#691 |
Postovi: 7,568
Dobro, ja samo pitam. Pošto ti ploča podržava ove quad procesore koje sam spomenul, a da su kaj lošiji od Q9400 - baš i nisu.![]() |
#692 |
Xulos :)
Postovi: 7,579
Kao sto sam ja napravio sa Dk P45-T2RS i onda se drkario s njom i reklamirao je mjesec dana (3 ploce zamjenio) da bi nakon izlaska novog bios-a ploca proradila kao beba.Nis ne treba odmah kupit kad je novo .Garant ni te ploce nece bit bez bugova , stovise bit ce ih ohohoj i samo ce bit glavobolja korisnicima( kao onaj sa P6T dlx i 12 GB rama) , umjesto da se strpe tam do 1-2 mj a i kasnije,ionda kupe kad to sve bude radilo kak treba.
#693 |
Postovi: 7,568
DFI LanParty DK P55-T3eH9 LGA-1156 ploča
DFI's retail-grade pack of motherboards for socket LGA-1156 platform will be lead by the LanParty Dark P55-T3eH9. Dressed in black and orange, the P55-T3eH9 sports a fairly standard feature-set for the Intel P55 chipset. The CPU socket is powered by a 6+2 phase VRM, and is wired to four DDR3 DIMM slots for dual-channel memory. Expansion slots include three PCI-Express x16, depending on what's under the heatsink south of the CPU socket, the orange slots could be (dual x16 or x8). The black slot looks like PCI-E x4, wired to the PCH. Two PCI-E x1 and PCI slots make for the rest of the expansion. Apart from all the features the P55 PCH provides, including six SATA II ports, an additional controllers add two SATA II, an eSATA and one IDE connector for two devices. Connectivity is care of one gigabit Ethernet controller, and a number of USB ports, including one mini-USB. A high-grade HD audio codec also provides digital audio connectivity through optical and coaxial SPDIF connectors. The LanParty Dark P55-T3eH9 is expected to be priced at 175€. Izvor: techPowerUp |
#695 |
Postovi: 7,568
Pa imaju Blood Iron i DK serije ploča, koje nisu vrh DFI-ove ponude. ![]() Ili ako pitaš općenito, imaš masu ECS, ASRock, Asus, MSI i Gigabyte P55 ploča koje ne budu koštale ko suho zlato. |
#696 |
Xulos :)
Postovi: 7,579
Zasto ova ploca : http://www.techpowerup.com/img/09-08-21/125c.jpg ima 2x 8 pin za procesor ?I jos nesto ova dfi-jevka ima 6 + 2 faznu regulaciju, asusica i55 saber ima 12 + 2 , a asus P7P55D ima digitalnu 32+2 .NIje li onda kod DFI 6+2 ipak premalo na odnosu ove 2 ili DK verzije imaju tako male regulacije (moja bivsa DK P45 je imala 4 faznu ).
#697 |
Postovi: 7,568
Ova DFI je namijenjena srednjem tržišnom segmentu, dok EVGA svoju ploču reklamira i svrstava u čisti high-end namijenjen brutalnom clockanju. Svaka od tih ploča je namijenjena različitim tržišnim segmentima i samim tim imaju bolju ili lošiju "opremu". Osim toga ne bi DFI plasiral tu ploču na tržište, da ploča ne zadovoljava sve potrebne standarde. |
#698 |
Xulos :)
Postovi: 7,579
A zasto ta evga ima 2x 8 EPS na sebi ? i de mi jos nest reci ak nije bed. Koja je svrha dolaska westmere u 32 nm procesu i koje ce on procesore zamjenit ? jel to nova arhitktura ili samo novo kodno ime tipa lynnfield , bloomfield?
