Staro 02.09.2009., 00:37   #1
Paxton
Expert from the shadow
Paxton's Avatar
Lokacija: Sibinj
Postovi: 696
BF2 patch is OUT!!!
Eto, igra koja je izasla 2005 je dobila svoju finalnu zakrpu.
Download ovdje
Nakon vise od godinu dana razvoja Battlefield 2 patch 1.5 je vani, patch toliko dugo ocekivan od zajednice, ovaj put su decki iz DICEa poslusali zahtjeve zajednice, i popravili neke od kriticnih nedostataka verzije 1.41, i pokusali da igru naprave malo vise hacker-proof, posto je u zadnje vrijeme bilo nemoguce igrati koliko je ljudi varalo na ranked serverima...
Changelog:
- Additional support for Windows Vista.
- Changes made to both the J10 and F35B to make them more balanced.
- Fixed the issue where picking up a players kit would cause CTD
- Added Highway Tampa as a required map.
- AA targeting tweaked to make it more effective.
- Updated BF2OpenAL.dll from version 1.1.1.0 to version 2.1.8.1
- Added a new map called Operation Blue Pearl.
- Added checks to prevent "runway grieving".
- Updated ch_gas_station collision mesh on Dragon Valley to be consistent with other gas station buildings
- Added Euro Force and Armored Fury as free to play content for all Battlefield 2 players.
- Various changes made to prevent cheating.
- Fixed the issue where MEC artillery piece on Operation Clean Sweep changes to the USMC's control when they capture the Airfield flag
- Added Widescreen support
- Tweaked the hit detection, hits will be more accurate to the model.
- Updated the Challenger2 HUD to show the correct icon instead of the M1A2 HUD icon
- Allowed BF2.exe to use more than 2Gb RAM
Takodjer je vazno napomenuti (pise u changelogu) da sada booster packovi dolaze BESPLATNO, no nazalost ne i special forces, i da vise dvd NIJE potreban za igru!
Paxton je online   Reply With Quote
Staro 02.09.2009., 01:07   #2
Markos
Markos's Avatar
Postovi: 1,060
aleluja fakat,hvala duhu svetom napokon,sad napokon nemoram non stop čupat igru van i dosta zakrpa ima patch
Markos je offline   Reply With Quote
Staro 02.09.2009., 02:43   #3
Paxton
Paxton's Avatar
Lokacija: Sibinj
Postovi: 696
Jedini problem je sto nije kumulativni, znaci mora se prvo instalirat 1.41, pa onda 1.5. Dosta brze se instalira nego 1.41. I zaboravio sam napomenit da je velik 1.9Gb
Staro 03.09.2009., 15:22   #4
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
jel igra tko? btw stvarno su se ovi brijači na BF ufurali u nove staze...nadam se da nisu oni mali Kinezi iz dokumentarca di su placeni da igraju po 12h dnevno
gbijelic je offline   Reply With Quote
Staro 03.09.2009., 17:44   #5
Paxton
Paxton's Avatar
Lokacija: Sibinj
Postovi: 696
Igra, evo IPova ako nekog zanima
Blue Pearl/Karkand, IO, FF=OFF 69.12.63.53:16567
Dragon Valey, vehicles FF=OFF 69.12.63.54:16567
ranked serveri, naravno.
Staro 03.09.2009., 18:15   #6
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
a sta fali 1.0 patchu ,meni igra radi super i bez patcheva,dobro da imam orginal vjerovatno bih koristio 1.5 ali dobro je i ovako
viper je offline   Reply With Quote
Staro 04.09.2009., 01:56   #7
Paxton
Paxton's Avatar
Lokacija: Sibinj
Postovi: 696
Procitaj pazljivije. I nema ni smisla igrati bez originala, botovi su previse glupi da bi pruzili ikakav izazov. Verzija 1.0 nema:
-co op mode
-8 novih mapa
-balansiraniju igru
-podrsku za widescreen
-razna poboljsanja protiv varanja na ranked serverima
-poboljsan hit detection
Staro 05.09.2009., 14:31   #8
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
Jel ima netko slicnih problema sa BF2 v1.5...naime igrao sam ga jucer i kada sam kasnije opet htjeo zaigrat svi serveri mi crveni...oznaceno je same version i izbacuje samo 10ak servera EAUK di nitko ne igra...ovi sa favoritesa su isto svi crveni a isto su v1.5 koje sam igrao juce bez problema...pokusao sam sve reinstalirat stavio sam patcheve ponovo i PB sam reinstalirao ručno updejtovo i opet sve isto...kak rjesit problem?
Čitajući strane forume vidim da dosta ljudi ima tih problema
Staro 05.09.2009., 14:34   #9
Paxton
Paxton's Avatar
Lokacija: Sibinj
Postovi: 696
Autor gbijelic Pregled postova
Probaj se spojit direktno na IPove koje sam ti poslao. Trenutno su prazni serveri, ali bice puni kroz koji sat. Bas da vidis koju ce ti poruku izbacit.
Staro 05.09.2009., 21:44   #10
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
Evo rjesio sam problem reinstalacijom igre, napominjem samo da se obavezno mora obrisati folder u My Document's-u, jer je vjerojatno u tome problem posto sam probao sve osim toga, pa ako netko bude imao slican problem (a vidim da je dosta ljudi)
