Staro 20.09.2009., 15:59   #1
fico007
Postovi: 260
"Dubinski" format diska
Nabavio sam polovni hard diski napravio običan format. Međutim kada idem s data recovery opet nađe neke gluposti koje su prije bile gore. Kojim programom napraviti neki "dubinski" format tako da se podaci koji su bili do tada više ne mogu išćitati programima za data recovery? Na tom disku nema operativnog sustava već će služiti samo za pohranu podataka.
Ako je post na krivnom mjestu, ispričavam se, premjestite ga.
fico007 je offline   Reply With Quote
Staro 20.09.2009., 16:08   #2
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
imaš alate koji više puta pređu cijeli disk za raznim patternima podataka i onda ga formatiraš pa imaš 'čist' disk.
vidio sam to na acronis cd-u, hiren's toolsima itd.
sko nemaš te alate, probaj npr s ovim, trebalo bi raditi:
http://www.giveawayoftheday.com/soft/708075/
uses the industry-accepted government and military strength algorithms to ensure complete data wiping
and assure you of the utmost security of your sensitive, personal or confidential data.
The program works with all standard hard drives and floppy disks and operates independently
of the operating system or any data that may exist on the target disk.
Best of all, it is quick, easy-to-use, and compatible with any PC independent
of the operating system on the
target disk.
Once a disk has been erased with AEVITA Erase Hard Drive, no data recovery tools,
regardless of their level of sophistication, will be able
to recover any data that previously existed on the disk.
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 20.09.2009., 17:06   #3
domy_os
domy_os's Avatar
Postovi: 18,969
Svaki proizvođač ima svoj alat za zero fill formatiranje pa potraži, skini, snimi na CD/DVD/disketu/stick, bootaj komp s toga i formatiraj.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 20.09.2009., 21:24   #4
khm
Lokacija: Slavonija
Postovi: 1,200
Ja to radim s ovim >>
http://www.killdisk.com/
khm je offline   Reply With Quote
Staro 20.09.2009., 21:43   #5
Delta S4
She`s back...
Postovi: 983
Autor khm Pregled postova
Ovo se čini kao interesantan programčić. Koliko je to pouzdano? Jer koliko čujem, jedina 100% metoda je fizičko uništenje diska A onda opet, banke često poklanjaju svoje stare kompove na diskovima kojih sigurno ima povjerljivih podataka, što znači da su prilično sigurni da se to više ne može recoverati. Malo sam zbunjen
Delta S4 je offline   Reply With Quote
Staro 20.09.2009., 21:58   #6
domy_os
domy_os's Avatar
Postovi: 18,969
Mi iz određenih firmi dobivamo PC-e bez diskova, a kad se neki od njih pokvari u jamstvenom roku, neće ga reklamirati nego kupuju novi.
Staro 21.09.2009., 00:47   #7
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Autor Delta S4 Pregled postova
Bez brige, ovo sto banke poklone nema bitnih podataka na sebi.
S druge strane, postoje i postupci kojima se podaci prakticno ucine nedostupnima, nije mljevenje diskova jedini nacin. Moze i softverski, magnetizacijom i slicno.
Igor Batinic
Staro 27.09.2009., 19:40   #8
Dome
Dome's Avatar
Lokacija: Trogir
Postovi: 25
http://hddguru.com/content/en/softwa...l-Format-Tool/
ja koristim ovaj program i zadovoljan sam.
Dome je offline   Reply With Quote
Staro 28.09.2009., 11:04   #9
fico007
Postovi: 260
Autor Dome Pregled postova
Hvala svima!
Koliko otprilike traje takav format (u mom slučaju se radi o 250 GB externom 2,5' hardu koji je spojen preko USB-a)?
Staro 30.09.2009., 11:28   #10
Dejmos
Dejmos's Avatar
Postovi: 116
Autor fico007 Pregled postova
Hvala svima!
Otprilike 4-5 sati , možda i više preko USB-a. Ovisno o metodi ubijanja podataka. Ja to radim sa Disk Wipe toolom na Winternalsima. Postoji i Level 4 koji navodno koristi američka vlada i ministarstvo obrane. To traje cijeli dan.
Dejmos je offline   Reply With Quote
Staro 08.10.2009., 16:29   #11
tocka
Postovi: 175
a kaj takvo imaš na kompu da bi se neko toliko namucio da dođe do tih podataka?
tocka je offline   Reply With Quote
Staro 13.10.2009., 13:35   #12
fico007
Postovi: 260
Autor tocka Pregled postova
To je USB disk, dakle nema veze s kompjuterom. Koristit ću ga za posao. Nije mi se jednom desilo da sam morao neke podatke spašavati a ono recovery program izvuče svega i svašta, pa se ti snađi. Da li ti se ikad desilo da nešto radiš nekoliko mjeseci i onda izgubiš podatke? Pa eto meni je, pa sad pušem i na hladno. Obzirom da je disk bio polovan, lijepo sam izbrisao podatke s low level formatom pa ako se i desi da ću morati raditi data recovery naći ću samo ono što trebam, a ne hrpu nečijih stvari (gluposti). Vjeruj, isplati se izgubiti malo više vremena na takav format diska.
Nadam se da si zadovoljan objašnjenjem.
Staro 15.10.2009., 01:00   #13
zoki1
Postovi: 23
Ovo je dobro, ima neke logike. Preventivna priprema diska za slučaj gubitka podataka :-)
zoki1 je offline   Reply With Quote
Staro 17.10.2009., 01:17   #14
victory
Postovi: 25
Koja ideja, ludoooo
victory je offline   Reply With Quote
