Staro 05.09.2009., 12:33   #1
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
razer lycosa touch panel ne svjetli
(ovo stavljam u ime prijatelja koji se pita da li da reklamira ili ne)
sve radi, samo touch panel ne svjetli
vidim po slikama da na njima svjetli, pa me zanima na kraju da li to treba svjetliti ili ne.
http://d4rkn3ss.files.wordpress.com/...ycosa-pic6.jpg
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 05.09.2009., 13:29   #2
Postovi: 23,543
Jesi probao upravljati osvjetljenjem kroz konfig drajver?
Jesi probao factory reset (to factory default settings, press and hold the “Razer Logo” button for 15 seconds while the Razer Lycosa is connected to a powered on computer)?
Ukoliko to neda rezultata neka ide na reklamaciju ako hoće.
Staro 05.09.2009., 20:05   #3
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Kolko sam skuzio, caps lock num lock i scroll lock svijetle i osvjetljavaju te tipke,i okvir touch panela, i sad mislim da je to ta svjetlost opcenito....ili bi fakat trebalo svjetliti?"
Logitech MX500
DELL 2007FP
Abit AV8
Staro 06.09.2009., 20:44   #4
chare
Happy hippo
chare's Avatar
Lokacija: Cakovec
Postovi: 562
meni je sve k s lycosom.. svijetlost nema veze sa caps num i scroll lockom... neznam zasto tebi ne radi to.. ja nisam imao nikakve probleme.. ali probaj negde na setting naci rjesenje.. meni se nije dalo traziti =))
jesi uopce instalirao drivere? probaj reinstall
chare je offline   Reply With Quote
