Datum registracije: Nov 2002
Postovi: 6
Omega Drivers 2.5.76 (4.9)
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
What's New? (2k/XP 2.5.76) * Based on the official Catalyst 4.9 drivers. * Removed ATITool from the package, it had many bugs and disabled a lot of stuff, like DVI support and DDC. If you have it installed, I recommend that you uninstall it before installing this set of drivers. * Re-Enabled Overclocking Anti-Protection, it was missing from last release, sorry. * Modified the ATI CP, now the Omega Drivers will use a built-in, special RadLinker version with the following features: (some new, some old) > Uses NO resources. > Some new settings for both D3D and OGL. > Can set Automatic Per-application profiles for OGL & D3D applications. > Desktop Gamma is working and NOT resetting to default after exiting a game. > Integrated Overclocking. > No need for Gamma Hotkeys anymore since you can now set an individual Gamma value for each game in their profile and done. > This new CP was made in conjunction with ChrisW, maker of Radlinker, as an exclusive feature for the Omega Drivers and we will keep adding features in future releases. * Modified driver installation/uninstall procedure with several new automatic features. * Since RadLinker is now a vital part of the Omega Drivers, it will not be an option to select during setup anymore, it will now automatically look for and uninstall ANY previous version and replace it with the new one. * Now, when uninstalling the Setup tools from the Omega options in the Start Menu, you will also have the option to uninstall the Display drivers in one pass. Known bugs: * Laptop video playback problem still here, see notes. * Hibernation and Standby are not working properly, I'm working on a fix. Important Notes: 1. Mobility users beware, these drivers don't support overlay video acceleration on some chipsets, specially in Sager notebooks with 9600 and 9700 Mobility cards. Other cards may be affected, but I haven't confirmed the bug on them. The last driver set that doesn't have this problem are my 2.5.44 drivers. Sorry for any inconveniences, I'm working on a fix for this matter, but all my tests show that this is an ATI related bug in the drivers and it doesn't have to do with any of the settings on my drivers. 2. CCC will work with the Omega Drivers, but is NOT recommended that you install it, all the functions found in CCC are already included with RadLinker Omega Edition or will be included in a near future as this new CP project develops. 3. The included Radlinker version in these drivers is NOT the one I was planning to release, the intended version will come soon in the form of an update to this set of drivers or in the next set based on the Cat 4.10. Osim na http://www.omegadrivers.net/ može se skinuti i na: http://downloads.driverheaven.net/index4.htm (Najnoviji Omega driveri kao i svi do sada izašli) Driveri malo kasne budući da čovjek živi u Puerto Ricu pa ga je drolja Jeanne ostavila par dana bez struje, a i autor Radlinkera je kasnio sa ispravkama. |
#3 | |
Postovi: 1,606
Super Moderators
Postovi: 17,485
Skinuo preključe, tek sam ih danas isprobao. Sve dela ok ![]() |
#6 | |
Caught Somewhere In Time
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
Lokacija: Ispred kompa
Postovi: 2,004
instalirao sam drivere pred jedno par dana i danas mi je sinulaideja da idem provjeriti di su se pomaknuli sa OGL-om i tako znam da sam prije igral CS-Zero COndition na 1280x1024 sa svime na max i na mapi aztec prilikom padanja kise znalo se pojaviti mala maglica koja je stvarno ubijala grafu. pad FPS je bil negdje na 20 (dalje u igri je sve islo normalno preko 30 Fps-a) (od oka) naravno AA i AF su bili u postpunosti isljucene tako da je to meni bilo katastrofalen performanse no kak sam znal da je GL koma na Aticama nisam mogle nis napraviti. i tako ja danas isporbam na 4.9 takodjer na 1280x1024 isto sve na max i pogledam ja opet mapu i vidim da jednostavno leti. rekoh idem ja na tesku artiljeriju i ja ovak odmah u glavu AF 16x i AA 4X . upalim na istom mjestu i igra i dalje leti prek 30 FPS-a: nuts : tak da preporucam obaveznu nadogradnju. samo da velim da na starijim drivereima AA i AF je bilo jednako samoubojstvu ako su ukljucene pa i na najslabijim postavkama. bas me zanima kaj bude nova verzija dolnjela u vidu porasta performasi GL-a .
Super Moderators
Postovi: 17,485
Driveri kao i uvijek delaju ko vurica, a i ne moraš imati onaj ništkoristi CCC ![]() Probao do sada pet-šest igri-samo klizi ![]() |
Datum registracije: Jul 2003
Postovi: 800
Probaj Richard Burns Rally,ne ide uopce!! ![]()
#10 | |
Postovi: 1,860
hm sad nema smisla pitat te kakave je taj burns?? |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
what the hell?!
idem ja reko skinuti drivere, instaliram, pokrenem advanced settings, kad tamo, skoro pa prazno! nigdje postavki za directx, ni openGL, na za OC kartice! morao sam skidati posebno radlinker da bi dobio te opcije! jeste tako svi ili? ovo je glupo! |
#12 | |
Administrator
Lokacija: Sesvete
Postovi: 15,962
Re: what the hell?!
#13 | |
Super Moderators
Postovi: 17,485
Re: what the hell?!
![]() ![]() ![]() Najčešći problem je ne čitanje "pročitaj me" ![]() Ostatci starih drivera i CP-a. A u pravilu je potrebno samo otići u Start/All Programs/Radeon Omega Drivers/(Re)Install Radeon Omega Drivers... I to ti je to. Ista procedura je i ako imaš problema sa samim driverima. Ja sam prvo sve fino de-instalirao i očistio, sve opcije su tu i dela ko bog. Nisi trebao skidati novi RadLinker, samo lupiš (re)istall i to je sve. E da, svaki put kad delaš re-istal Omege najbolje je koristiti Driver Cleaner Omega Edition kojeg dobiješ sa svakom verzijom drivera i ubuduće neće biti problema. |
#14 | |
Postovi: 800
RBR je zakon i po mom skromnom mišljenju deset puta bolji od colina4!! ![]()
#15 | |
Postovi: 1,860
![]() nego kaj se tvarno dešava s tim drajverima neće se opće pokrenut, smrzava ili kaj? a ak je stvarno taj Burns prava simulacija onda moram si to priskrbit |
#16 |
Postovi: 800
Ma zbloka se kod mjesta kad treba kreirat svoj profil. Burns je po meni prva prava simulacija relija! ![]() ![]()
#17 | |
Lika u mom srcu
Postovi: 9,887
Re: Re: what the hell?!
probat ću ponovno. daj mi točnipostupak kako ti to radiš? |
#18 | |
Postovi: 1,606
Re: Re: Re: what the hell?!
Start/All Programs/Radeon Omega Drivers/(Re)Install Radlinker |