#699 |
Agent 0
Lokacija: Kutina - ZG
Postovi: 4,312
Zato što je ploča must have za OC-ere, koji ce davati brutalne napone uz extremna hlađenja i frekvenciju iznad 5 gigi...i onda dolaze do brojki od 350W+ potrošnje procesora...a 8 pinski EPS je ograničen na nekih 300-350W. ![]() Da ne spominjem napajanja sa dva EPS-a, pa bi bio red da ih imaju kuda piknuti. ![]() Zadnje izmijenjeno od: Gilbert5. 25.08.2009. u 15:32. |
#700 | |
Postovi: 7,568
Westmare je kodni naziv za arhitekturu na kojoj budu temeljeni 32nm (manja potrošnja, IGP, nove instrukcije i tak dalje) Clarkdale, Arrandale i Gulftown procesori. Sve budu to i dalje modeli iz Intel Core i9, i7, i5 i i3 serije procesora. Mislim sve to ti piše kaj na ovim stranicama, kaj po netu, a ovo kaj ja radim je ništ više nego prijevod već postojećih materijala. Daj si truda i sam najdi sve kaj te zanima, jer ovo "prevađanje" IMHO nema nekog prevelikog smisla. |
#701 |
Xulos :)
Postovi: 7,579
Ok thx Gilb i McG , nebudem davio vise , iako volim cut iz prve ruke ovak, jer citao sam po wikipediji i sve mi je to onak previse kodnih imena i svega za skontat.
#702 | |
Lokacija: Dubrovnik
Postovi: 2,583
#703 |
Postovi: 7,568
Ma daleko od toga da sam ja ikakav izvor informacija. Moj zayeb za helij, spomenul sam ga samo da skuži za kakve uvjete je EVGA namijenil tu ploču s dva EPS konektora. |
#705 |
Datum registracije: Jul 2009
Postovi: 20
dobar dan....moze li mi neko reci nesto o intelovom procesoru Intel Xeon E5440....? hvala unaprijed....
#706 |
Je suis Schumi
Postovi: 1,524
Di sam stao? -Stalji smo onda kad je *ebem Šćepanović ![]() |
#707 |
Postovi: 7,568
DFI Hybrid P45-ION-T2A2 hibridna LGA-775 ploča
What we got a look at today was a pre-production version of the Hybrid P45-ION-T2A2 motherboard. At first, we didn’t know exactly what to expect, when DFI called and asked us to come and visit and see its "hybrid motherboard". We know the term in modern times from cars and most things green, but when the word is added before motherboard, it really did get us thinking exactly what we should expect and what we would be getting a look at on our visit. It turned out that DFI created a totally unique motherboard design that actually allows for two systems to run shared (KVM style) or fully independent of each other, on the one single board. The left side of the system is built up of the components for the nVidia Ion and Intel Atom platform. This part could be used as a low-power file server or torrent downloading system or even Blu-ray movie playback. And the right side of the board features the parts seen on a traditional P45 + Socket 775 CPU motherboard, which could be used for gaming, video editing or other intensive applications. Izvor: TweakTown Ploča i ideja su lude , ali da nisu mogli najti nekoga ko zna bar donekle razumljiv engleski. Tip je glavni inženjer i još k tome predstavlja novi proizvod, a engleski mu je strani pojam. Kome pukne film, nek rađe sluša nekaj konkretnije (1, 2 ), jer se tip žešće muči s riječima/izgovorom i jednostavno ga je grdo za slušati skoro 10min.![]() |
#708 |
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Pa majko mila, kakav je ovo engleski. Ne znam ni zasto ni kako, ali lik mi je poremetio ritam disanja svojim engleskim jezikom. ![]() Ideja je predobra, bas mi ovako nesto treba u zadnjih par mjeseci. Cijena je li-la, ali prvi put nesto takvo na trzistu pa je opravdano. Jedva cekam prve testove da vidimo kako to sve stvarno funkcionise.
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
#709 |
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 674
Ovo je jedno od fenomenalnijih ideja kaj sam videl u zadnje vrijeme. Evo kak uštediti na struji a i dok ti dođe frend imaš drugi kompjuter na kojem moreš zaigrati dotu .
