Lokacija: Gjakova
Postovi: 3
hi im lirjon i registered today on this forum i have a problem with my router my isp is ipko i have broadband conection why i cant configure the portforword on my router webstar epc2434 because doesnt show the portforword menu see on the screenshot only wireleess configuration shown how to show the portforword configuration menu please help me. ![]() |
Postovi: 23,658
To PortForward function worked first need to set a fixed network settings on the network card through which you are connected to the modem. To do this open the TCP / IP network card properties and select the "Use the following IP address" and set: - IP=192.168.100.2 - Subnet=255.255.255.0 - Gateway=192.168.100.1 On that device set PortForward functions under the Advanced menu (click on Advanced). If you can not open the page (disabled by ISP), try the following procedure: - switch off modem - disconnect cable from cable network (coaxial input) - switch on modem and now try access PortForward settings in web config - upon entry required (do not forget Applay button at the bottom of the page) - turned off the modem and reconnect cable from cable network (coaxial input) - switch on modem On this page you have an example of how to configure, eMule for example, you select / change for which application you need. |
Lokacija: Gjakova
Postovi: 3
thanks from you Nikky but advanced is for wireless setup to configure how many fast to have wiffi or to configure ip who can to conect in the router but is not to configure portforword see on the screenshot i can to configure only wireless i cant configure the portforword or anything other except wireless in wireless dont have a portforword i tried but i cant to do anything i dont now why i cant to setup LAN only i can WLAN. thanks again Nikky. |
Postovi: 23,658
Here you have Scientific_Atlanta_EPC2434 User manual. The main reason why you don't see all the options because the ISP is locked / disabled access to advanced options. Try contacting support to come and set what you need, it must be free of charge. |
Postovi: 284
Hi Lirjon, you have to be logged into router with administrative rights. Did you try some of these combinations: http://artofhacking.com/etc/passwd-s...ficatlanta.htm |
Lokacija: Gjakova
Postovi: 3
hi mahoona i tried but not work. can anyone to give me the direct link for portforword configuration for router epc2434 in http://192.168.100.1/ direct link like this http://192.168.100.1/__swdld.asp is forfirmware anyone if can to give the link for portforword please. only direct link can work for this, im sure for that because ine the http://192.168.100.1/ doesnt show in setup the firmware configuration but when i find this direct link i can configure this firmware and when i find the direct link for portforward configuration i hope i can configure this too. |
Postovi: 23,658
Maybe someone have this modem here becouse local cabel ISP Bnet provide internet + telephone and I think same modem model is used. For witch aplication you need PortForward function ? Do you contact tehnical support of yours ISP ? |
#8 | |
Lokacija: Splity
Postovi: 3,003
webstar feature is not enabled ![]() |
