory and has a TDP of 130W.
The processor operates at a frequency of 3.06 GHz (according to the latest rumor) and features a massive 12MB L3 cache. Again, Gulftown will be socket 1366 compatible and work with all X58 motherboards after a BIOS upgrade.'
Izvor: guru3d
Staro 15.12.2009., 13:27   #359
lit
Lokacija: hr
Postovi: 977
http://www.fudzilla.com/content/view/16828/1/
Izgleda da nema ništa od i9 skoro... izbacuju samo novu extreme verziju i7-980X sa 6 jezgri.
Staro 16.12.2009., 16:22   #360
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Intel launches 13 six-core Xeon CPUs on March 16 2010
'Intel is planning to release 13 dual-socket, 32nm Xeon processors with six cores on March 16th, 2010. The flagship is a six-core, 12-thread Xeon X5680 processor. The chip has a frequency of 3.33GHz, 12MB cache, Intel Turbo Boost, Hyperthreading and a 130W TDP.
In addition to the Xeon X5680, the March 16 release list includes five more six-core chips, all with 12 threads and 12MB of cache -- the Xeon X5670 (2.93GHz, 95W), X5660 (2.80GHz, 95W), X5650 (2.66GHz, 95W), L5640 (2.26GHz, 60W) and W3680 (3.33GHz, 130W).
Seven 32nm, quad-core processors are also listed, all with 12MB of cache -- the Xeon X5677 (3.46GHz, 130W), X5667 (3.06GHz, 95W), E5640 (2.66GHz, 80W), E5630 (2.53Hz, 80W), E5620 (2.40GHz, 80W), L5630 (2.13GHz, 40W), L5609 (1.86GHz, 40W). All of those chips, with the exception of the Xeon L5609, have eight threads, Hyperthreading and Turbo Boost. Three additional 45nm processors are also scheduled for release on the same date, this includes the quad-core Xeon E5507 (2.26GHz, 80W, 4MB cache), dual-core E5503 (2.00GHz, 80W, 4MB cache) and quad-core, eight-thread W3530 (2.80GHz, 130W, 8MB cache). '
Izvor: guru3d