PCE 100+kg demolition squad |
#710 |
Postovi: 7,703
čini se dobra ideja. ali kako god mislim da su iz normalnu ploču DFI pretvorili u hibridni s malim Juniorom. premalen broj sata ( koliko na filmu vidim 4 priključka ) i jedan PCI ( npr. audigy) koju su preblizu PCI-e grafičke s standarnim velikim hladnjakom. nije da prigovaram lošu ideju ali cijena će biti paprena. koliko vidim 399 usd. izgleda da još nije dovršeno a time i pouzdanost. kad malo razmislim za tu cijenu ipak dobiješ normalnu ploču 900kn i asrock Ion ploču cca 1300kn. više priključka i više prostora a sve spojiš u jedan monitor ( zaboravio sam kako se zove iz dva računala na jedan monitor s tipkovnicem i mišem )
__________________ |
#711 |
Lokacija: VG
Postovi: 1,760
Intel six-core Core i9 photo's 'Thoughy incredibly dull to look at, as they all look the same, the first photo's of a six-core Core i9 processor surfaced over the weekend, this is the Gulftown SKU based on 32nm Intel Some of its features are: Six-core Twelve threads Socket 1366 like 45nm Bloomfield 6×256KB of L2 cache 12MB of L3 cache Support for X58 chipset Turbo Boost technology Integrated three-channel memory controller QPI bus 130 W TDP (not 100% sure about this one though) It is rumored that Gulftown will launch in first half of 2010.' ![]() ![]() Izvor:guru3d |
#714 |
Postovi: 7,568
MSI "Big Bang" LGA-1156 ploča + Lucid Hydra 200
A year ago Lucid announced the Hydra 100: a physical chip that could enable hardware multi-GPU without any pesky SLi/Crossfire software, game profiles or anything like that. At a high level what Lucid's technology does is intercept OpenGL/DirectX commands from the CPU to the GPU and load balance them across any number of GPUs. The final buffers are read back by the Lucid chip and sent to primary GPU for display. The technology sounds flawless. You don't need to worry about game profiles or driver support, you just add more GPUs and they should be perfectly load balanced. Even more impressive is Lucid's claim that you can mix and match GPUs of different performance levels. For example you could put a GeForce GTX 285 and a GeForce 9800 GTX in parallel and the two would be perfectly load balanced by Lucid's hardware; you'd get a real speedup. Eventually, Lucid will also enable multi-GPU configurations from different vendors (e.g. one nVidia GPU + one AMD GPU). At least on paper, Lucid's technology has the potential to completely eliminate all of the multi-GPU silliness we've been dealing with for the past several years. Today, Lucid is announcing the final set of hardware that will be shipping within the next ~30 days. It's called the Hydra 200 and it will first be featured on MSI's Big Bang P55 motherboard. Unlike the Hydra 100 we talked about last year, 200 is built on a 65nm process node instead of 130nm. The architecture is widely improved thanks to much more experience with the chip on Lucid's part. There are three versions of the Hydra 200: the LT22114, the LT22102 and the LT22114. The only difference between the chips are the number of PCIe lanes. The high end product will be launching in October, with the other two versions shipping into mainstream and potentially mobile systems some time later. Izvor: AnandTech |
#715 |
Postovi: 7,703
Zanimljivo. Pošto ploča ima tri PCI-e pa bi mogao ići kao tri monitora ( Triple monitor ). ipak me pomalo podsjeća na Matrox TripleHead2Go
#716 |
Postovi: 34,075
Zgodna fora na istoj ploči imati endiviju i radajnera. Ali mislim da će to biti skupa ploča. Barem u početku.
#718 |
Lokacija: VG
Postovi: 1,760
Intel Gulftown comes with tower HSF 'At IDF Intel showed the processor cooler for its upcoming six-core Gulftown processors. As you can see this is a tower heatsink with four heatpipes, a large PWM fan, and a bolt-thru mounting kit instead of flimsy push-pins. It's unknown if Intel will ship this with all Gulftown processors, or only with the Extreme Edition models. Different from the previous design, the fresh cooler employs tower design with horizontal blowing for enhanced airflow, and it features four copper heatpipes. Als, no irritating Push-pin any more. It installs with screws.' ![]() Izvor:guru3d |
